[U-Boot] [PATCH] Handle environment variables like commands
The command interpreter checks always if an environment variable for that name exists and in this case the content of the variable is executed. It becomes possible to redefine all U-Boot commands. A new "builtin" command is added to be able to run builtin U-boot commands even if they are redefined.
Signed-off-by : Stefano Babic sbabic@denx.de --- common/hush.c | 9 ++++++++- common/main.c | 37 +++++++++++++++++++++++++++++++++++++ 2 files changed, 45 insertions(+), 1 deletions(-)
diff --git a/common/hush.c b/common/hush.c index 093c428..68f8a6a 100644 --- a/common/hush.c +++ b/common/hush.c @@ -1677,9 +1677,16 @@ static int run_pipe_real(struct pipe *pi) child->argv[i]); return -1; } - /* Look up command in command table */
+ /* Check if exists a variable with that name */ + if ((p = getenv (child->argv[i])) != NULL ) { + int rcode; + rcode = (parse_string_outer(p, + FLAG_PARSE_SEMICOLON | FLAG_EXIT_FROM_LOOP) != 0); + return rcode; + }
+ /* Look up command in command table */ if ((cmdtp = find_cmd(child->argv[i])) == NULL) { printf ("Unknown command '%s' - try 'help'\n", child->argv[i]); return -1; /* give up after bad command */ diff --git a/common/main.c b/common/main.c index c06ea07..b101b4f 100644 --- a/common/main.c +++ b/common/main.c @@ -1289,6 +1289,7 @@ int run_command (const char *cmd, int flag) int argc, inquotes; int repeatable = 1; int rc = 0; + char *runenv;
#ifdef DEBUG_PARSER printf ("[RUN_COMMAND] cmd[%p]="", cmd); @@ -1357,6 +1358,13 @@ int run_command (const char *cmd, int flag) continue; }
+ if ((runenv = getenv (argv[0])) != NULL ) { + if (run_command(runenv,flag) == -1) { + rc = -1; + } + continue; + } + /* Look up command in command table */ if ((cmdtp = find_cmd(argv[0])) == NULL) { printf ("Unknown command '%s' - try 'help'\n", argv[0]); @@ -1433,3 +1441,32 @@ int do_run (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) return 0; } #endif + +int do_builtin (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) +{ + int i; + + if (argc < 2) { + printf ("Usage:\n%s\n", cmdtp->usage); + return 1; + } + + /* Look up command in command table */ + if ((cmdtp = find_cmd(argv[1])) == NULL) { + printf ("Unknown builtin command '%s' - try 'help'\n", argv[1]); + return 1; + } + + /* Remove builtin from arg list */ + argc--; + + /* OK - call function to do the command */ + if ((cmdtp->cmd) (cmdtp, flag, argc, &argv[1]) != 0) { + return 1; + } +} + +U_BOOT_CMD( + builtin, CFG_MAXARGS, 1, do_builtin, + "builtin - run builtin commands\n", +);
It seems to me that the "builtin" command itself can still be redefined. Is this an issue?
Dear Petri Lehtinen,
Good catch. Yes, this must be prevented. Any variable named "builtin" must be ignored here - i. e. we should issue an erro when someone tries a "setenv", and ignore this variable explicitly (just in case someone sneaks this into the default environment, or uses un-fixed Linux tools to create such a variable).
Thanks.
I know, I wanted to know which is the preferred method to avoid that. One way is to avoid to set the variable, as you suggest. The other way is never execute a variable with the name "builtin" in the command interpreter: "setenv builtin <something>" remains possible but "builtin <command>" calls always the U-Boot commands.
Best regards, Stefano Babic
Dear Stefano,
We should do both: avoid that the variable gets set, and raise error messages (both in setenv() and in the fw_setenv Linux tool), but we should also be defensive and never execute it if we run into it (which could for example happen if we're being poresented an old environment where some user defined such a variable).
Dear Stefano,
Cool. That's just great.
If I had known it's suffcient to put ideas on a web page to have people put them into code I would have started doing this much earlier :-)
int rcode;
return rcode;
I think this covers only the hush shell version. We need something like this instead:
#ifdef CFG_HUSH_PARSER rcode = parse_string_outer(p, FLAG_PARSE_SEMICOLON | FLAG_EXIT_FROM_LOOP); #else rcode =run_command (p, 0); #endif
That's a good idea ;).
This is not true, I think. The change you are talking about is in hush.c (so it must cover *only* the hush shell). The other change is in the run_command() function and it is called when CFG_HUSH_PARSER is not defined. So both cases are covered.
Dear Stefano,
You are right, of course. I read only part of the patch, it seems. Sorry ...
On Wed, 2008-10-15 at 12:57 +0200, Wolfgang Denk wrote:
Dear Stefano,
int rcode;
return rcode;
Move the parse_string_outer() into run_command() instead.
Jocke
participants (6)
Joakim Tjernlund
Petri Lehtinen
Stefano Babic
stefano babic
stefano babic
