[U-Boot] [PATCH v3] ARM: mxs: tools: Use mkimage for BootStream generation
Now that mkimage can generate an BootStream for i.MX23 and i.MX28, use the mkimage as a default tool to generate the BootStreams instead of the elftosb tool. This cuts out another obscure dependency.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Otavio Salvador otavio@ossystems.com.br Cc: Stefano Babic sbabic@denx.de --- arch/arm/cpu/arm926ejs/mxs/Makefile | 11 ++++---- arch/arm/cpu/arm926ejs/mxs/mxsimage.mx23.cfg | 4 +-- arch/arm/cpu/arm926ejs/mxs/mxsimage.mx28.cfg | 4 +-- doc/README.mxs | 39 ++++++++++++++++++++++------ 4 files changed, 41 insertions(+), 17 deletions(-)
V2: Replace the ELFTOSB_TARGET with MKIMAGE_TARGET in mxs Makefile V3: Fix sude->sudo , move libssl-dev installation instructions.
diff --git a/arch/arm/cpu/arm926ejs/mxs/Makefile b/arch/arm/cpu/arm926ejs/mxs/Makefile index 3d66892..ea397c7 100644 --- a/arch/arm/cpu/arm926ejs/mxs/Makefile +++ b/arch/arm/cpu/arm926ejs/mxs/Makefile @@ -25,14 +25,15 @@ $(LIB): $(OBJS) $(call cmd_link_o_target, $(OBJS))
# Specify the target for use in elftosb call -ELFTOSB_TARGET-$(CONFIG_MX23) = imx23 -ELFTOSB_TARGET-$(CONFIG_MX28) = imx28 +MKIMAGE_TARGET-$(CONFIG_MX23) = mx23 +MKIMAGE_TARGET-$(CONFIG_MX28) = mx28
-$(OBJTREE)/u-boot.bd: $(SRCTREE)/$(CPUDIR)/$(SOC)/u-boot-$(ELFTOSB_TARGET-y).bd +$(OBJTREE)/mxsimage.cfg: $(SRCTREE)/$(CPUDIR)/$(SOC)/mxsimage.$(MKIMAGE_TARGET-y).cfg sed "s@OBJTREE@$(OBJTREE)@g" $^ > $@
-$(OBJTREE)/u-boot.sb: $(OBJTREE)/u-boot.bin $(OBJTREE)/spl/u-boot-spl.bin $(OBJTREE)/u-boot.bd - elftosb -zf $(ELFTOSB_TARGET-y) -c $(OBJTREE)/u-boot.bd -o $(OBJTREE)/u-boot.sb +$(OBJTREE)/u-boot.sb: $(OBJTREE)/u-boot.bin $(OBJTREE)/spl/u-boot-spl.bin $(OBJTREE)/mxsimage.cfg + $(OBJTREE)/tools/mkimage -n $(OBJTREE)/mxsimage.cfg -T mxsimage $@ +
diff --git a/arch/arm/cpu/arm926ejs/mxs/mxsimage.mx23.cfg b/arch/arm/cpu/arm926ejs/mxs/mxsimage.mx23.cfg index 8118767..c9cf4b3 100644 --- a/arch/arm/cpu/arm926ejs/mxs/mxsimage.mx23.cfg +++ b/arch/arm/cpu/arm926ejs/mxs/mxsimage.mx23.cfg @@ -1,6 +1,6 @@ SECTION 0x0 BOOTABLE TAG LAST - LOAD 0x0 spl/u-boot-spl.bin + LOAD 0x0 OBJTREE/spl/u-boot-spl.bin CALL 0x14 0x0 - LOAD 0x40000100 u-boot.bin + LOAD 0x40000100 OBJTREE/u-boot.bin CALL 0x40000100 0x0 diff --git a/arch/arm/cpu/arm926ejs/mxs/mxsimage.mx28.cfg b/arch/arm/cpu/arm926ejs/mxs/mxsimage.mx28.cfg index ea772f0..676f5c8 100644 --- a/arch/arm/cpu/arm926ejs/mxs/mxsimage.mx28.cfg +++ b/arch/arm/cpu/arm926ejs/mxs/mxsimage.mx28.cfg @@ -1,8 +1,8 @@ SECTION 0x0 BOOTABLE TAG LAST - LOAD 0x0 spl/u-boot-spl.bin + LOAD 0x0 OBJTREE/spl/u-boot-spl.bin LOAD IVT 0x8000 0x14 CALL HAB 0x8000 0x0 - LOAD 0x40000100 u-boot.bin + LOAD 0x40000100 OBJTREE/u-boot.bin LOAD IVT 0x8000 0x40000100 CALL HAB 0x8000 0x0 diff --git a/doc/README.mxs b/doc/README.mxs index 2919bbf..0235a5a 100644 --- a/doc/README.mxs +++ b/doc/README.mxs @@ -27,9 +27,25 @@ Contents 1) Prerequisites ----------------
-To make a MXS based board bootable, some tools are necessary. The first one is -the "elftosb" tool distributed by Freescale Semiconductor. The other one is the -"mxsboot" tool found in U-Boot source tree. +To make a MXS based board bootable, some tools are necessary. The only +mandatory tool is the "mxsboot" tool found in U-Boot source tree. The +tool is built automatically when compiling U-Boot for i.MX23 or i.MX28. + +The production of BootStream image is handled via "mkimage", which is +also part of the U-Boot source tree. The "mkimage" requires OpenSSL +development libraries to be installed. In case of Debian and derivates, +this is installed by running: + + $ sudo apt-get install libssl-dev + +NOTE: The "elftosb" tool distributed by Freescale Semiconductor is no + longer necessary for general use of U-Boot on i.MX23 and i.MX28. + The mkimage supports generation of BootStream images encrypted + with a zero key, which is the vast majority of use-cases. In + case you do need to produce image encrypted with non-zero key + or other special features, please use the "elftosb" tool, + otherwise continue to section 2). The installation procedure of + the "elftosb" is outlined below:
Firstly, obtain the elftosb archive from the following location:
@@ -63,11 +79,6 @@ copy the binary by hand: Make sure the "elftosb" binary can be found in your $PATH, in this case this means "/usr/local/bin/" has to be in your $PATH.
-Install the 'libssl-dev' package as well. On a Debian-based distribution, this -package can be installed as follows: - - $ sudo apt-get install libssl-dev - 2) Compiling U-Boot for a MXS based board -------------------------------------------
@@ -112,6 +123,18 @@ The code produces "u-boot.sb" file. This file needs to be augmented with a proper header to allow successful boot from SD or NAND. Adding the header is discussed in the following chapters.
+NOTE: The process that produces u-boot.sb uses the mkimage to generate the + BootStream. The BootStream is encrypted with zero key. In case you need + some special features of the BootStream and plan on using the "elftosb" + tool instead, the invocation to produce a compatible BootStream with the + one produced by mkimage is outlined below. For further details, refer to + the documentation bundled with the "elftosb" package. + + $ elftosb -zf imx23 -c arch/arm/cpu/arm926ejs/mxs/u-boot-imx23.bd \ + -o u-boot.sb + $ elftosb -zf imx28 -c arch/arm/cpu/arm926ejs/mxs/u-boot-imx28.bd \ + -o u-boot.sb + 3) Installation of U-Boot for a MXS based board to SD card ----------------------------------------------------------
This is clearly a mxsimage thing; I do believe MXSIMAGE_TARGET is more clear.
Dear Otavio Salvador,
Please read the patch again, the tool that is invoked is called "mkimage" . I disagree.
Best regards, Marek Vasut
But it is used to generate the mxsimage.cfg in .../mxsimage.$(MKIMAGE_TARGET-y).cfg
So it is really an mxsimage thing.
For something named MKIMAGE_TARGET I would expect it being in the mkimage call.
IFF you look at the pattern above (-ELFTOSB -> +MKIMAGE), you can see the name of the variable contains the name of the tool. I want to stick with MKIMAGE_ here.
Hi Marek,
Applied to u-boot-imx, -next branch, thanks !
Best regards, Stefano Babic
Otavio Salvador
Stefano Babic
