[U-Boot] [PATCH v4] x86: ich-spi: Convert driver to spi-mem ops
With the introduction of the new spi-mem model operations changed slightly. The new spi-mem operations make things a bit easier to handle for ich-spi flash interface. This patch converts the ich-spi driver by using spi-mem operations.
Signed-off-by: Bernhard Messerklinger bernhard.messerklinger@br-automation.com ---
Changes in v4: - fix changelog; fix local variable types and order Changes in v3: - update erase op code handling to work with latest master spi-nor driver Changes in v2: - make 2 routines static; update commit message a little bit
drivers/spi/ich.c | 258 +++++++++++++++++----------------------------- drivers/spi/ich.h | 9 +- 2 files changed, 95 insertions(+), 172 deletions(-)
diff --git a/drivers/spi/ich.c b/drivers/spi/ich.c index 03531a8c0c..60589dfb61 100644 --- a/drivers/spi/ich.c +++ b/drivers/spi/ich.c @@ -14,6 +14,8 @@ #include <pci_ids.h> #include <spi.h> #include <asm/io.h> +#include <spi-mem.h> +#include <div64.h>
#include "ich.h"
@@ -171,18 +173,6 @@ static int ich_init_controller(struct udevice *dev, return 0; }
-static inline void spi_use_out(struct spi_trans *trans, unsigned bytes) -{ - trans->out += bytes; - trans->bytesout -= bytes; -} - -static inline void spi_use_in(struct spi_trans *trans, unsigned bytes) -{ - trans->in += bytes; - trans->bytesin -= bytes; -} - static void spi_lock_down(struct ich_spi_platdata *plat, void *sbase) { if (plat->ich_version == ICHV_7) { @@ -213,47 +203,12 @@ static bool spi_lock_status(struct ich_spi_platdata *plat, void *sbase) return lock != 0; }
-static void spi_setup_type(struct spi_trans *trans, int data_bytes) -{ - trans->type = 0xFF; - - /* Try to guess spi type from read/write sizes */ - if (trans->bytesin == 0) { - if (trans->bytesout + data_bytes > 4) - /* - * If bytesin = 0 and bytesout > 4, we presume this is - * a write data operation, which is accompanied by an - * address. - */ - trans->type = SPI_OPCODE_TYPE_WRITE_WITH_ADDRESS; - else - trans->type = SPI_OPCODE_TYPE_WRITE_NO_ADDRESS; - return; - } - - if (trans->bytesout == 1) { /* and bytesin is > 0 */ - trans->type = SPI_OPCODE_TYPE_READ_NO_ADDRESS; - return; - } - - if (trans->bytesout == 4) /* and bytesin is > 0 */ - trans->type = SPI_OPCODE_TYPE_READ_WITH_ADDRESS; - - /* Fast read command is called with 5 bytes instead of 4 */ - if (trans->out[0] == SPI_OPCODE_FAST_READ && trans->bytesout == 5) { - trans->type = SPI_OPCODE_TYPE_READ_WITH_ADDRESS; - --trans->bytesout; - } -} - static int spi_setup_opcode(struct ich_spi_priv *ctlr, struct spi_trans *trans, bool lock) { uint16_t optypes; uint8_t opmenu[ctlr->menubytes];
- trans->opcode = trans->out[0]; - spi_use_out(trans, 1); if (!lock) { /* The lock is off, so just use index 0. */ ich_writeb(ctlr, trans->opcode, ctlr->opmenu); @@ -285,12 +240,7 @@ static int spi_setup_opcode(struct ich_spi_priv *ctlr, struct spi_trans *trans,
optypes = ich_readw(ctlr, ctlr->optype); optype = (optypes >> (opcode_index * 2)) & 0x3; - if (trans->type == SPI_OPCODE_TYPE_WRITE_NO_ADDRESS && - optype == SPI_OPCODE_TYPE_WRITE_WITH_ADDRESS && - trans->bytesout >= 3) { - /* We guessed wrong earlier. Fix it up. */ - trans->type = optype; - } + if (optype != trans->type) { printf("ICH SPI: Transaction doesn't fit type %d\n", optype); @@ -300,26 +250,6 @@ static int spi_setup_opcode(struct ich_spi_priv *ctlr, struct spi_trans *trans, } }
-static int spi_setup_offset(struct spi_trans *trans) -{ - /* Separate the SPI address and data */ - switch (trans->type) { - case SPI_OPCODE_TYPE_READ_NO_ADDRESS: - case SPI_OPCODE_TYPE_WRITE_NO_ADDRESS: - return 0; - case SPI_OPCODE_TYPE_READ_WITH_ADDRESS: - case SPI_OPCODE_TYPE_WRITE_WITH_ADDRESS: - trans->offset = ((uint32_t)trans->out[0] << 16) | - ((uint32_t)trans->out[1] << 8) | - ((uint32_t)trans->out[2] << 0); - spi_use_out(trans, 3); - return 1; - default: - printf("Unrecognized SPI transaction type %#x\n", trans->type); - return -EPROTO; - } -} - /* * Wait for up to 6s til status register bit(s) turn 1 (in case wait_til_set * below is true) or 0. In case the wait was for the bit(s) to set - write @@ -350,7 +280,7 @@ static int ich_status_poll(struct ich_spi_priv *ctlr, u16 bitmask, return -ETIMEDOUT; }
-void ich_spi_config_opcode(struct udevice *dev) +static void ich_spi_config_opcode(struct udevice *dev) { struct ich_spi_priv *ctlr = dev_get_priv(dev);
@@ -365,72 +295,48 @@ void ich_spi_config_opcode(struct udevice *dev) ich_writel(ctlr, SPI_OPMENU_UPPER, ctlr->opmenu + sizeof(u32)); }
-static int ich_spi_xfer(struct udevice *dev, unsigned int bitlen, - const void *dout, void *din, unsigned long flags) +static int ich_spi_exec_op(struct spi_slave *slave, const struct spi_mem_op *op) { - struct udevice *bus = dev_get_parent(dev); + struct udevice *bus = dev_get_parent(slave->dev); struct ich_spi_platdata *plat = dev_get_platdata(bus); struct ich_spi_priv *ctlr = dev_get_priv(bus); uint16_t control; int16_t opcode_index; int with_address; int status; - int bytes = bitlen / 8; struct spi_trans *trans = &ctlr->trans; - unsigned type = flags & (SPI_XFER_BEGIN | SPI_XFER_END); - int using_cmd = 0; bool lock = spi_lock_status(plat, ctlr->base); - int ret; - - /* We don't support writing partial bytes */ - if (bitlen % 8) { - debug("ICH SPI: Accessing partial bytes not supported\n"); - return -EPROTONOSUPPORT; - } + int ret = 0;
- /* An empty end transaction can be ignored */ - if (type == SPI_XFER_END && !dout && !din) - return 0; - - if (type & SPI_XFER_BEGIN) - memset(trans, '\0', sizeof(*trans)); + trans->in = NULL; + trans->out = NULL; + trans->type = 0xFF;
- /* Dp we need to come back later to finish it? */ - if (dout && type == SPI_XFER_BEGIN) { - if (bytes > ICH_MAX_CMD_LEN) { - debug("ICH SPI: Command length limit exceeded\n"); - return -ENOSPC; + if (op->data.nbytes) { + if (op->data.dir == SPI_MEM_DATA_IN) { + trans->in = op->data.buf.in; + trans->bytesin = op->data.nbytes; + } else { + trans->out = op->data.buf.out; + trans->bytesout = op->data.nbytes; } - memcpy(trans->cmd, dout, bytes); - trans->cmd_len = bytes; - debug_trace("ICH SPI: Saved %d bytes\n", bytes); - return 0; }
- /* - * We process a 'middle' spi_xfer() call, which has no - * SPI_XFER_BEGIN/END, as an independent transaction as if it had - * an end. We therefore repeat the command. This is because ICH - * seems to have no support for this, or because interest (in digging - * out the details and creating a special case in the code) is low. - */ - if (trans->cmd_len) { - trans->out = trans->cmd; - trans->bytesout = trans->cmd_len; - using_cmd = 1; - debug_trace("ICH SPI: Using %d bytes\n", trans->cmd_len); - } else { - trans->out = dout; - trans->bytesout = dout ? bytes : 0; - } + if (trans->opcode != op->cmd.opcode) + trans->opcode = op->cmd.opcode;
- trans->in = din; - trans->bytesin = din ? bytes : 0; + if (lock && trans->opcode == SPI_OPCODE_WRDIS) + return 0;
- /* There has to always at least be an opcode */ - if (!trans->bytesout) { - debug("ICH SPI: No opcode for transfer\n"); - return -EPROTO; + if (trans->opcode == SPI_OPCODE_WREN) { + /* + * Treat Write Enable as Atomic Pre-Op if possible + * in order to prevent the Management Engine from + * issuing a transaction between WREN and DATA. + */ + if (!lock) + ich_writew(ctlr, trans->opcode, ctlr->preop); + return 0; }
ret = ich_status_poll(ctlr, SPIS_SCIP, 0); @@ -442,23 +348,29 @@ static int ich_spi_xfer(struct udevice *dev, unsigned int bitlen, else ich_writeb(ctlr, SPIS_CDS | SPIS_FCERR, ctlr->status);
- spi_setup_type(trans, using_cmd ? bytes : 0); + /* Try to guess spi transaction type */ + if (op->data.dir == SPI_MEM_DATA_OUT) { + if (op->addr.nbytes) + trans->type = SPI_OPCODE_TYPE_WRITE_WITH_ADDRESS; + else + trans->type = SPI_OPCODE_TYPE_WRITE_NO_ADDRESS; + } else { + if (op->addr.nbytes) + trans->type = SPI_OPCODE_TYPE_READ_WITH_ADDRESS; + else + trans->type = SPI_OPCODE_TYPE_READ_NO_ADDRESS; + } + /* Special erase case handling */ + if (op->addr.nbytes && !op->data.buswidth) + trans->type = SPI_OPCODE_TYPE_WRITE_WITH_ADDRESS; + opcode_index = spi_setup_opcode(ctlr, trans, lock); if (opcode_index < 0) return -EINVAL; - with_address = spi_setup_offset(trans); - if (with_address < 0) - return -EINVAL;
- if (trans->opcode == SPI_OPCODE_WREN) { - /* - * Treat Write Enable as Atomic Pre-Op if possible - * in order to prevent the Management Engine from - * issuing a transaction between WREN and DATA. - */ - if (!lock) - ich_writew(ctlr, trans->opcode, ctlr->preop); - return 0; + if (op->addr.nbytes) { + trans->offset = op->addr.val; + with_address = 1; }
if (ctlr->speed && ctlr->max_speed >= 33000000) { @@ -472,13 +384,6 @@ static int ich_spi_xfer(struct udevice *dev, unsigned int bitlen, ich_writeb(ctlr, byte, ctlr->speed); }
- /* See if we have used up the command data */ - if (using_cmd && dout && bytes) { - trans->out = dout; - trans->bytesout = bytes; - debug_trace("ICH SPI: Moving to data, %d bytes\n", bytes); - } - /* Preset control fields */ control = SPIC_SCGO | ((opcode_index & 0x07) << 4);
@@ -513,22 +418,6 @@ static int ich_spi_xfer(struct udevice *dev, unsigned int bitlen, return 0; }
- /* - * Check if this is a write command atempting to transfer more bytes - * than the controller can handle. Iterations for writes are not - * supported here because each SPI write command needs to be preceded - * and followed by other SPI commands, and this sequence is controlled - * by the SPI chip driver. - */ - if (trans->bytesout > ctlr->databytes) { - debug("ICH SPI: Too much to write. This should be prevented by the driver's max_write_size?\n"); - return -EPROTO; - } - - /* - * Read or write up to databytes bytes at a time until everything has - * been sent. - */ while (trans->bytesout || trans->bytesin) { uint32_t data_length;
@@ -543,9 +432,7 @@ static int ich_spi_xfer(struct udevice *dev, unsigned int bitlen, /* Program data into FDATA0 to N */ if (trans->bytesout) { write_reg(ctlr, trans->out, ctlr->data, data_length); - spi_use_out(trans, data_length); - if (with_address) - trans->offset += data_length; + trans->bytesout -= data_length; }
/* Add proper control fields' values */ @@ -568,9 +455,7 @@ static int ich_spi_xfer(struct udevice *dev, unsigned int bitlen,
if (trans->bytesin) { read_reg(ctlr, ctlr->data, trans->in, data_length); - spi_use_in(trans, data_length); - if (with_address) - trans->offset += data_length; + trans->bytesin -= data_length; } }
@@ -581,6 +466,40 @@ static int ich_spi_xfer(struct udevice *dev, unsigned int bitlen, return 0; }
+static int ich_spi_adjust_size(struct spi_slave *slave, struct spi_mem_op *op) +{ + size_t page_offset; + int addr = op->addr.val; + unsigned int byte_count = op->data.nbytes; + + if (hweight32(ICH_BOUNDARY) == 1) { + page_offset = addr & (ICH_BOUNDARY - 1); + } else { + u64 aux = addr; + + page_offset = do_div(aux, ICH_BOUNDARY); + } + + if (op->data.dir == SPI_MEM_DATA_IN && slave->max_read_size) { + op->data.nbytes = min(ICH_BOUNDARY - page_offset, + slave->max_read_size); + } else if (slave->max_write_size) { + op->data.nbytes = min(ICH_BOUNDARY - page_offset, + slave->max_write_size); + } + + op->data.nbytes = min(op->data.nbytes, byte_count); + + return 0; +} + +static int ich_spi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + printf("ICH SPI: Only supports memory operations\n"); + return -1; +} + static int ich_spi_probe(struct udevice *dev) { struct ich_spi_platdata *plat = dev_get_platdata(dev); @@ -686,10 +605,17 @@ static int ich_spi_ofdata_to_platdata(struct udevice *dev) return ret; }
+static const struct spi_controller_mem_ops ich_controller_mem_ops = { + .adjust_op_size = ich_spi_adjust_size, + .supports_op = NULL, + .exec_op = ich_spi_exec_op, +}; + static const struct dm_spi_ops ich_spi_ops = { .xfer = ich_spi_xfer, .set_speed = ich_spi_set_speed, .set_mode = ich_spi_set_mode, + .mem_ops = &ich_controller_mem_ops, /* * cs_info is not needed, since we require all chip selects to be * in the device tree explicitly diff --git a/drivers/spi/ich.h b/drivers/spi/ich.h index a974241f98..3dfb2aaff1 100644 --- a/drivers/spi/ich.h +++ b/drivers/spi/ich.h @@ -100,13 +100,8 @@ enum { HSFC_FSMIE = 0x8000 };
-enum { - ICH_MAX_CMD_LEN = 5, -}; - struct spi_trans { - uint8_t cmd[ICH_MAX_CMD_LEN]; - int cmd_len; + uint8_t cmd; const uint8_t *out; uint32_t bytesout; uint8_t *in; @@ -166,6 +161,8 @@ struct spi_trans { #define SPI_OPMENU_LOWER ((SPI_OPMENU_3 << 24) | (SPI_OPMENU_2 << 16) | \ (SPI_OPMENU_1 << 8) | (SPI_OPMENU_0 << 0))
+#define ICH_BOUNDARY 0x1000 + enum ich_version { ICHV_7, ICHV_9,
On Fri, Aug 2, 2019 at 2:38 PM Bernhard Messerklinger bernhard.messerklinger@br-automation.com wrote:
Changes in v4:
Changes in v3:
Tested on Intel CrownBay and MinnowMax Tested-by: Bin Meng bmeng.cn@gmail.com
Changes in v4:
Changes in v3:
applied to u-boot-x86, thanks!
Bin Meng
