[PATCH] ARM: stm32: Inhibit PDDS because CSTBYDIS is set
The PWR_MPUCR CSTBYDIS bit is set, therefore the CA cores can never enter CStandby state and would always end up in CStop state. Clear the PDDS bit, which indicates the CA cores can enter CStandby state as it makes little sense to keep it set with CSTBYDIS also set.
This does however fix a problem too. When both PWR_MPUCR and PWR_MCUCR PDDS bits are set, then the chip enters CStandby state even though the PWR_MCUCR CSTBYDIS is set. Clearing the PWR_MPUCR PDDS prevents that from happening.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com Cc: uboot-stm32@st-md-mailman.stormreply.com --- arch/arm/mach-stm32mp/psci.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-stm32mp/psci.c b/arch/arm/mach-stm32mp/psci.c index 50e3fc4ae45..79734b5289b 100644 --- a/arch/arm/mach-stm32mp/psci.c +++ b/arch/arm/mach-stm32mp/psci.c @@ -754,7 +754,7 @@ void __secure psci_system_suspend(u32 __always_unused function_id, setbits_le32(STM32_RCC_BASE + RCC_MP_CIER, RCC_MP_CIFR_WKUPF);
setbits_le32(STM32_PWR_BASE + PWR_MPUCR, - PWR_MPUCR_CSSF | PWR_MPUCR_CSTDBYDIS | PWR_MPUCR_PDDS); + PWR_MPUCR_CSSF | PWR_MPUCR_CSTDBYDIS);
saved_mcudivr = readl(STM32_RCC_BASE + RCC_MCUDIVR); saved_pll3cr = readl(STM32_RCC_BASE + RCC_PLL3CR);
Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com
Thanks Patrick
Applied on stm32-master
Thanks Patrice
Patrice CHOTARD
Patrick DELAUNAY
