[U-Boot] [PATCH v3 10/14] rockchip: dts: Enable SARADC for rk3288-popmetal
Spam detection software, running on the system "lists.denx.de", has identified this incoming email as possible spam. The original message has been attached to this so you can view it or label similar future email. If you have any questions, see @@CONTACT_ADDRESS@@ for details.
Content preview: Enable the SARADC for download key pressed detect. Signed-off-by: David Wu david.wu@rock-chips.com --- Changes in v3: - Add commit message [...]
Content analysis details: (5.6 points, 5.0 required)
pts rule name description ---- ---------------------- -------------------------------------------------- 0.6 RCVD_IN_SORBS_WEB RBL: SORBS: sender is an abusable web server [58.22.7.114 listed in dnsbl.sorbs.net] 2.6 RCVD_IN_SBL RBL: Received via a relay in Spamhaus SBL [211.157.147.132 listed in zen.spamhaus.org] 2.4 RCVD_IN_MSPIKE_L5 RBL: Very bad reputation (-5) [211.157.147.132 listed in bl.mailspike.net] 0.0 RCVD_IN_MSPIKE_BL Mailspike blacklisted
0.6 RCVD_IN_SORBS_WEB RBL: SORBS: sender is an abusable web server [58.22.7.114 listed in dnsbl.sorbs.net] 2.6 RCVD_IN_SBL RBL: Received via a relay in Spamhaus SBL [211.157.147.132 listed in zen.spamhaus.org] 2.4 RCVD_IN_MSPIKE_L5 RBL: Very bad reputation (-5) [211.157.147.132 listed in bl.mailspike.net] 0.0 RCVD_IN_MSPIKE_BL Mailspike blacklisted Enable the SARADC for download key pressed detect.
Changes in v3:
Changes in v2: None
arch/arm/dts/rk3288-popmetal.dtsi | 4 ++++ 1 file changed, 4 insertions(+)
Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Changes in v3:
Changes in v2: None
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Signed-off-by: David Wu david.wu@rock-chips.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Changes in v3:
Changes in v2: None
Applied to u-boot-rockchip, thanks!
David Wu
Philipp Tomsich
