[PATCH] imx6: aristainetos: sync defconfig with 2020.10
as patch gpio: search for gpio label if gpio is not found through bank name
is now in mainline, but functionality is disabled, we need to enable
CONFIG_DM_GPIO_LOOKUP_LABEL
for the aristainetos boards.
Signed-off-by: Heiko Schocher hs@denx.de ---
I did not trigger a travis build as this patch only changes aristainetos defconfigs, which now work again with my automated tbot build:
http://xeidos.ddns.net/ubtestresults/result/224
configs/aristainetos2_defconfig | 3 ++- configs/aristainetos2b_defconfig | 3 ++- configs/aristainetos2bcsl_defconfig | 3 ++- configs/aristainetos2c_defconfig | 3 ++- 4 files changed, 8 insertions(+), 4 deletions(-)
diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index 6befc89a4c..07b7b4d46f 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -10,6 +10,7 @@ CONFIG_ENV_OFFSET_REDUND=0xE0000 CONFIG_IMX_HAB=y # CONFIG_CMD_DEKBLOB is not set # CONFIG_CMD_NANDBCB is not set +CONFIG_DEFAULT_DEVICE_TREE="imx6dl-aristainetos2_4" CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg" CONFIG_BOOTDELAY=3 @@ -53,7 +54,6 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y -CONFIG_DEFAULT_DEVICE_TREE="imx6dl-aristainetos2_4" CONFIG_OF_LIST="imx6dl-aristainetos2_4 imx6dl-aristainetos2_7" CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y @@ -62,6 +62,7 @@ CONFIG_ENV_SPI_EARLY=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_GPIO_HOG=y +CONFIG_DM_GPIO_LOOKUP_LABEL=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y CONFIG_LED=y diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index 1dbf432c7c..3bb1f6c681 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -9,6 +9,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_OFFSET_REDUND=0xE0000 CONFIG_IMX_HAB=y # CONFIG_CMD_DEKBLOB is not set +CONFIG_DEFAULT_DEVICE_TREE="imx6dl-aristainetos2b_4" CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg" CONFIG_BOOTDELAY=3 @@ -51,7 +52,6 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y -CONFIG_DEFAULT_DEVICE_TREE="imx6dl-aristainetos2b_4" CONFIG_OF_LIST="imx6dl-aristainetos2b_4 imx6dl-aristainetos2b_7" CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y @@ -60,6 +60,7 @@ CONFIG_ENV_SPI_EARLY=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_GPIO_HOG=y +CONFIG_DM_GPIO_LOOKUP_LABEL=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y CONFIG_LED=y diff --git a/configs/aristainetos2bcsl_defconfig b/configs/aristainetos2bcsl_defconfig index 010988452b..33af6ffaec 100644 --- a/configs/aristainetos2bcsl_defconfig +++ b/configs/aristainetos2bcsl_defconfig @@ -9,6 +9,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_OFFSET_REDUND=0xE0000 CONFIG_IMX_HAB=y # CONFIG_CMD_DEKBLOB is not set +CONFIG_DEFAULT_DEVICE_TREE="imx6dl-aristainetos2b_csl_4" CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg" CONFIG_BOOTDELAY=3 @@ -51,7 +52,6 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y -CONFIG_DEFAULT_DEVICE_TREE="imx6dl-aristainetos2b_csl_4" CONFIG_OF_LIST="imx6dl-aristainetos2b_csl_4 imx6dl-aristainetos2b_csl_7" CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y @@ -60,6 +60,7 @@ CONFIG_ENV_SPI_EARLY=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_GPIO_HOG=y +CONFIG_DM_GPIO_LOOKUP_LABEL=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y CONFIG_LED=y diff --git a/configs/aristainetos2c_defconfig b/configs/aristainetos2c_defconfig index 677c2ed00b..a69c9635a7 100644 --- a/configs/aristainetos2c_defconfig +++ b/configs/aristainetos2c_defconfig @@ -9,6 +9,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_OFFSET_REDUND=0xE0000 CONFIG_IMX_HAB=y # CONFIG_CMD_DEKBLOB is not set +CONFIG_DEFAULT_DEVICE_TREE="imx6dl-aristainetos2c_4" CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg" CONFIG_BOOTDELAY=3 @@ -51,7 +52,6 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y -CONFIG_DEFAULT_DEVICE_TREE="imx6dl-aristainetos2c_4" CONFIG_OF_LIST="imx6dl-aristainetos2c_4 imx6dl-aristainetos2c_7" CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y @@ -63,6 +63,7 @@ CONFIG_APBH_DMA=y CONFIG_APBH_DMA_BURST=y CONFIG_APBH_DMA_BURST8=y CONFIG_GPIO_HOG=y +CONFIG_DM_GPIO_LOOKUP_LABEL=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y CONFIG_LED=y
as patch gpio: search for gpio label if gpio is not found through bank name is now in mainline, but functionality is disabled, we need to enable CONFIG_DM_GPIO_LOOKUP_LABEL for the aristainetos boards. Signed-off-by: Heiko Schocher hs@denx.de
Best regards, Stefano Babic
Heiko Schocher
sbabic@denx.de
