[U-Boot] [PATCH V3] dm: gpio: pca953x: introduce driver model support for pca953x
Introduce a new driver that supports driver model for pca953x. The pca953x chips are used as I2C I/O expanders. This driver is designed to support the following chips: " 4 bits: pca9536, pca9537 8 bits: max7310, max7315, pca6107, pca9534, pca9538, pca9554, pca9556, pca9557, pca9574, tca6408, xra1202 16 bits: max7312, max7313, pca9535, pca9539, pca9555, pca9575, tca6416 24 bits: tca6424 40 bits: pca9505, pca9698 " But for now this driver only supports max 24 bits and pca953x compatible chips. pca957x compatible chips are not supported now. These can be addressed when we need to add such support for the different chips. This driver has been tested on i.MX6 SoloX Sabreauto board with max7310 i2c expander using gpio command as following:
=>gpio status -a Bank gpio@30_: gpio@30_0: input: 1 [ ]
=> dm tree: i2c [ ] | | `-- i2c@021a8000 gpio [ ] | | |-- gpio@30 gpio [ ] | | `-- gpio@32
Signed-off-by: Peng Fan van.freenix@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Wenyou Yang wenyou.yang@atmel.com Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Cc: Purna Chandra Mandal purna.mandal@microchip.com Cc: Thomas Chou thomas@wytron.com.tw Cc: Bhuvanchandra DV bhuvanchandra.dv@toradex.com Cc: Andrea Scian andrea.scian@dave.eu Cc: Michal Simek michal.simek@xilinx.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Acked-by: Simon Glass sjg@chromium.org Tested-by: Michal Simek michal.simek@xilinx.com #on ZynqMP zcu102 ---
V3: Add Michal's tested by Take Michal's suggestion, use hex vaule for gpio@[x].
V2: change bank name according to Simon's comments.
drivers/gpio/Kconfig | 22 +++ drivers/gpio/Makefile | 2 + drivers/gpio/pca953x_gpio.c | 349 ++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 373 insertions(+) create mode 100644 drivers/gpio/pca953x_gpio.c
diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 2311309..8ff657c 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -112,4 +112,26 @@ config MVEBU_GPIO help Say yes here to support Marvell MVEBU (Armada XP/38x) GPIOs.
+config DM_PCA953X + bool "PCA95[357]x, PCA9698, TCA64xx, and MAX7310 I/O ports" + depends on DM_GPIO + help + Say yes here to provide access to several register-oriented + SMBus I/O expanders, made mostly by NXP or TI. Compatible + models include: + + 4 bits: pca9536, pca9537 + + 8 bits: max7310, max7315, pca6107, pca9534, pca9538, pca9554, + pca9556, pca9557, pca9574, tca6408, xra1202 + + 16 bits: max7312, max7313, pca9535, pca9539, pca9555, pca9575, + tca6416 + + 24 bits: tca6424 + + 40 bits: pca9505, pca9698 + + Now, max 24 bits chips and PCA953X compatible chips are + supported endmenu diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index ea6e2ed..a7a466c 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -11,6 +11,8 @@ obj-$(CONFIG_AXP_GPIO) += axp_gpio.o endif obj-$(CONFIG_DM_GPIO) += gpio-uclass.o
+obj-$(CONFIG_DM_PCA953X) += pca953x_gpio.o + obj-$(CONFIG_AT91_GPIO) += at91_gpio.o obj-$(CONFIG_ATMEL_PIO4) += atmel_pio4.o obj-$(CONFIG_INTEL_ICH6_GPIO) += intel_ich6_gpio.o diff --git a/drivers/gpio/pca953x_gpio.c b/drivers/gpio/pca953x_gpio.c new file mode 100644 index 0000000..1eeb4c8 --- /dev/null +++ b/drivers/gpio/pca953x_gpio.c @@ -0,0 +1,349 @@ +/* + * Take linux kernel driver drivers/gpio/gpio-pca953x.c for reference. + * + * Copyright (C) 2016 Peng Fan van.freenix@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + * + */ + +/* + * Note: + * The driver's compatible table is borrowed from Linux Kernel, + * but now max supported gpio pins is 24 and only PCA953X_TYPE + * is supported. PCA957X_TYPE is not supported now. + * Also the Polarity Inversion feature is not supported now. + * + * TODO: + * 1. Support PCA957X_TYPE + * 2. Support max 40 gpio pins + * 3. Support Plolarity Inversion + */ + +#include <common.h> +#include <errno.h> +#include <dm.h> +#include <fdtdec.h> +#include <i2c.h> +#include <malloc.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <dt-bindings/gpio/gpio.h> + +#define PCA953X_INPUT 0 +#define PCA953X_OUTPUT 1 +#define PCA953X_INVERT 2 +#define PCA953X_DIRECTION 3 + +#define PCA_GPIO_MASK 0x00FF +#define PCA_INT 0x0100 +#define PCA953X_TYPE 0x1000 +#define PCA957X_TYPE 0x2000 +#define PCA_TYPE_MASK 0xF000 +#define PCA_CHIP_TYPE(x) ((x) & PCA_TYPE_MASK) + +enum { + PCA953X_DIRECTION_IN, + PCA953X_DIRECTION_OUT, +}; + +#define MAX_BANK 3 +#define BANK_SZ 8 + +/* + * struct pca953x_info - Data for pca953x + * + * @dev: udevice structure for the device + * @addr: i2c slave address + * @invert: Polarity inversion or not + * @gpio_count: the number of gpio pins that the device supports + * @chip_type: indicate the chip type,PCA953X or PCA957X + * @bank_count: the number of banks that the device supports + * @reg_output: array to hold the value of output registers + * @reg_direction: array to hold the value of direction registers + */ +struct pca953x_info { + struct udevice *dev; + unsigned int addr; + unsigned int invert; + unsigned int gpio_count; + unsigned int chip_type; + unsigned int bank_count; + u8 reg_output[MAX_BANK]; + u8 reg_direction[MAX_BANK]; +}; + +static int pca953x_write_single(struct udevice *dev, int reg, u8 val, + int offset) +{ + struct pca953x_info *info = dev_get_platdata(dev); + int bank_shift = fls((info->gpio_count - 1) / BANK_SZ); + int off = offset / BANK_SZ; + int ret = 0; + + ret = dm_i2c_write(dev, (reg << bank_shift) + off, &val, 1); + if (ret) { + dev_err(dev, "%s error\n", __func__); + return ret; + } + + return 0; +} + +static int pca953x_read_single(struct udevice *dev, int reg, u8 *val, + int offset) +{ + struct pca953x_info *info = dev_get_platdata(dev); + int bank_shift = fls((info->gpio_count - 1) / BANK_SZ); + int off = offset / BANK_SZ; + int ret; + u8 byte; + + ret = dm_i2c_read(dev, (reg << bank_shift) + off, &byte, 1); + if (ret) { + dev_err(dev, "%s error\n", __func__); + return ret; + } + + *val = byte; + + return 0; +} + +static int pca953x_read_regs(struct udevice *dev, int reg, u8 *val) +{ + struct pca953x_info *info = dev_get_platdata(dev); + int ret = 0; + + if (info->gpio_count <= 8) { + ret = dm_i2c_read(dev, reg, val, 1); + } else if (info->gpio_count <= 16) { + ret = dm_i2c_read(dev, reg << 1, val, info->bank_count); + } else { + dev_err(dev, "Unsupported now\n"); + return -EINVAL; + } + + return ret; +} + +static int pca953x_is_output(struct udevice *dev, int offset) +{ + struct pca953x_info *info = dev_get_platdata(dev); + + int bank = offset / BANK_SZ; + int off = offset % BANK_SZ; + + /*0: output; 1: input */ + return !(info->reg_direction[bank] & (1 << off)); +} + +static int pca953x_get_value(struct udevice *dev, unsigned offset) +{ + int ret; + u8 val = 0; + + ret = pca953x_read_single(dev, PCA953X_INPUT, &val, offset); + if (ret) + return ret; + + return (val >> offset) & 0x1; +} + +static int pca953x_set_value(struct udevice *dev, unsigned offset, + int value) +{ + struct pca953x_info *info = dev_get_platdata(dev); + int bank = offset / BANK_SZ; + int off = offset % BANK_SZ; + u8 val; + int ret; + + if (value) + val = info->reg_output[bank] | (1 << off); + else + val = info->reg_output[bank] & ~(1 << off); + + ret = pca953x_write_single(dev, PCA953X_OUTPUT, val, offset); + if (ret) + return ret; + + info->reg_output[bank] = val; + + return 0; +} + +static int pca953x_set_direction(struct udevice *dev, unsigned offset, int dir) +{ + struct pca953x_info *info = dev_get_platdata(dev); + int bank = offset / BANK_SZ; + int off = offset % BANK_SZ; + u8 val; + int ret; + + if (dir == PCA953X_DIRECTION_IN) + val = info->reg_direction[bank] | (1 << off); + else + val = info->reg_direction[bank] & ~(1 << off); + + ret = pca953x_write_single(dev, PCA953X_DIRECTION, val, offset); + if (ret) + return ret; + + info->reg_direction[bank] = val; + + return 0; +} + +static int pca953x_direction_input(struct udevice *dev, unsigned offset) +{ + return pca953x_set_direction(dev, offset, PCA953X_DIRECTION_IN); +} + +static int pca953x_direction_output(struct udevice *dev, unsigned offset, + int value) +{ + /* Configure output value. */ + pca953x_set_value(dev, offset, value); + + /* Configure direction as output. */ + pca953x_set_direction(dev, offset, PCA953X_DIRECTION_OUT); + + return 0; +} + +static int pca953x_get_function(struct udevice *dev, unsigned offset) +{ + if (pca953x_is_output(dev, offset)) + return GPIOF_OUTPUT; + else + return GPIOF_INPUT; +} + +static int pca953x_xlate(struct udevice *dev, struct gpio_desc *desc, + struct fdtdec_phandle_args *args) +{ + desc->offset = args->args[0]; + desc->flags = args->args[1] & GPIO_ACTIVE_LOW ? GPIOD_ACTIVE_LOW : 0; + + return 0; +} + +static const struct dm_gpio_ops pca953x_ops = { + .direction_input = pca953x_direction_input, + .direction_output = pca953x_direction_output, + .get_value = pca953x_get_value, + .set_value = pca953x_set_value, + .get_function = pca953x_get_function, + .xlate = pca953x_xlate, +}; + +static int pca953x_probe(struct udevice *dev) +{ + struct pca953x_info *info = dev_get_platdata(dev); + struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); + struct dm_i2c_chip *chip = dev_get_parent_platdata(dev); + char name[32], *str; + fdt_addr_t addr; + ulong driver_data; + int ret; + + if (!info) { + dev_err(dev, "platdata not ready\n"); + return -ENOMEM; + } + + if (!chip) { + dev_err(dev, "i2c not ready\n"); + return -ENODEV; + } + + addr = dev_get_addr(dev); + if (addr == FDT_ADDR_T_NONE) + return -ENODEV; + + info->addr = (unsigned int)addr; + + driver_data = dev_get_driver_data(dev); + + info->gpio_count = driver_data & PCA_GPIO_MASK; + if (info->gpio_count > MAX_BANK * BANK_SZ) { + dev_err(dev, "Max support %d pins now\n", MAX_BANK * BANK_SZ); + return -EINVAL; + } + + info->chip_type = PCA_CHIP_TYPE(driver_data); + if (info->chip_type != PCA953X_TYPE) { + dev_err(dev, "Only support PCA953X chip type now.\n"); + return -EINVAL; + } + + info->bank_count = DIV_ROUND_UP(info->gpio_count, BANK_SZ); + + ret = pca953x_read_regs(dev, PCA953X_OUTPUT, info->reg_output); + if (ret) { + dev_err(dev, "Error reading output register\n"); + return ret; + } + + ret = pca953x_read_regs(dev, PCA953X_DIRECTION, info->reg_direction); + if (ret) { + dev_err(dev, "Error reading direction register\n"); + return ret; + } + + snprintf(name, sizeof(name), "gpio@%x_", info->addr); + str = strdup(name); + if (!str) + return -ENOMEM; + uc_priv->bank_name = str; + uc_priv->gpio_count = info->gpio_count; + + dev_dbg(dev, "%s is ready\n", str); + + return 0; +} + +#define OF_953X(__nrgpio, __int) (ulong)(__nrgpio | PCA953X_TYPE | __int) +#define OF_957X(__nrgpio, __int) (ulong)(__nrgpio | PCA957X_TYPE | __int) + +static const struct udevice_id pca953x_ids[] = { + { .compatible = "nxp,pca9505", .data = OF_953X(40, PCA_INT), }, + { .compatible = "nxp,pca9534", .data = OF_953X(8, PCA_INT), }, + { .compatible = "nxp,pca9535", .data = OF_953X(16, PCA_INT), }, + { .compatible = "nxp,pca9536", .data = OF_953X(4, 0), }, + { .compatible = "nxp,pca9537", .data = OF_953X(4, PCA_INT), }, + { .compatible = "nxp,pca9538", .data = OF_953X(8, PCA_INT), }, + { .compatible = "nxp,pca9539", .data = OF_953X(16, PCA_INT), }, + { .compatible = "nxp,pca9554", .data = OF_953X(8, PCA_INT), }, + { .compatible = "nxp,pca9555", .data = OF_953X(16, PCA_INT), }, + { .compatible = "nxp,pca9556", .data = OF_953X(8, 0), }, + { .compatible = "nxp,pca9557", .data = OF_953X(8, 0), }, + { .compatible = "nxp,pca9574", .data = OF_957X(8, PCA_INT), }, + { .compatible = "nxp,pca9575", .data = OF_957X(16, PCA_INT), }, + { .compatible = "nxp,pca9698", .data = OF_953X(40, 0), }, + + { .compatible = "maxim,max7310", .data = OF_953X(8, 0), }, + { .compatible = "maxim,max7312", .data = OF_953X(16, PCA_INT), }, + { .compatible = "maxim,max7313", .data = OF_953X(16, PCA_INT), }, + { .compatible = "maxim,max7315", .data = OF_953X(8, PCA_INT), }, + + { .compatible = "ti,pca6107", .data = OF_953X(8, PCA_INT), }, + { .compatible = "ti,tca6408", .data = OF_953X(8, PCA_INT), }, + { .compatible = "ti,tca6416", .data = OF_953X(16, PCA_INT), }, + { .compatible = "ti,tca6424", .data = OF_953X(24, PCA_INT), }, + + { .compatible = "onsemi,pca9654", .data = OF_953X(8, PCA_INT), }, + + { .compatible = "exar,xra1202", .data = OF_953X(8, 0), }, + { } +}; + +U_BOOT_DRIVER(pca953x) = { + .name = "pca953x", + .id = UCLASS_GPIO, + .ops = &pca953x_ops, + .probe = pca953x_probe, + .platdata_auto_alloc_size = sizeof(struct pca953x_info), + .of_match = pca953x_ids, +};
+config DM_PCA953X
- bool "PCA95[357]x, PCA9698, TCA64xx, and MAX7310 I/O ports"
- depends on DM_GPIO
- help
models include:
tca6416
24 bits: tca6424
supported
- Take linux kernel driver drivers/gpio/gpio-pca953x.c for reference.
- Copyright (C) 2016 Peng Fan van.freenix@gmail.com
- Note:
- The driver's compatible table is borrowed from Linux Kernel,
- but now max supported gpio pins is 24 and only PCA953X_TYPE
- is supported. PCA957X_TYPE is not supported now.
- Also the Polarity Inversion feature is not supported now.
- TODO:
- Support PCA957X_TYPE
- Support max 40 gpio pins
- Support Plolarity Inversion
+enum {
- PCA953X_DIRECTION_IN,
- PCA953X_DIRECTION_OUT,
- struct pca953x_info - Data for pca953x
- @dev: udevice structure for the device
- @addr: i2c slave address
- @invert: Polarity inversion or not
- @gpio_count: the number of gpio pins that the device supports
- @chip_type: indicate the chip type,PCA953X or PCA957X
- @bank_count: the number of banks that the device supports
- @reg_output: array to hold the value of output registers
- @reg_direction: array to hold the value of direction registers
- struct udevice *dev;
- unsigned int addr;
- unsigned int invert;
- unsigned int gpio_count;
- unsigned int chip_type;
- unsigned int bank_count;
- u8 reg_output[MAX_BANK];
- u8 reg_direction[MAX_BANK];
int offset)
- struct pca953x_info *info = dev_get_platdata(dev);
- int bank_shift = fls((info->gpio_count - 1) / BANK_SZ);
- int off = offset / BANK_SZ;
- int ret = 0;
- ret = dm_i2c_write(dev, (reg << bank_shift) + off, &val, 1);
- if (ret) {
return ret;
int offset)
- int ret;
- u8 byte;
- ret = dm_i2c_read(dev, (reg << bank_shift) + off, &byte, 1);
- if (ret) {
return ret;
- *val = byte;
- int ret = 0;
- if (info->gpio_count <= 8) {
- } else if (info->gpio_count <= 16) {
- } else {
return -EINVAL;
- return ret;
- int bank = offset / BANK_SZ;
- int off = offset % BANK_SZ;
- /*0: output; 1: input */
- return !(info->reg_direction[bank] & (1 << off));
- int ret;
- u8 val = 0;
- ret = pca953x_read_single(dev, PCA953X_INPUT, &val, offset);
- if (ret)
return ret;
- return (val >> offset) & 0x1;
int value)
- u8 val;
- int ret;
- if (value)
- else
- ret = pca953x_write_single(dev, PCA953X_OUTPUT, val, offset);
- if (ret)
return ret;
- info->reg_output[bank] = val;
- u8 val;
- int ret;
- if (dir == PCA953X_DIRECTION_IN)
- else
- ret = pca953x_write_single(dev, PCA953X_DIRECTION, val, offset);
- if (ret)
return ret;
- info->reg_direction[bank] = val;
- return pca953x_set_direction(dev, offset, PCA953X_DIRECTION_IN);
int value)
- /* Configure output value. */
- pca953x_set_value(dev, offset, value);
- /* Configure direction as output. */
- pca953x_set_direction(dev, offset, PCA953X_DIRECTION_OUT);
- if (pca953x_is_output(dev, offset))
- else
return GPIOF_INPUT;
- desc->offset = args->args[0];
- desc->flags = args->args[1] & GPIO_ACTIVE_LOW ? GPIOD_ACTIVE_LOW : 0;
- .direction_input = pca953x_direction_input,
- .direction_output = pca953x_direction_output,
- .get_value = pca953x_get_value,
- .set_value = pca953x_set_value,
- .get_function = pca953x_get_function,
- .xlate = pca953x_xlate,
- struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev);
- struct dm_i2c_chip *chip = dev_get_parent_platdata(dev);
- char name[32], *str;
- fdt_addr_t addr;
- ulong driver_data;
- int ret;
- if (!info) {
return -ENOMEM;
- if (!chip) {
return -ENODEV;
- addr = dev_get_addr(dev);
addr = fdtdec_get_int(gd->fdt_blob, dev->of_offset, "reg", 0);
Please use this here based on that thread with Przemyslaw.
Thanks, Michal
Michal Simek
Peng Fan
