[GIT PULL] UniPhier SoC updates for v2020.10-rc3
Hi Tom,
Please pull a little more for v2020.10. Thanks.
The following changes since commit 789bfb52668ee609b2043de645e2f94bbd24fd1f:
Merge tag 'efi-2020-10-rc3-2' of https://gitlab.denx.de/u-boot/custodians/u-boot-efi (2020-08-15 09:01:01 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-uniphier.git tags/uniphier-v2020.10-2
for you to fetch changes up to 65282edbdf2f30e97c1680e856e6e9fb7af26f8b:
ARM: dts: uniphier: resync DT with Linux 5.9-rc1 (2020-08-18 02:01:14 +0900)
---------------------------------------------------------------- UniPhier SoC updates for v2020.10 (2nd)
- minor code cleanups
- sync DT with Linux
---------------------------------------------------------------- Masahiro Yamada (6): ARM: uniphier: rename include guard of include/configs/uniphier.h ARM: uniphier: remove unused uniphier_pin_init() ARM: uniphier: remove unneeded header inclusion from board_late_init.c serial: uniphier: fix typo in comment ARM: uniphier: use FIELD_GET() to get access to revision register fields ARM: dts: uniphier: resync DT with Linux 5.9-rc1
arch/arm/dts/uniphier-ld11-global.dts | 2 +- arch/arm/dts/uniphier-ld11-ref.dts | 8 +- arch/arm/dts/uniphier-ld20-global.dts | 2 +- arch/arm/dts/uniphier-ld20-ref.dts | 8 +- arch/arm/dts/uniphier-ld20.dtsi | 2 + arch/arm/dts/uniphier-ld4-ref.dts | 6 +- arch/arm/dts/uniphier-ld6b-ref.dts | 7 +- arch/arm/dts/uniphier-pinctrl.dtsi | 5 + arch/arm/dts/uniphier-pro4-ace.dts | 2 +- arch/arm/dts/uniphier-pro4-ref.dts | 8 +- arch/arm/dts/uniphier-pro4-sanji.dts | 3 +- arch/arm/dts/uniphier-pro5.dtsi | 190 +++++++++++++++--- arch/arm/dts/uniphier-pxs2-gentil.dts | 2 +- arch/arm/dts/uniphier-pxs2-vodka.dts | 2 +- arch/arm/dts/uniphier-pxs3-ref.dts | 10 +- arch/arm/dts/uniphier-pxs3.dtsi | 2 + arch/arm/dts/uniphier-sld8-ref.dts | 6 +- arch/arm/dts/uniphier-support-card.dtsi | 31 ++- arch/arm/mach-uniphier/Makefile | 1 - arch/arm/mach-uniphier/board_late_init.c | 3 +- arch/arm/mach-uniphier/init.h | 1 - arch/arm/mach-uniphier/pinctrl-glue.c | 30 --- arch/arm/mach-uniphier/sg-regs.h | 5 + arch/arm/mach-uniphier/soc-info.c | 21 +- drivers/serial/serial_uniphier.c | 2 +- include/configs/uniphier.h | 6 +- 26 files changed, 255 insertions(+), 110 deletions(-) delete mode 100644 arch/arm/mach-uniphier/pinctrl-glue.c
On Tue, Aug 18, 2020 at 02:12:54AM +0900, Masahiro Yamada wrote:
Hi Tom,
Masahiro Yamada
