[U-Boot] Wrong clocks computed when PCI_HOST disabled on MPC8313
12 Mar
2015
12 Mar
'15
6:31 p.m.
Hello,
I'm doing some work on the MPC8313, while not using the PCI bus. In order to compute the correct clocks I must set HRCWH_PCI_HOST in my configuration in order to compute the correct clock values (U-Boot clocks command, and startup message). I can live with PCI_HOST, so I will leave this on, but it might be nice to fix it in case someone wants to use this processor as PCI Agent...
Tjeerd Pinkert
3716
ir. Tjeerd Pinkert
