[U-Boot] [PATCH] Fix compile warnings for const correctness
Commit 6e37b1a3a25004d3df5867de49fff6b3fc9c4f04 modifies several net calls to take a (const char *) parameter instead of (char *), but in some cases the modified functions call other functions taking (char *). The end result is warnings about discarding the const qualifier.
This patch fixes these other function signatures.
Signed-off-by: Ben Warren biggerbadderben@gmail.com --- drivers/net/at91_emac.c | 2 +- drivers/net/eepro100.c | 3 ++- drivers/net/phy/miiphybb.c | 6 +++--- include/net.h | 2 +- net/eth.c | 2 +- 5 files changed, 8 insertions(+), 7 deletions(-)
diff --git a/drivers/net/at91_emac.c b/drivers/net/at91_emac.c index 0912f52..d82459b 100644 --- a/drivers/net/at91_emac.c +++ b/drivers/net/at91_emac.c @@ -162,7 +162,7 @@ int at91emac_write(at91_emac_t *at91mac, unsigned char addr,
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII)
-at91_emac_t *get_emacbase_by_name(char *devname) +at91_emac_t *get_emacbase_by_name(const char *devname) { struct eth_device *netdev;
diff --git a/drivers/net/eepro100.c b/drivers/net/eepro100.c index 5cb767a..22e14e3 100644 --- a/drivers/net/eepro100.c +++ b/drivers/net/eepro100.c @@ -321,7 +321,8 @@ static int set_phyreg (struct eth_device *dev, unsigned char addr, /* Check if given phyaddr is valid, i.e. there is a PHY connected. * Do this by checking model value field from ID2 register. */ -static struct eth_device* verify_phyaddr (char *devname, unsigned char addr) +static struct eth_device* verify_phyaddr (const char *devname, + unsigned char addr) { struct eth_device *dev; unsigned short value; diff --git a/drivers/net/phy/miiphybb.c b/drivers/net/phy/miiphybb.c index 2768c75..1045cf1 100644 --- a/drivers/net/phy/miiphybb.c +++ b/drivers/net/phy/miiphybb.c @@ -143,7 +143,7 @@ void bb_miiphy_init(void) } }
-static inline struct bb_miiphy_bus *bb_miiphy_getbus(char *devname) +static inline struct bb_miiphy_bus *bb_miiphy_getbus(const char *devname) { #ifdef CONFIG_BITBANGMII_MULTI int i; @@ -246,7 +246,7 @@ static void miiphy_pre(struct bb_miiphy_bus *bus, char read, * Returns: * 0 on success */ -int bb_miiphy_read(char *devname, unsigned char addr, +int bb_miiphy_read(const char *devname, unsigned char addr, unsigned char reg, unsigned short *value) { short rdreg; /* register working value */ @@ -327,7 +327,7 @@ int bb_miiphy_read(char *devname, unsigned char addr, * Returns: * 0 on success */ -int bb_miiphy_write (char *devname, unsigned char addr, +int bb_miiphy_write (const char *devname, unsigned char addr, unsigned char reg, unsigned short value) { struct bb_miiphy_bus *bus; diff --git a/include/net.h b/include/net.h index a180881..ab571eb 100644 --- a/include/net.h +++ b/include/net.h @@ -117,7 +117,7 @@ extern void eth_try_another(int first_restart); /* Change the device */ extern void eth_set_current(void); /* set nterface to ethcur var */ #endif extern struct eth_device *eth_get_dev(void); /* get the current device MAC */ -extern struct eth_device *eth_get_dev_by_name(char *devname); /* get device */ +extern struct eth_device *eth_get_dev_by_name(const char *devname); extern struct eth_device *eth_get_dev_by_index(int index); /* get dev @ index */ extern int eth_get_dev_index (void); /* get the device index */ extern void eth_parse_enetaddr(const char *addr, uchar *enetaddr); diff --git a/net/eth.c b/net/eth.c index de6d5c6..993306f 100644 --- a/net/eth.c +++ b/net/eth.c @@ -102,7 +102,7 @@ struct eth_device *eth_get_dev(void) return eth_current; }
-struct eth_device *eth_get_dev_by_name(char *devname) +struct eth_device *eth_get_dev_by_name(const char *devname) { struct eth_device *dev, *target_dev;
Ben Warren
