[U-Boot] [PATCH v3] script: Make the get_default_envs.sh script working with newest u-boot
This commit fixes several issues:
- After moving env related code to ./env directory the env_common.o file is no longer present in the system (has been replaced with built-in.o).
- Use ${OBJCOPY} if available, fallback to system default's objcopy if not present.
- Extend the script to accept different build directory than current one. It is extremely handy with OE usage, where source code is separated from build.
Signed-off-by: Lukasz Majewski lukma@denx.de Tested-by: Alex Kiernan alex.kiernan@gmail.com ---
Changes in v3: - Extend the objcopy to use CROSS_COMPILE if defined
Changes in v2: - Update comment information
scripts/get_default_envs.sh | 21 +++++++++++++++------ 1 file changed, 15 insertions(+), 6 deletions(-)
diff --git a/scripts/get_default_envs.sh b/scripts/get_default_envs.sh index 7955db60e5..184cc19ab7 100755 --- a/scripts/get_default_envs.sh +++ b/scripts/get_default_envs.sh @@ -6,16 +6,24 @@ #
# This file extracts default envs from built u-boot -# usage: get_default_envs.sh > u-boot-env-default.txt +# usage: get_default_envs.sh [build dir] > u-boot-env-default.txt set -ue
-ENV_OBJ_FILE="env_common.o" +: "${OBJCOPY:=${CROSS_COMPILE:-}objcopy}" + +ENV_OBJ_FILE="built-in.o" ENV_OBJ_FILE_COPY="copy_${ENV_OBJ_FILE}"
echoerr() { echo "$@" 1>&2; }
-path=$(readlink -f $0) -env_obj_file_path=$(find ${path%/scripts*} -not -path "*/spl/*" \ +if [ "$#" -eq 1 ]; then + path=${1} +else + path=$(readlink -f $0) + path=${path%/scripts*} +fi + +env_obj_file_path=$(find ${path} -path "*/env/*" -not -path "*/spl/*" \ -name "${ENV_OBJ_FILE}") [ -z "${env_obj_file_path}" ] && \ { echoerr "File '${ENV_OBJ_FILE}' not found!"; exit 1; } @@ -23,8 +31,9 @@ env_obj_file_path=$(find ${path%/scripts*} -not -path "*/spl/*" \ cp ${env_obj_file_path} ${ENV_OBJ_FILE_COPY}
# NOTE: objcopy saves its output to file passed in -# (copy_env_common.o in this case) -objcopy -O binary -j ".rodata.default_environment" ${ENV_OBJ_FILE_COPY} +# (copy_${ENV_OBJ_FILE} in this case) + +${OBJCOPY} -O binary -j ".rodata.default_environment" ${ENV_OBJ_FILE_COPY}
# Replace default '\0' with '\n' and sort entries tr '\0' '\n' < ${ENV_OBJ_FILE_COPY} | sort -u
present.
Lukasz Majewski
