[U-Boot] [PATCH v2] arm926ejs, at91: add common phy_reset function
add common phy reset code into a common function.
Signed-off-by: Heiko Schocher hs@denx.de Cc: Andreas Bießmann andreas.devel@googlemail.com Cc: Bo Shen voice.shen@atmel.com Cc: Jens Scharsig esw@bus-elektronik.de Cc: Sergey Lapin slapin@ossfans.org Cc: Stelian Pop stelian@popies.net Cc: Albin Tonnerre albin.tonnerre@free-electrons.com Cc: Eric Benard eric@eukrea.com Cc: Markus Hubig mhubig@imko.de
--- - changes for v2: - add comment from Andreas Bießmann: - constify timeout - add some more comment - add Markus Hubig to Copyright - removed makefile changes - add CONFIG_AT91_WANTS_COMMON_PHY - rebased against commit c2e5e802ecb7ab668ce9911b210ed68c804b349f - Patch based on the spl v4 patchset from Bo Shen, see: http://lists.denx.de/pipermail/u-boot/2013-November/167235.html --- arch/arm/cpu/at91-common/Makefile | 1 + arch/arm/cpu/at91-common/phy.c | 57 +++++++++++++++++++++++++ arch/arm/include/asm/arch-at91/at91_common.h | 1 + board/BuS/vl_ma2sc/vl_ma2sc.c | 18 +------- board/afeb9260/afeb9260.c | 18 +------- board/atmel/at91sam9260ek/at91sam9260ek.c | 19 +-------- board/atmel/at91sam9263ek/at91sam9263ek.c | 19 +-------- board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 19 +-------- board/bluewater/snapper9260/snapper9260.c | 16 +------ board/calao/sbc35_a9g20/sbc35_a9g20.c | 19 +-------- board/eukrea/cpu9260/cpu9260.c | 18 +------- board/taskit/stamp9g20/stamp9g20.c | 31 +------------- include/configs/afeb9260.h | 2 +- include/configs/at91sam9260ek.h | 1 + include/configs/at91sam9263ek.h | 1 + include/configs/at91sam9m10g45ek.h | 1 + include/configs/cpu9260.h | 1 + include/configs/sbc35_a9g20.h | 1 + include/configs/snapper9260.h | 1 + include/configs/stamp9g20.h | 1 + include/configs/vl_ma2sc.h | 1 + 21 files changed, 79 insertions(+), 167 deletions(-) create mode 100644 arch/arm/cpu/at91-common/phy.c
diff --git a/arch/arm/cpu/at91-common/Makefile b/arch/arm/cpu/at91-common/Makefile index d97053f..5b97838 100644 --- a/arch/arm/cpu/at91-common/Makefile +++ b/arch/arm/cpu/at91-common/Makefile @@ -8,4 +8,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
+obj-$(CONFIG_AT91_WANTS_COMMON_PHY) += phy.o obj-$(CONFIG_SPL_BUILD) += mpddrc.o spl.o diff --git a/arch/arm/cpu/at91-common/phy.c b/arch/arm/cpu/at91-common/phy.c new file mode 100644 index 0000000..3b6c60c --- /dev/null +++ b/arch/arm/cpu/at91-common/phy.c @@ -0,0 +1,57 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian@popies.net + * Lead Tech Design <www.leadtechdesign.com> + * + * (C) Copyright 2012 + * Markus Hubig mhubig@imko.de + * IMKO GmbH <www.imko.de> + * + * Copyright (C) 2013 DENX Software Engineering, hs@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/sizes.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <watchdog.h> + +void at91_phy_reset(void) +{ + unsigned long erstl; + unsigned long start = get_timer(0); + unsigned long const timeout = 1000; /* 1000ms */ + at91_rstc_t *rstc = (at91_rstc_t *)ATMEL_BASE_RSTC; + + erstl = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK; + + /* + * Need to reset PHY -> 500ms reset + * Reset PHY by pulling the NRST line for 500ms to low. To do so + * disable user reset for low level on NRST pin and poll the NRST + * level in reset status register. + */ + writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(0x0D) | + AT91_RSTC_MR_URSTEN, &rstc->mr); + + writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr); + + /* Wait for end of hardware reset */ + while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL)) { + /* avoid shutdown by watchdog */ + WATCHDOG_RESET(); + mdelay(10); + + /* timeout for not getting stuck in an endless loop */ + if (get_timer(start) >= timeout) { + puts("*** ERROR: Timeout waiting for PHY reset!\n"); + break; + } + }; + + /* Restore NRST value */ + writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN, &rstc->mr); +} diff --git a/arch/arm/include/asm/arch-at91/at91_common.h b/arch/arm/include/asm/arch-at91/at91_common.h index 3ca4d5b..59e2f43 100644 --- a/arch/arm/include/asm/arch-at91/at91_common.h +++ b/arch/arm/include/asm/arch-at91/at91_common.h @@ -26,5 +26,6 @@ void at91_plla_init(u32 pllar); void at91_mck_init(u32 mckr); void at91_pmc_init(void); void mem_init(void); +void at91_phy_reset(void);
#endif /* AT91_COMMON_H */ diff --git a/board/BuS/vl_ma2sc/vl_ma2sc.c b/board/BuS/vl_ma2sc/vl_ma2sc.c index e2ae6fd..412ff3b 100644 --- a/board/BuS/vl_ma2sc/vl_ma2sc.c +++ b/board/BuS/vl_ma2sc/vl_ma2sc.c @@ -16,7 +16,6 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_pmc.h> #include <asm/arch/at91_pio.h> -#include <asm/arch/at91_rstc.h> #include <asm/arch/at91sam9263.h> #include <asm/arch/gpio.h> #include <asm/arch/at91_common.h> @@ -76,25 +75,12 @@ static void vl_ma2sc_nand_hw_init(void) #ifdef CONFIG_MACB static void vl_ma2sc_macb_hw_init(void) { - unsigned long erstl; at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_rstc_t *rstc = (at91_rstc_t *) ATMEL_BASE_RSTC; + /* Enable clock */ writel(1 << ATMEL_ID_EMAC, &pmc->pcer);
- erstl = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK; - - /* Need to reset PHY -> 500ms reset */ - writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(0x0D) | - AT91_RSTC_MR_URSTEN, &rstc->mr); - - writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr); - /* Wait for end hardware reset */ - while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL)) - ; - - /* Restore NRST value */ - writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN, &rstc->mr); + at91_phy_reset();
at91_macb_hw_init(); } diff --git a/board/afeb9260/afeb9260.c b/board/afeb9260/afeb9260.c index e1b1c10..ea9575d 100644 --- a/board/afeb9260/afeb9260.c +++ b/board/afeb9260/afeb9260.c @@ -13,7 +13,6 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> -#include <asm/arch/at91_rstc.h> #include <asm/arch/gpio.h> #include <asm/io.h> #include <asm/arch/hardware.h> @@ -67,8 +66,6 @@ static void afeb9260_macb_hw_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; - struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC; - unsigned long erstl;
/* Enable EMAC clock */ @@ -94,20 +91,7 @@ static void afeb9260_macb_hw_init(void) pin_to_mask(AT91_PIN_PA28), &pioa->pudr);
- erstl = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK; - - /* Need to reset PHY -> 500ms reset */ - writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(13) | - AT91_RSTC_MR_URSTEN, &rstc->mr); - writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr); - - /* Wait for end hardware reset */ - while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL)) - ; - /* Restore NRST value */ - writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN, - &rstc->mr); - + at91_phy_reset();
/* Re-enable pull-up */ writel(pin_to_mask(AT91_PIN_PA14) | diff --git a/board/atmel/at91sam9260ek/at91sam9260ek.c b/board/atmel/at91sam9260ek/at91sam9260ek.c index 263de49..7f14af1 100644 --- a/board/atmel/at91sam9260ek/at91sam9260ek.c +++ b/board/atmel/at91sam9260ek/at91sam9260ek.c @@ -12,7 +12,6 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> -#include <asm/arch/at91_rstc.h> #include <asm/arch/gpio.h> #include <atmel_mci.h>
@@ -73,8 +72,6 @@ static void at91sam9260ek_macb_hw_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; - struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC; - unsigned long erstl;
/* Enable EMAC clock */ writel(1 << ATMEL_ID_EMAC0, &pmc->pcer); @@ -98,21 +95,7 @@ static void at91sam9260ek_macb_hw_init(void) pin_to_mask(AT91_PIN_PA28), &pioa->pudr);
- erstl = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK; - - /* Need to reset PHY -> 500ms reset */ - writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(13) | - AT91_RSTC_MR_URSTEN, &rstc->mr); - - writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr); - - /* Wait for end hardware reset */ - while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL)) - ; - - /* Restore NRST value */ - writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN, - &rstc->mr); + at91_phy_reset();
/* Re-enable pull-up */ writel(pin_to_mask(AT91_PIN_PA14) | diff --git a/board/atmel/at91sam9263ek/at91sam9263ek.c b/board/atmel/at91sam9263ek/at91sam9263ek.c index 2e9246f..d42a173 100644 --- a/board/atmel/at91sam9263ek/at91sam9263ek.c +++ b/board/atmel/at91sam9263ek/at91sam9263ek.c @@ -12,7 +12,6 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> -#include <asm/arch/at91_rstc.h> #include <asm/arch/at91_matrix.h> #include <asm/arch/at91_pio.h> #include <asm/arch/clk.h> @@ -82,10 +81,9 @@ static void at91sam9263ek_nand_hw_init(void) #ifdef CONFIG_MACB static void at91sam9263ek_macb_hw_init(void) { - unsigned long erstl; at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIO; - at91_rstc_t *rstc = (at91_rstc_t *) ATMEL_BASE_RSTC; + /* Enable clock */ writel(1 << ATMEL_ID_EMAC, &pmc->pcer);
@@ -97,23 +95,10 @@ static void at91sam9263ek_macb_hw_init(void) * * PHY has internal pull-down */ - writel(1 << 25, &pio->pioc.pudr); writel((1 << 25) | (1 <<26), &pio->pioe.pudr);
/* Re-enable pull-up */ writel(1 << 25, &pio->pioc.puer); diff --git a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c index 6a071f6..b7e2efd 100644 --- a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c +++ b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c @@ -12,7 +12,6 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> -#include <asm/arch/at91_rstc.h> #include <asm/arch/gpio.h> #include <asm/arch/clk.h> #include <lcd.h> @@ -88,8 +87,6 @@ static void at91sam9m10g45ek_macb_hw_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; - struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC; - unsigned long erstl;
/* Enable clock */ writel(1 << ATMEL_ID_EMAC, &pmc->pcer); @@ -107,21 +104,7 @@ static void at91sam9m10g45ek_macb_hw_init(void) pin_to_mask(AT91_PIN_PA13), &pioa->pudr);
/* Re-enable pull-up */ writel(pin_to_mask(AT91_PIN_PA15) | diff --git a/board/bluewater/snapper9260/snapper9260.c b/board/bluewater/snapper9260/snapper9260.c index 8a6919d..bfde129 100644 --- a/board/bluewater/snapper9260/snapper9260.c +++ b/board/bluewater/snapper9260/snapper9260.c @@ -14,7 +14,6 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> -#include <asm/arch/at91_rstc.h> #include <asm/arch/gpio.h> #include <net.h> #include <netdev.h> @@ -31,8 +30,6 @@ static void macb_hw_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; - struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC; - unsigned long erstl;
/* Enable clock */ writel(1 << ATMEL_ID_EMAC0, &pmc->pcer); @@ -54,18 +51,7 @@ static void macb_hw_init(void) /* Enable ethernet power */ pca953x_set_val(0x28, IO_EXP_ETH_POWER, 0);
- /* Need to reset PHY -> 500ms reset */ - erstl = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK; - writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(13) | - AT91_RSTC_MR_URSTEN, &rstc->mr); - writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr); - - /* Wait for end hardware reset */ - while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL)) - ; - - /* Restore NRST value */ - writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN, &rstc->mr); + at91_phy_reset();
/* Bring the ethernet out of reset */ pca953x_set_val(0x28, IO_EXP_ETH_RESET, 1); diff --git a/board/calao/sbc35_a9g20/sbc35_a9g20.c b/board/calao/sbc35_a9g20/sbc35_a9g20.c index ecf261c..2074a93 100644 --- a/board/calao/sbc35_a9g20/sbc35_a9g20.c +++ b/board/calao/sbc35_a9g20/sbc35_a9g20.c @@ -15,7 +15,6 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> -#include <asm/arch/at91_rstc.h> #include <asm/arch/gpio.h>
#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) @@ -77,8 +76,6 @@ static void sbc35_a9g20_macb_hw_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; - struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC; - unsigned long erstl;
/* Enable EMAC clock */ writel(1 << ATMEL_ID_EMAC0, &pmc->pcer); @@ -102,21 +99,7 @@ static void sbc35_a9g20_macb_hw_init(void) pin_to_mask(AT91_PIN_PA28), &pioa->pudr);
/* Re-enable pull-up */ writel(pin_to_mask(AT91_PIN_PA14) | diff --git a/board/eukrea/cpu9260/cpu9260.c b/board/eukrea/cpu9260/cpu9260.c index 5e1524e..274f72d 100644 --- a/board/eukrea/cpu9260/cpu9260.c +++ b/board/eukrea/cpu9260/cpu9260.c @@ -17,7 +17,6 @@ #include <asm/arch/at91_common.h> #include <asm/arch/at91_matrix.h> #include <asm/arch/at91_pmc.h> -#include <asm/arch/at91_rstc.h> #include <asm/arch/at91_pio.h> #include <asm/arch/clk.h> #include <asm/arch/hardware.h> @@ -89,29 +88,14 @@ static void cpu9260_nand_hw_init(void) #ifdef CONFIG_MACB static void cpu9260_macb_hw_init(void) { - unsigned long rstcmr; at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_rstc_t *rstc = (at91_rstc_t *) ATMEL_BASE_RSTC;
at91_set_pio_pullup(AT91_PIO_PORTA, 17, 1);
- rstcmr = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK; - - /* Need to reset PHY -> 500ms reset */ - writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(0xD) | - AT91_RSTC_MR_URSTEN, &rstc->mr); - - writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr); - - /* Wait for end hardware reset */ - while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL)) - ; - - /* Restore NRST value */ - writel(AT91_RSTC_KEY | rstcmr | AT91_RSTC_MR_URSTEN, &rstc->mr); + at91_phy_reset();
at91_macb_hw_init(); } diff --git a/board/taskit/stamp9g20/stamp9g20.c b/board/taskit/stamp9g20/stamp9g20.c index 704a63b..27cdf77 100644 --- a/board/taskit/stamp9g20/stamp9g20.c +++ b/board/taskit/stamp9g20/stamp9g20.c @@ -19,7 +19,6 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> -#include <asm/arch/at91_rstc.h> #include <asm/arch/gpio.h> #include <watchdog.h>
@@ -67,8 +66,6 @@ static void stamp9G20_nand_hw_init(void) static void stamp9G20_macb_hw_init(void) { struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; - struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC; - unsigned long erstl;
/* Enable the PHY Chip via PA26 on the Stamp 2 Adaptor */ at91_set_gpio_output(AT91_PIN_PA26, 0); @@ -91,33 +88,7 @@ static void stamp9G20_macb_hw_init(void) pin_to_mask(AT91_PIN_PA28), &pioa->pudr);
- erstl = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK; - - /* Need to reset PHY -> 500ms reset */ - writel(AT91_RSTC_KEY | (AT91_RSTC_MR_ERSTL(13) & - ~AT91_RSTC_MR_URSTEN), &rstc->mr); - writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr); - - /* Wait for end of hardware reset */ - unsigned long start = get_timer(0); - unsigned long timeout = 1000; /* 1000ms */ - - while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL)) { - - /* avoid shutdown by watchdog */ - WATCHDOG_RESET(); - mdelay(10); - - /* timeout for not getting stuck in an endless loop */ - if (get_timer(start) >= timeout) { - puts("*** ERROR: Timeout waiting for PHY reset!\n"); - break; - }; - }; - - /* Restore NRST value */ - writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN, - &rstc->mr); + at91_phy_reset();
/* Re-enable pull-up */ writel(pin_to_mask(AT91_PIN_PA14) | diff --git a/include/configs/afeb9260.h b/include/configs/afeb9260.h index 5e71898..14bac15 100644 --- a/include/configs/afeb9260.h +++ b/include/configs/afeb9260.h @@ -106,7 +106,7 @@ /* Ethernet */ #define CONFIG_MACB #define CONFIG_RESET_PHY_R - +#define CONFIG_AT91_WANTS_COMMON_PHY #define CONFIG_NET_RETRY_COUNT 20
/* USB */ diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 1c4bb81..73917b0 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -181,6 +181,7 @@ #define CONFIG_RMII 1 #define CONFIG_NET_RETRY_COUNT 20 #define CONFIG_RESET_PHY_R 1 +#define CONFIG_AT91_WANTS_COMMON_PHY
/* USB */ #define CONFIG_USB_ATMEL diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 0a1969d..b9aa036 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -275,6 +275,7 @@ #define CONFIG_RMII 1 #define CONFIG_NET_RETRY_COUNT 20 #define CONFIG_RESET_PHY_R 1 +#define CONFIG_AT91_WANTS_COMMON_PHY
/* USB */ #define CONFIG_USB_ATMEL diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 2095fe6..aaaa8ec 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -120,6 +120,7 @@ #define CONFIG_RMII #define CONFIG_NET_RETRY_COUNT 20 #define CONFIG_RESET_PHY_R +#define CONFIG_AT91_WANTS_COMMON_PHY
/* USB */ #define CONFIG_USB_EHCI diff --git a/include/configs/cpu9260.h b/include/configs/cpu9260.h index ccf36a5..22c0a09 100644 --- a/include/configs/cpu9260.h +++ b/include/configs/cpu9260.h @@ -310,6 +310,7 @@ #define CONFIG_RMII #define CONFIG_NET_RETRY_COUNT 20 #define CONFIG_MACB_SEARCH_PHY +#define CONFIG_AT91_WANTS_COMMON_PHY
/* LEDS */ /* Status LED */ diff --git a/include/configs/sbc35_a9g20.h b/include/configs/sbc35_a9g20.h index cbcd4e1..7e16c45 100644 --- a/include/configs/sbc35_a9g20.h +++ b/include/configs/sbc35_a9g20.h @@ -115,6 +115,7 @@ #define CONFIG_NET_RETRY_COUNT 20 #define CONFIG_RESET_PHY_R #define CONFIG_MACB_SEARCH_PHY +#define CONFIG_AT91_WANTS_COMMON_PHY
/* USB */ #define CONFIG_USB_ATMEL diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h index 5436bae..5b957f0 100644 --- a/include/configs/snapper9260.h +++ b/include/configs/snapper9260.h @@ -59,6 +59,7 @@ #define CONFIG_RMII #define CONFIG_NET_RETRY_COUNT 20 #define CONFIG_RESET_PHY_R +#define CONFIG_AT91_WANTS_COMMON_PHY #define CONFIG_TFTP_PORT #define CONFIG_TFTP_TSIZE
diff --git a/include/configs/stamp9g20.h b/include/configs/stamp9g20.h index 248e657..51339b1 100644 --- a/include/configs/stamp9g20.h +++ b/include/configs/stamp9g20.h @@ -145,6 +145,7 @@ #ifdef CONFIG_MACB # define CONFIG_RMII /* use reduced MII inteface */ # define CONFIG_NET_RETRY_COUNT 20 /* # of DHCP/BOOTP retries */ +#define CONFIG_AT91_WANTS_COMMON_PHY
/* BOOTP and DHCP options */ # define CONFIG_BOOTP_BOOTFILESIZE diff --git a/include/configs/vl_ma2sc.h b/include/configs/vl_ma2sc.h index 1489080..aacb84c 100644 --- a/include/configs/vl_ma2sc.h +++ b/include/configs/vl_ma2sc.h @@ -330,6 +330,7 @@ #define CONFIG_RMII #define CONFIG_NET_MULTI #define CONFIG_NET_RETRY_COUNT 5 +#define CONFIG_AT91_WANTS_COMMON_PHY
#define CONFIG_OVERWRITE_ETHADDR_ONCE
Am 2013-11-18 08:07, schrieb Heiko Schocher:
- changes for v2:
- constify timeout
I have successfully tested this patch for vl_ma2sc, so:
Acked-by: Jens Scharsig (BuS Elektronik) esw@bus-elektronik.de Tested-by: Jens Scharsig (BuS Elektronik) esw@bus-elektronik.de
Hello Jens,
Am 18.11.2013 10:00, schrieb esw@bus-elektronik.de:
Signed-off-by: Heiko Schocherhs@denx.de Cc: Andreas Bießmannandreas.devel@googlemail.com Cc: Bo Shenvoice.shen@atmel.com Cc: Jens Scharsigesw@bus-elektronik.de Cc: Sergey Lapinslapin@ossfans.org Cc: Stelian Popstelian@popies.net Cc: Albin Tonnerrealbin.tonnerre@free-electrons.com Cc: Eric Benarderic@eukrea.com Cc: Markus Hubigmhubig@imko.de
- changes for v2:
- constify timeout
Acked-by: Jens Scharsig (BuS Elektronik)esw@bus-elektronik.de Tested-by: Jens Scharsig (BuS Elektronik)esw@bus-elektronik.de
Thanks for testing!
bye, Heiko
Hi Heiko,
- changes for v2:
- constify timeout
Test OK on at91sam9m10g45ek board.
Tested-by: Bo Shen voice.shen@atmel.com Acked-by: Bo Shen voice.shen@atmel.com
Best Regards, Bo Shen
Dear Heiko Schocher,
Heiko Schocher hs@denx.de writes:
Signed-off-by: Heiko Schocher hs@denx.de Cc: Andreas Bießmann andreas.devel@googlemail.com Cc: Bo Shen voice.shen@atmel.com Cc: Jens Scharsig esw@bus-elektronik.de Cc: Sergey Lapin slapin@ossfans.org Cc: Stelian Pop stelian@popies.net Cc: Albin Tonnerre albin.tonnerre@free-electrons.com Cc: Eric Benard eric@eukrea.com Cc: Markus Hubig mhubig@imko.de Acked-by: Jens Scharsig (BuS Elektronik) esw@bus-elektronik.de Tested-by: Jens Scharsig (BuS Elektronik) esw@bus-elektronik.de Tested-by: Bo Shen voice.shen@atmel.com Acked-by: Bo Shen voice.shen@atmel.com
- changes for v2:
- constify timeout
applied to u-boot-atmel/master, thanks!
Best regards, Andreas Bießmann
Andreas Bießmann
Bo Shen
Heiko Schocher
