[U-Boot] [PATCH 0/4] fix propagation of flags from do_env_default()
The function do_env_default() doesn't propagate flags to himport_r(). It causes the "-f" option to have no effect on the execution of "env default" commands.
Fix the call paths from do_env_default() to himport_r() to pass flags correctly.
Yaniv Levinsky (4): cmd: nvedit: rename flags in do_env_default cmd: nvedit: propagate envflag to set_default_vars cmd: nvedit: set H_INTERACTIVE in do_env_default env: common: accept flags on reset to default env
arch/arm/mach-imx/mx6/opos6ul.c | 2 +- cmd/nvedit.c | 11 ++++++----- common/board_r.c | 2 +- common/spl/spl_dfu.c | 2 +- env/common.c | 27 ++++++++++++--------------- env/ext4.c | 2 +- env/fat.c | 2 +- env/mmc.c | 12 ++++++------ env/nand.c | 6 +++--- env/sata.c | 2 +- env/sf.c | 10 +++++----- env/ubi.c | 6 +++--- include/environment.h | 4 ++-- 13 files changed, 43 insertions(+), 45 deletions(-)
The naming convention for flags in nvedit.c is: * The hashtable flag (defined in search.h) is named "env_flag" * The command flag argument (defined in command.h) is named "flag"
This convention is kept in functions like do_env_print(), do_env_set() and do_env_delete(), but not in do_env_default().
Rename the hashtable flag in do_env_default() from "flag" to "env_flag". Rename the command flag in do_env_default() from "__flag" to "flag".
No functional change.
Signed-off-by: Yaniv Levinsky yaniv.levinsky@compulab.co.il Reviewed-by: Igor Grinberg grinberg@compulab.co.il --- cmd/nvedit.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index ddc888a4fd..d456d2fc9b 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -777,10 +777,10 @@ int envmatch(uchar *s1, int i2) }
#ifndef CONFIG_SPL_BUILD -static int do_env_default(cmd_tbl_t *cmdtp, int __flag, +static int do_env_default(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - int all = 0, flag = 0; + int all = 0, env_flag = 0;
debug("Initial value for argc=%d\n", argc); while (--argc > 0 && **++argv == '-') { @@ -792,7 +792,7 @@ static int do_env_default(cmd_tbl_t *cmdtp, int __flag, all = 1; break; case 'f': /* force */ - flag |= H_FORCE; + env_flag |= H_FORCE; break; default: return cmd_usage(cmdtp);
- The hashtable flag (defined in search.h) is named "env_flag"
- The command flag argument (defined in command.h) is named "flag"
The env_flag in do_env_default() doesn't get propagated and therefore gets ignored by himport_r(). This breaks to ability to "forcibly" reset variables to their default values using the environment command.
Scenario example of the problem: # setenv kernel uImage # setenv .flags kernel:so # env default -f kernel ## Error: Can't overwrite "kernel" himport_r: can't insert "kernel=zImage" into hash table
Change the call path so it will pass the flag correctly.
Signed-off-by: Yaniv Levinsky yaniv.levinsky@compulab.co.il Acked-by: Igor Grinberg grinberg@compulab.co.il --- cmd/nvedit.c | 2 +- env/common.c | 5 +++-- include/environment.h | 2 +- 3 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index d456d2fc9b..1955dee0d0 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -807,7 +807,7 @@ static int do_env_default(cmd_tbl_t *cmdtp, int flag, } if (!all && (argc > 0)) { /* Reset individual variables */ - set_default_vars(argc, argv); + set_default_vars(argc, argv, env_flag); return 0; }
diff --git a/env/common.c b/env/common.c index dc8a14f519..6cf5eddaf6 100644 --- a/env/common.c +++ b/env/common.c @@ -91,15 +91,16 @@ void set_default_env(const char *s)
/* [re]set individual variables to their value in the default environment */ -int set_default_vars(int nvars, char * const vars[]) +int set_default_vars(int nvars, char * const vars[], int flags) { /* * Special use-case: import from default environment * (and use \0 as a separator) */ + flags |= H_NOCLEAR | H_INTERACTIVE; return himport_r(&env_htab, (const char *)default_environment, sizeof(default_environment), '\0', - H_NOCLEAR | H_INTERACTIVE, 0, nvars, vars); + flags, 0, nvars, vars); }
/* diff --git a/include/environment.h b/include/environment.h index 70b7eda428..2fe1f3eb48 100644 --- a/include/environment.h +++ b/include/environment.h @@ -275,7 +275,7 @@ char *env_get_default(const char *name); void set_default_env(const char *s);
/* [re]set individual variables to their value in the default environment */ -int set_default_vars(int nvars, char * const vars[]); +int set_default_vars(int nvars, char * const vars[], int flags);
/* Import from binary representation into hash table */ int env_import(const char *buf, int check);
The function set_default_vars() in common.c adds H_INTERACTIVE to the h_import() flag, but the function has no way of telling if the command actually was user directed like this flag suggest. The flag should be set by the calling function do_env_default() in nvedit.c instead, where the command is certainty user directed.
Move the H_INTERACTIVE flag from set_default_vars() to do_env_default().
Signed-off-by: Yaniv Levinsky yaniv.levinsky@compulab.co.il Acked-by: Igor Grinberg grinberg@compulab.co.il --- cmd/nvedit.c | 2 +- env/common.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 1955dee0d0..8b73c606ca 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -780,7 +780,7 @@ int envmatch(uchar *s1, int i2) static int do_env_default(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - int all = 0, env_flag = 0; + int all = 0, env_flag = H_INTERACTIVE;
debug("Initial value for argc=%d\n", argc); while (--argc > 0 && **++argv == '-') { diff --git a/env/common.c b/env/common.c index 6cf5eddaf6..05183a4af0 100644 --- a/env/common.c +++ b/env/common.c @@ -97,7 +97,7 @@ int set_default_vars(int nvars, char * const vars[], int flags) * Special use-case: import from default environment * (and use \0 as a separator) */ - flags |= H_NOCLEAR | H_INTERACTIVE; + flags |= H_NOCLEAR; return himport_r(&env_htab, (const char *)default_environment, sizeof(default_environment), '\0', flags, 0, nvars, vars);
The function set_default_env() sets the hashtable flags for import_r(). Formally set_default_env() doesn't accept flags from its callers. In practice the caller can (un)set the H_INTERACTIVE flag, but it has to be done using the first character of the function's string argument. Other flags like H_FORCE can't be set by the caller.
Change the function to accept flags argument. The benefits are: 1. The caller will have to explicitly set the H_INTERACTIVE flag, instead of un-setting it using a special char in a string. 2. Add the ability to propagate flags from the caller to himport(), especially the H_FORCE flag from do_env_default() in nvedit.c that currently gets ignored for "env default -a -f" commands. 3. Flags and messages will not be coupled together. A caller will be able to set flags without passing a string and vice versa.
Please note: The propagation of H_FORCE from do_env_default() does not introduce any functional changes, because currently himport_r() is set to destroy the old environment regardless if H_FORCE flag is set or not. More changes are needed to utilize the propagation of H_FORCE.
Signed-off-by: Yaniv Levinsky yaniv.levinsky@compulab.co.il Acked-by: Igor Grinberg grinberg@compulab.co.il --- arch/arm/mach-imx/mx6/opos6ul.c | 2 +- cmd/nvedit.c | 3 ++- common/board_r.c | 2 +- common/spl/spl_dfu.c | 2 +- env/common.c | 22 +++++++++------------- env/ext4.c | 2 +- env/fat.c | 2 +- env/mmc.c | 12 ++++++------ env/nand.c | 6 +++--- env/sata.c | 2 +- env/sf.c | 10 +++++----- env/ubi.c | 6 +++--- include/environment.h | 2 +- 13 files changed, 35 insertions(+), 38 deletions(-)
diff --git a/arch/arm/mach-imx/mx6/opos6ul.c b/arch/arm/mach-imx/mx6/opos6ul.c index af3384d10e..94a3d71201 100644 --- a/arch/arm/mach-imx/mx6/opos6ul.c +++ b/arch/arm/mach-imx/mx6/opos6ul.c @@ -127,7 +127,7 @@ int board_late_init(void)
/* In bootstrap don't use the env vars */ if (((reg & 0x3000000) >> 24) == 0x1) { - set_default_env(NULL); + set_default_env(NULL, 0); env_set("preboot", ""); }
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 8b73c606ca..796867c62c 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -802,7 +802,8 @@ static int do_env_default(cmd_tbl_t *cmdtp, int flag, debug("Final value for argc=%d\n", argc); if (all && (argc == 0)) { /* Reset the whole environment */ - set_default_env("## Resetting to default environment\n"); + set_default_env("## Resetting to default environment\n", + env_flag); return 0; } if (!all && (argc > 0)) { diff --git a/common/board_r.c b/common/board_r.c index 6b297068bd..8495777953 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -454,7 +454,7 @@ static int initr_env(void) if (should_load_env()) env_relocate(); else - set_default_env(NULL); + set_default_env(NULL, 0); #ifdef CONFIG_OF_CONTROL env_set_addr("fdtcontroladdr", gd->fdt_blob); #endif diff --git a/common/spl/spl_dfu.c b/common/spl/spl_dfu.c index b8e3a6c89e..01178f611f 100644 --- a/common/spl/spl_dfu.c +++ b/common/spl/spl_dfu.c @@ -38,7 +38,7 @@ int spl_dfu_cmd(int usbctrl, char *dfu_alt_info, char *interface, char *devstr) int ret;
/* set default environment */ - set_default_env(0); + set_default_env(NULL, 0); str_env = env_get(dfu_alt_info); if (!str_env) { pr_err(""dfu_alt_info" env variable not defined!\n"); diff --git a/env/common.c b/env/common.c index 05183a4af0..1430100c85 100644 --- a/env/common.c +++ b/env/common.c @@ -58,22 +58,18 @@ char *env_get_default(const char *name) return ret_val; }
-void set_default_env(const char *s) +void set_default_env(const char *s, int flags) { - int flags = 0; - if (sizeof(default_environment) > ENV_SIZE) { puts("*** Error - default environment is too large\n\n"); return; }
if (s) { - if (*s == '!') { + if ((flags & H_INTERACTIVE) == 0) { printf("*** Warning - %s, " - "using default environment\n\n", - s + 1); + "using default environment\n\n", s); } else { - flags = H_INTERACTIVE; puts(s); } } else { @@ -117,7 +113,7 @@ int env_import(const char *buf, int check) memcpy(&crc, &ep->crc, sizeof(crc));
if (crc32(0, ep->data, ENV_SIZE) != crc) { - set_default_env("!bad CRC"); + set_default_env("bad CRC", 0); return -EIO; } } @@ -130,7 +126,7 @@ int env_import(const char *buf, int check)
pr_err("Cannot import environment: errno = %d\n", errno);
- set_default_env("!import failed"); + set_default_env("import failed", 0);
return -EIO; } @@ -155,7 +151,7 @@ int env_import_redund(const char *buf1, int buf1_read_fail, }
if (buf1_read_fail && buf2_read_fail) { - set_default_env("!bad env area"); + set_default_env("bad env area", 0); return -EIO; } else if (!buf1_read_fail && buf2_read_fail) { gd->env_valid = ENV_VALID; @@ -171,7 +167,7 @@ int env_import_redund(const char *buf1, int buf1_read_fail, tmp_env2->crc;
if (!crc1_ok && !crc2_ok) { - set_default_env("!bad CRC"); + set_default_env("bad CRC", 0); return -EIO; } else if (crc1_ok && !crc2_ok) { gd->env_valid = ENV_VALID; @@ -233,10 +229,10 @@ void env_relocate(void) if (gd->env_valid == ENV_INVALID) { #if defined(CONFIG_ENV_IS_NOWHERE) || defined(CONFIG_SPL_BUILD) /* Environment not changable */ - set_default_env(NULL); + set_default_env(NULL, 0); #else bootstage_error(BOOTSTAGE_ID_NET_CHECKSUM); - set_default_env("!bad CRC"); + set_default_env("bad CRC", 0); #endif } else { env_load(); diff --git a/env/ext4.c b/env/ext4.c index 7626784ca6..09c5e4a491 100644 --- a/env/ext4.c +++ b/env/ext4.c @@ -119,7 +119,7 @@ static int env_ext4_load(void) return env_import(buf, 1);
err_env_relocate: - set_default_env(NULL); + set_default_env(NULL, 0);
return -EIO; } diff --git a/env/fat.c b/env/fat.c index 5e5b1efe89..7f74c64dfe 100644 --- a/env/fat.c +++ b/env/fat.c @@ -122,7 +122,7 @@ static int env_fat_load(void) return env_import(buf, 1);
return -EIO; } diff --git a/env/mmc.c b/env/mmc.c index 5e3da6dca7..c3cf35d01b 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -155,19 +155,19 @@ static inline int mmc_set_env_part(struct mmc *mmc) {return 0; }; static const char *init_mmc_for_env(struct mmc *mmc) { if (!mmc) - return "!No MMC card found"; + return "No MMC card found";
#if CONFIG_IS_ENABLED(BLK) struct udevice *dev;
if (blk_get_from_parent(mmc->dev, &dev)) - return "!No block device"; + return "No block device"; #else if (mmc_init(mmc)) - return "!MMC init failed"; + return "MMC init failed"; #endif if (mmc_set_env_part(mmc)) - return "!MMC partition switch failed"; + return "MMC partition switch failed";
return NULL; } @@ -298,7 +298,7 @@ fini: fini_mmc_for_env(mmc); err: if (ret) - set_default_env(errmsg); + set_default_env(errmsg, 0);
#endif return ret; @@ -339,7 +339,7 @@ fini: fini_mmc_for_env(mmc); err: if (ret) - set_default_env(errmsg); + set_default_env(errmsg, 0); #endif return ret; } diff --git a/env/nand.c b/env/nand.c index aecf445c21..3698e68957 100644 --- a/env/nand.c +++ b/env/nand.c @@ -327,7 +327,7 @@ static int env_nand_load(void) tmp_env2 = (env_t *)malloc(CONFIG_ENV_SIZE); if (tmp_env1 == NULL || tmp_env2 == NULL) { puts("Can't allocate buffers for environment\n"); - set_default_env("!malloc() failed"); + set_default_env("malloc() failed", 0); ret = -EIO; goto done; } @@ -366,14 +366,14 @@ static int env_nand_load(void) if (mtd && !get_nand_env_oob(mtd, &nand_env_oob_offset)) { printf("Found Environment offset in OOB..\n"); } else { - set_default_env("!no env offset in OOB"); + set_default_env("no env offset in OOB", 0); return; } #endif
ret = readenv(CONFIG_ENV_OFFSET, (u_char *)buf); if (ret) { - set_default_env("!readenv() failed"); + set_default_env("readenv() failed", 0); return -EIO; }
diff --git a/env/sata.c b/env/sata.c index e5715e6d51..59aedf4d76 100644 --- a/env/sata.c +++ b/env/sata.c @@ -106,7 +106,7 @@ static void env_sata_load(void) }
if (read_env(sata, CONFIG_ENV_SIZE, CONFIG_ENV_OFFSET, buf)) { - set_default_env(NULL); + set_default_env(NULL, 0); return -EIO; }
diff --git a/env/sf.c b/env/sf.c index 7f7f731992..494510533a 100644 --- a/env/sf.c +++ b/env/sf.c @@ -60,7 +60,7 @@ static int setup_flash_device(void) ret = spi_flash_probe_bus_cs(CONFIG_ENV_SPI_BUS, CONFIG_ENV_SPI_CS, 0, 0, &new); if (ret) { - set_default_env("!spi_flash_probe_bus_cs() failed"); + set_default_env("spi_flash_probe_bus_cs() failed", 0); return ret; }
@@ -72,7 +72,7 @@ static int setup_flash_device(void) CONFIG_ENV_SPI_CS, CONFIG_ENV_SPI_MAX_HZ, CONFIG_ENV_SPI_MODE); if (!env_flash) { - set_default_env("!spi_flash_probe() failed"); + set_default_env("spi_flash_probe() failed", 0); return -EIO; } } @@ -173,7 +173,7 @@ static int env_sf_load(void) tmp_env2 = (env_t *)memalign(ARCH_DMA_MINALIGN, CONFIG_ENV_SIZE); if (!tmp_env1 || !tmp_env2) { - set_default_env("!malloc() failed"); + set_default_env("malloc() failed", 0); ret = -EIO; goto out; } @@ -268,7 +268,7 @@ static int env_sf_load(void)
buf = (char *)memalign(ARCH_DMA_MINALIGN, CONFIG_ENV_SIZE); if (!buf) { - set_default_env("!malloc() failed"); + set_default_env("malloc() failed", 0); return -EIO; }
@@ -279,7 +279,7 @@ static int env_sf_load(void) ret = spi_flash_read(env_flash, CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, buf); if (ret) { - set_default_env("!spi_flash_read() failed"); + set_default_env("spi_flash_read() failed", 0); goto err_read; }
diff --git a/env/ubi.c b/env/ubi.c index d28247b34d..eb2346f3a1 100644 --- a/env/ubi.c +++ b/env/ubi.c @@ -114,7 +114,7 @@ static int env_ubi_load(void) if (ubi_part(CONFIG_ENV_UBI_PART, NULL)) { printf("\n** Cannot find mtd partition "%s"\n", CONFIG_ENV_UBI_PART); - set_default_env(NULL); + set_default_env(NULL, 0); return -EIO; }
@@ -151,14 +151,14 @@ static int env_ubi_load(void) if (ubi_part(CONFIG_ENV_UBI_PART, NULL)) { printf("\n** Cannot find mtd partition "%s"\n", CONFIG_ENV_UBI_PART); - set_default_env(NULL); + set_default_env(NULL, 0); return -EIO; }
if (ubi_volume_read(CONFIG_ENV_UBI_VOLUME, buf, CONFIG_ENV_SIZE)) { printf("\n** Unable to read env from %s:%s **\n", CONFIG_ENV_UBI_PART, CONFIG_ENV_UBI_VOLUME); - set_default_env(NULL); + set_default_env(NULL, 0); return -EIO; }
diff --git a/include/environment.h b/include/environment.h index 2fe1f3eb48..5e90f157e8 100644 --- a/include/environment.h +++ b/include/environment.h @@ -272,7 +272,7 @@ void env_crc_update(void); char *env_get_default(const char *name);
/* [re]set to the default environment */ -void set_default_env(const char *s); +void set_default_env(const char *s, int flags);
/* [re]set individual variables to their value in the default environment */ int set_default_vars(int nvars, char * const vars[], int flags);
- The caller will have to explicitly set the H_INTERACTIVE flag, instead of un-setting it using a special char in a string.
- Add the ability to propagate flags from the caller to himport(), especially the H_FORCE flag from do_env_default() in nvedit.c that currently gets ignored for "env default -a -f" commands.
- Flags and messages will not be coupled together. A caller will be able to set flags without passing a string and vice versa.
Gentle ping.
Yaniv Levinsky
