[U-Boot] [PATCH] mtd: spi: Add DM support to SH QSPI driver
Add DM support to the SH QSPI driver while retaining non-DM support. The later is required as this driver is used in SPL which has a size limitation of 16 kiB.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- drivers/spi/sh_qspi.c | 215 +++++++++++++++++++++++++++++++++++--------------- 1 file changed, 150 insertions(+), 65 deletions(-)
diff --git a/drivers/spi/sh_qspi.c b/drivers/spi/sh_qspi.c index e9123e2c39..64dfd748d6 100644 --- a/drivers/spi/sh_qspi.c +++ b/drivers/spi/sh_qspi.c @@ -67,15 +67,12 @@ struct sh_qspi_regs { };
struct sh_qspi_slave { +#ifndef CONFIG_DM_SPI struct spi_slave slave; +#endif struct sh_qspi_regs *regs; };
-static inline struct sh_qspi_slave *to_sh_qspi(struct spi_slave *slave) -{ - return container_of(slave, struct sh_qspi_slave, slave); -} - static void sh_qspi_init(struct sh_qspi_slave *ss) { /* QSPI initialize */ @@ -119,15 +116,8 @@ static void sh_qspi_init(struct sh_qspi_slave *ss) setbits_8(&ss->regs->spcr, SPCR_SPE); }
-int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - return 1; -} - -void spi_cs_activate(struct spi_slave *slave) +static void sh_qspi_cs_activate(struct sh_qspi_slave *ss) { - struct sh_qspi_slave *ss = to_sh_qspi(slave); - /* Set master mode only */ writeb(SPCR_MSTR, &ss->regs->spcr);
@@ -147,61 +137,15 @@ void spi_cs_activate(struct spi_slave *slave) setbits_8(&ss->regs->spcr, SPCR_SPE); }
-void spi_cs_deactivate(struct spi_slave *slave) +static void sh_qspi_cs_deactivate(struct sh_qspi_slave *ss) { - struct sh_qspi_slave *ss = to_sh_qspi(slave); - /* Disable SPI Function */ clrbits_8(&ss->regs->spcr, SPCR_SPE); }
-void spi_init(void) -{ - /* nothing to do */ -} - -struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int mode) -{ - struct sh_qspi_slave *ss; - - if (!spi_cs_is_valid(bus, cs)) - return NULL; - - ss = spi_alloc_slave(struct sh_qspi_slave, bus, cs); - if (!ss) { - printf("SPI_error: Fail to allocate sh_qspi_slave\n"); - return NULL; - } - - ss->regs = (struct sh_qspi_regs *)SH_QSPI_BASE; - - /* Init SH QSPI */ - sh_qspi_init(ss); - - return &ss->slave; -} - -void spi_free_slave(struct spi_slave *slave) +static int sh_qspi_xfer_common(struct sh_qspi_slave *ss, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) { - struct sh_qspi_slave *spi = to_sh_qspi(slave); - - free(spi); -} - -int spi_claim_bus(struct spi_slave *slave) -{ - return 0; -} - -void spi_release_bus(struct spi_slave *slave) -{ -} - -int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, - void *din, unsigned long flags) -{ - struct sh_qspi_slave *ss = to_sh_qspi(slave); u32 nbyte, chunk; int i, ret = 0; u8 dtdata = 0, drdata; @@ -210,7 +154,7 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout,
if (dout == NULL && din == NULL) { if (flags & SPI_XFER_END) - spi_cs_deactivate(slave); + sh_qspi_cs_deactivate(ss); return 0; }
@@ -222,7 +166,7 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, nbyte = bitlen / 8;
if (flags & SPI_XFER_BEGIN) { - spi_cs_activate(slave); + sh_qspi_cs_activate(ss);
/* Set 1048576 byte */ writel(0x100000, spbmul0); @@ -273,7 +217,148 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, }
return ret; } + +#ifndef CONFIG_DM_SPI +static inline struct sh_qspi_slave *to_sh_qspi(struct spi_slave *slave) +{ + return container_of(slave, struct sh_qspi_slave, slave); +} + +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return 1; +} + +void spi_cs_activate(struct spi_slave *slave) +{ + struct sh_qspi_slave *ss = to_sh_qspi(slave); + + sh_qspi_cs_activate(ss); +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + struct sh_qspi_slave *ss = to_sh_qspi(slave); + + sh_qspi_cs_deactivate(ss); +} + +void spi_init(void) +{ + /* nothing to do */ +} + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct sh_qspi_slave *ss; + + if (!spi_cs_is_valid(bus, cs)) + return NULL; + + ss = spi_alloc_slave(struct sh_qspi_slave, bus, cs); + if (!ss) { + printf("SPI_error: Fail to allocate sh_qspi_slave\n"); + return NULL; + } + + ss->regs = (struct sh_qspi_regs *)SH_QSPI_BASE; + + /* Init SH QSPI */ + sh_qspi_init(ss); + + return &ss->slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + struct sh_qspi_slave *spi = to_sh_qspi(slave); + + free(spi); +} + +int spi_claim_bus(struct spi_slave *slave) +{ + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct sh_qspi_slave *ss = to_sh_qspi(slave); + + return sh_qspi_xfer_common(ss, bitlen, dout, din, flags); +} + +#else + +#include <dm.h> + +static int sh_qspi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct udevice *bus = dev->parent; + struct sh_qspi_slave *ss = dev_get_platdata(bus); + + return sh_qspi_xfer_common(ss, bitlen, dout, din, flags); +} + +static int sh_qspi_set_speed(struct udevice *dev, uint speed) +{ + /* This is a SPI NOR controller, do nothing. */ + return 0; +} + +static int sh_qspi_set_mode(struct udevice *dev, uint mode) +{ + /* This is a SPI NOR controller, do nothing. */ + return 0; +} + +static int sh_qspi_probe(struct udevice *dev) +{ + struct sh_qspi_slave *ss = dev_get_platdata(dev); + + sh_qspi_init(ss); + + return 0; +} + +static int sh_qspi_ofdata_to_platdata(struct udevice *dev) +{ + struct sh_qspi_slave *plat = dev_get_platdata(dev); + + plat->regs = (struct sh_qspi_regs *)dev_read_addr(dev); + + return 0; +} + +static const struct dm_spi_ops sh_qspi_ops = { + .xfer = sh_qspi_xfer, + .set_speed = sh_qspi_set_speed, + .set_mode = sh_qspi_set_mode, +}; + +static const struct udevice_id sh_qspi_ids[] = { + { .compatible = "renesas,qspi" }, + { } +}; + +U_BOOT_DRIVER(sh_qspi) = { + .name = "sh_qspi", + .id = UCLASS_SPI, + .of_match = sh_qspi_ids, + .ops = &sh_qspi_ops, + .ofdata_to_platdata = sh_qspi_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct sh_qspi_slave), + .probe = sh_qspi_probe, +}; +#endif
We are trying to drop non-dm code as much as possible (with MIGRATION.txt policy), how about adding PLTADATA or spi read glue code or any other?
Jagan.
The SPL on that board (silk) has 16 kiB limit, right now I am at 15500 B with gcc 7.x already, adding any more overhead will make it overflow. So while I'd like to have it all fancy DM and stuff, it's not possible.
How about having simple glue code for SPL, since it anyway used for read in real?
I'd prefer to use the same driver for both SPL and U-Boot instead of hacking stuff up. Not sure what exactly you mean by "glue" though.
Something that bypass spi stack and read the flash with local code, this usually suited for low SRAM size like silk example spl_spi_sunxi.c
But I am not _that_ cripplingly low, so I'd prefer to stick to a standard solution instead of some hack.
On Sat, Aug 25, 2018 at 11:04 PM, Marek Vasut marek.vasut@gmail.com wrote: > Add DM support to the SH QSPI driver while retaining non-DM support. > The later is required as this driver is used in SPL which has a size > limitation of 16 kiB. > > Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com > Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org > --- > drivers/spi/sh_qspi.c | 215 +++++++++++++++++++++++++++++++++++--------------- > 1 file changed, 150 insertions(+), 65 deletions(-) > > diff --git a/drivers/spi/sh_qspi.c b/drivers/spi/sh_qspi.c > index e9123e2c39..64dfd748d6 100644 > --- a/drivers/spi/sh_qspi.c > +++ b/drivers/spi/sh_qspi.c > @@ -67,15 +67,12 @@ struct sh_qspi_regs { > }; > > struct sh_qspi_slave { > +#ifndef CONFIG_DM_SPI
OK, is this a fix or shall I take it for next?
Applied to u-boot-spi/master
Jagan Teki
