[PATCH 1/2] sifive: fu540: Add sample SD gpt partition layout
This is a sample GPT partition layout for SD card, right now three important partitions are added to make the system bootable.
Right now the board doesn't support the environment, so the U-Boot environment and ESP partitions will add in future.
partition layout:
Part Start LBA End LBA Name Attributes Type GUID Partition GUID 1 0x00000800 0x00000fff "loader1" attrs: 0x0000000000000000 type: 5b193300-fc78-40cd-8002-e86c45580b47 guid: 3b86e786-4b78-4bb2-92ac-7c7b45e73d33 2 0x00001000 0x00002fff "loader2" attrs: 0x0000000000000000 type: 2e54b353-1271-4842-806f-e436d6af6985 guid: c09e2067-3c33-4ceb-993a-fbdc29a6a8cf 3 0x00003000 0x03b9ffde "system" attrs: 0x0000000000000004 type: 0fc63daf-8483-4772-8e79-3d69d8477de4 type: linux guid: 99f4fd58-6e52-4a2b-b5f0-035f5756ad01
Note: - loader1 would be fsbl or spl - loader2 would be U-Boot or U-Boot proper
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Note: On top of https://patchwork.ozlabs.org/cover/1263480/
board/sifive/fu540/Kconfig | 2 ++ include/configs/sifive-fu540.h | 13 +++++++++++++ 2 files changed, 15 insertions(+)
diff --git a/board/sifive/fu540/Kconfig b/board/sifive/fu540/Kconfig index 5c67aab96a..43d01bab8d 100644 --- a/board/sifive/fu540/Kconfig +++ b/board/sifive/fu540/Kconfig @@ -32,6 +32,8 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply CMD_EXT4 imply CMD_FAT imply CMD_FS_GENERIC + imply CMD_GPT + imply PARTITION_TYPE_GUID imply CMD_NET imply CMD_PING imply CLK_SIFIVE diff --git a/include/configs/sifive-fu540.h b/include/configs/sifive-fu540.h index ef3ae9b650..189e70d7be 100644 --- a/include/configs/sifive-fu540.h +++ b/include/configs/sifive-fu540.h @@ -47,6 +47,15 @@
#include <config_distro_bootcmd.h>
+#define TYPE_GUID_LOADER1 "5B193300-FC78-40CD-8002-E86C45580B47" +#define TYPE_GUID_LOADER2 "2E54B353-1271-4842-806F-E436D6AF6985" +#define TYPE_GUID_SYSTEM "0FC63DAF-8483-4772-8E79-3D69D8477DE4" + +#define PARTS_DEFAULT \ + "name=loader1,start=1M,size=1M,type=${type_guid_gpt_loader1};" \ + "name=loader2,size=4MB,type=${type_guid_gpt_loader2};" \ + "name=system,size=-,bootable,type=${type_guid_gpt_system};" + #define CONFIG_EXTRA_ENV_SETTINGS \ "fdt_high=0xffffffffffffffff\0" \ "initrd_high=0xffffffffffffffff\0" \ @@ -55,6 +64,10 @@ "scriptaddr=0x88100000\0" \ "pxefile_addr_r=0x88200000\0" \ "ramdisk_addr_r=0x88300000\0" \ + "type_guid_gpt_loader1=" TYPE_GUID_LOADER1 "\0" \ + "type_guid_gpt_loader2=" TYPE_GUID_LOADER2 "\0" \ + "type_guid_gpt_system=" TYPE_GUID_SYSTEM "\0" \ + "partitions=" PARTS_DEFAULT "\0" \ BOOTENV
#define CONFIG_PREBOOT \
Add U-Boot proper sector start offset for SiFive FU540. This value is based on the partition layout supported by SiFive FU540.
u-boot.itb need to write on this specific offset so-that the SPL will retrieve it from here and load.
common/spl/Kconfig | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 07eee56219..4c36864602 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -308,7 +308,7 @@ config SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR ARCH_MX6 || ARCH_MX7 || \ ARCH_ROCKCHIP || ARCH_MVEBU || ARCH_SOCFPGA || \ ARCH_AT91 || ARCH_ZYNQ || ARCH_KEYSTONE || OMAP34XX || \ - OMAP44XX || OMAP54XX || AM33XX || AM43XX + OMAP44XX || OMAP54XX || AM33XX || AM43XX || TARGET_SIFIVE_FU540 help Use sector number for specifying U-Boot location on MMC/SD in raw mode. @@ -325,6 +325,7 @@ config SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR default 0x300 if ARCH_ZYNQ || ARCH_KEYSTONE || OMAP34XX || OMAP44XX || \ OMAP54XX || AM33XX || AM43XX || ARCH_K3 default 0x4000 if ARCH_ROCKCHIP + default 0x1000 if TARGET_SIFIVE_FU540 help Address on the MMC to load U-Boot from, when the MMC is being used in raw mode. Units: MMC sectors (1 sector = 512 bytes).
Jagan Teki
