[U-Boot-Users] Kernel XIP
Hello,
I configured for kernel XIP and created xipImage. When I tried to load it through u-boot, it complained about invalid magic number. Later I added a 64 byte header required for u-boot with the following mkimage command:
mkimage -A arm -O linux -T kernel -C none -a 0x00080000 -e 0x00080040 -d xipImage XIPImage.
Actually some of the document found at CELF wiki specifies that we need to give "-x" option to mkimage. With -x option, mkimage fails with the following error message :
mkimage: Bad file: "xipImage" has invalid buffer for XIP.
After looking into the mkimage source code, found that it expects 0xFF for the first 64 bytes of xipImage. Which is missing in the xipImage I have built. There must be some in-consistency between the way xipImage is built or mkimage command.
Also, I didn't find any significance of the code for "-x" if we specify the "entry point" correctly (load address + 0x40).
After the mkimage, I flashed the XIPImage at address 0x00080000. After resetting the board, I got the following boot messages :
## Booting image at 00080000 ... Image Name: Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2009016 Bytes = 1.9 MB Load Address: 00080000 Entry Point: 00080040 Verifying Checksum ... OK XIP Kernel Image ... OK
Starting kernel ...
And it stops here....
Any idea what is going wrong here ?
My configuration:
Processor : ARM926EJ-Sid(wb) rev 3 (v5l) Kernel : 2.6.10
Regards Shivappa
In message DCAFE6B52143A24082BB128C3AEF61E07C70EF@BLR-EC-MBX03.wipro.com you wrote:
U-Boot does not provide direct support for XIP on ARM; the existing code has only been tested on PowerPC.
Search the ARM linux mailing list and you will find an extensive discussion about all these issues.
I´ve the same problem! Did you find a solution for this problem? -- View this message in context: http://www.nabble.com/Kernel+XIP-t79165.html#a4469807 Sent from the Uboot - Users forum at Nabble.com.
Hurricane555
shivappa.kushtagi@wipro.com
