[U-Boot] [Patch] fsl_esdhc: Fix DMA transfer completion waiting loop
Rework the waiting for transfer completion loop condition to continue waiting until both Transfer Complete and DMA End interrupts occur. Checking of DLA bit in Present State register looks not needed in addition to interrupts status checking, so it can be removed from the condition. Also, DMA Error condition is added to the list of data errors, checked in the loop.
Signed-off-by: Andrew Gabbasov andrew_gabbasov@mentor.com --- drivers/mmc/fsl_esdhc.c | 3 +-- include/fsl_esdhc.h | 4 +++- 2 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 54b5363..814bba4 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -400,8 +400,7 @@ esdhc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, struct mmc_data *data)
if (irqstat & DATA_ERR) return COMM_ERR; - } while (!(irqstat & IRQSTAT_TC) && - (esdhc_read32(®s->prsstat) & PRSSTAT_DLA)); + } while ((irqstat & DATA_COMPLETE) != DATA_COMPLETE); #endif }
diff --git a/include/fsl_esdhc.h b/include/fsl_esdhc.h index 47d2fe4..ea0880b 100644 --- a/include/fsl_esdhc.h +++ b/include/fsl_esdhc.h @@ -63,7 +63,9 @@ #define IRQSTAT_CC (0x00000001)
#define CMD_ERR (IRQSTAT_CIE | IRQSTAT_CEBE | IRQSTAT_CCE) -#define DATA_ERR (IRQSTAT_DEBE | IRQSTAT_DCE | IRQSTAT_DTOE) +#define DATA_ERR (IRQSTAT_DEBE | IRQSTAT_DCE | IRQSTAT_DTOE | \ + IRQSTAT_DMAE) +#define DATA_COMPLETE (IRQSTAT_TC | IRQSTAT_DINT)
#define IRQSTATEN 0x0002e034 #define IRQSTATEN_DMAE (0x10000000)
Am 08.04.2013 11:06, schrieb Andrew Gabbasov:
#endif }} while ((irqstat & DATA_COMPLETE) != DATA_COMPLETE);
IRQSTAT_DMAE)
I can't say anything to the content of the patches ;)
But are this patch and the patch from Eric
http://patchwork.ozlabs.org/patch/233595/
fine and should be applied together, now?
Thanks
Dirk
IRQSTAT_DMAE)
I see the same. I apply both on u-boot-imx and send an update pull request to Albert.
Best regards, Stefano
IRQSTAT_DMAE)
I haven't tested this myself, but I got the following issue report regarding this patch:
Using a SANDISK ULTRA II 8GB card (or alternatively Transcend 16GB or 32GB cards) and trying an mmc write [1] into the upper area of the 8GB card makes the write hang in 9 of 10 cases. Sometimes even more. Reverting this patch make these writes work again.
mmc read does work fine, though. Even newer SANDISK Extreme III or several micro SD cards are working fine.
Any idea?
Best regards
Dirk
[1]
mmc write 0x10800000 70ea40 1
Hi Dirk, ________________________________________
From: Behme, Dirk - Bosch Sent: Monday, June 10, 2013 16:06 To: Gabbasov, Andrew Cc: u-boot@lists.denx.de; Stefano Babic; Fleming Andy-AFLEMING Subject: Re: [U-Boot] [Patch] fsl_esdhc: Fix DMA transfer completion waiting loop
IRQSTAT_DMAE)
Any idea?
Best regards
Dirk
So far the only idea that comes into my mind is that DMA for some reason completes its part of work too early so that the corresponding interrupt status bit appears and has already been cleared even before entering this loop.
I will be trying to reproduce the issue.
Meanwhile, is it possible to ask the reporter (who obviously can reproduce it) to try to add the debug print from the diff below and show what it prints when the write command hangs and when it succeeds?
Thanks.
Best regards, Andrew
diff -u fsl_esdhc.c.orig fsl_esdhc.c --- fsl_esdhc.c.orig 2013-05-30 03:48:26.000000000 -0500 +++ fsl_esdhc.c 2013-06-10 09:38:30.071905119 -0500 @@ -329,6 +329,7 @@
irqstat = esdhc_read32(®s->irqstat); esdhc_write32(®s->irqstat, irqstat); + printf("fsl_esdhc: irqstat = 0x%08x\n", irqstat);
/* Reset CMD and DATA portions on error */ if (irqstat & (CMD_ERR | IRQSTAT_CTOE)) {
IRQSTAT_DMAE)
Any idea?
Best regards
Dirk
Thanks.
1. Sandisk 8GB Ultra 2 class 4 SDHC
[ 23.967081] MMC write: dev # 0, block # 7400000, count 1 ... fsl_esdhc: irqstat = 0x00000001 [ 23.977473] fsl_esdhc: irqstat = 0x00000009 => hang
With "fsl_esdhc: Fix DMA transfer completion waiting loop" reverted: [ 41.769231] MMC write: dev # 0, block # 7400000, count 1 ... fsl_esdhc: irqstat = 0x00000001 [ 41.779622] fsl_esdhc: irqstat = 0x00000009 [ 41.798490] fsl_esdhc: irqstat = 0x00000001 [ 41.802593] 1 blocks write: OK => work
2. Sandisk 16GB Extreme class 10 (30MB/s)
[ 45.871140] MMC write: dev # 0, block # 7400000, count 1 ... fsl_esdhc: irqstat = 0x00000001 [ 45.881528] fsl_esdhc: irqstat = 0x00000001 [ 46.054409] fsl_esdhc: irqstat = 0x00000001 [ 46.058513] 1 blocks write: OK => work
With "fsl_esdhc: Fix DMA transfer completion waiting loop" reverted: [ 17.901514] MMC write: dev # 0, block # 7400000, count 1 ... fsl_esdhc: irqstat = 0x00000001 [ 17.911901] fsl_esdhc: irqstat = 0x00000001 [ 18.081153] fsl_esdhc: irqstat = 0x00000001 [ 18.085256] 1 blocks write: OK => work
Best regards
Dirk
From: Behme, Dirk - Bosch Sent: Tuesday, June 11, 2013 12:16 To: Gabbasov, Andrew Cc: u-boot@lists.denx.de; Stefano Babic; Fleming Andy-AFLEMING Subject: Re: [U-Boot] [Patch] fsl_esdhc: Fix DMA transfer completion waiting loop
Hi Dirk,
[ skipped ]
Any idea?
Best regards
Dirk
Thanks.
printf("fsl_esdhc: irqstat = 0x%08x\n", irqstat); /* Reset CMD and DATA portions on error */ if (irqstat & (CMD_ERR | IRQSTAT_CTOE)) {
- Sandisk 8GB Ultra 2 class 4 SDHC
- Sandisk 16GB Extreme class 10 (30MB/s)
Best regards
Dirk
Indeed, the DMA End interrupt bit appears in the register already by the time of Command Complete event. Then, it gets cleared together with command-related bits. So, the data completion waiting loop, that starts later, never gets it and waits forever.
One of solutions could be to explicitly clear only the command related bits (command complete and may be command errors). However, it is easier just not clear the bits at all, leave them all until the data part processing completes too, and clear the whole register at once at the very end (which is being done anyway).
I'm submitting the patch removing clearing of interrupt status bits at that point. See Subject line "fsl_esdhc: Do not clear interrupt status bits until data processed".
Thanks.
After waiting for the command completion event, the interrupt status bits, that occured to be set by that time, are cleared by writing them back. It is supposed, that it should be command related bits (command complete and may be command errors).
However, in some cases the DMA already completes by that time before the full transaction completes. The corresponding DINT bit gets set and then cleared before even entering the loop, waiting for data part completion. That waiting loop never gets this bit set, causing the operation to hang. This is reported to happen, for example, for write operation of 1 sector to upper area (block #7400000) of SanDisk Ultra II 8GB card.
The solution could be to explicitly clear only command related interrupt status bits. However, since subsequent processing does not rely on any command bits state, it could be easier just to remove clearing of any bits at that point, leaving them all until all data processing completes. After that the whole register will be cleared at once.
Also, on occasion, interrupts masking moved to before writing the command, just for the case there should be no chance of interrupt between the first command and interrupts masking.
Reported-by: Dirk Behme dirk.behme@de.bosch.com Signed-off-by: Andrew Gabbasov andrew_gabbasov@mentor.com --- drivers/mmc/fsl_esdhc.c | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 861f4b9..b501b4d 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -310,6 +310,9 @@ esdhc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, struct mmc_data *data) /* Figure out the transfer arguments */ xfertyp = esdhc_xfertyp(cmd, data);
+ /* Mask all irqs */ + esdhc_write32(®s->irqsigen, 0); + /* Send the command */ esdhc_write32(®s->cmdarg, cmd->cmdarg); #if defined(CONFIG_FSL_USDHC) @@ -320,15 +323,11 @@ esdhc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, struct mmc_data *data) esdhc_write32(®s->xfertyp, xfertyp); #endif
- /* Mask all irqs */ - esdhc_write32(®s->irqsigen, 0); - /* Wait for the command to complete */ while (!(esdhc_read32(®s->irqstat) & (IRQSTAT_CC | IRQSTAT_CTOE))) ;
irqstat = esdhc_read32(®s->irqstat); - esdhc_write32(®s->irqstat, irqstat);
Acked-by: Dirk Behme dirk.behme@de.bosch.com
Thanks
Dirk
- /* Send the command */ esdhc_write32(®s->cmdarg, cmd->cmdarg); #if defined(CONFIG_FSL_USDHC)
/* Mask all irqs */
Reported-by: Dirk Behme dirk.behme@de.bosch.com Signed-off-by: Andrew Gabbasov andrew_gabbasov@mentor.com Acked-by: Dirk Behme dirk.behme@de.bosch.com
Applied, Thanks!
Andy
participants (6)
Andrew Gabbasov
Andy Fleming
Dirk Behme
Dirk Behme
Gabbasov, Andrew
Stefano Babic
