[PATCH] usb: host: ehci-generic: Handle DM_RESET=n case
In case CONFIG_DM_RESET=n, reset_get_bulk() returns -ENOTSUPP. Do not fail in that case either. This is a valid use case, e.g. in case the reset driver is a no-op and would only waste space in the build.
Fixes: 81755b8c20f ("usb: host: ehci-generic: Make resets and clocks optional") Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: Andre Przywara andre.przywara@arm.com Cc: Patrice Chotard patrice.chotard@foss.st.com --- drivers/usb/host/ehci-generic.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/host/ehci-generic.c b/drivers/usb/host/ehci-generic.c index a765a307a32..83fe701ff67 100644 --- a/drivers/usb/host/ehci-generic.c +++ b/drivers/usb/host/ehci-generic.c @@ -81,7 +81,7 @@ static int ehci_usb_probe(struct udevice *dev) }
err = reset_get_bulk(dev, &priv->resets); - if (err && err != -ENOENT) { + if (err && err != -ENOENT && err != -ENOTSUPP) { dev_err(dev, "Failed to get resets (err=%d)\n", err); goto clk_err; }
Hi Marek
- if (err && err != -ENOENT && err != -ENOTSUPP) { dev_err(dev, "Failed to get resets (err=%d)\n", err); goto clk_err; }
A similar patch can be applied for testing return value of clk_get_bulk() ? In case CONFIG_CLK is not set, clk_get_bulk() can return -ENOSYS.
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
El Tue, Jan 24, 2023 at 09:07:58AM +0100, Patrice CHOTARD deia:
Hi Marek
I thought without CONFIG_CLK the USB port wouldn't work in general ? Is there a case where it works ? (a board with the clocks enabled before U-Boot or something?) I once sent a patch[1] allowing some of the clocks to fail to be got, but it still returned error if they all failed.
[1] https://patchwork.ozlabs.org/project/uboot/patch/Y44+ayJfUlI08ptM@localhost/
Hi Xavier
Hi Marek
Yes it's the case for stih410-b2260 board. All clocks are enabled by default by bootrom. I have just noticed that CONFIG_CLK is enabled for this board, but it shouldn't as there is no clock driver implemented for it.
I made a quick test on stih410-b2260 (i haven't test this board for a while) with CONFIG_CLK disable as it should be, and the following patch is needed :
err = 0; ret = clk_get_bulk(dev, &priv->clocks); - if (ret && ret != -ENOENT) { + if (ret && ret != -ENOENT && ret != -ENOSYS) { dev_err(dev, "Failed to get clocks (ret=%d)\n", ret); return ret;
This patch is superseeded and v3 [1] doesn't update ehci_generic.c anymore ?
[1] https://patchwork.ozlabs.org/project/uboot/patch/Y5IWpjYLB4aXMy9o@localhost/
Patrice
On 1/24/23 09:07, Patrice CHOTARD wrote:
Hi Marek
I would much prefer a proper STIH clock driver however.
And looking at R-Car CPG, I think I will also write a reset controller driver instead of this patch.
Hi Marek
diff --git a/drivers/usb/host/ehci-generic.c b/drivers/usb/host/ehci-generic.c index a765a307a32..83fe701ff67 100644 --- a/drivers/usb/host/ehci-generic.c +++ b/drivers/usb/host/ehci-generic.c @@ -81,7 +81,7 @@ static int ehci_usb_probe(struct udevice *dev) } err = reset_get_bulk(dev, &priv->resets); - if (err && err != -ENOENT) { + if (err && err != -ENOENT && err != -ENOTSUPP) { dev_err(dev, "Failed to get resets (err=%d)\n", err); goto clk_err; }
Ok, i will prepare patches for STIH, i think i should also add stub reset and regulator drivers for this platform.
Patrice
Patrice CHOTARD
