[U-Boot] Pull request, u-boot-tegra/master
Tom,
Please pull u-boot-tegra/master into U-Boot/master. Thanks!
All Tegra builds are OK, and Stephen's automated test system reports that all tests pass.
The following changes since commit cb1cbdd96962931de2ac948a184874e2672f3f96:
x86: qemu: efi: Add two boards for EFI 32-bit and 64-bit payload (2016-08-30 09:26:05 +0800)
git://git.denx.de/u-boot-tegra.git master
for you to fetch changes up to b615267633996a9410a88b54a55965d8b021f6f8:
ARM: tegra: Add support for TK1-SOM board from Colorado Engineering (2016-09-01 09:24:30 -0700)
---------------------------------------------------------------- Peter Chubb (1): ARM: tegra: Add support for TK1-SOM board from Colorado Engineering
Stephen Warren (1): ARM: tegra: use numeric versioning for p2771-0000
arch/arm/dts/Makefile | 5 +- arch/arm/dts/tegra124-cei-tk1-som.dts | 477 +++++++++++++++++++++ ...71-0000-a02.dts => tegra186-p2771-0000-000.dts} | 4 +- ...71-0000-b00.dts => tegra186-p2771-0000-500.dts} | 4 +- arch/arm/mach-tegra/tegra124/Kconfig | 12 + board/cei/cei-tk1-som/Kconfig | 12 + board/cei/cei-tk1-som/MAINTAINERS | 6 + board/cei/cei-tk1-som/Makefile | 9 + board/cei/cei-tk1-som/cei-tk1-som.c | 65 +++ board/cei/cei-tk1-som/pinmux-config-cei-tk1-som.h | 301 +++++++++++++ board/nvidia/venice2/as3722_init.h | 8 +- configs/cei-tk1-som_defconfig | 47 ++ ...0000-a02_defconfig => p2771-0000-000_defconfig} | 4 +- ...0000-b00_defconfig => p2771-0000-500_defconfig} | 4 +- include/configs/cei-tk1-som.h | 73 ++++ 15 files changed, 1017 insertions(+), 14 deletions(-) create mode 100644 arch/arm/dts/tegra124-cei-tk1-som.dts rename arch/arm/dts/{tegra186-p2771-0000-a02.dts => tegra186-p2771-0000-000.dts} (82%) rename arch/arm/dts/{tegra186-p2771-0000-b00.dts => tegra186-p2771-0000-500.dts} (83%) create mode 100644 board/cei/cei-tk1-som/Kconfig create mode 100644 board/cei/cei-tk1-som/MAINTAINERS create mode 100644 board/cei/cei-tk1-som/Makefile create mode 100644 board/cei/cei-tk1-som/cei-tk1-som.c create mode 100644 board/cei/cei-tk1-som/pinmux-config-cei-tk1-som.h create mode 100644 configs/cei-tk1-som_defconfig rename configs/{p2771-0000-a02_defconfig => p2771-0000-000_defconfig} (87%) rename configs/{p2771-0000-b00_defconfig => p2771-0000-500_defconfig} (87%) create mode 100644 include/configs/cei-tk1-som.h
On Thu, Sep 01, 2016 at 10:32:11AM -0700, Tom Warren wrote:
Tom,
Tom Warren
