[PATCH v2] efi_selftests: fix controllers repeated selftesting
Running the controller selftest more than one times fails with
=> setenv efi_selftest 'controllers' && bootefi selftest Testing EFI API implementation Selected test: 'controllers' Setting up 'controllers' Setting up 'controllers' succeeded Executing 'controllers' Executing 'controllers' succeeded Summary: 0 failures
=> bootefi selftest Testing EFI API implementation Selected test: 'controllers' Setting up 'controllers' lib/efi_selftest/efi_selftest_controllers.c(280): ERROR: InstallProtocolInterface failed lib/efi_selftest/efi_selftest.c(89): ERROR: Setting up 'controllers' failed Summary: 1 failures
There are multiple reason for this. We don't uninstall the binding interface from the controller handle and we don't reset the handle pointers either. So let's uninstall all the protocols properly and reset the handles to NULL on setup().
While at it add a forgotten check when uninstalling protocols from the handle_controller and make sure the number of child controllers is 0
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- Changes since v1: - Move the binding protocol removal to .teardown() - return EFI_ST_FAILURE if the last count_child_controllers() fails
lib/efi_selftest/efi_selftest_controllers.c | 26 ++++++++++++++++++++- 1 file changed, 25 insertions(+), 1 deletion(-)
diff --git a/lib/efi_selftest/efi_selftest_controllers.c b/lib/efi_selftest/efi_selftest_controllers.c index d2bbd1c4f65b..79bc86fb0c3a 100644 --- a/lib/efi_selftest/efi_selftest_controllers.c +++ b/lib/efi_selftest/efi_selftest_controllers.c @@ -271,6 +271,8 @@ static int setup(const efi_handle_t img_handle, efi_status_t ret;
boottime = systable->boottime; + handle_controller = NULL; + handle_driver = NULL;
/* Create controller handle */ ret = boottime->install_protocol_interface( @@ -402,14 +404,36 @@ static int execute(void) /* Check number of child controllers */ ret = count_child_controllers(handle_controller, &guid_controller, &count); - if (ret == EFI_SUCCESS) + if (ret == EFI_SUCCESS || count != 0) { efi_st_error("Uninstall failed\n"); + return EFI_ST_FAILURE; + } + + return EFI_ST_SUCCESS; }
+ /* + * Tear down unit test. + * + */ +static int teardown(void) +{ + efi_status_t ret; + /* Uninstall binding protocol */ + ret = boottime->uninstall_protocol_interface(handle_driver, + &guid_driver_binding_protocol, + &binding_interface); + if (ret != EFI_SUCCESS) + efi_st_error("Failed to uninstall protocols\n"); + + return ret; +} + EFI_UNIT_TEST(controllers) = { .name = "controllers", .phase = EFI_EXECUTE_BEFORE_BOOTTIME_EXIT, .setup = setup, .execute = execute, + .teardown = teardown, }; -- 2.39.2
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
Ilias Apalodimas
