[U-Boot] [PATCH 10/11] mvebu: Support Synology DS414
This adds support for the MV78230 based DS414 NAS by Synology. The relevant bits have been extracted from the 'synogpl-5004-armadaxp' package Synology kindly published, garnished with a fair amount of trial-and-error.
Sadly, support is far from perfect. The major parts I have failed in are SATA and XHCI support. Details about these and some other things follow:
SATA Support ------------
There is a Marvell 88SX7042 controller attached to PCIe which is supported by Linux's sata_mv driver but sadly not U-Boot's mvsata_ide. I'm not sure if extending the latter to support PCI devices is worth the effort at all. Porting sata_mv from Linux exceeded my brain's capacities. :(
XHCI Support ------------
There is an EtronTech EJ168A XHCI controller attached to PCIe which drives the two rear USB3 ports. After a bit of playing around I managed to get it recognized by xhci-pci, but never was able to access any devices attached to it. Enabling it in ds414 board config shows that it does not respond to commands for whatever reason. The (somewhat) bright side to it is that it is not even supported in Synology's customized U-Boot, but that also means nowhere to steal the relevant bits from.
EHCI Support ------------
This seems functional after issuing 'usb start'. At least it detects USB storage devices, and IIRC reading from them was OK. OTOH Linux fails to register the controller if 'usb start' wasn't given before in U-Boot.
According to Synology sources, this board seems to support USB device (gadget?) mode. Though I didn't play around with it.
PCIe Support ------------
This is fine, but trying to gate the clocks of unused lanes will hang PCI enum. In addition to that, pci_mvebu seems not to support DM_PCI.
DDR3 Training -------------
Marvell/Synology uses eight PUPs instead of four. Does not look like this is meant to be customized in mainline U-Boot at all. OTOH I have no idea what a "PUP" actually is.
PEX Init --------
Synology uses different values than mainline U-Boot with this patch: pex_max_unit_get returns 2, pex_max_if_get returns 7 and max_serdes_lines is set to 7. Not changing this seems to not have an impact, although I'm not entirely sure it does not cause issues I am not aware of.
Signed-off-by: Phil Sutter phil@nwl.cc --- arch/arm/Kconfig | 1 + arch/arm/dts/Makefile | 2 + arch/arm/dts/armada-xp-synology-ds414.dts | 330 +++++++++++++++++++++ arch/arm/mach-mvebu/Kconfig | 3 + arch/arm/mach-mvebu/serdes/axp/board_env_spec.h | 5 +- .../arm/mach-mvebu/serdes/axp/high_speed_env_lib.c | 8 +- board/Synology/ds414/Kconfig | 12 + board/Synology/ds414/Makefile | 1 + board/Synology/ds414/ds414.c | 173 +++++++++++ board/Synology/ds414/kwbimage.cfg | 12 + configs/ds414_defconfig | 12 + include/configs/ds414.h | 153 ++++++++++ 12 files changed, 709 insertions(+), 3 deletions(-) create mode 100644 arch/arm/dts/armada-xp-synology-ds414.dts create mode 100644 board/Synology/ds414/Kconfig create mode 100644 board/Synology/ds414/Makefile create mode 100644 board/Synology/ds414/ds414.c create mode 100644 board/Synology/ds414/kwbimage.cfg create mode 100644 configs/ds414_defconfig create mode 100644 include/configs/ds414.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 7383975..4ea56e7 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -807,6 +807,7 @@ source "board/hisilicon/hikey/Kconfig" source "board/imx31_phycore/Kconfig" source "board/isee/igep0033/Kconfig" source "board/maxbcm/Kconfig" +source "board/Synology/ds414/Kconfig" source "board/mpl/vcma9/Kconfig" source "board/olimex/mx23_olinuxino/Kconfig" source "board/phytec/pcm051/Kconfig" diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 03f984a..d6fc0bb 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -51,6 +51,8 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-388-gp.dtb \ armada-xp-gp.dtb
+dtb-$(CONFIG_TARGET_DS414) += armada-xp-synology-ds414.dtb + dtb-$(CONFIG_ARCH_UNIPHIER) += \ uniphier-ph1-ld4-ref.dtb \ uniphier-ph1-ld6b-ref.dtb \ diff --git a/arch/arm/dts/armada-xp-synology-ds414.dts b/arch/arm/dts/armada-xp-synology-ds414.dts new file mode 100644 index 0000000..749fdba --- /dev/null +++ b/arch/arm/dts/armada-xp-synology-ds414.dts @@ -0,0 +1,330 @@ +/* + * Device Tree file for Synology DS414 + * + * Copyright (C) 2014, Arnaud EBALARD arno@natisbad.org + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version + * 2 of the License, or (at your option) any later version. + * + * Note: this Device Tree assumes that the bootloader has remapped the + * internal registers to 0xf1000000 (instead of the old 0xd0000000). + * The 0xf1000000 is the default used by the recent, DT-capable, U-Boot + * bootloaders provided by Marvell. It is used in recent versions of + * DSM software provided by Synology. Nonetheless, some earlier boards + * were delivered with an older version of u-boot that left internal + * registers mapped at 0xd0000000. If you have such a device you will + * not be able to directly boot a kernel based on this Device Tree. In + * that case, the preferred solution is to update your bootloader (e.g. + * by upgrading to latest version of DSM, or building a new one and + * installing it from u-boot prompt) or adjust the Devive Tree + * (s/0xf1000000/0xd0000000/ in 'ranges' below). + */ + +/dts-v1/; + +#include <dt-bindings/input/input.h> +#include <dt-bindings/gpio/gpio.h> +#include "armada-xp-mv78230.dtsi" + +/ { + model = "Synology DS414"; + compatible = "synology,ds414", "marvell,armadaxp-mv78230", + "marvell,armadaxp", "marvell,armada-370-xp"; + + chosen { + bootargs = "console=ttyS0,115200 earlyprintk"; + stdout-path = &uart0; + }; + + memory { + device_type = "memory"; + reg = <0 0x00000000 0 0x40000000>; /* 1GB */ + }; + + soc { + ranges = <MBUS_ID(0xf0, 0x01) 0 0 0xf1000000 0x100000 + MBUS_ID(0x01, 0x1d) 0 0 0xfff00000 0x100000>; + + pcie-controller { + status = "okay"; + + /* + * Connected to Marvell 88SX7042 SATA-II controller + * handling the four disks. + */ + pcie@1,0 { + /* Port 0, Lane 0 */ + status = "okay"; + }; + + /* + * Connected to EtronTech EJ168A XHCI controller + * providing the two rear USB 3.0 ports. + */ + pcie@5,0 { + /* Port 1, Lane 0 */ + status = "okay"; + }; + }; + + internal-regs { + + /* RTC is provided by Seiko S-35390A below */ + rtc@10300 { + status = "disabled"; + }; + + spi0: spi@10600 { + status = "okay"; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "micron,n25q064"; + reg = <0>; /* Chip select 0 */ + spi-max-frequency = <20000000>; + + /* + * Warning! + * + * Synology u-boot uses its compiled-in environment + * and it seems Synology did not care to change u-boot + * default configuration in order to allow saving a + * modified environment at a sensible location. So, + * if you do a 'saveenv' under u-boot, your modified + * environment will be saved at 1MB after the start + * of the flash, i.e. in the middle of the uImage. + * For that reason, it is strongly advised not to + * change the default environment, unless you know + * what you are doing. + */ + partition@00000000 { /* u-boot */ + label = "RedBoot"; + reg = <0x00000000 0x000d0000>; /* 832KB */ + }; + + partition@000c0000 { /* uImage */ + label = "zImage"; + reg = <0x000d0000 0x002d0000>; /* 2880KB */ + }; + + partition@003a0000 { /* uInitramfs */ + label = "rd.gz"; + reg = <0x003a0000 0x00430000>; /* 4250KB */ + }; + + partition@007d0000 { /* MAC address and serial number */ + label = "vendor"; + reg = <0x007d0000 0x00010000>; /* 64KB */ + }; + + partition@007e0000 { + label = "RedBoot config"; + reg = <0x007e0000 0x00010000>; /* 64KB */ + }; + + partition@007f0000 { + label = "FIS directory"; + reg = <0x007f0000 0x00010000>; /* 64KB */ + }; + }; + }; + + i2c@11000 { + clock-frequency = <400000>; + status = "okay"; + + s35390a: s35390a@30 { + compatible = "sii,s35390a"; + reg = <0x30>; + }; + }; + + /* Connected to a header on device's PCB. This + * provides the main console for the device. + * + * Warning: the device may not boot with a 3.3V + * USB-serial converter connected when the power + * button is pressed. The converter needs to be + * connected a few seconds after pressing the + * power button. This is possibly due to UART0_TXD + * pin being sampled at reset (bit 0 of SAR). + */ + serial@12000 { + status = "okay"; + }; + + /* Connected to a Microchip PIC16F883 for power control */ + serial@12100 { + status = "okay"; + }; + + poweroff@12100 { + compatible = "synology,power-off"; + reg = <0x12100 0x100>; + clocks = <&coreclk 0>; + }; + + /* Front USB 2.0 port */ + usb@50000 { + status = "okay"; + }; + + mdio { + phy0: ethernet-phy@0 { /* Marvell 88E1512 */ + reg = <0>; + }; + + phy1: ethernet-phy@1 { /* Marvell 88E1512 */ + reg = <1>; + }; + }; + + ethernet@70000 { + status = "okay"; + pinctrl-0 = <&ge0_rgmii_pins>; + pinctrl-names = "default"; + phy = <&phy1>; + phy-mode = "rgmii-id"; + }; + + ethernet@74000 { + pinctrl-0 = <&ge1_rgmii_pins>; + pinctrl-names = "default"; + status = "okay"; + phy = <&phy0>; + phy-mode = "rgmii-id"; + }; + }; + }; + + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-0 = <&sata1_pwr_pin &sata2_pwr_pin + &sata3_pwr_pin &sata4_pwr_pin>; + pinctrl-names = "default"; + + sata1_regulator: sata1-regulator { + compatible = "regulator-fixed"; + reg = <1>; + regulator-name = "SATA1 Power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + startup-delay-us = <2000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + gpio = <&gpio1 10 GPIO_ACTIVE_HIGH>; + }; + + sata2_regulator: sata2-regulator { + compatible = "regulator-fixed"; + reg = <2>; + regulator-name = "SATA2 Power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + startup-delay-us = <4000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + gpio = <&gpio1 12 GPIO_ACTIVE_HIGH>; + }; + + sata3_regulator: sata3-regulator { + compatible = "regulator-fixed"; + reg = <3>; + regulator-name = "SATA3 Power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + startup-delay-us = <6000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + gpio = <&gpio1 13 GPIO_ACTIVE_HIGH>; + }; + + sata4_regulator: sata4-regulator { + compatible = "regulator-fixed"; + reg = <4>; + regulator-name = "SATA4 Power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + startup-delay-us = <8000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + gpio = <&gpio1 14 GPIO_ACTIVE_HIGH>; + }; + }; +}; + +&pinctrl { + sata1_pwr_pin: sata1-pwr-pin { + marvell,pins = "mpp42"; + marvell,function = "gpio"; + }; + + sata2_pwr_pin: sata2-pwr-pin { + marvell,pins = "mpp44"; + marvell,function = "gpio"; + }; + + sata3_pwr_pin: sata3-pwr-pin { + marvell,pins = "mpp45"; + marvell,function = "gpio"; + }; + + sata4_pwr_pin: sata4-pwr-pin { + marvell,pins = "mpp46"; + marvell,function = "gpio"; + }; + + sata1_pres_pin: sata1-pres-pin { + marvell,pins = "mpp34"; + marvell,function = "gpio"; + }; + + sata2_pres_pin: sata2-pres-pin { + marvell,pins = "mpp35"; + marvell,function = "gpio"; + }; + + sata3_pres_pin: sata3-pres-pin { + marvell,pins = "mpp40"; + marvell,function = "gpio"; + }; + + sata4_pres_pin: sata4-pres-pin { + marvell,pins = "mpp41"; + marvell,function = "gpio"; + }; + + syno_id_bit0_pin: syno-id-bit0-pin { + marvell,pins = "mpp26"; + marvell,function = "gpio"; + }; + + syno_id_bit1_pin: syno-id-bit1-pin { + marvell,pins = "mpp28"; + marvell,function = "gpio"; + }; + + syno_id_bit2_pin: syno-id-bit2-pin { + marvell,pins = "mpp29"; + marvell,function = "gpio"; + }; + + fan1_alarm_pin: fan1-alarm-pin { + marvell,pins = "mpp33"; + marvell,function = "gpio"; + }; + + fan2_alarm_pin: fan2-alarm-pin { + marvell,pins = "mpp32"; + marvell,function = "gpio"; + }; +}; diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index 79ff0e8..612bafb 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -13,6 +13,9 @@ config TARGET_DB_MV784MP_GP config TARGET_MAXBCM bool "Support maxbcm"
+config TARGET_DS414 + bool "Support Synology DS414" + endchoice
config SYS_SOC diff --git a/arch/arm/mach-mvebu/serdes/axp/board_env_spec.h b/arch/arm/mach-mvebu/serdes/axp/board_env_spec.h index 36e0ed8..e0d5828 100644 --- a/arch/arm/mach-mvebu/serdes/axp/board_env_spec.h +++ b/arch/arm/mach-mvebu/serdes/axp/board_env_spec.h @@ -43,8 +43,9 @@ #define RD_78460_SERVER_REV2_ID (DB_78X60_PCAC_REV2_ID + 1) #define DB_784MP_GP_ID (RD_78460_SERVER_REV2_ID + 1) #define RD_78460_CUSTOMER_ID (DB_784MP_GP_ID + 1) -#define MV_MAX_BOARD_ID (RD_78460_CUSTOMER_ID + 1) -#define INVALID_BAORD_ID 0xFFFFFFFF +#define SYNOLOGY_DS414_ID (RD_78460_CUSTOMER_ID + 1) +#define MV_MAX_BOARD_ID (SYNOLOGY_DS414_ID + 1) +#define INVALID_BOARD_ID 0xFFFFFFFF
/* Sample at Reset */ #define MPP_SAMPLE_AT_RESET(id) (0x18230 + (id * 4)) diff --git a/arch/arm/mach-mvebu/serdes/axp/high_speed_env_lib.c b/arch/arm/mach-mvebu/serdes/axp/high_speed_env_lib.c index 6c7738c..511a850 100644 --- a/arch/arm/mach-mvebu/serdes/axp/high_speed_env_lib.c +++ b/arch/arm/mach-mvebu/serdes/axp/high_speed_env_lib.c @@ -66,6 +66,8 @@ static u32 board_id_get(void) return DB_784MP_GP_ID; #elif defined(CONFIG_RD_78460_CUSTOMER) return RD_78460_CUSTOMER_ID; +#elif defined(CONFIG_SYNOLOGY_DS414) + return SYNOLOGY_DS414_ID; #else /* * Return 0 here for custom board as this should not be used @@ -191,8 +193,11 @@ __weak MV_BIN_SERDES_CFG *board_serdes_cfg_get(u8 pex_mode)
u16 ctrl_model_get(void) { - /* Right now only MV78460 supported */ +#if defined(CONFIG_SYNOLOGY_DS414) + return MV_78230_DEV_ID; +#else return MV_78460_DEV_ID; +#endif }
u32 get_line_cfg(u32 line_num, MV_BIN_SERDES_CFG *info) @@ -241,6 +246,7 @@ int serdes_phy_config(void) case RD_78460_SERVER_ID: case RD_78460_SERVER_REV2_ID: case DB_78X60_PCAC_ID: + case SYNOLOGY_DS414_ID: satr11 = (0x1 << 1) | 1; break; case FPGA_88F78XX0_ID: diff --git a/board/Synology/ds414/Kconfig b/board/Synology/ds414/Kconfig new file mode 100644 index 0000000..4d30852 --- /dev/null +++ b/board/Synology/ds414/Kconfig @@ -0,0 +1,12 @@ +if TARGET_DS414 + +config SYS_BOARD + default "ds414" + +config SYS_VENDOR + default "Synology" + +config SYS_CONFIG_NAME + default "ds414" + +endif diff --git a/board/Synology/ds414/Makefile b/board/Synology/ds414/Makefile new file mode 100644 index 0000000..aad8c43 --- /dev/null +++ b/board/Synology/ds414/Makefile @@ -0,0 +1 @@ +obj-y := ds414.o diff --git a/board/Synology/ds414/ds414.c b/board/Synology/ds414/ds414.c new file mode 100644 index 0000000..88252f6 --- /dev/null +++ b/board/Synology/ds414/ds414.c @@ -0,0 +1,173 @@ +#include <common.h> +#include <miiphy.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/soc.h> +#include <linux/mbus.h> + +#include "../drivers/ddr/marvell/axp/ddr3_hw_training.h" +#include "../arch/arm/mach-mvebu/serdes/axp/high_speed_env_spec.h" +#include "../arch/arm/mach-mvebu/serdes/axp/board_env_spec.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* GPP and MPP settings as found in mvBoardEnvSpec.c of Synology's U-Boot */ + +#define DS414_GPP_OUT_VAL_LOW (BIT(25) | BIT(30)) +#define DS414_GPP_OUT_VAL_MID (BIT(10) | BIT(15)) +#define DS414_GPP_OUT_VAL_HIGH (0) + +#define DS414_GPP_OUT_POL_LOW (0) +#define DS414_GPP_OUT_POL_MID (0) +#define DS414_GPP_OUT_POL_HIGH (0) + +#define DS414_GPP_OUT_ENA_LOW (~(BIT(25) | BIT(30))) +#define DS414_GPP_OUT_ENA_MID (~(BIT(10) | BIT(12) | \ + BIT(13) | BIT(14) | BIT(15))) +#define DS414_GPP_OUT_ENA_HIGH (~0) + +static const u32 ds414_mpp_control[] = { + 0x11111111, + 0x22221111, + 0x22222222, + 0x00000000, + 0x11110000, + 0x00004000, + 0x00000000, + 0x00000000, + 0x00000000 +}; + +/* DDR3 static MC configuration */ + +/* 1G_v1 (4x2Gbits) adapted by DS414 */ +MV_DRAM_MC_INIT syno_ddr3_b0_667_1g_v1[MV_MAX_DDR3_STATIC_SIZE] = { + {0x00001400, 0x73014A28}, /*DDR SDRAM Configuration Register */ + {0x00001404, 0x30000800}, /*Dunit Control Low Register */ + {0x00001408, 0x44148887}, /*DDR SDRAM Timing (Low) Register */ + /* {0x0000140C, 0x38000C6}, */ /*DDR SDRAM Timing (High) Register */ + {0x0000140C, 0x3AD83FEA}, /*DDR SDRAM Timing (High) Register */ + + {0x00001410, 0x14000000}, /*DDR SDRAM Address Control Register */ + + {0x00001414, 0x00000000}, /*DDR SDRAM Open Pages Control Register */ + {0x00001418, 0x00000e00}, /*DDR SDRAM Operation Register */ + {0x00001420, 0x00000004}, /*DDR SDRAM Extended Mode Register */ + {0x00001424, 0x0000F3FF}, /*Dunit Control High Register */ + {0x00001428, 0x000F8830}, /*Dunit Control High Register */ + {0x0000142C, 0x054C36F4}, /*Dunit Control High Register */ + {0x0000147C, 0x0000C671}, + + {0x000014a0, 0x00000001}, + {0x000014a8, 0x00000100}, /*2:1 */ + {0x00020220, 0x00000006}, + + {0x00001494, 0x00010000}, /*DDR SDRAM ODT Control (Low) Register */ + {0x00001498, 0x00000000}, /*DDR SDRAM ODT Control (High) Register */ + {0x0000149C, 0x00000001}, /*DDR Dunit ODT Control Register */ + + {0x000014C0, 0x192424C9}, /* DRAM address and Control Driving Strenght */ + {0x000014C4, 0x0AAA24C9}, /* DRAM Data and DQS Driving Strenght */ + + {0x000200e8, 0x3FFF0E01}, /* DO NOT Modify - Open Mbus Window - 2G - Mbus is required for the training sequence*/ + {0x00020184, 0x3FFFFFE0}, /* DO NOT Modify - Close fast path Window to - 2G */ + + {0x0001504, 0x3FFFFFE1}, /* CS0 Size */ + {0x000150C, 0x00000000}, /* CS1 Size */ + {0x0001514, 0x00000000}, /* CS2 Size */ + {0x000151C, 0x00000000}, /* CS3 Size */ + + /* {0x00001524, 0x0000C800}, */ + {0x00001538, 0x00000009}, /*Read Data Sample Delays Register */ + {0x0000153C, 0x00000009}, /*Read Data Ready Delay Register */ + + {0x000015D0, 0x00000650}, /*MR0 */ + {0x000015D4, 0x00000044}, /*MR1 */ + {0x000015D8, 0x00000010}, /*MR2 */ + {0x000015DC, 0x00000000}, /*MR3 */ + + {0x000015E4, 0x00203c18}, /*ZQC Configuration Register */ + {0x000015EC, 0xF800A225}, /*DDR PHY */ + + {0x0, 0x0} +}; + +MV_DRAM_MODES ds414_ddr_modes[MV_DDR3_MODES_NUMBER] = { + {"ds414_1333-667", 0x3, 0x5, 0x0, A0, syno_ddr3_b0_667_1g_v1, NULL}, +}; + +extern MV_SERDES_CHANGE_M_PHY serdes_change_m_phy[]; + +MV_BIN_SERDES_CFG ds414_serdes_cfg[] = { + { MV_PEX_ROOT_COMPLEX, 0x02011111, 0x00000000, + { PEX_BUS_MODE_X4, PEX_BUS_MODE_X1, PEX_BUS_DISABLED, + PEX_BUS_DISABLED }, + 0x0040, serdes_change_m_phy + } +}; + +MV_DRAM_MODES *ddr3_get_static_ddr_mode(void) +{ + return &ds414_ddr_modes[0]; +} + +MV_BIN_SERDES_CFG *board_serdes_cfg_get(u8 pex_mode) +{ + return &ds414_serdes_cfg[0]; +} + +int board_early_init_f(void) +{ + int i; + + /* Set GPP Out value */ + reg_write(GPP_DATA_OUT_REG(0), DS414_GPP_OUT_VAL_LOW); + reg_write(GPP_DATA_OUT_REG(1), DS414_GPP_OUT_VAL_MID); + reg_write(GPP_DATA_OUT_REG(2), DS414_GPP_OUT_VAL_HIGH); + + /* set GPP polarity */ + reg_write(GPP_DATA_IN_POL_REG(0), DS414_GPP_OUT_POL_LOW); + reg_write(GPP_DATA_IN_POL_REG(1), DS414_GPP_OUT_POL_MID); + reg_write(GPP_DATA_IN_POL_REG(2), DS414_GPP_OUT_POL_HIGH); + + /* Set GPP Out Enable */ + reg_write(GPP_DATA_OUT_EN_REG(0), DS414_GPP_OUT_ENA_LOW); + reg_write(GPP_DATA_OUT_EN_REG(1), DS414_GPP_OUT_ENA_MID); + reg_write(GPP_DATA_OUT_EN_REG(2), DS414_GPP_OUT_ENA_HIGH); + + for (i = 0; i < ARRAY_SIZE(ds414_mpp_control); i++) + reg_write(MPP_CONTROL_REG(i), ds414_mpp_control[i]); + + return 0; +} + +int board_init(void) +{ + u32 pwr_mng_ctrl_reg; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = mvebu_sdram_bar(0) + 0x100; + + /* gate unused clocks */ + /* Note: disabling unused PCIe lanes will hang PCI bus scan */ + pwr_mng_ctrl_reg = reg_read(POWER_MNG_CTRL_REG); + pwr_mng_ctrl_reg &= ~(BIT(0)); /* Audio */ + pwr_mng_ctrl_reg &= ~(BIT(1) | BIT(2)); /* GE3, GE2 */ + //pwr_mng_ctrl_reg &= ~(BIT(10) | BIT(11) | BIT(12)); /* PCIe11 - PCIe13 */ + pwr_mng_ctrl_reg &= ~(BIT(14) | BIT(15)); /* SATA0 link and core */ + pwr_mng_ctrl_reg &= ~(BIT(16)); /* LCD */ + pwr_mng_ctrl_reg &= ~(BIT(17)); /* SDIO */ + pwr_mng_ctrl_reg &= ~(BIT(19) | BIT(20)); /* USB1 and USB2 */ + //pwr_mng_ctrl_reg &= ~(BIT(26) | BIT(27)); /* PCIe20 and PCIe30 */ + pwr_mng_ctrl_reg &= ~(BIT(29) | BIT(30)); /* SATA1 link and core */ + reg_write(POWER_MNG_CTRL_REG, pwr_mng_ctrl_reg); + + return 0; +} + +int checkboard(void) +{ + puts("Board: DS414\n"); + + return 0; +} diff --git a/board/Synology/ds414/kwbimage.cfg b/board/Synology/ds414/kwbimage.cfg new file mode 100644 index 0000000..cc05792 --- /dev/null +++ b/board/Synology/ds414/kwbimage.cfg @@ -0,0 +1,12 @@ +# +# Copyright (C) 2014 Stefan Roese sr@denx.de +# + +# Armada XP uses version 1 image format +VERSION 1 + +# Boot Media configurations +BOOT_FROM spi + +# Binary Header (bin_hdr) with DDR3 training code +BINARY spl/u-boot-spl.bin 0000005b 00000068 diff --git a/configs/ds414_defconfig b/configs/ds414_defconfig new file mode 100644 index 0000000..b826a10 --- /dev/null +++ b/configs/ds414_defconfig @@ -0,0 +1,12 @@ +CONFIG_ARM=y +CONFIG_ARCH_MVEBU=y +CONFIG_TARGET_DS414=y +CONFIG_DEFAULT_DEVICE_TREE="armada-xp-synology-ds414" +CONFIG_SPL=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_SETEXPR is not set +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SYS_NS16550=y diff --git a/include/configs/ds414.h b/include/configs/ds414.h new file mode 100644 index 0000000..38d7e01 --- /dev/null +++ b/include/configs/ds414.h @@ -0,0 +1,153 @@ +/* + * Copyright (C) 2014 Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _CONFIG_SYNOLOGY_DS414_H +#define _CONFIG_SYNOLOGY_DS414_H + +/* + * High Level Configuration Options (easy to change) + */ +#define CONFIG_ARMADA_XP /* SOC Family Name */ +#define CONFIG_SYNOLOGY_DS414 /* board target name for DDR training and PCIe init */ +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ +#endif +#define CONFIG_DISPLAY_BOARDINFO_LATE + +/* + * TEXT_BASE needs to be below 16MiB, since this area is scrubbed + * for DDR ECC byte filling in the SPL before loading the main + * U-Boot into it. + */ +#define CONFIG_SYS_TEXT_BASE 0x00800000 +#define CONFIG_SYS_TCLK 250000000 /* 250MHz */ + +/* + * Commands configuration + */ +#define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ENV +#define CONFIG_CMD_I2C +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PCI_ENUM +#define CONFIG_CMD_PING +#define CONFIG_CMD_SF +#define CONFIG_CMD_SPI +#define CONFIG_CMD_TFTPPUT +#define CONFIG_CMD_TIME +#define CONFIG_CMD_USB + +/* I2C */ +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MVTWSI +#define CONFIG_I2C_MVTWSI_BASE0 MVEBU_TWSI_BASE +#define CONFIG_SYS_I2C_SLAVE 0x0 +#define CONFIG_SYS_I2C_SPEED 100000 + +/* SPI NOR flash default params, used by sf commands */ +#define CONFIG_SF_DEFAULT_SPEED 1000000 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_3 + +/* Environment in SPI NOR flash */ +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_OFFSET 0x7E0000 /* RedBoot config partition in DTS */ +#define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ +#define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64KiB sectors */ + +#define CONFIG_PHY_MARVELL /* there is a marvell phy */ +#define CONFIG_PHY_ADDR { 0x1, 0x0 } +#define CONFIG_SYS_NETA_INTERFACE_TYPE PHY_INTERFACE_MODE_RGMII + +#define CONFIG_SYS_ALT_MEMTEST + +/* PCIe support */ +#define CONFIG_PCI +#define CONFIG_PCI_MVEBU +#define CONFIG_PCI_SCAN_SHOW + +/* USB/EHCI/XHCI configuration */ + +/* FIXME: broken XHCI support + * Below defines should enable support for the two rear USB3 ports. Sadly, this + * does not work because: + * - xhci-pci seems not to support DM_USB, so with that enabled it is not + * found. To workaround, uncomment CONFIG_DM_USB define. + * - USB init fails, controller seems not to respond in time */ +#if 0 +#define CONFIG_DM_USB +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 +#define CONFIG_USB_XHCI +#define CONFIG_USB_XHCI_PCI +#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 +#endif + +#if !defined(CONFIG_USB_XHCI) || defined(CONFIG_DM_USB) +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_MARVELL +#define CONFIG_EHCI_IS_TDI +#endif + +#define CONFIG_USB_STORAGE +#define CONFIG_SYS_MVFS + +/* + * mv-common.h should be defined after CMD configs since it used them + * to enable certain macros + */ +#include "mv-common.h" + +/* + * Memory layout while starting into the bin_hdr via the + * BootROM: + * + * 0x4000.4000 - 0x4003.4000 headers space (192KiB) + * 0x4000.4030 bin_hdr start address + * 0x4003.4000 - 0x4004.7c00 BootROM memory allocations (15KiB) + * 0x4007.fffc BootROM stack top + * + * The address space between 0x4007.fffc and 0x400f.fff is not locked in + * L2 cache thus cannot be used. + */ + +/* SPL */ +/* Defines for SPL */ +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_TEXT_BASE 0x40004030 +#define CONFIG_SPL_MAX_SIZE ((128 << 10) - 0x4030) + +#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + (128 << 10)) +#define CONFIG_SPL_BSS_MAX_SIZE (16 << 10) + +#define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \ + CONFIG_SPL_BSS_MAX_SIZE) +#define CONFIG_SYS_SPL_MALLOC_SIZE (16 << 10) + +#define CONFIG_SPL_STACK (0x40000000 + ((192 - 16) << 10)) +#define CONFIG_SPL_BOOTROM_SAVE (CONFIG_SPL_STACK + 4) + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT + +/* SPL related SPI defines */ +#define CONFIG_SPL_SPI_SUPPORT +#define CONFIG_SPL_SPI_FLASH_SUPPORT +#define CONFIG_SPL_SPI_LOAD +#define CONFIG_SPL_SPI_BUS 0 +#define CONFIG_SPL_SPI_CS 0 +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 + +/* Enable DDR support in SPL (DDR3 training from Marvell bin_hdr) */ +#define CONFIG_SYS_MVEBU_DDR_AXP +#define MV_DDR_32BIT + +/* Use random ethernet address if not configured */ +#define CONFIG_LIB_RAND +#define CONFIG_NET_RANDOM_ETHADDR + +#endif /* _CONFIG_SYNOLOGY_DS414_H */
Phil Sutter
