Please pull u-boot-x86
Hi Tom,
This PR contains the following x86 changes for v2023.04 release:
- x86: Bug fixes of previous BayTrail platform CONFIG_TEXT_BASE changes
The following changes since commit 8be7b4629e87ff8db08dd087c81d58129d029bad:
Merge tag 'efi-2023.04-rc5' of https://source.denx.de/u-boot/custodians/u-boot-efi (2023-03-25 09:40:19 -0400)
https://source.denx.de/u-boot/custodians/u-boot-x86.git
for you to fetch changes up to 843e840dbacbf5b419f230d63f00990ac8efe7e4:
x86: som-db5800-som-6867: Fix up adjustment of CONFIG_TEXT_BASE (2023-03-27 09:38:44 +0800)
---------------------------------------------------------------- Simon Glass (5): x86: minnowmax: Fix up adjustment of CONFIG_TEXT_BASE x86: bayleybay: Fix up adjustment of CONFIG_TEXT_BASE x86: conga-qeval20-qa3-e3845: Fix up adjustment of CONFIG_TEXT_BASE x86: dfi-bt700: Fix up adjustment of CONFIG_TEXT_BASE x86: som-db5800-som-6867: Fix up adjustment of CONFIG_TEXT_BASE
arch/x86/dts/bayleybay.dts | 2 +- arch/x86/dts/baytrail_som-db5800-som-6867.dts | 2 +- arch/x86/dts/conga-qeval20-qa3-e3845.dts | 2 +- arch/x86/dts/dfi-bt700.dtsi | 2 +- arch/x86/dts/minnowmax.dts | 2 +- configs/bayleybay_defconfig | 1 + configs/conga-qeval20-qa3-e3845-internal-uart_defconfig | 1 + configs/conga-qeval20-qa3-e3845_defconfig | 1 + configs/dfi-bt700-q7x-151_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/som-db5800-som-6867_defconfig | 1 + configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig | 1 + configs/theadorable-x86-conga-qa3-e3845_defconfig | 1 + configs/theadorable-x86-dfi-bt700_defconfig | 1 + doc/board/intel/minnowmax.rst | 15 +++++++++++++-- 15 files changed, 27 insertions(+), 7 deletions(-)
Regards, Bin
On Mon, Mar 27, 2023 at 09:42:25AM +0800, Bin Meng wrote:
Hi Tom,
Bin Meng
