[U-Boot] [PATCH] imx: ipu: fix occasional hang following disabling of channel
It has been observed that some IMX6SDL SoC will hang appx 0.1% of boots between disabling the ipu channel and disabling DMA preceeding an OS boot unless an extra delay is added here.
The specific cause is still under investigation.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- drivers/video/ipu_common.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/video/ipu_common.c b/drivers/video/ipu_common.c index 5873531..3c1bbbb 100644 --- a/drivers/video/ipu_common.c +++ b/drivers/video/ipu_common.c @@ -1109,6 +1109,7 @@ int32_t ipu_disable_channel(ipu_channel_t channel) if ((channel == MEM_BG_SYNC) || (channel == MEM_FG_SYNC) || (channel == MEM_DC_SYNC)) { ipu_dp_dc_disable(channel, 0); + mdelay(50); }
/* Disable DMA channel(s) */
Hi Tim,
Does your code base contain this patch[1]? It probably addressed the same issue you meet.
[1] http://lists.denx.de/pipermail/u-boot/2014-February/174533.html
Regards, Liu Ying
mdelay(50);
-- 1.9.1
On Sat, Apr 4, 2015 at 7:52 AM, Liu Ying Ying.Liu@freescale.com wrote:
Hi Tim,
Regards, Liu Ying
Liu,
It certainly does not - this issue was encountered back on 2014-04. I was hoping you might have some knowledge of this one!
I will re-test for this specific issue now that I am re-based on master.
Thanks,
Tim
Liu Ying
Tim Harvey
