[PATCH] mmc: sdhci: Fix HISPD bit handling
SDHCI HISPD bits need to be configured based on desired mmc timings mode and some HISPD quirks.
So, handle the HISPD bit based on the mmc computed selected mode(timing parameter) rather than fixed mmc card clock frequency.
Linux handle the HISPD similar like this in below commit,
commit <501639bf2173> ("mmc: sdhci: fix SDHCI_QUIRK_NO_HISPD_BIT handling")
This eventually fixed the mmc write issue observed in rk3399 sdhci controller.
Bug log for refernece, => gpt write mmc 0 $partitions Writing GPT: mmc write failed ** Can't write to device 0 ** ** Can't write to device 0 ** error!
Cc: Kever Yang kever.yang@rock-chips.com Cc: Peng Fan peng.fan@nxp.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/mmc/sdhci.c | 23 +++++++++++++++-------- 1 file changed, 15 insertions(+), 8 deletions(-)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 92cc8434af..280b8c88eb 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -594,14 +594,21 @@ static int sdhci_set_ios(struct mmc *mmc) ctrl &= ~SDHCI_CTRL_4BITBUS; }
- if (mmc->clock > 26000000) - ctrl |= SDHCI_CTRL_HISPD; - else - ctrl &= ~SDHCI_CTRL_HISPD; - - if ((host->quirks & SDHCI_QUIRK_NO_HISPD_BIT) || - (host->quirks & SDHCI_QUIRK_BROKEN_HISPD_MODE)) - ctrl &= ~SDHCI_CTRL_HISPD; + if (!(host->quirks & SDHCI_QUIRK_NO_HISPD_BIT) || + !(host->quirks & SDHCI_QUIRK_BROKEN_HISPD_MODE)) { + if (mmc->selected_mode == MMC_HS || + mmc->selected_mode == SD_HS || + mmc->selected_mode == MMC_DDR_52 || + mmc->selected_mode == MMC_HS_200 || + mmc->selected_mode == MMC_HS_400 || + mmc->selected_mode == UHS_SDR25 || + mmc->selected_mode == UHS_SDR50 || + mmc->selected_mode == UHS_SDR104 || + mmc->selected_mode == UHS_DDR50) + ctrl |= SDHCI_CTRL_HISPD; + else + ctrl &= ~SDHCI_CTRL_HISPD; + }
sdhci_writeb(host, ctrl, SDHCI_HOST_CONTROL);
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
- else
else
Jaehoon Chung
Jagan Teki
