[PATCH 0/3] mmc: fsl_esdhc_spl: Fix booting P2020 from SD card
This patch series contains fixes which makes SPL running on P2020 board to load proper U-Boot from SD card with non-default or non-common configuration. Tested on P2020 based board.
Pali Rohár (3): mmc: fsl_esdhc_spl: pre-PBL: check for BOOT signature instead of MBR/DBR mmc: fsl_esdhc_spl: pre-PBL: fix determining U-Boot size mmc: fsl_esdhc_spl: Call mmc_init() before booting from SD card
drivers/mmc/fsl_esdhc_spl.c | 44 +++++++++++++++++++++++++++---------- 1 file changed, 32 insertions(+), 12 deletions(-)
Pre-PBL BootROMs (MPC8536E, MPC8569E, P2020, P1011, P1012, P1013, P1020, P1021, P1022) require custom BOOT signature on sector 0 and MBR/DBR signature is not required at all.
So add check for BOOT signature and remove check for MBR/DBR.
This allows U-Boot SPL to load proper U-Boot on pre-PBL BootROMs platforms also from SD cards which do not have MBR/DBR signature on sector 0.
Signed-off-by: Pali Rohár pali@kernel.org --- drivers/mmc/fsl_esdhc_spl.c | 27 +++++++++++++++++++++++++-- 1 file changed, 25 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc_spl.c b/drivers/mmc/fsl_esdhc_spl.c index bee76572ac6c..109f558dcad3 100644 --- a/drivers/mmc/fsl_esdhc_spl.c +++ b/drivers/mmc/fsl_esdhc_spl.c @@ -14,6 +14,8 @@ * on SDCard, so we must read the MBR to get the start address and code * length of the u-boot image, then calculate the address of the env. */ +#define ESDHC_BOOT_SIGNATURE_OFF 0x40 +#define ESDHC_BOOT_SIGNATURE 0x424f4f54 #define ESDHC_BOOT_IMAGE_SIZE 0x48 #define ESDHC_BOOT_IMAGE_ADDR 0x50 #define MBRDBR_BOOT_SIG_55 0x1fe @@ -61,6 +63,9 @@ void __noreturn mmc_boot(void) uchar *tmp_buf; u32 blklen; uchar val; +#ifndef CONFIG_SPL_FSL_PBL + u32 val32; +#endif uint i, byte_num; #endif u32 offset, code_len; @@ -94,16 +99,34 @@ void __noreturn mmc_boot(void) hang(); }
+#ifdef CONFIG_SPL_FSL_PBL val = *(tmp_buf + MBRDBR_BOOT_SIG_55); if (0x55 != val) { - puts("spl: mmc signature is not valid!!\n"); + puts("spl: mmc MBR/DBR signature is not valid!!\n"); hang(); } val = *(tmp_buf + MBRDBR_BOOT_SIG_AA); if (0xAA != val) { - puts("spl: mmc signature is not valid!!\n"); + puts("spl: mmc MBR/DBR signature is not valid!!\n"); hang(); } +#else + /* + * Booting from On-Chip ROM (eSDHC or eSPI), Document Number: AN3659, Rev. 2, 06/2012. + * Pre-PBL BootROMs (MPC8536E, MPC8569E, P2020, P1011, P1012, P1013, P1020, P1021, P1022) + * require custom BOOT signature on sector 0 and MBR/DBR signature is not required at all. + */ + byte_num = 4; + val32 = 0; + for (i = 0; i < byte_num; i++) { + val = *(tmp_buf + ESDHC_BOOT_SIGNATURE_OFF + i); + val32 = (val32 << 8) + val; + } + if (val32 != ESDHC_BOOT_SIGNATURE) { + puts("spl: mmc BOOT signature is not valid!!\n"); + hang(); + } +#endif
byte_num = 4; offset = 0;
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
- on SDCard, so we must read the MBR to get the start address and code
- length of the u-boot image, then calculate the address of the env.
- u32 val32;
hang(); } val = *(tmp_buf + MBRDBR_BOOT_SIG_AA); if (0xAA != val) {puts("spl: mmc MBR/DBR signature is not valid!!\n");
hang(); }puts("spl: mmc MBR/DBR signature is not valid!!\n");
+#else
- byte_num = 4;
- val32 = 0;
- for (i = 0; i < byte_num; i++) {
- if (val32 != ESDHC_BOOT_SIGNATURE) {
hang();
In pre-PBL header is stored size of code which BootROM copies from SD card to L2/SRAM. This size has upper limit of L2 cache size. In most cases this is size of U-Boot SPL or size of L2 cache.
Therefore this size in pre-PBL header cannot be used for determining size of proper U-Boot.
So always use CONFIG_SYS_MMC_U_BOOT_SIZE for determining size of proper U-Boot which stored on SD card.
Signed-off-by: Pali Rohár pali@kernel.org --- drivers/mmc/fsl_esdhc_spl.c | 12 ++---------- 1 file changed, 2 insertions(+), 10 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc_spl.c b/drivers/mmc/fsl_esdhc_spl.c index 109f558dcad3..b87597a88e1d 100644 --- a/drivers/mmc/fsl_esdhc_spl.c +++ b/drivers/mmc/fsl_esdhc_spl.c @@ -79,7 +79,6 @@ void __noreturn mmc_boot(void)
#ifdef CONFIG_FSL_CORENET offset = CONFIG_SYS_MMC_U_BOOT_OFFS; - code_len = CONFIG_SYS_MMC_U_BOOT_SIZE; #else blklen = mmc->read_bl_len; tmp_buf = malloc(blklen); @@ -135,18 +134,11 @@ void __noreturn mmc_boot(void) offset = (offset << 8) + val; } offset += CONFIG_SYS_MMC_U_BOOT_OFFS; - /* Get the code size from offset 0x48 */ - byte_num = 4; - code_len = 0; - for (i = 0; i < byte_num; i++) { - val = *(tmp_buf + ESDHC_BOOT_IMAGE_SIZE + i); - code_len = (code_len << 8) + val; - } - code_len -= CONFIG_SYS_MMC_U_BOOT_OFFS; +#endif /* * Load U-Boot image from mmc into RAM */ -#endif + code_len = CONFIG_SYS_MMC_U_BOOT_SIZE; blk_start = ALIGN(offset, mmc->read_bl_len) / mmc->read_bl_len; blk_cnt = ALIGN(code_len, mmc->read_bl_len) / mmc->read_bl_len; err = mmc->block_dev.block_read(&mmc->block_dev, blk_start, blk_cnt,
- byte_num = 4;
- code_len = 0;
+#endif /*
- Load U-Boot image from mmc into RAM
*/ -#endif
- code_len = CONFIG_SYS_MMC_U_BOOT_SIZE; blk_start = ALIGN(offset, mmc->read_bl_len) / mmc->read_bl_len; blk_cnt = ALIGN(code_len, mmc->read_bl_len) / mmc->read_bl_len; err = mmc->block_dev.block_read(&mmc->block_dev, blk_start, blk_cnt,
If env is stored on SD card then U-Boot SPL automatically calls mmc_init() before it is going to load proper U-Boot from SD card.
If env is not stored on SD card then U-Boot SPL fails to read proper U-Boot from SD card due to missing mmc_init() call.
So add missing mmc_init() call into fsl_esdhc_spl's mmc_boot() function. It fixes booting from SD card on P2020 boards without env support in SPL.
mmc_init() returns early if card was already initialized, so there is no issue with calling this function more times.
Signed-off-by: Pali Rohár pali@kernel.org --- drivers/mmc/fsl_esdhc_spl.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/drivers/mmc/fsl_esdhc_spl.c b/drivers/mmc/fsl_esdhc_spl.c index b87597a88e1d..0146a231b221 100644 --- a/drivers/mmc/fsl_esdhc_spl.c +++ b/drivers/mmc/fsl_esdhc_spl.c @@ -77,6 +77,11 @@ void __noreturn mmc_boot(void) hang(); }
+ if (mmc_init(mmc)) { + puts("spl: mmc device init failed!\n"); + hang(); + } + #ifdef CONFIG_FSL_CORENET offset = CONFIG_SYS_MMC_U_BOOT_OFFS; #else
- if (mmc_init(mmc)) {
hang();
Jaehoon Chung
Pali Rohár
