[U-Boot-Users] [PATCH] QUAD100HD: Allow the environment to be put into flash.
After moving TEXT_BASE the value for CFG_ENV_ADDR was incorrect. Also use a redundant environment.
Signed-off-by: Gary Jennejohn garyj@denx.de --- include/configs/quad100hd.h | 13 +++++++++---- 1 files changed, 9 insertions(+), 4 deletions(-)
diff --git a/include/configs/quad100hd.h b/include/configs/quad100hd.h index b2a7030..c0813bf 100644 --- a/include/configs/quad100hd.h +++ b/include/configs/quad100hd.h @@ -41,7 +41,9 @@ #define PLLMR0_DEFAULT PLLMR0_266_133_66 /* no PCI */ #define PLLMR1_DEFAULT PLLMR1_266_133_66 /* no PCI */
-#define CFG_ENV_IS_IN_EEPROM 1 /* use the EEPROM for environment vars */ +/* the environment is in the EEPROM by default */ +#define CFG_ENV_IS_IN_EEPROM +#undef CFG_ENV_IS_IN_FLASH
#define CONFIG_NET_MULTI 1 #define CONFIG_HAS_ETH1 1 @@ -198,9 +200,12 @@
#ifdef CFG_ENV_IS_IN_FLASH #define CFG_ENV_SECT_SIZE 0x10000 /* size of one complete sector */ -#define CFG_ENV_SIZE 0x10000 /* Total Size of Environment Sector */ -#define CFG_ENV_OFFSET 0x00050000 /* Offset of Environment Sector */ -#define CFG_ENV_ADDR (CFG_FLASH_BASE + CFG_ENV_OFFSET) +/* the environment is located before u-boot */ +#define CFG_ENV_ADDR (TEXT_BASE - CFG_ENV_SECT_SIZE) + +/* Address and size of Redundant Environment Sector */ +#define CFG_ENV_ADDR_REDUND (CFG_ENV_ADDR - CFG_ENV_SECT_SIZE) +#define CFG_ENV_SIZE_REDUND (CFG_ENV_SECT_SIZE) #endif
#ifdef CFG_ENV_IS_IN_EEPROM
Applied to quad100hd branch. Thanks.
Best regards, Stefan
Gary Jennejohn
Stefan Roese
