[PATCH v2 0/6] mx6cuboxi: enable OF_PLATDATA with MMC support
The SPL in iMX6 boards is restricted to 68 KB as this is the free available space in OCRAM for most revisions. In this context, adding OF_CONTROL and DM increases the SPL size which could make it difficult to add specific features required for custom scenarios.
These patches aim to take advantage of OF_PLATADATA in order to reduce the SPL size in this scenario, by parsing DT data to generate platdata structures, and thus removing the overhead caused by DT and related libraries.
This series is focused in MMC driver, which is used for boot in boards such as Cubox-i. Also, in order to support CD, the OF_PLATDATA support is also implemented on GPIO driver.
Changes in v2: - Improve commit message with footprint reduction
Walter Lozano (6): mmc: fsl_esdhc_imx: rename driver name to match ll_entry mmc: fsl_esdhc_imx: add OF_PLATDATA support gpio: mxc_gpio: add OF_PLATDATA support mmc: fsl_esdhc_imx: add CD support when OF_PLATDATA is enabled drivers: rename more drivers to match compatible string mx6cuboxi: enable OF_PLATDATA
configs/mx6cuboxi_defconfig | 1 + drivers/gpio/mxc_gpio.c | 18 +++++- drivers/mmc/fsl_esdhc_imx.c | 94 +++++++++++++++++++++++++----- drivers/pinctrl/nxp/pinctrl-imx6.c | 6 +- drivers/video/imx/mxc_ipuv3_fb.c | 4 +- 5 files changed, 103 insertions(+), 20 deletions(-)
As discussed in commit <addf358bac1d2bd0> rename fsl_esdhc_imx driver to allow the OF_PLATDATA support.
Signed-off-by: Walter Lozano walter.lozano@collabora.com ---
(no changes since v1)
drivers/mmc/fsl_esdhc_imx.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index 5b61eeb214..7d76b144a7 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -1644,7 +1644,7 @@ static int fsl_esdhc_bind(struct udevice *dev) #endif
U_BOOT_DRIVER(fsl_esdhc) = { - .name = "fsl-esdhc-mmc", + .name = "fsl_esdhc", .id = UCLASS_MMC, .of_match = fsl_esdhc_ids, .ops = &fsl_esdhc_ops,
On Wed, 22 Jul 2020 at 07:14, Walter Lozano walter.lozano@collabora.com wrote:
In order to reduce the footprint of SPL by removing dtb and library overhead add OF_PLATDATA support to fsl_esdhc_imx. This initial approach does not support card detection, which will be enabled after adding OF_PLATDATA support to GPIO.
drivers/mmc/fsl_esdhc_imx.c | 67 +++++++++++++++++++++++++++++-------- 1 file changed, 53 insertions(+), 14 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index 7d76b144a7..f2509b5cc9 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -33,6 +33,9 @@ #include <dm.h> #include <asm-generic/gpio.h> #include <dm/pinctrl.h> +#include <dt-structs.h> +#include <mapmem.h> +#include <dm/ofnode.h>
#if !CONFIG_IS_ENABLED(BLK) #include "mmc_private.h" @@ -102,6 +105,11 @@ struct fsl_esdhc { };
struct fsl_esdhc_plat { +#if CONFIG_IS_ENABLED(OF_PLATDATA) + /* Put this first since driver model will copy the data here */ + struct dtd_fsl_esdhc dtplat; +#endif + struct mmc_config cfg; struct mmc mmc; }; @@ -1378,25 +1386,19 @@ __weak void init_clk_usdhc(u32 index) { }
-static int fsl_esdhc_probe(struct udevice *dev) +static int fsl_esdhc_ofdata_to_platdata(struct udevice *dev) { - struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); - struct fsl_esdhc_plat *plat = dev_get_platdata(dev); +#if !CONFIG_IS_ENABLED(OF_PLATDATA) struct fsl_esdhc_priv *priv = dev_get_priv(dev); - const void *fdt = gd->fdt_blob; - int node = dev_of_offset(dev); - struct esdhc_soc_data *data = - (struct esdhc_soc_data *)dev_get_driver_data(dev); #if CONFIG_IS_ENABLED(DM_REGULATOR) struct udevice *vqmmc_dev; + int ret; #endif + const void *fdt = gd->fdt_blob; + int node = dev_of_offset(dev); + fdt_addr_t addr; unsigned int val; - struct mmc *mmc; -#if !CONFIG_IS_ENABLED(BLK) - struct blk_desc *bdesc; -#endif - int ret;
addr = dev_read_addr(dev); if (addr == FDT_ADDR_T_NONE) @@ -1404,8 +1406,6 @@ static int fsl_esdhc_probe(struct udevice *dev) priv->esdhc_regs = (struct fsl_esdhc *)addr; priv->dev = dev; priv->mode = -1; - if (data) - priv->flags = data->flags;
val = dev_read_u32_default(dev, "bus-width", -1); if (val == 8) @@ -1469,6 +1469,40 @@ static int fsl_esdhc_probe(struct udevice *dev) priv->vs18_enable = 1; } #endif +#endif + return 0; +} + +static int fsl_esdhc_probe(struct udevice *dev) +{ + struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); + struct fsl_esdhc_plat *plat = dev_get_platdata(dev); + struct fsl_esdhc_priv *priv = dev_get_priv(dev); + struct esdhc_soc_data *data = + (struct esdhc_soc_data *)dev_get_driver_data(dev); + struct mmc *mmc; +#if !CONFIG_IS_ENABLED(BLK) + struct blk_desc *bdesc; +#endif + int ret; + +#if CONFIG_IS_ENABLED(OF_PLATDATA) + struct dtd_fsl_esdhc *dtplat = &plat->dtplat; + unsigned int val; + + priv->esdhc_regs = map_sysmem(dtplat->reg[0], dtplat->reg[1]); + val = plat->dtplat.bus_width; + if (val == 8) + priv->bus_width = 8; + else if (val == 4) + priv->bus_width = 4; + else + priv->bus_width = 1; + priv->non_removable = 1; +#endif + + if (data) + priv->flags = data->flags;
/* * TODO: @@ -1520,9 +1554,11 @@ static int fsl_esdhc_probe(struct udevice *dev) return ret; }
+#if !CONFIG_IS_ENABLED(OF_PLATDATA) ret = mmc_of_parse(dev, &plat->cfg); if (ret) return ret; +#endif
mmc = &plat->mmc; mmc->cfg = &plat->cfg; @@ -1647,6 +1683,7 @@ U_BOOT_DRIVER(fsl_esdhc) = { .name = "fsl_esdhc", .id = UCLASS_MMC, .of_match = fsl_esdhc_ids, + .ofdata_to_platdata = fsl_esdhc_ofdata_to_platdata, .ops = &fsl_esdhc_ops, #if CONFIG_IS_ENABLED(BLK) .bind = fsl_esdhc_bind, @@ -1655,4 +1692,6 @@ U_BOOT_DRIVER(fsl_esdhc) = { .platdata_auto_alloc_size = sizeof(struct fsl_esdhc_plat), .priv_auto_alloc_size = sizeof(struct fsl_esdhc_priv), }; + +U_BOOT_DRIVER_ALIAS(fsl_esdhc, fsl_imx6q_usdhc) #endif
overhead, add
Continuing with the OF_PLATADATA support for iMX6 to reduce SPL footprint, add it to mxc_gpio. Thanks to this, it will be possible to enable card detection on MMC driver.
drivers/gpio/mxc_gpio.c | 18 +++++++++++++++++- 1 file changed, 17 insertions(+), 1 deletion(-)
diff --git a/drivers/gpio/mxc_gpio.c b/drivers/gpio/mxc_gpio.c index 316dcc757b..fc49b5b577 100644 --- a/drivers/gpio/mxc_gpio.c +++ b/drivers/gpio/mxc_gpio.c @@ -13,6 +13,8 @@ #include <asm/arch/imx-regs.h> #include <asm/gpio.h> #include <asm/io.h> +#include <dt-structs.h> +#include <mapmem.h>
enum mxc_gpio_direction { MXC_GPIO_DIRECTION_IN, @@ -22,6 +24,10 @@ enum mxc_gpio_direction { #define GPIO_PER_BANK 32
struct mxc_gpio_plat { +#if CONFIG_IS_ENABLED(OF_PLATDATA) + /* Put this first since driver model will copy the data here */ + struct dtd_gpio_mxc dtplat; +#endif int bank_index; struct gpio_regs *regs; }; @@ -306,8 +312,16 @@ static int mxc_gpio_bind(struct udevice *dev) * is statically initialized in U_BOOT_DEVICES.Here * will return. */ - if (plat) + + if (plat) { +#if CONFIG_IS_ENABLED(OF_PLATDATA) + struct dtd_gpio_mxc *dtplat = &plat->dtplat; + + plat->regs = map_sysmem(dtplat->reg[0], dtplat->reg[1]); + plat->bank_index = dev->req_seq; +#endif return 0; + }
addr = devfdt_get_addr(dev); if (addr == FDT_ADDR_T_NONE) @@ -350,6 +364,8 @@ U_BOOT_DRIVER(gpio_mxc) = { .bind = mxc_gpio_bind, };
+U_BOOT_DRIVER_ALIAS(gpio_mxc, fsl_imx6q_gpio) + #if !CONFIG_IS_ENABLED(OF_CONTROL) static const struct mxc_gpio_plat mxc_plat[] = { { 0, (struct gpio_regs *)GPIO1_BASE_ADDR },
Hi Walter,
This conflicts with commit 6103e570cdd0d0e854b071ee17b14589356a82bd Author: Ye Li ye.li@nxp.com Date: Tue Jun 9 20:29:51 2020 -0700
gpio: mxc_gpio: Improve to use ofdata_to_platdata
already mainlined. Can you take a look ? Thanks !
Best regards, Stefano
- /* Put this first since driver model will copy the data here */
- struct dtd_gpio_mxc dtplat;
- if (plat)
- if (plat) {
+#endif return 0;
Hi Stefano,
On 27/7/20 09:10, Stefano Babic wrote:
Hi Walter,
Sure, thanks for pointing at the issue. I've already sent a new version.
Regards,
Walter
- if (plat)
- if (plat) {
+#endif return 0;
- #if !CONFIG_IS_ENABLED(OF_CONTROL) static const struct mxc_gpio_plat mxc_plat[] = { { 0, (struct gpio_regs *)GPIO1_BASE_ADDR },
After enabling OF_PLATDATA support to both MMC and GPIO drivers add the support for card detection.
drivers/mmc/fsl_esdhc_imx.c | 27 ++++++++++++++++++++++++++- 1 file changed, 26 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index f2509b5cc9..4448565b5a 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -1498,7 +1498,32 @@ static int fsl_esdhc_probe(struct udevice *dev) priv->bus_width = 4; else priv->bus_width = 1; - priv->non_removable = 1; + + if (dtplat->non_removable) + priv->non_removable = 1; + else + priv->non_removable = 0; + +#if CONFIG_IS_ENABLED(DM_GPIO) + if (!priv->non_removable) { + struct udevice *gpiodev; + struct driver_info *info; + + info = (struct driver_info *)dtplat->cd_gpios->node; + + ret = device_get_by_driver_info(info, &gpiodev); + + if (ret) + return ret; + + ret = gpio_dev_request_index(gpiodev, gpiodev->name, "cd-gpios", + dtplat->cd_gpios->arg[0], GPIOD_IS_IN, + dtplat->cd_gpios->arg[1], &priv->cd_gpio); + + if (ret) + return ret; + } +#endif #endif
if (data)
On Wed, 22 Jul 2020 at 07:15, Walter Lozano walter.lozano@collabora.com wrote:
See below
else
Can this use if() ?
if (ret)
return ret;
if (ret)
return ret;
+#endif #endif
if (data)
-- 2.20.1
Continuing with the approach in commit <addf358bac1d2bd0> rename additional drivers to allow the OF_PLATDATA support.
drivers/pinctrl/nxp/pinctrl-imx6.c | 6 ++++-- drivers/video/imx/mxc_ipuv3_fb.c | 4 ++-- 2 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/drivers/pinctrl/nxp/pinctrl-imx6.c b/drivers/pinctrl/nxp/pinctrl-imx6.c index aafa3057ad..84004e5921 100644 --- a/drivers/pinctrl/nxp/pinctrl-imx6.c +++ b/drivers/pinctrl/nxp/pinctrl-imx6.c @@ -41,8 +41,8 @@ static const struct udevice_id imx6_pinctrl_match[] = { { /* sentinel */ } };
-U_BOOT_DRIVER(imx6_pinctrl) = { - .name = "imx6-pinctrl", +U_BOOT_DRIVER(fsl_imx6q_iomuxc) = { + .name = "fsl_imx6q_iomuxc", .id = UCLASS_PINCTRL, .of_match = of_match_ptr(imx6_pinctrl_match), .probe = imx6_pinctrl_probe, @@ -51,3 +51,5 @@ U_BOOT_DRIVER(imx6_pinctrl) = { .ops = &imx_pinctrl_ops, .flags = DM_FLAG_PRE_RELOC, }; + +U_BOOT_DRIVER_ALIAS(fsl_imx6q_iomuxc, fsl_imx6dl_iomuxc) diff --git a/drivers/video/imx/mxc_ipuv3_fb.c b/drivers/video/imx/mxc_ipuv3_fb.c index 587d62f2d8..492bc3e829 100644 --- a/drivers/video/imx/mxc_ipuv3_fb.c +++ b/drivers/video/imx/mxc_ipuv3_fb.c @@ -660,8 +660,8 @@ static const struct udevice_id ipuv3_video_ids[] = { { } };
-U_BOOT_DRIVER(ipuv3_video) = { - .name = "ipuv3_video", +U_BOOT_DRIVER(fsl_imx6q_ipu) = { + .name = "fsl_imx6q_ipu", .id = UCLASS_VIDEO, .of_match = ipuv3_video_ids, .bind = ipuv3_video_bind,
As both MMC and GPIO driver now supports OF_PLATDATA, enable it in defconfig in order to reduce the SPL footprint. After applying this setting the SPL reduction is 5 KB, which partially compensates the increment due to DM.
configs/mx6cuboxi_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index cd4d4da43e..54e5b76f3c 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -42,6 +42,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6dl-hummingboard2-emmc-som-v15" CONFIG_OF_LIST="imx6dl-hummingboard2-emmc-som-v15 imx6q-hummingboard2-emmc-som-v15" CONFIG_MULTI_DTB_FIT=y +CONFIG_SPL_OF_PLATDATA=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y
Changes in v2:
Hi Walter,
Subject: [PATCH v2 0/6] mx6cuboxi: enable OF_PLATDATA with MMC support
Do you have some data that how much is decreased using OF_PLATDATA?
Thanks, Peng.
Changes in v2:
-- 2.20.1
Hi Peng
On 22/7/20 22:34, Peng Fan wrote:
Hi Walter,
Yes, I updated the commit message on Patch 6/6, but should have updated the cover letter. With OF_PLATDATA enabled the reduction on mx6cuboxi_defconfig is 5 KB, which is half of the overhead introduced by DM on this config. Additionally, I've in my backlog some additional patches for further improvements.
Regards,
Walter
Changes in v2:
-- 2.20.1
Peng Fan
Stefano Babic
Walter Lozano
