[U-Boot] Please pull u-boot-fsl-qoriq master
Tom,
The following changes since commit a43d46a73cb2c40481791cb292b8eb0b5a80d55e:
arm: v7R: Add support for enabling caches (2018-05-07 15:53:29 -0400)
git://git.denx.de/u-boot-fsl-qoriq.git
for you to fetch changes up to a6f2a6eafe0e5ad71c41341219ae3b187c1f738a:
driver: net: fsl-mc: updated copyright info (2018-05-09 09:17:51 -0500)
---------------------------------------------------------------- Ashish Kumar (3): armv8: ls1088a: Move CONFIG_BOOTARGS and CONFIG_CMD_GREPENV to defconfig armv8: ls1088aqds: Enable mdio commands on u-boot prompt armv8: ls1088: Update 1900MT/s DDR timing to bring consistency
Hou Zhiqiang (2): armv8/fsl-lsch2: correct QMAN clock armv8/fsl-lsch2: make the workaround for PIN MUX erratum A010539 robust
Jagdish Gediya (2): mtd: nand: fsl_ifc: Fix eccstat array overflow for IFC ver >= 2.0.0 mtd: nand: fsl_ifc: Fix nand waitfunc return value
Rajat Srivastava (1): spi: fsl_qspi: Introduce is_controller_busy function
Ruchika Gupta (1): armv8: sec_firmware: Remove JR3 from device tree node in all cases
Sriram Dash (1): armv8: layerscape: Avoid code duplication for TZASC Instantiation
Sumit Garg (1): armv8: sec_firmware: Add support for multiple loadables
Takuma Ueba (1): powerpc: mpc85xx: Improve Work-around for Erratum A005125
Yogesh Gaur (1): driver: net: fsl-mc: updated copyright info
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 8 +++ arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 4 +- .../arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c | 4 +- arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 62 ++++++++++++---------- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 1 + arch/arm/cpu/armv8/sec_firmware.c | 59 +++++++++++++++----- arch/powerpc/cpu/mpc85xx/release.S | 7 +++ board/freescale/ls1088a/ddr.h | 4 +- board/freescale/ls1088a/eth_ls1088aqds.c | 2 + configs/ls1088aqds_defconfig | 3 ++ configs/ls1088aqds_qspi_SECURE_BOOT_defconfig | 3 ++ configs/ls1088aqds_qspi_defconfig | 3 ++ configs/ls1088aqds_sdcard_ifc_defconfig | 3 ++ configs/ls1088aqds_sdcard_qspi_defconfig | 3 ++ configs/ls1088ardb_qspi_SECURE_BOOT_defconfig | 3 ++ configs/ls1088ardb_qspi_defconfig | 3 ++ .../ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig | 3 ++ configs/ls1088ardb_sdcard_qspi_defconfig | 3 ++ doc/uImage.FIT/sec_firmware_ppa.its | 49 +++++++++++++++++ drivers/mtd/nand/fsl_ifc_nand.c | 37 ++++++------- drivers/net/fsl-mc/dpbp.c | 2 +- drivers/net/fsl-mc/dpio/dpio.c | 2 +- drivers/net/fsl-mc/dpmac.c | 2 +- drivers/net/fsl-mc/dpni.c | 2 +- drivers/net/fsl-mc/dprc.c | 2 +- drivers/net/fsl-mc/fsl_dpmng_cmd.h | 2 +- drivers/net/fsl-mc/mc.c | 4 +- drivers/net/ldpaa_eth/ldpaa_eth.c | 2 +- drivers/net/ldpaa_eth/ldpaa_eth.h | 2 +- drivers/spi/fsl_qspi.c | 31 +++++++---- include/configs/ls1088a_common.h | 5 -- include/fsl-mc/fsl_dpbp.h | 2 +- include/fsl-mc/fsl_dpio.h | 2 +- include/fsl-mc/fsl_dpmac.h | 2 +- include/fsl-mc/fsl_dpni.h | 2 +- include/fsl-mc/fsl_dprc.h | 2 +- include/fsl-mc/fsl_mc_cmd.h | 2 +- include/fsl-mc/fsl_mc_private.h | 2 +- include/fsl_ifc.h | 4 +- 39 files changed, 235 insertions(+), 103 deletions(-) create mode 100644 doc/uImage.FIT/sec_firmware_ppa.its
Thanks.
York
On Fri, May 11, 2018 at 04:20:11AM +0000, York Sun wrote:
Tom,
York Sun
