[U-Boot] [PATCH V2 1/3] ARM: socfpga: clk: Obtain handoff base clock via DM
Bind fixed clock driver to the base clock instantiated in the handoff DT and use DM clock framework to get their clock rate. This replaces the ad-hoc DT parsing present thus far.
Signed-off-by: Marek Vasut marex@denx.de Cc: Chin Liang See chin.liang.see@intel.com Cc: Dinh Nguyen dinguyen@kernel.org Cc: Ley Foon Tan ley.foon.tan@intel.com --- V2: Drop device_probe() which is unneeded because it's performed by uclass_get_device_by_name() already --- arch/arm/mach-socfpga/Kconfig | 2 ++ arch/arm/mach-socfpga/clock_manager_arria10.c | 37 ++++++++++++++++++--------- 2 files changed, 27 insertions(+), 12 deletions(-)
diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig index 5c1df2cf1f..2655289a72 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -11,6 +11,8 @@ config TARGET_SOCFPGA_ARRIA10 bool select ALTERA_SDRAM select SPL_BOARD_INIT if SPL + select CLK + select SPL_CLK if SPL
config TARGET_SOCFPGA_CYCLONE5 bool diff --git a/arch/arm/mach-socfpga/clock_manager_arria10.c b/arch/arm/mach-socfpga/clock_manager_arria10.c index defa2f6261..cadb090387 100644 --- a/arch/arm/mach-socfpga/clock_manager_arria10.c +++ b/arch/arm/mach-socfpga/clock_manager_arria10.c @@ -7,6 +7,8 @@ #include <fdtdec.h> #include <asm/io.h> #include <dm.h> +#include <clk.h> +#include <dm/device-internal.h> #include <asm/arch/clock_manager.h>
static const struct socfpga_clock_manager *clock_manager_base = @@ -141,9 +143,9 @@ struct strtopu32 { };
const struct strtopu32 dt_to_val[] = { - { "/clocks/altera_arria10_hps_eosc1", &eosc1_hz}, - { "/clocks/altera_arria10_hps_cb_intosc_ls", &cb_intosc_hz}, - { "/clocks/altera_arria10_hps_f2h_free", &f2s_free_hz}, + { "altera_arria10_hps_eosc1", &eosc1_hz }, + { "altera_arria10_hps_cb_intosc_ls", &cb_intosc_hz }, + { "altera_arria10_hps_f2h_free", &f2s_free_hz }, };
static int of_to_struct(const void *blob, int node, const struct strtou32 *cfg_tab, @@ -163,28 +165,39 @@ static int of_to_struct(const void *blob, int node, const struct strtou32 *cfg_t return 0; }
-static void of_get_input_clks(const void *blob) +static int of_get_input_clks(const void *blob) { - int node, i; + struct udevice *dev; + struct clk clk; + int i, ret;
for (i = 0; i < ARRAY_SIZE(dt_to_val); i++) { - node = fdt_path_offset(blob, dt_to_val[i].str); + memset(&clk, 0, sizeof(clk));
- if (node < 0) - continue; + ret = uclass_get_device_by_name(UCLASS_CLK, dt_to_val[i].str, + &dev); + if (ret) + return ret;
- fdtdec_get_int_array(blob, node, "clock-frequency", - dt_to_val[i].p, 1); + ret = clk_request(dev, &clk); + if (ret) + return ret; + + *dt_to_val[i].p = clk_get_rate(&clk); } + + return 0; }
static int of_get_clk_cfg(const void *blob, struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) { - int node, child, len; + int ret, node, child, len; const char *node_name;
- of_get_input_clks(blob); + ret = of_get_input_clks(blob); + if (ret) + return ret;
node = fdtdec_next_compatible(blob, 0, COMPAT_ALTERA_SOCFPGA_CLK_INIT);
The L4SP and MMC clock precalculation is specific to Gen5, it is not needed on Arria10/Stratix10. Isolate it to Gen5 until there is a proper clock driver for Gen5, at which point this will go away completely.
Signed-off-by: Marek Vasut marex@denx.de Cc: Chin Liang See chin.liang.see@intel.com Cc: Dinh Nguyen dinguyen@kernel.org Cc: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/clock_manager.c | 2 ++ 1 file changed, 2 insertions(+) --- V2: No change
diff --git a/arch/arm/mach-socfpga/clock_manager.c b/arch/arm/mach-socfpga/clock_manager.c index 59ede59b59..9f3c643df8 100644 --- a/arch/arm/mach-socfpga/clock_manager.c +++ b/arch/arm/mach-socfpga/clock_manager.c @@ -42,9 +42,11 @@ int cm_wait_for_fsm(void)
int set_cpu_clk_info(void) { +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) /* Calculate the clock frequencies required for drivers */ cm_get_l4_sp_clk_hz(); cm_get_mmc_controller_clk_hz(); +#endif
gd->bd->bi_arm_freq = cm_get_mpu_clk_hz() / 1000000; gd->bd->bi_dsp_freq = 0;
The variables removed in this patch are never used, they are only ever assigned and then waste precious memory. Drop both the assignment and the variables.
Signed-off-by: Marek Vasut marex@denx.de Cc: Chin Liang See chin.liang.see@intel.com Cc: Dinh Nguyen dinguyen@kernel.org Cc: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/clock_manager_arria10.c | 19 ++----------------- 1 file changed, 2 insertions(+), 17 deletions(-) --- V2: No change
diff --git a/arch/arm/mach-socfpga/clock_manager_arria10.c b/arch/arm/mach-socfpga/clock_manager_arria10.c index cadb090387..9bc87aab7d 100644 --- a/arch/arm/mach-socfpga/clock_manager_arria10.c +++ b/arch/arm/mach-socfpga/clock_manager_arria10.c @@ -17,10 +17,6 @@ static const struct socfpga_clock_manager *clock_manager_base = static u32 eosc1_hz; static u32 cb_intosc_hz; static u32 f2s_free_hz; -static u32 cm_l4_main_clk_hz; -static u32 cm_l4_sp_clk_hz; -static u32 cm_l4_mp_clk_hz; -static u32 cm_l4_sys_free_clk_hz;
struct mainpll_cfg { u32 vco0_psrc; @@ -965,18 +961,7 @@ int cm_basic_init(const void *blob) if (rval) return rval;
- rval = cm_full_cfg(&main_cfg, &per_cfg); - - cm_l4_main_clk_hz = - cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MAINCLK_LSB); - - cm_l4_mp_clk_hz = cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MPCLK_LSB); - - cm_l4_sp_clk_hz = cm_get_l4_sp_clk_hz(); - - cm_l4_sys_free_clk_hz = cm_get_noc_clk_hz() / 4; - - return rval; + return cm_full_cfg(&main_cfg, &per_cfg); }
unsigned long cm_get_mpu_clk_hz(void) @@ -1173,5 +1158,5 @@ void cm_print_clock_quick_summary(void) printf("L4 MP %8d kHz\n", cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MPCLK_LSB) / 1000); printf("L4 SP %8d kHz\n", cm_get_l4_sp_clk_hz() / 1000); - printf("L4 sys free %8d kHz\n", cm_l4_sys_free_clk_hz / 1000); + printf("L4 sys free %8d kHz\n", cm_get_noc_clk_hz() / 4000); }
diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach- socfpga/Kconfig index 5c1df2cf1f..2655289a72 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -11,6 +11,8 @@ config TARGET_SOCFPGA_ARRIA10 bool select ALTERA_SDRAM select SPL_BOARD_INIT if SPL
- select CLK
- select SPL_CLK if SPL
config TARGET_SOCFPGA_CYCLONE5 bool diff --git a/arch/arm/mach-socfpga/clock_manager_arria10.c b/arch/arm/mach-socfpga/clock_manager_arria10.c index defa2f6261..cadb090387 100644 --- a/arch/arm/mach-socfpga/clock_manager_arria10.c +++ b/arch/arm/mach-socfpga/clock_manager_arria10.c @@ -7,6 +7,8 @@ #include <fdtdec.h> #include <asm/io.h> #include <dm.h> +#include <clk.h> +#include <dm/device-internal.h> #include <asm/arch/clock_manager.h> static const struct socfpga_clock_manager *clock_manager_base = @@ -141,9 +143,9 @@ struct strtopu32 { }; const struct strtopu32 dt_to_val[] = {
- { "altera_arria10_hps_eosc1", &eosc1_hz },
- { "altera_arria10_hps_cb_intosc_ls", &cb_intosc_hz },
- { "altera_arria10_hps_f2h_free", &f2s_free_hz },
}; static int of_to_struct(const void *blob, int node, const struct strtou32 *cfg_tab, @@ -163,28 +165,39 @@ static int of_to_struct(const void *blob, int node, const struct strtou32 *cfg_t return 0; } -static void of_get_input_clks(const void *blob) +static int of_get_input_clks(const void *blob) {
- int node, i;
- struct udevice *dev;
- struct clk clk;
- int i, ret;
if (node < 0)
continue;
dt_to_val[i].str,
&dev);
if (ret)
return ret;
dt_to_val[i].p, 1);
if (ret)
return ret;
} static int of_get_clk_cfg(const void *blob, struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) {
- int ret, node, child, len;
- ret = of_get_input_clks(blob);
- if (ret)
return ret;
Reviewed-by: Ley Foon Tan ley.foon.tan@intel.com
Regards Ley Foon
Ley Foon Tan
