Re: [U-Boot-Users] [DNX#2006091242000069] [PATCH] Add support for Errata DDR6 on MPC 834x sy [...]
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006091242000069] was created:
<snip>
Signed-off-by: Timur Tabi timur@freescale.com
cpu/mpc83xx/spd_sdram.c | 40 ++++++++++++++++++++++++++++++++++++++++ 1 files changed, 40 insertions(+), 0 deletions(-)
diff --git a/cpu/mpc83xx/spd_sdram.c b/cpu/mpc83xx/spd_sdram.c index 48624fe..f796822 100644 --- a/cpu/mpc83xx/spd_sdram.c +++ b/cpu/mpc83xx/spd_sdram.c @@ -112,6 +112,9 @@ long int spd_sdram() unsigned int law_size; unsigned char caslat; unsigned int trfc, trfc_clk, trfc_low; +#ifdef CONFIG_MPC834X
- int caslat_83xx; /* For Errata DDR6 */
CFG_READ_SPD(SPD_EEPROM_ADDRESS, 0, 1, (uchar *) & spd, sizeof (spd)); #ifdef SPD_DEBUG @@ -222,6 +225,39 @@ #endif return 0; }
+#ifdef CONFIG_MPC834X +/* Errata DDR6
- This errata affects all MPC8349E, MPC8343E and MPC8347E processors.
- if ((tmp1 >= 280) && (tmp1 < 350)) { /* CSB=333 */
if (spd.mid[0] == 0x2c) {
/* Micron memory running at 333 MHz */
/* Chances are, U-Boot will crash before we get here,
but just in case, display a message and return error. */
printf("Micron DDR not supported at 333MHz CSB\n");
} else if (spd.mid[0] == 0xad) {
printf("Hynix DDR does not require Errata DDR6\n");
} else {
/* enable 2 cycle Earlier for CL=2.5 or 3 */
ddr->debug_reg = 0x202c0000;
printf("Errata DDR6 (debug_reg=0x%x)\n", ddr->debug_reg);
caslat_83xx = caslat;
- if ((tmp1 >= 230) && (tmp1 < 280)) { /* CSB=266 */
if (spd.mid[0] != 0x2c) /* non-Micron */
caslat_83xx = caslat - 1;
- if ((tmp1 >= 90) && (tmp1 < 230)) { /* CSB=200 */
caslat = 3;
caslat_83xx = 2;
- note: caslat must also be programmed into ddr->sdram_mode
- register.
@@ -237,7 +273,11 @@ #endif (((picos_to_clk(spd.trp * 250) & 0x07) << 28 ) | ((picos_to_clk(spd.tras * 1000) & 0x0f ) << 24 ) | ((picos_to_clk(spd.trcd * 250) & 0x07) << 20 ) | +#ifdef CONFIG_MPC834x
((caslat_83xx & 0x07) << 16 ) |
+#else ((caslat & 0x07) << 16 ) | +#endif (trfc_low << 12 ) | ( 0x300 ) | ((picos_to_clk(spd.trrd * 250) & 0x07) << 4) | 1); -- 1.4.2
</snip>
Your U-Boot support team
DENX Support System
