[U-Boot] [PATCH 1/2] dt: sun8i: Perfect r_pio node of the A83T
Perfect `r_pio` node of the A83T based on `pio` node.
Signed-off-by: Ziping Chen techping.chan@gmail.com --- arch/arm/dts/sun8i-a83t.dtsi | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/dts/sun8i-a83t.dtsi b/arch/arm/dts/sun8i-a83t.dtsi index 0fe73e173f..128fe954c4 100644 --- a/arch/arm/dts/sun8i-a83t.dtsi +++ b/arch/arm/dts/sun8i-a83t.dtsi @@ -257,6 +257,11 @@ compatible = "allwinner,sun8i-a83t-r-pinctrl"; reg = <0x01f02c00 0x400>; interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&osc24M>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <3>; + #gpio-cells = <3>; }; }; };
The SinA83T is an A83T core/daughter board combo from Sinlinx.
Add support for it.
Signed-off-by: Ziping Chen techping.chan@gmail.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/sun8i-a83t-sinlinx-sina83t.dts | 107 ++++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 6 ++ configs/Sinlinx_SinA83T_defconfig | 21 ++++++ 4 files changed, 136 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/sun8i-a83t-sinlinx-sina83t.dts create mode 100644 configs/Sinlinx_SinA83T_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 8b8f5e9e76..c0eae9f443 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -305,7 +305,8 @@ dtb-$(CONFIG_MACH_SUN8I_A33) += \ dtb-$(CONFIG_MACH_SUN8I_A83T) += \ sun8i-a83t-allwinner-h8homlet-v2.dtb \ sun8i-a83t-cubietruck-plus.dtb \ - sun8i-a83t-sinovoip-bpi-m3.dtb + sun8i-a83t-sinovoip-bpi-m3.dtb \ + sun8i-a83t-sinlinx-sina83t.dtb dtb-$(CONFIG_MACH_SUN8I_H3) += \ sun8i-h2-plus-orangepi-zero.dtb \ sun8i-h3-bananapi-m2-plus.dtb \ diff --git a/arch/arm/dts/sun8i-a83t-sinlinx-sina83t.dts b/arch/arm/dts/sun8i-a83t-sinlinx-sina83t.dts new file mode 100644 index 0000000000..ae50e022d4 --- /dev/null +++ b/arch/arm/dts/sun8i-a83t-sinlinx-sina83t.dts @@ -0,0 +1,107 @@ +/* + * Copyright 2017 Ziping Chen + * Ziping Chen techping.chan@gmail.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun8i-a83t.dtsi" +#include "sunxi-common-regulators.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/pinctrl/sun4i-a10.h> + +/ { + model = "Sinlinx SinA83T"; + compatible = "sinlinx,sina83t", "allwinner,sun8i-a83t"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + leds { + compatible = "gpio-leds"; + + usr_led { + label = "sinlinx:blue:usr"; + gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>; /* PL10 */ + default-state = "on"; + }; + }; +}; + +#define USB_CLASS_HUB 9 + +&ehci0 { + /* USB 2.0 4 port hub IC */ + status = "okay"; + #address-cells = <2>; + #size-cells = <2>; + + hub { + compatible = "usb-hub"; + usb,device-class = <USB_CLASS_HUB>; + #address-cells = <1>; + #size-cells = <0>; + }; +}; + +&ehci1 { + status = "okay"; +}; + +&ohci0 { + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; + +&usb_otg { + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 0f1290acc0..d9370f6d63 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -299,6 +299,12 @@ S: Maintained F: configs/Sinlinx_SinA33_defconfig W: http://linux-sunxi.org/Sinlinx_SinA33
+SINLINX SINA83T BOARD +M: Ziping Chen techping.chan@gmail.com +S: Maintained +F: configs/Sinlinx_SinA83T_defconfig +W: http://linux-sunxi.org/Sinlinx_SinA83T + SINOVOIP BPI M2 PLUS H3 BOARD M: Icenowy Zheng icenowy@aosc.io S: Maintained diff --git a/configs/Sinlinx_SinA83T_defconfig b/configs/Sinlinx_SinA83T_defconfig new file mode 100644 index 0000000000..d80ac77a58 --- /dev/null +++ b/configs/Sinlinx_SinA83T_defconfig @@ -0,0 +1,21 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN8I_A83T=y +CONFIG_DRAM_CLK=600 +CONFIG_DRAM_ZQ=15355 +CONFIG_DRAM_ODT_EN=y +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_AXP_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-sinlinx-sina83t" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_AXP_DLDO4_VOLT=3300 +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_MUSB_HOST=y
Add support for it.
- sun8i-a83t-sinovoip-bpi-m3.dtb \
- sun8i-a83t-sinlinx-sina83t.dtb
DT should be ordered alphabetically, so before the BPi M3.
- Copyright 2017 Ziping Chen
- Ziping Chen techping.chan@gmail.com
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This file is free software; you can redistribute it and/or
- Or, alternatively,
- b) Permission is hereby granted, free of charge, to any person
conditions:
- model = "Sinlinx SinA83T";
- compatible = "sinlinx,sina83t", "allwinner,sun8i-a83t";
- aliases {
serial0 = &uart0;
- chosen {
- leds {
usr_led {
+&ehci0 {
- /* USB 2.0 4 port hub IC */
- status = "okay";
- #address-cells = <2>;
- #size-cells = <2>;
- hub {
#size-cells = <0>;
+&ehci1 {
- status = "okay";
+&ohci0 {
- status = "okay";
+&uart0 {
- pinctrl-names = "default";
- pinctrl-0 = <&uart0_pins_a>;
- status = "okay";
+&usb_otg {
- status = "okay";
Can you contribute that DT with Linux first? We share them with Linux, and it should be accepted there first.
Thanks! Maxime
Previously I did not submit the patch to linux because of the missing a83t's DT support of Linux... And I saw Bananapi M3 haven't been supported for Linux, but for U-Boot.
Well, now I will try to fix up the a83t's DT support for Linux, and then submitted it to uboot.
BTW, I found that the U-Boot's DT is a little different from the Linux's DT. Sometime I should adjust the DT file slightly to make it compatible for each other. For exmaple, Linux now uses "sun8i-h3-h5.dtsi" and "sun8i-h3.dtsi" for a h3 device, while U-Boot only uses "sun8i-h3.dtsi".
I would like to say that it is important to keep the consistency of U-Boot's and Linux's DT. And I am very glam to help for these works.
Thanks Ziping Chen
On Jun 10, 2017 12:51 AM, "Maxime Ripard" maxime.ripard@free-electrons.com wrote:
Add support for it.
- whole.
the
conditions:
aliases {
serial0 = &uart0;
chosen {
leds {
usr_led {
+&ehci0 {
status = "okay";
#size-cells = <2>;
hub {
#size-cells = <0>;
+&ehci1 {
status = "okay";
+&ohci0 {
status = "okay";
+&uart0 {
status = "okay";
+&usb_otg {
status = "okay";
Thanks! Maxime
-- Maxime Ripard, Free Electrons Embedded Linux and Kernel engineering http://free-electrons.com
U-Boot has BPI M3, configs/Sinovoip_BPI_M3_defconfig
Yes, we did some recent addition sun50i-h5.dtsi ie in-line with Linux. So more can add anytime to sync with Linux.
Jagan.
Jagan Teki
Maxime Ripard
Ziping Chen
