[PATCH v5 0/8] Add MV88E6xxx DSA driver and use on gwventana
This series adds a DSA driver for the MV88E6xxx based on drivers/net/phy/mv88e61xx and uses it in the gwventana_gw5904_defconfig.
The hope is that the other three boards that use the MV88E61xx driver can move to this as well eventually so that we can remove the non-dm driver and the 4 Kconfig options it requires.
The MV88E6xxx has an MDIO interface thus DM_MDIO must be used so support for a UCLASS_MDIO driver is added to the fec_mxc ethernet driver in a way that allows a fallback to the previous non DM_MDIO case as there are many boards out there using this driver that define DM_MDIO but do not have the required dt props for a DM_MDIO driver which would cause a regression.
Additionally some other patches are here suggested by Vladimir: - ensure MDIO children are scanned on post-bind is needed - sanity check DSA driver required ops are present - allow DSA drivers to not require xmit/recv functions - remove unecessary xmit/recv functions from ksz9477 driver
v5: - fix typo in defconfig update - added support for MV88E6320 - added Fabio's rb tag v4: - use standard Linux internal MDIO dt structure - use PHY_FIXED_ID define - rename to mv88e6xxx - sort includes alphabetically - remove dsa term from function names - reduce indentation level and remove unecessary code in of probe_mdio function - rename pdev to mdev to represent mdio device
v3: - fix mdios node in dt - add Vladimir's rb tag's
v2: - added Ramon's rb tag's to first two patches - add patches for dsa-uclass to sanity check ops and make xmit/recv optional - fec: fix fallback for non conforming DM_MDIO dts - mv88e61xx: - rebase on v2022.07-rc2 (use ofnode_get_phy_node) - remove unused commented out fields from struct - remove unused PORT_MASK macro - remove phy from priv struct name - refactor code from original drivers/net/phy/mv88e61xx with suggestions from review to consolidate some functions into mv88e61xx_dsa_port_enable - remove unecessary skiping of disabling of CPU port - remove unecessary dev_set_parent_priv - remove unnecessary static init flag - replace debug with a dev_warn if switch device-id unsupported - remove unnecessary xmit/recv functions as we rely on the fact that only a single port is active instead of mangling packets
Tested on a Gateworks GW5904 which has a Marvell 88E6176 switch hanging off the IMX6 FEC.
Best Regards,
Tim
Tim Harvey (8): net: mdio-uclass: scan for dm mdio children on post-bind net: dsa: move cpu port probe to dsa_post_probe net: dsa: ensure dsa driver has proper ops net: dsa: allow rcv() and xmit() to be optional net: ksz9477: remove unnecessary xmit and recv functions net: fec: add support for DM_MDIO net: add MV88E61xx DSA driver board: gw_ventana: enable MV88E61XX DSA support
arch/arm/dts/imx6qdl-gw5904.dtsi | 31 + board/gateworks/gw_ventana/gw_ventana.c | 50 +- configs/gwventana_gw5904_defconfig | 7 +- drivers/net/Kconfig | 7 + drivers/net/Makefile | 1 + drivers/net/fec_mxc.c | 90 ++- drivers/net/ksz9477.c | 23 - drivers/net/mv88e6xxx.c | 828 ++++++++++++++++++++++++ net/dsa-uclass.c | 57 +- net/mdio-uclass.c | 4 + 10 files changed, 1026 insertions(+), 72 deletions(-) create mode 100644 drivers/net/mv88e6xxx.c
If a DM_MDIO driver is used we need to scan the subnodes as well.
Signed-off-by: Tim Harvey tharvey@gateworks.com Signed-off-by: Vladimir Oltean vladimir.oltean@nxp.com Reviewed-by: Ramon Fried rfried.dev@gmail.com Reviewed-by: Fabio Estevam festevam@denx.de --- v5: - added Fabio's rb tag v4: - no changes v3: - no changes v2: - added Ramon's rb tag --- net/mdio-uclass.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/net/mdio-uclass.c b/net/mdio-uclass.c index 4401492ca015..d80037d0ac71 100644 --- a/net/mdio-uclass.c +++ b/net/mdio-uclass.c @@ -49,7 +49,11 @@ static int dm_mdio_post_bind(struct udevice *dev) return -EINVAL; }
+#if CONFIG_IS_ENABLED(OF_REAL) + return dm_scan_fdt_dev(dev); +#else return 0; +#endif }
int dm_mdio_read(struct udevice *mdio_dev, int addr, int devad, int reg)
In order to ensure that a DSA driver probe gets called before dsa_ops->port_probe move the port_probe of the cpu_port to a post-probe function.
Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Ramon Fried rfried.dev@gmail.com Reviewed-by: Vladimir Oltean vladimir.oltean@nxp.com Reviewed-by: Fabio Estevam festevam@denx.de --- v5: - added Fabio's rb tag v4: - no changes v3: - added Vladimir's rb tag v2: - added Ramon's rb tag --- net/dsa-uclass.c | 13 +++++++++++-- 1 file changed, 11 insertions(+), 2 deletions(-)
diff --git a/net/dsa-uclass.c b/net/dsa-uclass.c index 5b7046432ff3..a37e76e25a8f 100644 --- a/net/dsa-uclass.c +++ b/net/dsa-uclass.c @@ -466,7 +466,6 @@ static int dsa_pre_probe(struct udevice *dev) { struct dsa_pdata *pdata = dev_get_uclass_plat(dev); struct dsa_priv *priv = dev_get_uclass_priv(dev); - struct dsa_ops *ops = dsa_get_ops(dev); int err;
priv->num_ports = pdata->num_ports; @@ -482,6 +481,15 @@ static int dsa_pre_probe(struct udevice *dev) if (err) return err;
+ return 0; +} + +static int dsa_post_probe(struct udevice *dev) +{ + struct dsa_priv *priv = dev_get_uclass_priv(dev); + struct dsa_ops *ops = dsa_get_ops(dev); + int err; + /* Simulate a probing event for the CPU port */ if (ops->port_probe) { err = ops->port_probe(dev, priv->cpu_port, @@ -491,13 +499,14 @@ static int dsa_pre_probe(struct udevice *dev) }
return 0; -} +};
UCLASS_DRIVER(dsa) = { .id = UCLASS_DSA, .name = "dsa", .post_bind = dsa_post_bind, .pre_probe = dsa_pre_probe, + .post_probe = dsa_post_probe, .per_device_auto = sizeof(struct dsa_priv), .per_device_plat_auto = sizeof(struct dsa_pdata), .per_child_plat_auto = sizeof(struct dsa_port_pdata),
On Tue, Oct 04, 2022 at 09:49:12AM -0700, Tim Harvey wrote:
diff --git a/net/dsa-uclass.c b/net/dsa-uclass.c index 5b7046432ff3..a37e76e25a8f 100644 --- a/net/dsa-uclass.c +++ b/net/dsa-uclass.c @@ -466,7 +466,6 @@ static int dsa_pre_probe(struct udevice *dev) +static int dsa_post_probe(struct udevice *dev) +{
- struct dsa_priv *priv = dev_get_uclass_priv(dev);
- int err;
- /* Simulate a probing event for the CPU port */ if (ops->port_probe) { err = ops->port_probe(dev, priv->cpu_port,
return 0; -} +};
Semicolons aren't needed at the end of functions.
Add a function to sanity check a dsa driver having proper ops.
Suggested-by: Vladimir Oltean vladimir.oltean@nxp.com Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Vladimir Oltean vladimir.oltean@nxp.com Reviewed-by: Fabio Estevam festevam@denx.de --- v5: - added Fabio's rb tag v4: - no changes v3: - added Vladimir's rb tag v2: new patch --- net/dsa-uclass.c | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/net/dsa-uclass.c b/net/dsa-uclass.c index a37e76e25a8f..e74dc178ff69 100644 --- a/net/dsa-uclass.c +++ b/net/dsa-uclass.c @@ -342,6 +342,19 @@ U_BOOT_DRIVER(dsa_port) = { .plat_auto = sizeof(struct eth_pdata), };
+static int dsa_sanitize_ops(struct udevice *dev) +{ + struct dsa_ops *ops = dsa_get_ops(dev); + + if ((!ops->xmit || !ops->rcv) && + (!ops->port_enable && !ops->port_disable)) { + dev_err(dev, "Packets cannot be steered to ports\n"); + return -EINVAL; + } + + return 0; +} + /* * This function mostly deals with pulling information out of the device tree * into the pdata structure. @@ -358,6 +371,10 @@ static int dsa_post_bind(struct udevice *dev) if (!ofnode_valid(node)) return -ENODEV;
+ err = dsa_sanitize_ops(dev); + if (err) + return err; + pdata->master_node = ofnode_null();
node = ofnode_find_subnode(node, "ports");
Allow rcv() and xmit() dsa driver ops to be optional in case a driver does not care to mangle a packet as in U-Boot only one network port is enabled at a time and thus no packet mangling is necessary.
Suggested-by: Vladimir Oltean vladimir.oltean@nxp.com Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Vladimir Oltean vladimir.oltean@nxp.com Reviewed-by: Fabio Estevam festevam@denx.de --- v5: - added Fabio's rb tag v4: - no changes v3: - added Vladimir's rb tag v2: new patch --- net/dsa-uclass.c | 27 ++++++++++++++++++--------- 1 file changed, 18 insertions(+), 9 deletions(-)
diff --git a/net/dsa-uclass.c b/net/dsa-uclass.c index e74dc178ff69..37a84b88cd10 100644 --- a/net/dsa-uclass.c +++ b/net/dsa-uclass.c @@ -131,16 +131,14 @@ static void dsa_port_stop(struct udevice *pdev) * We copy the frame to a stack buffer where we have reserved headroom and * tailroom space. Headroom and tailroom are set to 0. */ -static int dsa_port_send(struct udevice *pdev, void *packet, int length) +static int dsa_port_mangle_packet(struct udevice *pdev, void *packet, int length) { + struct dsa_port_pdata *port_pdata = dev_get_parent_plat(pdev); struct udevice *dev = dev_get_parent(pdev); struct dsa_priv *priv = dev_get_uclass_priv(dev); int head = priv->headroom, tail = priv->tailroom; - struct udevice *master = dsa_get_master(dev); struct dsa_ops *ops = dsa_get_ops(dev); uchar dsa_packet_tmp[PKTSIZE_ALIGN]; - struct dsa_port_pdata *port_pdata; - int err;
if (length + head + tail > PKTSIZE_ALIGN) return -EINVAL; @@ -152,10 +150,21 @@ static int dsa_port_send(struct udevice *pdev, void *packet, int length) /* copy back to preserve original buffer alignment */ memcpy(packet, dsa_packet_tmp, length);
- port_pdata = dev_get_parent_plat(pdev); - err = ops->xmit(dev, port_pdata->index, packet, length); - if (err) - return err; + return ops->xmit(dev, port_pdata->index, packet, length); +} + +static int dsa_port_send(struct udevice *pdev, void *packet, int length) +{ + struct udevice *dev = dev_get_parent(pdev); + struct udevice *master = dsa_get_master(dev); + struct dsa_ops *ops = dsa_get_ops(dev); + int err; + + if (ops->xmit) { + err = dsa_port_mangle_packet(pdev, packet, length); + if (err) + return err; + }
return eth_get_ops(master)->send(master, packet, length); } @@ -172,7 +181,7 @@ static int dsa_port_recv(struct udevice *pdev, int flags, uchar **packetp) int length, port_index, err;
length = eth_get_ops(master)->recv(master, flags, packetp); - if (length <= 0) + if (length <= 0 || !ops->rcv) return length;
Remove the unnecessary xmit and recv functions.
Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Vladimir Oltean vladimir.oltean@nxp.com Reviewed-by: Fabio Estevam festevam@denx.de --- v5: - added Fabio's rb tag v4: - no changes v3: - added Vladimir's rb tag v2: new patch --- drivers/net/ksz9477.c | 23 ----------------------- 1 file changed, 23 deletions(-)
diff --git a/drivers/net/ksz9477.c b/drivers/net/ksz9477.c index ed8f1895cb12..fb5c76c600be 100644 --- a/drivers/net/ksz9477.c +++ b/drivers/net/ksz9477.c @@ -62,7 +62,6 @@
struct ksz_dsa_priv { struct udevice *dev; - int active_port; };
static inline int ksz_read8(struct udevice *dev, u32 reg, u8 *val) @@ -382,9 +381,6 @@ static int ksz_port_enable(struct udevice *dev, int port, struct phy_device *phy data8 |= SW_START; ksz_write8(priv->dev, REG_SW_OPERATION, data8);
- /* keep track of current enabled non-cpu port */ - priv->active_port = port; - return 0; }
@@ -413,28 +409,9 @@ static void ksz_port_disable(struct udevice *dev, int port, struct phy_device *p */ }
-static int ksz_xmit(struct udevice *dev, int port, void *packet, int length) -{ - dev_dbg(dev, "%s P%d %d\n", __func__, port + 1, length); - - return 0; -} - -static int ksz_recv(struct udevice *dev, int *port, void *packet, int length) -{ - struct ksz_dsa_priv *priv = dev_get_priv(dev); - - dev_dbg(dev, "%s P%d %d\n", __func__, priv->active_port + 1, length); - *port = priv->active_port; - - return 0; -}; - static const struct dsa_ops ksz_dsa_ops = { .port_enable = ksz_port_enable, .port_disable = ksz_port_disable, - .xmit = ksz_xmit, - .rcv = ksz_recv, };
static int ksz_probe_mdio(struct udevice *dev)
Add support for DM_MDIO by registering a UCLASS_MDIO driver and attempting to use it. This is necessary if wanting to use a DSA driver for example hanging off of the FEC MAC.
Care is taken to fallback to non DM_MDIO mii bus as several boards define DM_MDIO without having the proper device-tree configuration necessary such as an mdio subnode, a phy-mode prop, and either a valid phy-handle prop or fixed-phy subnode which will cause dm_eth_phy_connect() to fail.
Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Fabio Estevam festevam@denx.de --- v5: - added Fabio's rb tag v4: - no changes v3: - no changes v2: - fix fallback mechanism for legacy dt's that do not have phy-handle and mdio subnode --- drivers/net/fec_mxc.c | 90 ++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 88 insertions(+), 2 deletions(-)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index bbc4434ddb9e..7057472710fa 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -30,6 +30,8 @@ #include <asm/arch/imx-regs.h> #include <asm/mach-imx/sys_proto.h> #include <asm-generic/gpio.h> +#include <dm/device_compat.h> +#include <dm/lists.h>
#include "fec_mxc.h" #include <eth_phy.h> @@ -1026,6 +1028,81 @@ struct mii_dev *fec_get_miibus(ulong base_addr, int dev_id) return bus; }
+#ifdef CONFIG_DM_MDIO +struct dm_fec_mdio_priv { + struct ethernet_regs *regs; +}; + +static int dm_fec_mdio_read(struct udevice *dev, int addr, int devad, int reg) +{ + struct dm_fec_mdio_priv *priv = dev_get_priv(dev); + + return fec_mdio_read(priv->regs, addr, reg); +} + +static int dm_fec_mdio_write(struct udevice *dev, int addr, int devad, int reg, u16 data) +{ + struct dm_fec_mdio_priv *priv = dev_get_priv(dev); + + return fec_mdio_write(priv->regs, addr, reg, data); +} + +static const struct mdio_ops dm_fec_mdio_ops = { + .read = dm_fec_mdio_read, + .write = dm_fec_mdio_write, +}; + +static int dm_fec_mdio_probe(struct udevice *dev) +{ + struct dm_fec_mdio_priv *priv = dev_get_priv(dev); + + priv->regs = (struct ethernet_regs *)ofnode_get_addr(dev_ofnode(dev->parent)); + + return 0; +} + +U_BOOT_DRIVER(fec_mdio) = { + .name = "fec_mdio", + .id = UCLASS_MDIO, + .probe = dm_fec_mdio_probe, + .ops = &dm_fec_mdio_ops, + .priv_auto = sizeof(struct dm_fec_mdio_priv), +}; + +static int dm_fec_bind_mdio(struct udevice *dev) +{ + struct udevice *mdiodev; + const char *name; + ofnode mdio; + int ret = -ENODEV; + + /* for a UCLASS_MDIO driver we need to bind and probe manually + * for an internal MDIO bus that has no dt compatible of its own + */ + ofnode_for_each_subnode(mdio, dev_ofnode(dev)) { + name = ofnode_get_name(mdio); + + if (strcmp(name, "mdio")) + continue; + + ret = device_bind_driver_to_node(dev, "fec_mdio", + name, mdio, &mdiodev); + if (ret) { + printf("%s bind %s failed: %d\n", __func__, name, ret); + break; + } + + /* need to probe it as there is no compatible to do so */ + ret = uclass_get_device_by_ofnode(UCLASS_MDIO, mdio, &mdiodev); + if (!ret) + return 0; + printf("%s probe %s failed: %d\n", __func__, name, ret); + } + + return ret; +} +#endif + static int fecmxc_read_rom_hwaddr(struct udevice *dev) { struct fec_priv *priv = dev_get_priv(dev); @@ -1089,7 +1166,7 @@ static int device_get_phy_addr(struct fec_priv *priv, struct udevice *dev)
static int fec_phy_init(struct fec_priv *priv, struct udevice *dev) { - struct phy_device *phydev; + struct phy_device *phydev = NULL; int addr;
addr = device_get_phy_addr(priv, dev); @@ -1097,7 +1174,10 @@ static int fec_phy_init(struct fec_priv *priv, struct udevice *dev) addr = CONFIG_FEC_MXC_PHYADDR; #endif
- phydev = phy_connect(priv->bus, addr, dev, priv->interface); + if (IS_ENABLED(CONFIG_DM_MDIO)) + phydev = dm_eth_phy_connect(dev); + if (!phydev) + phydev = phy_connect(priv->bus, addr, dev, priv->interface); if (!phydev) return -ENODEV;
@@ -1228,6 +1308,12 @@ static int fecmxc_probe(struct udevice *dev)
priv->dev_id = dev_seq(dev);
+ if (IS_ENABLED(CONFIG_DM_MDIO)) { + ret = dm_fec_bind_mdio(dev); + if (ret && ret != -ENODEV) + return ret; + } + #ifdef CONFIG_DM_ETH_PHY bus = eth_phy_get_mdio_bus(dev); #endif
Add a DSA driver for the MV88E61xx compatible GbE Ethernet switches.
Cc: Marek BehĂșn marek.behun@nic.cz Cc: Vladimir Oltean vladimir.oltean@nxp.com Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Vladimir Oltean vladimir.oltean@nxp.com Reviewed-by: Fabio Estevam festevam@denx.de --- v5: - added support for MV88E6320 - added Fabio's rb tag v4: - rename to mv88e6xxx - sort includes alphabetically - remove dsa term from function names - reduce indentation level and remove unecessary code in of probe_mdio function - rename pdev to mdev to represent mdio device v3: - Added Vladimir's rb tag v2: - rebase on v2022.07-rc1 (use ofnode_get_phy_node) - remove unused commented out fields from struct - remove unused PORT_MASK macro - remove phy from priv struct name - refactor code from original drivers/net/phy/mv88e61xx with suggestions from review to consolidate some functions into mv88e61xx_dsa_port_enable - remove unecessary skiping of disabling of CPU port - remove unecessary dev_set_parent_priv - remove unnecessary static init flag - replace debug with a dev_warn if switch device-id unsupported - remove unnecessary xmit/recv functions as we rely on the fact that only a single port is active instead of mangling packets --- drivers/net/Kconfig | 7 + drivers/net/Makefile | 1 + drivers/net/mv88e6xxx.c | 833 ++++++++++++++++++++++++++++++++++++++++ 3 files changed, 841 insertions(+) create mode 100644 drivers/net/mv88e6xxx.c
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 6bbbadc5eef3..5508dacbcc49 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -438,6 +438,13 @@ config KSZ9477 This driver implements a DSA switch driver for the KSZ9477 family of GbE switches using the I2C interface.
+config MV88E6XXX + bool "Marvell MV88E6xxx GbE switch DSA driver" + depends on DM_DSA && DM_MDIO + help + This driver implements a DSA switch driver for the MV88E6xxx family + of GbE switches using the MDIO interface + config MVGBE bool "Marvell Orion5x/Kirkwood network interface support" depends on ARCH_KIRKWOOD || ARCH_ORION5X diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 96b7678e9882..f05fd58e3fa7 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -59,6 +59,7 @@ obj-$(CONFIG_MEDIATEK_ETH) += mtk_eth.o obj-$(CONFIG_MPC8XX_FEC) += mpc8xx_fec.o obj-$(CONFIG_MT7620_ETH) += mt7620-eth.o obj-$(CONFIG_MT7628_ETH) += mt7628-eth.o +obj-$(CONFIG_MV88E6XXX) += mv88e6xxx.o obj-$(CONFIG_MVGBE) += mvgbe.o obj-$(CONFIG_MVMDIO) += mvmdio.o obj-$(CONFIG_MVNETA) += mvneta.o diff --git a/drivers/net/mv88e6xxx.c b/drivers/net/mv88e6xxx.c new file mode 100644 index 000000000000..e59e2464c641 --- /dev/null +++ b/drivers/net/mv88e6xxx.c @@ -0,0 +1,833 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 + * Gateworks Corporation <www.gateworks.com> + * Tim Harvey tharvey@gateworks.com + * + * (C) Copyright 2015 + * Elecsys Corporation <www.elecsyscorp.com> + * Kevin Smith kevin.smith@elecsyscorp.com + * + * Original driver: + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Prafulla Wadaskar prafulla@marvell.com + */ + +/* + * DSA driver for mv88e6xxx ethernet switches. + * + * This driver configures the mv88e6xxx for basic use as a DSA switch. + * + * This driver was adapted from drivers/net/phy/mv88e61xx and tested + * on the mv88e6176 via an SGMII interface. + */ + +#include <bitfield.h> +#include <common.h> +#include <dm/device.h> +#include <dm/device_compat.h> +#include <dm/device-internal.h> +#include <dm/lists.h> +#include <dm/of_extra.h> +#include <linux/delay.h> +#include <miiphy.h> +#include <net/dsa.h> + +/* Device addresses */ +#define DEVADDR_PHY(p) (p) +#define DEVADDR_SERDES 0x0F + +/* SMI indirection registers for multichip addressing mode */ +#define SMI_CMD_REG 0x00 +#define SMI_DATA_REG 0x01 + +/* Global registers */ +#define GLOBAL1_STATUS 0x00 +#define GLOBAL1_CTRL 0x04 +#define GLOBAL1_MON_CTRL 0x1A + +/* Global 2 registers */ +#define GLOBAL2_REG_PHY_CMD 0x18 +#define GLOBAL2_REG_PHY_DATA 0x19 +#define GLOBAL2_REG_SCRATCH 0x1A + +/* Port registers */ +#define PORT_REG_STATUS 0x00 +#define PORT_REG_PHYS_CTRL 0x01 +#define PORT_REG_SWITCH_ID 0x03 +#define PORT_REG_CTRL 0x04 +#define PORT_REG_VLAN_MAP 0x06 +#define PORT_REG_VLAN_ID 0x07 +#define PORT_REG_LED_CTRL 0x16 + +/* Phy registers */ +#define PHY_REG_CTRL1 0x10 +#define PHY_REG_STATUS1 0x11 +#define PHY_REG_PAGE 0x16 + +/* Serdes registers */ +#define SERDES_REG_CTRL_1 0x10 + +/* Phy page numbers */ +#define PHY_PAGE_COPPER 0 +#define PHY_PAGE_SERDES 1 + +/* Register fields */ +#define GLOBAL1_CTRL_SWRESET BIT(15) + +#define GLOBAL1_MON_CTRL_CPUDEST_SHIFT 4 +#define GLOBAL1_MON_CTRL_CPUDEST_WIDTH 4 + +#define PORT_REG_STATUS_SPEED_SHIFT 8 +#define PORT_REG_STATUS_SPEED_10 0 +#define PORT_REG_STATUS_SPEED_100 1 +#define PORT_REG_STATUS_SPEED_1000 2 + +#define PORT_REG_STATUS_CMODE_MASK 0xF +#define PORT_REG_STATUS_CMODE_100BASE_X 0x8 +#define PORT_REG_STATUS_CMODE_1000BASE_X 0x9 +#define PORT_REG_STATUS_CMODE_SGMII 0xa + +#define PORT_REG_PHYS_CTRL_RGMII_DELAY_RXCLK BIT(15) +#define PORT_REG_PHYS_CTRL_RGMII_DELAY_TXCLK BIT(14) +#define PORT_REG_PHYS_CTRL_PCS_AN_EN BIT(10) +#define PORT_REG_PHYS_CTRL_PCS_AN_RST BIT(9) +#define PORT_REG_PHYS_CTRL_FC_VALUE BIT(7) +#define PORT_REG_PHYS_CTRL_FC_FORCE BIT(6) +#define PORT_REG_PHYS_CTRL_LINK_VALUE BIT(5) +#define PORT_REG_PHYS_CTRL_LINK_FORCE BIT(4) +#define PORT_REG_PHYS_CTRL_DUPLEX_VALUE BIT(3) +#define PORT_REG_PHYS_CTRL_DUPLEX_FORCE BIT(2) +#define PORT_REG_PHYS_CTRL_SPD1000 BIT(1) +#define PORT_REG_PHYS_CTRL_SPD100 BIT(0) +#define PORT_REG_PHYS_CTRL_SPD_MASK (BIT(1) | BIT(0)) + +#define PORT_REG_CTRL_PSTATE_SHIFT 0 +#define PORT_REG_CTRL_PSTATE_WIDTH 2 + +#define PORT_REG_VLAN_ID_DEF_VID_SHIFT 0 +#define PORT_REG_VLAN_ID_DEF_VID_WIDTH 12 + +#define PORT_REG_VLAN_MAP_TABLE_SHIFT 0 +#define PORT_REG_VLAN_MAP_TABLE_WIDTH 11 + +#define SERDES_REG_CTRL_1_FORCE_LINK BIT(10) + +/* Field values */ +#define PORT_REG_CTRL_PSTATE_DISABLED 0 +#define PORT_REG_CTRL_PSTATE_FORWARD 3 + +#define PHY_REG_CTRL1_ENERGY_DET_OFF 0 +#define PHY_REG_CTRL1_ENERGY_DET_SENSE_PULSE 1 +#define PHY_REG_CTRL1_ENERGY_DET_SENSE_ONLY 2 +#define PHY_REG_CTRL1_ENERGY_DET_SENSE_XMIT 3 + +/* PHY Status Register */ +#define PHY_REG_STATUS1_SPEED 0xc000 +#define PHY_REG_STATUS1_GBIT 0x8000 +#define PHY_REG_STATUS1_100 0x4000 +#define PHY_REG_STATUS1_DUPLEX 0x2000 +#define PHY_REG_STATUS1_SPDDONE 0x0800 +#define PHY_REG_STATUS1_LINK 0x0400 +#define PHY_REG_STATUS1_ENERGY 0x0010 + +/* + * Macros for building commands for indirect addressing modes. These are valid + * for both the indirect multichip addressing mode and the PHY indirection + * required for the writes to any PHY register. + */ +#define SMI_BUSY BIT(15) +#define SMI_CMD_CLAUSE_22 BIT(12) +#define SMI_CMD_CLAUSE_22_OP_READ (2 << 10) +#define SMI_CMD_CLAUSE_22_OP_WRITE (1 << 10) + +#define SMI_CMD_READ (SMI_BUSY | SMI_CMD_CLAUSE_22 | \ + SMI_CMD_CLAUSE_22_OP_READ) +#define SMI_CMD_WRITE (SMI_BUSY | SMI_CMD_CLAUSE_22 | \ + SMI_CMD_CLAUSE_22_OP_WRITE) + +#define SMI_CMD_ADDR_SHIFT 5 +#define SMI_CMD_ADDR_WIDTH 5 +#define SMI_CMD_REG_SHIFT 0 +#define SMI_CMD_REG_WIDTH 5 + +/* Defines for Scratch and Misc Registers */ +#define SCRATCH_UPDATE BIT(15) +#define SCRATCH_ADDR_SHIFT 8 +#define SCRATCH_ADDR_WIDTH 7 + +/* Scratch registers */ +#define SCRATCH_ADDR_GPIO0DIR 0x62 /* GPIO[7:0] direction 1=input */ +#define SCRATCH_ADDR_GPIO1DIR 0x63 /* GPIO[14:8] direction 1=input */ +#define SCRATCH_ADDR_GPIO0DATA 0x64 /* GPIO[7:0] data */ +#define SCRATCH_ADDR_GPIO1DATA 0x65 /* GPIO[14:8] data */ +#define SCRATCH_ADDR_GPIO0CTRL 0x68 /* GPIO[1:0] control */ +#define SCRATCH_ADDR_GPIO1CTRL 0x69 /* GPIO[3:2] control */ + +/* ID register values for different switch models */ +#define PORT_SWITCH_ID_6020 0x0200 +#define PORT_SWITCH_ID_6070 0x0700 +#define PORT_SWITCH_ID_6071 0x0710 +#define PORT_SWITCH_ID_6096 0x0980 +#define PORT_SWITCH_ID_6097 0x0990 +#define PORT_SWITCH_ID_6172 0x1720 +#define PORT_SWITCH_ID_6176 0x1760 +#define PORT_SWITCH_ID_6220 0x2200 +#define PORT_SWITCH_ID_6240 0x2400 +#define PORT_SWITCH_ID_6250 0x2500 +#define PORT_SWITCH_ID_6320 0x1150 +#define PORT_SWITCH_ID_6352 0x3520 + +struct mv88e6xxx_priv { + int smi_addr; + int id; + int port_count; /* Number of switch ports */ + int port_reg_base; /* Base of the switch port registers */ + u8 global1; /* Offset of Switch Global 1 registers */ + u8 global2; /* Offset of Switch Global 2 registers */ + u8 phy_ctrl1_en_det_shift; /* 'EDet' bit field offset */ + u8 phy_ctrl1_en_det_width; /* Width of 'EDet' bit field */ + u8 phy_ctrl1_en_det_ctrl; /* 'EDet' control value */ +}; + +static inline int smi_cmd(int cmd, int addr, int reg) +{ + cmd = bitfield_replace(cmd, SMI_CMD_ADDR_SHIFT, SMI_CMD_ADDR_WIDTH, + addr); + cmd = bitfield_replace(cmd, SMI_CMD_REG_SHIFT, SMI_CMD_REG_WIDTH, reg); + return cmd; +} + +static inline int smi_cmd_read(int addr, int reg) +{ + return smi_cmd(SMI_CMD_READ, addr, reg); +} + +static inline int smi_cmd_write(int addr, int reg) +{ + return smi_cmd(SMI_CMD_WRITE, addr, reg); +} + +/* Wait for the current SMI indirect command to complete */ +static int mv88e6xxx_smi_wait(struct udevice *dev, int smi_addr) +{ + int val; + u32 timeout = 100; + + do { + val = dm_mdio_read(dev->parent, smi_addr, MDIO_DEVAD_NONE, SMI_CMD_REG); + if (val >= 0 && (val & SMI_BUSY) == 0) + return 0; + + mdelay(1); + } while (--timeout); + + dev_err(dev, "SMI busy timeout\n"); + return -ETIMEDOUT; +} + +/* + * The mv88e6xxx has three types of addresses: the smi bus address, the device + * address, and the register address. The smi bus address distinguishes it on + * the smi bus from other PHYs or switches. The device address determines + * which on-chip register set you are reading/writing (the various PHYs, their + * associated ports, or global configuration registers). The register address + * is the offset of the register you are reading/writing. + * + * When the mv88e6xxx is hardware configured to have address zero, it behaves in + * single-chip addressing mode, where it responds to all SMI addresses, using + * the smi address as its device address. This obviously only works when this + * is the only chip on the SMI bus. This allows the driver to access device + * registers without using indirection. When the chip is configured to a + * non-zero address, it only responds to that SMI address and requires indirect + * writes to access the different device addresses. + */ +static int mv88e6xxx_reg_read(struct udevice *dev, int addr, int reg) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + int smi_addr = priv->smi_addr; + int res; + + /* In single-chip mode, the device can be addressed directly */ + if (smi_addr == 0) + return dm_mdio_read(dev->parent, addr, MDIO_DEVAD_NONE, reg); + + /* Wait for the bus to become free */ + res = mv88e6xxx_smi_wait(dev, smi_addr); + if (res < 0) + return res; + + /* Issue the read command */ + res = dm_mdio_write(dev->parent, smi_addr, MDIO_DEVAD_NONE, SMI_CMD_REG, + smi_cmd_read(addr, reg)); + if (res < 0) + return res; + + /* Wait for the read command to complete */ + res = mv88e6xxx_smi_wait(dev, smi_addr); + if (res < 0) + return res; + + /* Read the data */ + res = dm_mdio_read(dev->parent, smi_addr, MDIO_DEVAD_NONE, SMI_DATA_REG); + if (res < 0) + return res; + + return bitfield_extract(res, 0, 16); +} + +/* See the comment above mv88e6xxx_reg_read */ +static int mv88e6xxx_reg_write(struct udevice *dev, int addr, int reg, u16 val) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + int smi_addr = priv->smi_addr; + int res; + + /* In single-chip mode, the device can be addressed directly */ + if (smi_addr == 0) + return dm_mdio_write(dev->parent, addr, MDIO_DEVAD_NONE, reg, val); + + /* Wait for the bus to become free */ + res = mv88e6xxx_smi_wait(dev, smi_addr); + if (res < 0) + return res; + + /* Set the data to write */ + res = dm_mdio_write(dev->parent, smi_addr, MDIO_DEVAD_NONE, + SMI_DATA_REG, val); + if (res < 0) + return res; + + /* Issue the write command */ + res = dm_mdio_write(dev->parent, smi_addr, MDIO_DEVAD_NONE, SMI_CMD_REG, + smi_cmd_write(addr, reg)); + if (res < 0) + return res; + + /* Wait for the write command to complete */ + res = mv88e6xxx_smi_wait(dev, smi_addr); + if (res < 0) + return res; + + return 0; +} + +static int mv88e6xxx_phy_wait(struct udevice *dev) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + int val; + u32 timeout = 100; + + do { + val = mv88e6xxx_reg_read(dev, priv->global2, GLOBAL2_REG_PHY_CMD); + if (val >= 0 && (val & SMI_BUSY) == 0) + return 0; + + mdelay(1); + } while (--timeout); + + return -ETIMEDOUT; +} + +static int mv88e6xxx_phy_read_indirect(struct udevice *dev, int phyad, int devad, int reg) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + int res; + + /* Issue command to read */ + res = mv88e6xxx_reg_write(dev, priv->global2, + GLOBAL2_REG_PHY_CMD, + smi_cmd_read(phyad, reg)); + + /* Wait for data to be read */ + res = mv88e6xxx_phy_wait(dev); + if (res < 0) + return res; + + /* Read retrieved data */ + return mv88e6xxx_reg_read(dev, priv->global2, + GLOBAL2_REG_PHY_DATA); +} + +static int mv88e6xxx_phy_write_indirect(struct udevice *dev, int phyad, + int devad, int reg, u16 data) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + int res; + + /* Set the data to write */ + res = mv88e6xxx_reg_write(dev, priv->global2, + GLOBAL2_REG_PHY_DATA, data); + if (res < 0) + return res; + /* Issue the write command */ + res = mv88e6xxx_reg_write(dev, priv->global2, + GLOBAL2_REG_PHY_CMD, + smi_cmd_write(phyad, reg)); + if (res < 0) + return res; + + /* Wait for command to complete */ + return mv88e6xxx_phy_wait(dev); +} + +/* Wrapper function to make calls to phy_read_indirect simpler */ +static int mv88e6xxx_phy_read(struct udevice *dev, int phy, int reg) +{ + return mv88e6xxx_phy_read_indirect(dev, DEVADDR_PHY(phy), + MDIO_DEVAD_NONE, reg); +} + +/* Wrapper function to make calls to phy_write_indirect simpler */ +static int mv88e6xxx_phy_write(struct udevice *dev, int phy, int reg, u16 val) +{ + return mv88e6xxx_phy_write_indirect(dev, DEVADDR_PHY(phy), + MDIO_DEVAD_NONE, reg, val); +} + +static int mv88e6xxx_port_read(struct udevice *dev, u8 port, u8 reg) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + + return mv88e6xxx_reg_read(dev, priv->port_reg_base + port, reg); +} + +static int mv88e6xxx_port_write(struct udevice *dev, u8 port, u8 reg, u16 val) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + + return mv88e6xxx_reg_write(dev, priv->port_reg_base + port, reg, val); +} + +static int mv88e6xxx_set_page(struct udevice *dev, u8 phy, u8 page) +{ + return mv88e6xxx_phy_write(dev, phy, PHY_REG_PAGE, page); +} + +static int mv88e6xxx_get_switch_id(struct udevice *dev) +{ + int res; + + res = mv88e6xxx_port_read(dev, 0, PORT_REG_SWITCH_ID); + if (res < 0) + return res; + return res & 0xfff0; +} + +static bool mv88e6xxx_6352_family(struct udevice *dev) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + + switch (priv->id) { + case PORT_SWITCH_ID_6172: + case PORT_SWITCH_ID_6176: + case PORT_SWITCH_ID_6240: + case PORT_SWITCH_ID_6352: + return true; + } + return false; +} + +static int mv88e6xxx_get_cmode(struct udevice *dev, u8 port) +{ + int res; + + res = mv88e6xxx_port_read(dev, port, PORT_REG_STATUS); + if (res < 0) + return res; + return res & PORT_REG_STATUS_CMODE_MASK; +} + +static int mv88e6xxx_switch_reset(struct udevice *dev) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + int time; + int val; + u8 port; + + /* Disable all ports */ + for (port = 0; port < priv->port_count; port++) { + val = mv88e6xxx_port_read(dev, port, PORT_REG_CTRL); + if (val < 0) + return val; + val = bitfield_replace(val, PORT_REG_CTRL_PSTATE_SHIFT, + PORT_REG_CTRL_PSTATE_WIDTH, + PORT_REG_CTRL_PSTATE_DISABLED); + val = mv88e6xxx_port_write(dev, port, PORT_REG_CTRL, val); + if (val < 0) + return val; + } + + /* Wait 2 ms for queues to drain */ + udelay(2000); + + /* Reset switch */ + val = mv88e6xxx_reg_read(dev, priv->global1, GLOBAL1_CTRL); + if (val < 0) + return val; + val |= GLOBAL1_CTRL_SWRESET; + val = mv88e6xxx_reg_write(dev, priv->global1, GLOBAL1_CTRL, val); + if (val < 0) + return val; + + /* Wait up to 1 second for switch reset complete */ + for (time = 1000; time; time--) { + val = mv88e6xxx_reg_read(dev, priv->global1, GLOBAL1_CTRL); + if (val >= 0 && ((val & GLOBAL1_CTRL_SWRESET) == 0)) + break; + udelay(1000); + } + if (!time) + return -ETIMEDOUT; + + return 0; +} + +static int mv88e6xxx_serdes_init(struct udevice *dev) +{ + int val; + + val = mv88e6xxx_set_page(dev, DEVADDR_SERDES, PHY_PAGE_SERDES); + if (val < 0) + return val; + + /* Power up serdes module */ + val = mv88e6xxx_phy_read(dev, DEVADDR_SERDES, MII_BMCR); + if (val < 0) + return val; + val &= ~(BMCR_PDOWN); + val = mv88e6xxx_phy_write(dev, DEVADDR_SERDES, MII_BMCR, val); + if (val < 0) + return val; + + return 0; +} + +static int mv88e6xxx_fixed_port_setup(struct udevice *dev, u8 port) +{ + struct dsa_pdata *dsa_pdata = dev_get_uclass_plat(dev); + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + int val; + + val = mv88e6xxx_port_read(dev, port, PORT_REG_PHYS_CTRL); + if (val < 0) + return val; + + val &= ~(PORT_REG_PHYS_CTRL_SPD_MASK | + PORT_REG_PHYS_CTRL_FC_VALUE | + PORT_REG_PHYS_CTRL_FC_FORCE); + val |= PORT_REG_PHYS_CTRL_FC_FORCE | + PORT_REG_PHYS_CTRL_DUPLEX_VALUE | + PORT_REG_PHYS_CTRL_DUPLEX_FORCE; + + if (priv->id == PORT_SWITCH_ID_6071) { + val |= PORT_REG_PHYS_CTRL_SPD100; + } else { + val |= PORT_REG_PHYS_CTRL_PCS_AN_EN | + PORT_REG_PHYS_CTRL_PCS_AN_RST | + PORT_REG_PHYS_CTRL_SPD1000; + } + + if (port == dsa_pdata->cpu_port) + val |= PORT_REG_PHYS_CTRL_LINK_VALUE | + PORT_REG_PHYS_CTRL_LINK_FORCE; + + return mv88e6xxx_port_write(dev, port, PORT_REG_PHYS_CTRL, val); +} + +/* + * This function is used to pre-configure the required register + * offsets, so that the indirect register access to the PHY registers + * is possible. This is necessary to be able to read the PHY ID + * while driver probing or in get_phy_id(). The globalN register + * offsets must be initialized correctly for a detected switch, + * otherwise detection of the PHY ID won't work! + */ +static int mv88e6xxx_priv_reg_offs_pre_init(struct udevice *dev) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + + /* + * Initial 'port_reg_base' value must be an offset of existing + * port register, then reading the ID should succeed. First, try + * to read via port registers with device address 0x10 (88E6096 + * and compatible switches). + */ + priv->port_reg_base = 0x10; + priv->id = mv88e6xxx_get_switch_id(dev); + if (priv->id != 0xfff0) { + priv->global1 = 0x1B; + priv->global2 = 0x1C; + return 0; + } + + /* + * Now try via port registers with device address 0x08 + * (88E6020 and compatible switches). + */ + priv->port_reg_base = 0x08; + priv->id = mv88e6xxx_get_switch_id(dev); + if (priv->id != 0xfff0) { + priv->global1 = 0x0F; + priv->global2 = 0x07; + return 0; + } + + dev_warn(dev, "%s Unknown ID 0x%x\n", __func__, priv->id); + + return -ENODEV; +} + +static int mv88e6xxx_mdio_read(struct udevice *dev, int addr, int devad, int reg) +{ + return mv88e6xxx_phy_read_indirect(dev->parent, DEVADDR_PHY(addr), + MDIO_DEVAD_NONE, reg); +} + +static int mv88e6xxx_mdio_write(struct udevice *dev, int addr, int devad, + int reg, u16 val) +{ + return mv88e6xxx_phy_write_indirect(dev->parent, DEVADDR_PHY(addr), + MDIO_DEVAD_NONE, reg, val); +} + +static const struct mdio_ops mv88e6xxx_mdio_ops = { + .read = mv88e6xxx_mdio_read, + .write = mv88e6xxx_mdio_write, +}; + +static int mv88e6xxx_mdio_bind(struct udevice *dev) +{ + char name[32]; + static int num_devices; + + sprintf(name, "mv88e6xxx-mdio-%d", num_devices++); + device_set_name(dev, name); + + return 0; +} + +U_BOOT_DRIVER(mv88e6xxx_mdio) = { + .name = "mv88e6xxx_mdio", + .id = UCLASS_MDIO, + .ops = &mv88e6xxx_mdio_ops, + .bind = mv88e6xxx_mdio_bind, + .priv_auto = sizeof(struct mv88e6xxx_priv), + .plat_auto = sizeof(struct mdio_perdev_priv), +}; + +static int mv88e6xxx_port_enable(struct udevice *dev, int port, struct phy_device *phy) +{ + struct dsa_pdata *dsa_pdata = dev_get_uclass_plat(dev); + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + int val, ret; + + dev_dbg(dev, "%s P%d phy:0x%08x %s\n", __func__, port, + phy->phy_id, phy_string_for_interface(phy->interface)); + + /* + * Enable energy-detect sensing on PHY, used to determine when a PHY + * port is physically connected + */ + val = mv88e6xxx_phy_read(dev, port, PHY_REG_CTRL1); + if (val < 0) + return val; + val = bitfield_replace(val, priv->phy_ctrl1_en_det_shift, + priv->phy_ctrl1_en_det_width, + priv->phy_ctrl1_en_det_ctrl); + val = mv88e6xxx_phy_write(dev, port, PHY_REG_CTRL1, val); + if (val < 0) + return val; + + /* enable port */ + val = mv88e6xxx_port_read(dev, port, PORT_REG_CTRL); + if (val < 0) + return val; + val = bitfield_replace(val, PORT_REG_CTRL_PSTATE_SHIFT, + PORT_REG_CTRL_PSTATE_WIDTH, + PORT_REG_CTRL_PSTATE_FORWARD); + val = mv88e6xxx_port_write(dev, port, PORT_REG_CTRL, val); + if (val < 0) + return val; + + /* configure RGMII delays for fixed link */ + if (phy->phy_id == PHY_FIXED_ID) { + /* Physical Control register: Table 62 */ + val = mv88e6xxx_port_read(dev, port, PORT_REG_PHYS_CTRL); + val &= ~(PORT_REG_PHYS_CTRL_RGMII_DELAY_RXCLK || + PORT_REG_PHYS_CTRL_RGMII_DELAY_TXCLK); + if (phy->interface == PHY_INTERFACE_MODE_RGMII_ID || + phy->interface == PHY_INTERFACE_MODE_RGMII_RXID) + val |= PORT_REG_PHYS_CTRL_RGMII_DELAY_RXCLK; + if (phy->interface == PHY_INTERFACE_MODE_RGMII_ID || + phy->interface == PHY_INTERFACE_MODE_RGMII_TXID) + val |= PORT_REG_PHYS_CTRL_RGMII_DELAY_TXCLK; + val |= BIT(5) | BIT(4); /* Force link */ + ret = mv88e6xxx_port_write(dev, port, PORT_REG_PHYS_CTRL, val); + if (ret < 0) + return ret; + + ret = mv88e6xxx_fixed_port_setup(dev, port); + if (ret < 0) + return ret; + } + + if (port == dsa_pdata->cpu_port) { + /* Set CPUDest for cpu port */ + val = mv88e6xxx_reg_read(dev, priv->global1, GLOBAL1_MON_CTRL); + if (val < 0) + return val; + val = bitfield_replace(val, GLOBAL1_MON_CTRL_CPUDEST_SHIFT, + GLOBAL1_MON_CTRL_CPUDEST_WIDTH, port); + val = mv88e6xxx_reg_write(dev, priv->global1, GLOBAL1_MON_CTRL, val); + if (val < 0) + return val; + + if (mv88e6xxx_6352_family(dev)) { + /* initialize serdes */ + val = mv88e6xxx_get_cmode(dev, dsa_pdata->cpu_port); + if (val < 0) + return val; + if (val == PORT_REG_STATUS_CMODE_100BASE_X || + val == PORT_REG_STATUS_CMODE_1000BASE_X || + val == PORT_REG_STATUS_CMODE_SGMII) { + val = mv88e6xxx_serdes_init(dev); + if (val < 0) + return val; + } + } + } + + return 0; +} + +static void mv88e6xxx_port_disable(struct udevice *dev, int port, struct phy_device *phy) +{ + int val; + + dev_dbg(dev, "%s P%d phy:0x%x\n", __func__, port, phy->phy_id); + + val = mv88e6xxx_port_read(dev, port, PORT_REG_CTRL); + if (val < 0) + return; + val = bitfield_replace(val, PORT_REG_CTRL_PSTATE_SHIFT, + PORT_REG_CTRL_PSTATE_WIDTH, + PORT_REG_CTRL_PSTATE_DISABLED); + val = mv88e6xxx_port_write(dev, port, PORT_REG_CTRL, val); + if (val < 0) + return; +} + +static const struct dsa_ops mv88e6xxx_dsa_ops = { + .port_enable = mv88e6xxx_port_enable, + .port_disable = mv88e6xxx_port_disable, +}; + +/* bind and probe the switch mdios */ +static int mv88e6xxx_probe_mdio(struct udevice *dev) +{ + struct udevice *mdev; + ofnode node, mdios; + const char *name; + int ret; + + /* bind phy ports of mdios child node to mv88e6xxx_mdio device */ + mdios = dev_read_subnode(dev, "mdios"); + if (!ofnode_valid(mdios)) + return 0; + + ofnode_for_each_subnode(node, mdios) { + name = ofnode_get_name(node); + ret = device_bind_driver_to_node(dev, + "mv88e6xxx_mdio", + name, node, NULL); + if (ret) { + dev_err(dev, "failed to bind %s: %d\n", name, ret); + continue; + } + + /* need to probe it as there is no compatible to do so */ + ret = uclass_get_device_by_ofnode(UCLASS_MDIO, node, &mdev); + if (ret) { + dev_err(dev, "failed to probe %s: %d\n", name, ret); + continue; + } + } + + return ret; +} + +static int mv88e6xxx_probe(struct udevice *dev) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + struct udevice *master = dsa_get_master(dev); + int ret; + + if (!master) + return -ENODEV; + + dev_dbg(dev, "%s master:%s\n", __func__, master->name); + + /* probe internal mdio bus */ + ret = mv88e6xxx_probe_mdio(dev); + if (ret) + return ret; + + ret = mv88e6xxx_priv_reg_offs_pre_init(dev); + if (ret) + return ret; + + dev_dbg(dev, "ID=0x%x PORT_BASE=0x%02x GLOBAL1=0x%02x GLOBAL2=0x%02x\n", + priv->id, priv->port_reg_base, priv->global1, priv->global2); + switch (priv->id) { + case PORT_SWITCH_ID_6096: + case PORT_SWITCH_ID_6097: + case PORT_SWITCH_ID_6172: + case PORT_SWITCH_ID_6176: + case PORT_SWITCH_ID_6240: + case PORT_SWITCH_ID_6352: + priv->port_count = 11; + priv->phy_ctrl1_en_det_shift = 8; + priv->phy_ctrl1_en_det_width = 2; + priv->phy_ctrl1_en_det_ctrl = + PHY_REG_CTRL1_ENERGY_DET_SENSE_XMIT; + break; + case PORT_SWITCH_ID_6020: + case PORT_SWITCH_ID_6070: + case PORT_SWITCH_ID_6071: + case PORT_SWITCH_ID_6220: + case PORT_SWITCH_ID_6250: + case PORT_SWITCH_ID_6320: + priv->port_count = 7; + priv->phy_ctrl1_en_det_shift = 14; + priv->phy_ctrl1_en_det_width = 1; + priv->phy_ctrl1_en_det_ctrl = + PHY_REG_CTRL1_ENERGY_DET_SENSE_PULSE; + break; + default: + return -ENODEV; + } + + ret = mv88e6xxx_switch_reset(dev); + if (ret < 0) + return ret; + + dsa_set_tagging(dev, 0, 0); + + return 0; +} + +static const struct udevice_id mv88e6xxx_ids[] = { + { .compatible = "marvell,mv88e6085" }, + { } +}; + +U_BOOT_DRIVER(mv88e6xxx) = { + .name = "mv88e6xxx", + .id = UCLASS_DSA, + .of_match = mv88e6xxx_ids, + .probe = mv88e6xxx_probe, + .ops = &mv88e6xxx_dsa_ops, + .priv_auto = sizeof(struct mv88e6xxx_priv), +};
Please also rewrite "61xx" from the commit message into "6xxx".
Cc: Marek BehÄÈn marek.behun@nic.cz Cc: Vladimir Oltean vladimir.oltean@nxp.com Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Vladimir Oltean vladimir.oltean@nxp.com Reviewed-by: Fabio Estevam festevam@denx.de
v5:
v4:
v3:
v2:
+config MV88E6XXX
- bool "Marvell MV88E6xxx GbE switch DSA driver"
- depends on DM_DSA && DM_MDIO
- help
I don't think they are all gigabit.
config MVGBE bool "Marvell Orion5x/Kirkwood network interface support" depends on ARCH_KIRKWOOD || ARCH_ORION5X diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 96b7678e9882..f05fd58e3fa7 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -59,6 +59,7 @@ obj-$(CONFIG_MEDIATEK_ETH) += mtk_eth.o obj-$(CONFIG_MPC8XX_FEC) += mpc8xx_fec.o obj-$(CONFIG_MT7620_ETH) += mt7620-eth.o obj-$(CONFIG_MT7628_ETH) += mt7628-eth.o +obj-$(CONFIG_MV88E6XXX) += mv88e6xxx.o obj-$(CONFIG_MVGBE) += mvgbe.o obj-$(CONFIG_MVMDIO) += mvmdio.o obj-$(CONFIG_MVNETA) += mvneta.o diff --git a/drivers/net/mv88e6xxx.c b/drivers/net/mv88e6xxx.c new file mode 100644 index 000000000000..e59e2464c641 --- /dev/null +++ b/drivers/net/mv88e6xxx.c +static int mv88e6xxx_switch_reset(struct udevice *dev) +{
- struct mv88e6xxx_priv *priv = dev_get_priv(dev);
- int time;
- int val;
- u8 port;
- /* Disable all ports */
- for (port = 0; port < priv->port_count; port++) {
if (val < 0)
return val;
if (val < 0)
return val;
- /* Wait 2 ms for queues to drain */
- udelay(2000);
- /* Reset switch */
- val = mv88e6xxx_reg_read(dev, priv->global1, GLOBAL1_CTRL);
- if (val < 0)
return val;
- val |= GLOBAL1_CTRL_SWRESET;
- val = mv88e6xxx_reg_write(dev, priv->global1, GLOBAL1_CTRL, val);
- if (val < 0)
return val;
- /* Wait up to 1 second for switch reset complete */
for switch reset *to* complete
- for (time = 1000; time; time--) {
Maybe "time_ms"? Or "retries"?
break;
udelay(1000);
- if (!time)
return -ETIMEDOUT;
- int val;
- val = mv88e6xxx_set_page(dev, DEVADDR_SERDES, PHY_PAGE_SERDES);
- if (val < 0)
return val;
- /* Power up serdes module */
- val = mv88e6xxx_phy_read(dev, DEVADDR_SERDES, MII_BMCR);
- if (val < 0)
return val;
- val &= ~(BMCR_PDOWN);
- val = mv88e6xxx_phy_write(dev, DEVADDR_SERDES, MII_BMCR, val);
- if (val < 0)
return val;
- struct dsa_pdata *dsa_pdata = dev_get_uclass_plat(dev);
- int val;
- val = mv88e6xxx_port_read(dev, port, PORT_REG_PHYS_CTRL);
- if (val < 0)
return val;
- val &= ~(PORT_REG_PHYS_CTRL_SPD_MASK |
- val |= PORT_REG_PHYS_CTRL_FC_FORCE |
- if (priv->id == PORT_SWITCH_ID_6071) {
- } else {
The speed and duplex are available in struct phy_device which is passed to mv88e6xxx_port_enable() for all ports, so why hack them?
- if (port == dsa_pdata->cpu_port)
- return mv88e6xxx_port_write(dev, port, PORT_REG_PHYS_CTRL, val);
- This function is used to pre-configure the required register
- offsets, so that the indirect register access to the PHY registers
- is possible. This is necessary to be able to read the PHY ID
- while driver probing or in get_phy_id(). The globalN register
- offsets must be initialized correctly for a detected switch,
- otherwise detection of the PHY ID won't work!
- priv->port_reg_base = 0x10;
- priv->id = mv88e6xxx_get_switch_id(dev);
- if (priv->id != 0xfff0) {
- priv->port_reg_base = 0x08;
- dev_warn(dev, "%s Unknown ID 0x%x\n", __func__, priv->id);
- return -ENODEV;
- return mv88e6xxx_phy_read_indirect(dev->parent, DEVADDR_PHY(addr),
int reg, u16 val)
- return mv88e6xxx_phy_write_indirect(dev->parent, DEVADDR_PHY(addr),
Please align MDIO_DEVAD_NONE to the open bracket.
- .read = mv88e6xxx_mdio_read,
- .write = mv88e6xxx_mdio_write,
- char name[32];
- static int num_devices;
- sprintf(name, "mv88e6xxx-mdio-%d", num_devices++);
- device_set_name(dev, name);
- .name = "mv88e6xxx_mdio",
- .id = UCLASS_MDIO,
- .ops = &mv88e6xxx_mdio_ops,
- .bind = mv88e6xxx_mdio_bind,
- .priv_auto = sizeof(struct mv88e6xxx_priv),
You are not using dev_get_priv(dev) with dev == the MDIO controller udevice. You are always calling phy_read|write_indirect with dev->parent, and calling dev_get_priv() on that. So you are allocating private data for nothing.
- .plat_auto = sizeof(struct mdio_perdev_priv),
- int val, ret;
- dev_dbg(dev, "%s P%d phy:0x%08x %s\n", __func__, port,
What if it's not a PHY port?
- val = mv88e6xxx_phy_read(dev, port, PHY_REG_CTRL1);
- if (val < 0)
return val;
- val = bitfield_replace(val, priv->phy_ctrl1_en_det_shift,
- val = mv88e6xxx_phy_write(dev, port, PHY_REG_CTRL1, val);
- if (val < 0)
return val;
- /* enable port */
- val = mv88e6xxx_port_read(dev, port, PORT_REG_CTRL);
- if (val < 0)
return val;
- val = bitfield_replace(val, PORT_REG_CTRL_PSTATE_SHIFT,
- val = mv88e6xxx_port_write(dev, port, PORT_REG_CTRL, val);
- if (val < 0)
return val;
- /* configure RGMII delays for fixed link */
- if (phy->phy_id == PHY_FIXED_ID) {
The 5 and the 4 are PORT_REG_PHYS_CTRL_LINK_VALUE | PORT_REG_PHYS_CTRL_LINK_FORCE, right? This makes either this or this assignment from mv88e6xxx_fixed_port_setup() redundant:
if (port == dsa_pdata->cpu_port) val |= PORT_REG_PHYS_CTRL_LINK_VALUE | PORT_REG_PHYS_CTRL_LINK_FORCE;
I'd prefer you keep the macros as opposed to the magic values, but force the link unconditionally for all fixed ports, rather than just for the CPU port. There might come support for cascaded DSA ports in the future, and this entire shebang will need to be patched otherwise.
if (ret < 0)
return ret;
All of this logic from the "if" branch can be moved into mv88e6xxx_fixed_port_setup().
if (ret < 0)
return ret;
- if (port == dsa_pdata->cpu_port) {
if (val < 0)
return val;
if (val < 0)
return val;
Since you don't use DSA/EDSA tags and you are quite averse to them, I don't think you need to set the CPUDest.
if (val < 0)
return val;
if (val < 0)
return val;
You can/should initialize the SERDES regardless of whether this is the CPU port or not, if the C_MODE dictates so. Otherwise said, the "if (port == dsa_pdata->cpu_port)" check should disappear.
Additionally, you should validate that phy->interface matches what the C_MODE reports for this port (I understand that changing the C_MODE is possible but not exactly without its issues), and report an error on mismatch, to avoid people scratching their heads.
- int val;
- dev_dbg(dev, "%s P%d phy:0x%x\n", __func__, port, phy->phy_id);
- if (val < 0)
return;
- if (val < 0)
return;
The assignment of "val" and then its checking is quite useless here, either print an error or remove it.
- .port_enable = mv88e6xxx_port_enable,
- .port_disable = mv88e6xxx_port_disable,
- struct udevice *mdev;
- ofnode node, mdios;
- const char *name;
- int ret;
- /* bind phy ports of mdios child node to mv88e6xxx_mdio device */
- mdios = dev_read_subnode(dev, "mdios");
- if (!ofnode_valid(mdios))
I wrote a long, angry comment about the parsing of this "mdios" container node. Please squash the fixup from patch 8/8 into the code here, I just wasted 10 minutes which I'm not getting back.
- ofnode_for_each_subnode(node, mdios) {
"mv88e6xxx_mdio",
name, node, NULL);
if (ret) {
continue;
if (ret) {
continue;
- return ret;
- int ret;
- if (!master)
return -ENODEV;
Remove this.
You could consider treating the 'status = "disabled";' case, however. Look at sja1105_probe() for example.
- dev_dbg(dev, "%s master:%s\n", __func__, master->name);
Useless variable, please remove it and stop looking at it in probe().
- /* probe internal mdio bus */
- ret = mv88e6xxx_probe_mdio(dev);
- if (ret)
return ret;
- ret = mv88e6xxx_priv_reg_offs_pre_init(dev);
- if (ret)
return ret;
- dev_dbg(dev, "ID=0x%x PORT_BASE=0x%02x GLOBAL1=0x%02x GLOBAL2=0x%02x\n",
- switch (priv->id) {
- case PORT_SWITCH_ID_6096:
- case PORT_SWITCH_ID_6097:
- case PORT_SWITCH_ID_6172:
- case PORT_SWITCH_ID_6176:
- case PORT_SWITCH_ID_6240:
- case PORT_SWITCH_ID_6352:
break;
- case PORT_SWITCH_ID_6020:
- case PORT_SWITCH_ID_6070:
- case PORT_SWITCH_ID_6071:
- case PORT_SWITCH_ID_6220:
- case PORT_SWITCH_ID_6250:
- case PORT_SWITCH_ID_6320:
break;
- default:
return -ENODEV;
- ret = mv88e6xxx_switch_reset(dev);
- if (ret < 0)
return ret;
- dsa_set_tagging(dev, 0, 0);
Just don't call this, it doesn't do anything.
- { .compatible = "marvell,mv88e6085" },
- .name = "mv88e6xxx",
- .id = UCLASS_DSA,
- .of_match = mv88e6xxx_ids,
- .probe = mv88e6xxx_probe,
- .ops = &mv88e6xxx_dsa_ops,
2.25.1
On Tue, Oct 4, 2022 at 4:48 PM Vladimir Oltean vladimir.oltean@nxp.com wrote:
v5:
v4:
v3:
v2:
+config MV88E6XXX
help
int time;
int val;
u8 port;
if (val < 0)
return val;
if (val < 0)
return val;
udelay(2000);
/* Reset switch */
if (val < 0)
return val;
if (val < 0)
return val;
ok - I will clean up this code taken from original driver
break;
udelay(1000);
if (!time)
return -ETIMEDOUT;
int val;
if (val < 0)
return val;
if (val < 0)
return val;
if (val < 0)
return val;
int val;
if (val < 0)
return val;
} else {
I think it likely makes sense to just remove mv88e6xxx_fixed_port_setup taken from the original driver due to the redundancy you point out later.
For fixed ports, I would expect phy->speed and phy->duplex to be set for fixed ports when port_enable is called but I find speed=0 and duplex=-1 instead. Do you know why these are not getting passed in per the fixed config in dt?
Maybe I should be ignoring speed/duplex/flow-control and just leaving the register alone as it defaults to auto-negotiate?
return -ENODEV;
int reg, u16 val)
char name[32];
.id = UCLASS_MDIO,
int val, ret;
if (val < 0)
return val;
if (val < 0)
return val;
/* enable port */
if (val < 0)
return val;
if (val < 0)
return val;
if (ret < 0)
return ret;
Right... or just roll this fixed port setup code into port_enable
if (ret < 0)
return ret;
if (val < 0)
return val;
if (val < 0)
return val;
if (val < 0)
return val;
if (val < 0)
return val;
It seems to me that this C_MODE validation should be done only for fixed phy's right?
Is this what you had in mind? if (phy->phy_id == PHY_FIXED_ID) { switch (phy->interface) { case PHY_INTERFACE_MODE_RGMII: case PHY_INTERFACE_MODE_RGMII_RXID: case PHY_INTERFACE_MODE_RGMII_TXID: case PHY_INTERFACE_MODE_RGMII_ID: if (val != PORT_REG_STATUS_CMODE_RGMII) goto mismatch; break; case PHY_INTERFACE_MODE_1000BASEX: if (val != PORT_REG_STATUS_CMODE_1000BASE_X) goto mismatch; break; mismatch: default: dev_err(dev, "Mismatched PHY mode %s on port %d!\n",
phy_string_for_interface(phy->interface), port); break; } }
int val;
if (val < 0)
return;
if (val < 0)
return;
ofnode node, mdios;
const char *name;
int ret;
ya, I'm really sorry about that - I squashed the mdio parsing changes you requested into the wrong patch and wasted your time (not to mention made you angry by appearing to ignore your previous request)
At one time I was merely trying to convert the existing drivers/net/phy/mv88e61xx.c driver to DM/DSA and not rewrite it and I think that was clear as you originally gave me your Reviewed-By tag on v2 [1]. However, that was a long time ago and after a delay on my part submitting a v3 you started to ask me to clean up some things from the original driver while I was at it (which I should have just done to begin with). I hope we are getting close here. I'm not all that familiar with switch architecture so this has been a much larger effort than I thought it would be but I'm happy that we have at least one other board interested in using this DM/DSA version of the driver and would like to keep making progress on obsoleting the original non DM driver.
All of your comments in this review make sense to me with the exception of the C_MODE validation and fixed port config (above).
Best Regards,
Tim
Tim [1] https://lists.denx.de/pipermail/u-boot/2022-May/484368.html
"mv88e6xxx_mdio",
name, node, NULL);
if (ret) {
continue;
if (ret) {
continue;
return ret;
int ret;
if (!master)
return -ENODEV;
Remove this.
if (ret)
return ret;
if (ret)
return ret;
switch (priv->id) {
break;
break;
default:
return -ENODEV;
if (ret < 0)
return ret;
.id = UCLASS_DSA,
2.25.1
Add MV88E61XX DSA support: - update dt: U-Boot dsa driver requires different device-tree syntax than the linux driver in order to link the dsa ports to the mdio bus. - update defconfig - replace mv88e61xx_hw_reset weak override with board_phy_config support for mv88e61xx configuration that is outside the scope of the DSA driver
Note that the dt changes were not placed in a u-boot.dtsi as it is intended that these changes get merged with the Linux dt's.
Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Fabio Estevam festevam@denx.de --- v5: - fix typo in defconfig s/MV88E61XX/MV88E6XXX - added Fabio's rb tag - added note to commit log v4: - use standard Linux internal MDIO dt structure - use PHY_FIXED_ID define v3: - move mdio's mdio@0 subnode v2: no changes --- arch/arm/dts/imx6qdl-gw5904.dtsi | 31 +++++++++++++++ board/gateworks/gw_ventana/gw_ventana.c | 50 +++++++++---------------- configs/gwventana_gw5904_defconfig | 7 ++-- drivers/net/mv88e6xxx.c | 29 ++++++-------- 4 files changed, 64 insertions(+), 53 deletions(-)
diff --git a/arch/arm/dts/imx6qdl-gw5904.dtsi b/arch/arm/dts/imx6qdl-gw5904.dtsi index 612b6e068e28..487dd7648274 100644 --- a/arch/arm/dts/imx6qdl-gw5904.dtsi +++ b/arch/arm/dts/imx6qdl-gw5904.dtsi @@ -212,6 +212,27 @@ compatible = "marvell,mv88e6085"; reg = <0>;
+ mdio { + #address-cells = <1>; + #size-cells = <0>; + + sw_phy0: ethernet-phy@0 { + reg = <0x0>; + }; + + sw_phy1: ethernet-phy@1 { + reg = <0x1>; + }; + + sw_phy2: ethernet-phy@2 { + reg = <0x2>; + }; + + sw_phy3: ethernet-phy@3 { + reg = <0x3>; + }; + }; + ports { #address-cells = <1>; #size-cells = <0>; @@ -219,27 +240,37 @@ port@0 { reg = <0>; label = "lan4"; + phy-handle = <&sw_phy0>; };
port@1 { reg = <1>; label = "lan3"; + phy-handle = <&sw_phy1>; };
port@2 { reg = <2>; label = "lan2"; + phy-handle = <&sw_phy2>; };
port@3 { reg = <3>; label = "lan1"; + phy-handle = <&sw_phy3>; };
port@5 { reg = <5>; label = "cpu"; ethernet = <&fec>; + phy-mode = "rgmii-id"; + + fixed-link { + speed = <1000>; + full-duplex; + }; }; }; }; diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c index 99f52b9953e2..1c3da2c82707 100644 --- a/board/gateworks/gw_ventana/gw_ventana.c +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -83,44 +83,30 @@ int board_phy_config(struct phy_device *phydev) break; }
+ /* Fixed PHY: for GW5904/GW5909 this is Marvell 88E6176 GbE Switch */ + if (phydev->phy_id == PHY_FIXED_ID && + (board_type == GW5904 || board_type == GW5909)) { + struct mii_dev *bus = miiphy_get_dev_by_name("mdio"); + + puts("MV88E61XX "); + /* GPIO[0] output CLK125 for RGMII_REFCLK */ + bus->write(bus, 0x1c, 0, 0x1a, (1 << 15) | (0x62 << 8) | 0xfe); + bus->write(bus, 0x1c, 0, 0x1a, (1 << 15) | (0x68 << 8) | 7); + + /* Port 0-3 LED configuration: Table 80/82 */ + /* LED configuration: 7:4-green (8=Activity) 3:0 amber (8=Link) */ + bus->write(bus, 0x10, 0, 0x16, 0x8088); + bus->write(bus, 0x11, 0, 0x16, 0x8088); + bus->write(bus, 0x12, 0, 0x16, 0x8088); + bus->write(bus, 0x13, 0, 0x16, 0x8088); + } + if (phydev->drv->config) phydev->drv->config(phydev);
return 0; }
-#ifdef CONFIG_MV88E61XX_SWITCH -int mv88e61xx_hw_reset(struct phy_device *phydev) -{ - struct mii_dev *bus = phydev->bus; - - /* GPIO[0] output, CLK125 */ - debug("enabling RGMII_REFCLK\n"); - bus->write(bus, 0x1c /*MV_GLOBAL2*/, 0, - 0x1a /*MV_SCRATCH_MISC*/, - (1 << 15) | (0x62 /*MV_GPIO_DIR*/ << 8) | 0xfe); - bus->write(bus, 0x1c /*MV_GLOBAL2*/, 0, - 0x1a /*MV_SCRATCH_MISC*/, - (1 << 15) | (0x68 /*MV_GPIO01_CNTL*/ << 8) | 7); - - /* RGMII delay - Physical Control register bit[15:14] */ - debug("setting port%d RGMII rx/tx delay\n", CONFIG_MV88E61XX_CPU_PORT); - /* forced 1000mbps full-duplex link */ - bus->write(bus, 0x10 + CONFIG_MV88E61XX_CPU_PORT, 0, 1, 0xc0fe); - phydev->autoneg = AUTONEG_DISABLE; - phydev->speed = SPEED_1000; - phydev->duplex = DUPLEX_FULL; - - /* LED configuration: 7:4-green (8=Activity) 3:0 amber (8=Link) */ - bus->write(bus, 0x10, 0, 0x16, 0x8088); - bus->write(bus, 0x11, 0, 0x16, 0x8088); - bus->write(bus, 0x12, 0, 0x16, 0x8088); - bus->write(bus, 0x13, 0, 0x16, 0x8088); - - return 0; -} -#endif // CONFIG_MV88E61XX_SWITCH - #if defined(CONFIG_VIDEO_IPUV3) static void enable_hdmi(struct display_info_t const *dev) { diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index fb5870fa5803..50115b21e263 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -109,13 +109,12 @@ CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_PHYLIB=y -CONFIG_MV88E61XX_SWITCH=y -CONFIG_MV88E61XX_CPU_PORT=5 -CONFIG_MV88E61XX_PHY_PORTS=0xf -CONFIG_MV88E61XX_FIXED_PORTS=0x0 +CONFIG_PHY_FIXED=y CONFIG_DM_MDIO=y +CONFIG_DM_DSA=y CONFIG_E1000=y CONFIG_FEC_MXC=y +CONFIG_MV88E6XXX=y CONFIG_MII=y CONFIG_PCI=y CONFIG_PCIE_IMX=y diff --git a/drivers/net/mv88e6xxx.c b/drivers/net/mv88e6xxx.c index e59e2464c641..09ce6dd1142d 100644 --- a/drivers/net/mv88e6xxx.c +++ b/drivers/net/mv88e6xxx.c @@ -728,31 +728,26 @@ static const struct dsa_ops mv88e6xxx_dsa_ops = { static int mv88e6xxx_probe_mdio(struct udevice *dev) { struct udevice *mdev; - ofnode node, mdios; const char *name; + ofnode node; int ret;
- /* bind phy ports of mdios child node to mv88e6xxx_mdio device */ - mdios = dev_read_subnode(dev, "mdios"); - if (!ofnode_valid(mdios)) + /* bind phy ports of mdio child node to mv88e6xxx_mdio device */ + node = dev_read_subnode(dev, "mdio"); + if (!ofnode_valid(node)) return 0;
- ofnode_for_each_subnode(node, mdios) { - name = ofnode_get_name(node); - ret = device_bind_driver_to_node(dev, - "mv88e6xxx_mdio", - name, node, NULL); - if (ret) { - dev_err(dev, "failed to bind %s: %d\n", name, ret); - continue; - } - + name = ofnode_get_name(node); + ret = device_bind_driver_to_node(dev, + "mv88e6xxx_mdio", + name, node, NULL); + if (ret) { + dev_err(dev, "failed to bind %s: %d\n", name, ret); + } else { /* need to probe it as there is no compatible to do so */ ret = uclass_get_device_by_ofnode(UCLASS_MDIO, node, &mdev); - if (ret) { + if (ret) dev_err(dev, "failed to probe %s: %d\n", name, ret); - continue; - } }
return ret;
Not really correct. Better said, U-Boot requires a more restrictive subset of what DT bindings Linux supports, for sake of simplicity of the code. It is equally valid to link ports to their internal PHY by phy-handle in the Linux mv88e6xxx driver.
- update defconfig
v5:
v4:
v3:
v2: no changes
mdio {
#size-cells = <0>;
reg = <0x0>;
reg = <0x1>;
reg = <0x2>;
reg = <0x3>;
phy-handle = <&sw_phy0>; }; port@1 { reg = <1>; label = "lan3";
phy-handle = <&sw_phy1>; }; port@2 { reg = <2>; label = "lan2";
phy-handle = <&sw_phy2>; }; port@3 { reg = <3>; label = "lan1";
phy-handle = <&sw_phy3>; }; port@5 { reg = <5>; label = "cpu";
This is not used, please remove it.
ethernet = <&fec>;
fixed-link {
speed = <1000>;
full-duplex;
Binding looks good, thanks.
- /* Fixed PHY: for GW5904/GW5909 this is Marvell 88E6176 GbE Switch */
- if (phydev->phy_id == PHY_FIXED_ID &&
puts("MV88E61XX ");
Ugh. I'll have to get over this.
BTW, does this run before or after the switch driver getting probed? Don't you lose the config once you reset the switch? How do you ensure ordering?
return 0; }
- ofnode node; int ret;
- /* bind phy ports of mdio child node to mv88e6xxx_mdio device */
- node = dev_read_subnode(dev, "mdio");
- if (!ofnode_valid(node)) return 0;
"mv88e6xxx_mdio",
name, node, NULL);
if (ret) {
continue;
"mv88e6xxx_mdio",
name, node, NULL);
- if (ret) {
- } else { /* need to probe it as there is no compatible to do so */ ret = uclass_get_device_by_ofnode(UCLASS_MDIO, node, &mdev);
if (ret) {
continue;
return ret;
Please move this hunk into patch 7/8.
-- 2.25.1
On Tue, Oct 4, 2022 at 4:58 PM Vladimir Oltean vladimir.oltean@nxp.com wrote:
Agreed - I will update the commit message now that I understand the MDIO bindings correctly.
- update defconfig
v5:
v4:
v3:
v2: no changes
mdio {
#size-cells = <0>;
reg = <0x0>;
reg = <0x1>;
reg = <0x2>;
reg = <0x3>;
ok - will remove
ethernet = <&fec>;
fixed-link {
speed = <1000>;
full-duplex;
Great! Thanks for working through this with me. I will submit that hunk to the Linux dt as well.
puts("MV88E61XX ");
Yes, I know you don't like this code and I do plan on submitting a follow-up patch that adds some defines and/or functions that can be used to make it at least more readable. There are currently around 70 board files that use board_phy_config() to perform direct PHY register writes for gpio/led/pin config for things that are currently not defined well enough via bindings to do in drivers and they all read more or less like the above.
In all the NIC drivers I've looked at the driver probe function performs a phy-reset followed by binding internal mdios, then calls phy_config() at the end of the probe which hooks to the board_phy_config() function that has always been there for per-board obscure register config like this.
if (phydev->drv->config) phydev->drv->config(phydev); return 0;
<snip>
"mv88e6xxx_mdio",
name, node, NULL);
if (ret) {
continue;
"mv88e6xxx_mdio",
name, node, NULL);
if (ret) {
if (ret) {
continue;
} } return ret;
Yes, I apologize for this - I squashed the above into this board-specific patch instead of the mv88e6xxx driver patch which caused you to waste some time while reviwing the driver patch.
Best Regards,
Tim
Tim Harvey
Vladimir Oltean
