[U-Boot] [PATCH v2] tools/setlocalversion: Update from the Linux Kernel
Several bugfixes have occurred upstream since this script was imported into U-Boot. In particular, the script currently in U-Boot does not describe commit f8bbb4dad0e9d91b7a51d6cc54dcf66d142f50fe correctly, resulting in a version of "2011.09" instead of "2011.09-01460-gf8bbb4d".
With that commit checked out, the command "git name-rev --tags HEAD" gives this result: HEAD tags/v2011.12-rc1~30^2
Then the "changes" regex does not match because of the trailing '^2': grep -E '^HEAD[[:space:]]+(.*~[0-9]*|undefined)$'
The new version of tools/setlocalversion in the kernel correctly handles those situations by using different plumbing commands.
The version from the kernel is not directly usable as it has code for supporting CONFIG_LOCALVERSION from Kconfig, but the version that was imported is very similar to the one in Linux v3.2-rc4.
Signed-off-by: Kyle Moffett Kyle.D.Moffett@boeing.com Cc: Wolfgang Denk wd@denx.de --- tools/setlocalversion | 138 ++++++++++++++++++++++++++++++++++++++++--------- 1 files changed, 113 insertions(+), 25 deletions(-)
diff --git a/tools/setlocalversion b/tools/setlocalversion index e11f54f..70ab70d 100755 --- a/tools/setlocalversion +++ b/tools/setlocalversion @@ -1,40 +1,128 @@ #!/bin/sh -# Print additional version information for non-release trees. +# +# This scripts adds local version information from the version +# control systems git, mercurial (hg) and subversion (svn). +# +# It was originally copied from the Linux kernel v3.2.0-rc4 and modified +# to support the U-Boot build-system. +#
usage() { - echo "Usage: $0 [srctree]" >&2 + echo "Usage: $0 [--save-scmversion] [srctree]" >&2 exit 1 }
-cd "${1:-.}" || usage +scm_only=false +srctree=. +if test "$1" = "--save-scmversion"; then + scm_only=true + shift +fi +if test $# -gt 0; then + srctree=$1 + shift +fi +if test $# -gt 0 -o ! -d "$srctree"; then + usage +fi + +scm_version() +{ + local short + short=false + + cd "$srctree" + if test -e .scmversion; then + cat .scmversion + return + fi + if test "$1" = "--short"; then + short=true + fi + + # Check for git and a git repo. + if test -e .git && head=`git rev-parse --verify --short HEAD 2>/dev/null`; then + + # If we are at a tagged commit (like "v2.6.30-rc6"), we ignore + # it, because this version is defined in the top level Makefile. + if [ -z "`git describe --exact-match 2>/dev/null`" ]; then + + # If only the short version is requested, don't bother + # running further git commands + if $short; then + echo "+" + return + fi + # If we are past a tagged commit (like + # "v2.6.30-rc5-302-g72357d5"), we pretty print it. + if atag="`git describe 2>/dev/null`"; then + echo "$atag" | awk -F- '{printf("-%05d-%s", $(NF-1),$(NF))}'
-# Check for git and a git repo. -if head=`git rev-parse --verify HEAD 2>/dev/null`; then - # Do we have an untagged version? - if git name-rev --tags HEAD | \ - grep -E '^HEAD[[:space:]]+(.*~[0-9]*|undefined)$' > /dev/null; then - (git describe || git describe --tags || git describe --all --long) \ - 2>/dev/null | awk -F- '{printf("-%05d-%s", $(NF-1),$(NF))}' + # If we don't have a tag at all we print -g{commitish}. + else + printf '%s%s' -g $head + fi + fi + + # Is this git on svn? + if git config --get svn-remote.svn.url >/dev/null; then + printf -- '-svn%s' "`git svn find-rev $head`" + fi + + # Update index only on r/w media + [ -w . ] && git update-index --refresh --unmerged > /dev/null + + # Check for uncommitted changes + if git diff-index --name-only HEAD | grep -v "^scripts/package" \ + | read dummy; then + printf '%s' -dirty + fi + + # All done with git + return fi
- # Are there uncommitted changes? - git update-index --refresh --unmerged > /dev/null - if git diff-index --name-only HEAD | grep -v "^scripts/package" \ - | read dummy; then - printf '%s' -dirty + # Check for mercurial and a mercurial repo. + if test -d .hg && hgid=`hg id 2>/dev/null`; then + # Do we have an tagged version? If so, latesttagdistance == 1 + if [ "`hg log -r . --template '{latesttagdistance}'`" == "1" ]; then + id=`hg log -r . --template '{latesttag}'` + printf '%s%s' -hg "$id" + else + tag=`printf '%s' "$hgid" | cut -d' ' -f2` + if [ -z "$tag" -o "$tag" = tip ]; then + id=`printf '%s' "$hgid" | sed 's/[+ ].*//'` + printf '%s%s' -hg "$id" + fi + fi + + # Are there uncommitted changes? + # These are represented by + after the changeset id. + case "$hgid" in + *+|*+\ *) printf '%s' -dirty ;; + esac + + # All done with mercurial + return fi
- # Is this git on svn? - if git config --get svn-remote.svn.url >/dev/null; then - printf -- '-svn%s' "`git svn find-rev $head`" + # Check for svn and a svn repo. + if rev=`svn info 2>/dev/null | grep '^Last Changed Rev'`; then + rev=`echo $rev | awk '{print $NF}'` + printf -- '-svn%s' "$rev" + + # All done with svn + return fi -fi +}
-# Check for svn and a svn repo. -if rev=`svn info 2>/dev/null` ; then - rev=`echo "${rev}" | grep '^Revision' | awk '{print $NF}'` - printf -- '-svn%s' $rev +if $scm_only; then + if test ! -e .scmversion; then + res=$(scm_version) + echo "$res" >.scmversion + fi + exit fi
-# Check for any localversion-* files -printf '%s' "`cat localversion-* 2>/dev/null`" +scm_version +exit 0
NAK: this breaks localversion-* support
ignoring that, i'm not sure you really need to delete the CONFIG_xxx handling. under u-boot, they'd expand to like "" which would end at the same code. by keeping as much code as possible in common, it should make future updates easier.
the only place i see where you need to deviate from the kernel code is: if test -e include/config/auto.conf; then . include/config/auto.conf else echo "Error: kernelrelease not valid - run 'make prepare' to update it" exit 1 fi
so that part i would write as: # Disabled for u-boot #if test -e include/config/auto.conf; then # . include/config/auto.conf #else # echo "Error: kernelrelease not valid - run 'make prepare' to update it" # exit 1 #fi -mike
Ah, I missed that somehow. I'd read through the U-Boot version and did not remember seeing that part so I assumed it wasn't necessary.
Ok, I will respin, retest, and resubmit as you suggest.
Cheers, Kyle Moffett
-- Curious about my work on the Debian powerpcspe port? I'm keeping a blog here: http://pureperl.blogspot.com/
Kyle Moffett
Mike Frysinger
Moffett, Kyle D
