[U-Boot] Please pull u-boot-mmc
Dear Tom,
Could pull these patches on u-boot/master?
The following changes since commit 9b1b6d42256a4c2e59c803afdbf90d39371e61ba:
Revert "Increase default of CONFIG_SYS_MALLOC_F_LEN for SPL_OF_CONTROL" (2016-09-19 15:20:09 -0400)
http://git.denx.de/u-boot-mmc.git master
for you to fetch changes up to 2b42903397b4d6b68fe2af95565a8953b08ab96e:
mmc: dw_mmc: push/pop all FIFO data if any data request (2016-09-21 16:00:14 +0900)
---------------------------------------------------------------- Jacob Chen (1): mmc: dw_mmc: push/pop all FIFO data if any data request
Masahiro Yamada (6): mmc: sdhci: move sdhci_reset() call to sdhci_init() mmc: sdhci: move error message to more relevant place mmc: sdhci: move broken voltage quirk handling to sdhci_setup_cfg() mmc: sdhci: move SDMA capability check to sdhci_setup_cfg() mmc: sdhci: drop CONFIG_ from CONFIG_SDHCI_CMD_DEFAULT_TIME mmc: sdhci: drop CONFIG_ from CONFIG_SDHCI_CMD_MAX_TIMEOUT
Peng Fan (2): mmc: sd: extracting erase related information from sd status mmc: sd: optimize erase
Wenyou Yang (1): mmc: sdhci: Add the programmable clock mode support
drivers/mmc/dw_mmc.c | 23 ++++++----- drivers/mmc/mmc.c | 68 +++++++++++++++++++++++++++++++ drivers/mmc/mmc_write.c | 9 ++++- drivers/mmc/sdhci.c | 105 ++++++++++++++++++++++++++++++------------------ include/mmc.h | 9 +++++ include/sdhci.h | 2 + 6 files changed, 164 insertions(+), 52 deletions(-)
Best Regards, Jaehoon Chung
On Wed, Sep 21, 2016 at 04:29:37PM +0900, Jaehoon Chung wrote:
Dear Tom,
Jaehoon Chung
