[PULL] Pull request for u-boot/master v2024.01 = u-boot-stm32-20220124
Hi Tom
Please pull the STM32 related patches for u-boot/master, v2022.04: u-boot-stm32-20220124
CI status: https://source.denx.de/u-boot/custodians/u-boot-stm/-/pipelines/10748
Thanks Patrice
The following changes since commit d323242b62920be08e3a2efb1a61bd9bdf9ed583:
Merge https://source.denx.de/u-boot/custodians/u-boot-sh (2022-01-23 09:54:49 -0500)
https://source.denx.de/u-boot/custodians/u-boot-stm.git tags/u-boot-stm32-20220124
for you to fetch changes up to 22c0815ecaa538de51a5204caceec850d5965126:
configs: stm32mp15: Enable OF_BOARD flag (2022-01-24 11:03:21 +0100)
---------------------------------------------------------------- - stm32mp15: sync DT with kernel v5.16 - stm32mp15: Enable OF_BOARD config flag - DHCOM: sync DT with kernel 5.15.12 - stm32mp: Fix USB boot device - stm32mp: Remove bootcount activation - stm32mp: Fix board_get_alt_info_mmc() - board: stm32mp1: solve compilation issue when ENV_IS_IN_MMC is deactivated - stm32prog: add partition name in treat_partition_list error messages
---------------------------------------------------------------- Heinrich Schuchardt (1): stm32mp: fix board_get_alt_info_mmc()
Marek Vasut (4): arm: stm32mp: Fix USB boot device report ARM: dts: stm32: Add DFU support for DHCOR recovery ARM: dts: stm32: Synchronize DHCOR DTs with Linux 5.15.12 ARM: dts: stm32: Synchronize DHCOM DTs with Linux 5.15.12
Patrice Chotard (1): configs: stm32mp15: Enable OF_BOARD flag
Patrick Delaunay (5): stm32mp: remove the bootcount activation stm32mp: correct the dependency for bootcount configs arm: dts: stm32mp15: alignment with v5.16 board: stm32mp1: solve compilation issue when ENV_IS_IN_MMC is deactivated stm32prog: add partition name in treat_partition_list error messages
arch/arm/dts/Makefile | 1 - arch/arm/dts/stm32mp15-pinctrl.dtsi | 8 +- arch/arm/dts/stm32mp151.dtsi | 19 +- arch/arm/dts/stm32mp157a-avenger96.dts | 8 - arch/arm/dts/stm32mp157a-dhcor-avenger96.dts | 38 ++ arch/arm/dts/stm32mp15xx-dhcom-drc02.dts | 162 +------- arch/arm/dts/stm32mp15xx-dhcom-drc02.dtsi | 165 ++++++++ arch/arm/dts/stm32mp15xx-dhcom-pdk2-u-boot.dtsi | 4 + arch/arm/dts/stm32mp15xx-dhcom-pdk2.dts | 14 +- arch/arm/dts/stm32mp15xx-dhcom-pdk2.dtsi | 325 ++++++++++++++++ arch/arm/dts/stm32mp15xx-dhcom-picoitx-u-boot.dtsi | 6 +- arch/arm/dts/stm32mp15xx-dhcom-picoitx.dts | 88 +---- arch/arm/dts/stm32mp15xx-dhcom-picoitx.dtsi | 147 +++++++ ...p15xx-dhcom.dtsi => stm32mp15xx-dhcom-som.dtsi} | 387 ++++++++++-------- arch/arm/dts/stm32mp15xx-dhcom-u-boot.dtsi | 43 +- .../dts/stm32mp15xx-dhcor-avenger96-u-boot.dtsi | 2 + arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts | 202 +--------- arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi | 431 +++++++++++++++++++++ arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi | 7 +- ...dhcor-io3v3.dtsi => stm32mp15xx-dhcor-som.dtsi} | 30 +- arch/arm/dts/stm32mp15xx-dhcor-u-boot.dtsi | 50 +++ arch/arm/dts/stm32mp15xx-dkx.dtsi | 2 +- arch/arm/mach-stm32mp/Kconfig | 11 +- arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c | 12 +- arch/arm/mach-stm32mp/spl.c | 2 +- board/st/common/stm32mp_dfu.c | 2 +- board/st/stm32mp1/stm32mp1.c | 6 +- configs/stm32mp15_dhcor_basic_defconfig | 14 +- include/configs/stm32mp15_common.h | 1 - include/configs/stm32mp15_dh_dhsom.h | 7 + 30 files changed, 1510 insertions(+), 684 deletions(-) delete mode 100644 arch/arm/dts/stm32mp157a-avenger96.dts create mode 100644 arch/arm/dts/stm32mp157a-dhcor-avenger96.dts create mode 100644 arch/arm/dts/stm32mp15xx-dhcom-drc02.dtsi create mode 100644 arch/arm/dts/stm32mp15xx-dhcom-pdk2.dtsi create mode 100644 arch/arm/dts/stm32mp15xx-dhcom-picoitx.dtsi rename arch/arm/dts/{stm32mp15xx-dhcom.dtsi => stm32mp15xx-dhcom-som.dtsi} (56%) create mode 100644 arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi rename arch/arm/dts/{stm32mp15xx-dhcor-io3v3.dtsi => stm32mp15xx-dhcor-som.dtsi} (91%)
On Mon, Jan 24, 2022 at 01:21:33PM +0100, Patrice CHOTARD wrote:
Hi Tom
Thanks Patrice
Patrice CHOTARD
