[U-Boot] [PATCH v2 3/9] ColdFire: Remove platforms mii.c file
Will use mcfmii.c driver in drivers/net rather than keep creating new mii.c for each future platform. Remove EB+MCF-EV123, cobra5272, idmr, M5235EVB, M5271EVB, M5272C3, M5275EVB, M5282EVB, M5329EVB, M5373EVB, M54451EVB, M54455EVB, M547xEVB, and M548xEVB's mii.c
Signed-off-by: TsiChung Liew Tsi-Chung.Liew@freescale.com --- board/BuS/EB+MCF-EV123/Makefile | 2 +- board/BuS/EB+MCF-EV123/mii.c | 304 --------------------------------- board/cobra5272/Makefile | 2 +- board/cobra5272/mii.c | 303 --------------------------------- board/freescale/m5235evb/Makefile | 2 +- board/freescale/m5235evb/mii.c | 307 ---------------------------------- board/freescale/m5271evb/Makefile | 2 +- board/freescale/m5271evb/mii.c | 303 --------------------------------- board/freescale/m5272c3/Makefile | 2 +- board/freescale/m5272c3/mii.c | 303 --------------------------------- board/freescale/m5275evb/Makefile | 2 +- board/freescale/m5275evb/mii.c | 319 ----------------------------------- board/freescale/m5282evb/Makefile | 2 +- board/freescale/m5282evb/mii.c | 304 --------------------------------- board/freescale/m5329evb/Makefile | 2 +- board/freescale/m5329evb/mii.c | 306 ---------------------------------- board/freescale/m5373evb/Makefile | 2 +- board/freescale/m5373evb/mii.c | 306 ---------------------------------- board/freescale/m54451evb/Makefile | 2 +- board/freescale/m54451evb/mii.c | 303 --------------------------------- board/freescale/m54455evb/Makefile | 2 +- board/freescale/m54455evb/mii.c | 324 ------------------------------------ board/freescale/m547xevb/Makefile | 2 +- board/freescale/m547xevb/mii.c | 322 ----------------------------------- board/freescale/m548xevb/Makefile | 2 +- board/freescale/m548xevb/mii.c | 322 ----------------------------------- board/idmr/Makefile | 2 +- board/idmr/mii.c | 303 --------------------------------- 28 files changed, 14 insertions(+), 4343 deletions(-) delete mode 100644 board/BuS/EB+MCF-EV123/mii.c delete mode 100644 board/cobra5272/mii.c delete mode 100644 board/freescale/m5235evb/mii.c delete mode 100644 board/freescale/m5271evb/mii.c delete mode 100644 board/freescale/m5272c3/mii.c delete mode 100644 board/freescale/m5275evb/mii.c delete mode 100644 board/freescale/m5282evb/mii.c delete mode 100644 board/freescale/m5329evb/mii.c delete mode 100644 board/freescale/m5373evb/mii.c delete mode 100644 board/freescale/m54451evb/mii.c delete mode 100644 board/freescale/m54455evb/mii.c delete mode 100644 board/freescale/m547xevb/mii.c delete mode 100644 board/freescale/m548xevb/mii.c delete mode 100644 board/idmr/mii.c
diff --git a/board/BuS/EB+MCF-EV123/Makefile b/board/BuS/EB+MCF-EV123/Makefile index ceeffa7..ed3ac07 100644 --- a/board/BuS/EB+MCF-EV123/Makefile +++ b/board/BuS/EB+MCF-EV123/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).a
-COBJS = $(BOARD).o cfm_flash.o flash.o VCxK.o mii.o +COBJS = $(BOARD).o cfm_flash.o flash.o VCxK.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/BuS/EB+MCF-EV123/mii.c b/board/BuS/EB+MCF-EV123/mii.c deleted file mode 100644 index 7f92514..0000000 --- a/board/BuS/EB+MCF-EV123/mii.c +++ /dev/null @@ -1,304 +0,0 @@ -/* - * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. - * TsiChung Liew (Tsi-Chung.Liew@freescale.com) - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/fec.h> -#include <asm/immap.h> - -#include <config.h> -#include <net.h> - -DECLARE_GLOBAL_DATA_PTR; - -#if defined(CONFIG_CMD_NET) && defined(CONFIG_NET_MULTI) -#undef MII_DEBUG -#undef ET_DEBUG - -int fecpin_setclear(struct eth_device *dev, int setclear) -{ - if (setclear) { - MCFGPIO_PASPAR |= 0x0F00; - MCFGPIO_PEHLPAR = CONFIG_SYS_PEHLPAR; - } else { - MCFGPIO_PASPAR &= 0xF0FF; - MCFGPIO_PEHLPAR &= ~CONFIG_SYS_PEHLPAR; - } - return 0; -} - -#if defined(CONFIG_SYS_DISCOVER_PHY) || defined(CONFIG_CMD_MII) -#include <miiphy.h> - -/* Make MII read/write commands for the FEC. */ -#define mk_mii_read(ADDR, REG) (0x60020000 | ((ADDR << 23) | (REG & 0x1f) << 18)) - -#define mk_mii_write(ADDR, REG, VAL) (0x50020000 | ((ADDR << 23) | (REG & 0x1f) << 18) | (VAL & 0xffff)) - -/* PHY identification */ -#define PHY_ID_LXT970 0x78100000 /* LXT970 */ -#define PHY_ID_LXT971 0x001378e0 /* LXT971 and 972 */ -#define PHY_ID_82555 0x02a80150 /* Intel 82555 */ -#define PHY_ID_QS6612 0x01814400 /* QS6612 */ -#define PHY_ID_AMD79C784 0x00225610 /* AMD 79C784 */ -#define PHY_ID_AMD79C874VC 0x0022561B /* AMD 79C874 */ -#define PHY_ID_LSI80225 0x0016f870 /* LSI 80225 */ -#define PHY_ID_LSI80225B 0x0016f880 /* LSI 80225/B */ -#define PHY_ID_DP83848VV 0x20005C90 /* National 83848 */ -#define PHY_ID_DP83849 0x20005CA2 /* National 82849 */ - -#define STR_ID_LXT970 "LXT970" -#define STR_ID_LXT971 "LXT971" -#define STR_ID_82555 "Intel82555" -#define STR_ID_QS6612 "QS6612" -#define STR_ID_AMD79C784 "AMD79C784" -#define STR_ID_AMD79C874VC "AMD79C874VC" -#define STR_ID_LSI80225 "LSI80225" -#define STR_ID_LSI80225B "LSI80225/B" -#define STR_ID_DP83848VV "N83848" -#define STR_ID_DP83849 "N83849" - -/**************************************************************************** - * mii_init -- Initialize the MII for MII command without ethernet - * This function is a subset of eth_init - **************************************************************************** - */ -void mii_reset(struct fec_info_s *info) -{ - volatile fec_t *fecp = (fec_t *) (info->miibase); - int i; - - fecp->ecr = FEC_ECR_RESET; - for (i = 0; (fecp->ecr & FEC_ECR_RESET) && (i < FEC_RESET_DELAY); ++i) { - udelay(1); - } - if (i == FEC_RESET_DELAY) { - printf("FEC_RESET_DELAY timeout\n"); - } -} - -/* send command to phy using mii, wait for result */ -uint mii_send(uint mii_cmd) -{ - struct fec_info_s *info; - struct eth_device *dev; - volatile fec_t *ep; - uint mii_reply; - int j = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - ep = (fec_t *) info->miibase; - - ep->mmfr = mii_cmd; /* command to phy */ - - /* wait for mii complete */ - while (!(ep->eir & FEC_EIR_MII) && (j < MCFFEC_TOUT_LOOP)) { - udelay(1); - j++; - } - if (j >= MCFFEC_TOUT_LOOP) { - printf("MII not complete\n"); - return -1; - } - - mii_reply = ep->mmfr; /* result from phy */ - ep->eir = FEC_EIR_MII; /* clear MII complete */ -#ifdef ET_DEBUG - printf("%s[%d] %s: sent=0x%8.8x, reply=0x%8.8x\n", - __FILE__, __LINE__, __FUNCTION__, mii_cmd, mii_reply); -#endif - - return (mii_reply & 0xffff); /* data read from phy */ -} -#endif /* CONFIG_SYS_DISCOVER_PHY || CONFIG_CMD_MII */ - -#if defined(CONFIG_SYS_DISCOVER_PHY) -int mii_discover_phy(struct eth_device *dev) -{ -#define MAX_PHY_PASSES 11 - struct fec_info_s *info = dev->priv; - int phyaddr, pass; - uint phyno, phytype; - - if (info->phyname_init) - return info->phy_addr; - - phyaddr = -1; /* didn't find a PHY yet */ - for (pass = 1; pass <= MAX_PHY_PASSES && phyaddr < 0; ++pass) { - if (pass > 1) { - /* PHY may need more time to recover from reset. - * The LXT970 needs 50ms typical, no maximum is - * specified, so wait 10ms before try again. - * With 11 passes this gives it 100ms to wake up. - */ - udelay(10000); /* wait 10ms */ - } - - for (phyno = 0; phyno < 32 && phyaddr < 0; ++phyno) { - - phytype = mii_send(mk_mii_read(phyno, PHY_PHYIDR1)); -#ifdef ET_DEBUG - printf("PHY type 0x%x pass %d type\n", phytype, pass); -#endif - if (phytype != 0xffff) { - phyaddr = phyno; - phytype <<= 16; - phytype |= - mii_send(mk_mii_read(phyno, PHY_PHYIDR2)); - - switch (phytype & 0xffffffff) { - case PHY_ID_AMD79C874VC: - strcpy(info->phy_name, - STR_ID_AMD79C874VC); - info->phyname_init = 1; - break; - default: - strcpy(info->phy_name, "unknown"); - info->phyname_init = 1; - break; - } - -#ifdef ET_DEBUG - printf("PHY @ 0x%x pass %d type ", phyno, pass); - switch (phytype & 0xffffffff) { - case PHY_ID_AMD79C874VC: - printf(STR_ID_AMD79C874VC); - break; - default: - printf("0x%08x\n", phytype); - break; - } -#endif - } - } - } - if (phyaddr < 0) - printf("No PHY device found.\n"); - - return phyaddr; -} -#endif /* CONFIG_SYS_DISCOVER_PHY */ - -void mii_init(void) __attribute__((weak,alias("__mii_init"))); - -void __mii_init(void) -{ - volatile fec_t *fecp; - struct fec_info_s *info; - struct eth_device *dev; - int miispd = 0, i = 0; - u16 autoneg = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - fecp = (fec_t *) info->miibase; - - fecpin_setclear(dev, 1); - - mii_reset(info); - - /* We use strictly polling mode only */ - fecp->eimr = 0; - - /* Clear any pending interrupt */ - fecp->eir = 0xffffffff; - - /* Set MII speed */ - miispd = (gd->bus_clk / 1000000) / 5; - fecp->mscr = miispd << 1; - - info->phy_addr = mii_discover_phy(dev); - -#define AUTONEGLINK (PHY_BMSR_AUTN_COMP | PHY_BMSR_LS) - while (i < MCFFEC_TOUT_LOOP) { - autoneg = 0; - miiphy_read(dev->name, info->phy_addr, PHY_BMSR, &autoneg); - i++; - - if ((autoneg & AUTONEGLINK) == AUTONEGLINK) - break; - - udelay(500); - } - if (i >= MCFFEC_TOUT_LOOP) { - printf("Auto Negotiation not complete\n"); - } - - /* adapt to the half/full speed settings */ - info->dup_spd = miiphy_duplex(dev->name, info->phy_addr) << 16; - info->dup_spd |= miiphy_speed(dev->name, info->phy_addr); -} - -/***************************************************************************** - * Read and write a MII PHY register, routines used by MII Utilities - * - * FIXME: These routines are expected to return 0 on success, but mii_send - * does _not_ return an error code. Maybe 0xFFFF means error, i.e. - * no PHY connected... - * For now always return 0. - * FIXME: These routines only work after calling eth_init() at least once! - * Otherwise they hang in mii_send() !!! Sorry! - *****************************************************************************/ - -int mcffec_miiphy_read(char *devname, unsigned char addr, unsigned char reg, - unsigned short *value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_read(0x%x) @ 0x%x = ", reg, addr); -#endif - rdreg = mii_send(mk_mii_read(addr, reg)); - - *value = rdreg; - -#ifdef MII_DEBUG - printf("0x%04x\n", *value); -#endif - - return 0; -} - -int mcffec_miiphy_write(char *devname, unsigned char addr, unsigned char reg, - unsigned short value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_write(0x%x) @ 0x%x = ", reg, addr); -#endif - - rdreg = mii_send(mk_mii_write(addr, reg, value)); - -#ifdef MII_DEBUG - printf("0x%04x\n", value); -#endif - - return 0; -} - -#endif /* CONFIG_CMD_NET, FEC_ENET & NET_MULTI */ diff --git a/board/cobra5272/Makefile b/board/cobra5272/Makefile index be704b7..cf07cf4 100644 --- a/board/cobra5272/Makefile +++ b/board/cobra5272/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
-COBJS = $(BOARD).o flash.o mii.o +COBJS = $(BOARD).o flash.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/cobra5272/mii.c b/board/cobra5272/mii.c deleted file mode 100644 index 161c694..0000000 --- a/board/cobra5272/mii.c +++ /dev/null @@ -1,303 +0,0 @@ -/* - * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. - * TsiChung Liew (Tsi-Chung.Liew@freescale.com) - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/fec.h> -#include <asm/immap.h> - -#include <config.h> -#include <net.h> - -DECLARE_GLOBAL_DATA_PTR; - -#if defined(CONFIG_CMD_NET) && defined(CONFIG_NET_MULTI) -#undef MII_DEBUG -#undef ET_DEBUG - -int fecpin_setclear(struct eth_device *dev, int setclear) -{ - volatile gpio_t *gpio = (gpio_t *) MMAP_GPIO; - - if (setclear) { - gpio->gpio_pbcnt |= GPIO_PBCNT_E_MDC | GPIO_PBCNT_E_RXER | GPIO_PBCNT_E_RXD1 | GPIO_PBCNT_E_RXD2 | GPIO_PBCNT_E_RXD3 | GPIO_PBCNT_E_TXD1 | GPIO_PBCNT_E_TXD2 | GPIO_PBCNT_E_TXD3; - } else { - } - return 0; -} - -#if defined(CONFIG_SYS_DISCOVER_PHY) || defined(CONFIG_CMD_MII) -#include <miiphy.h> - -/* Make MII read/write commands for the FEC. */ -#define mk_mii_read(ADDR, REG) (0x60020000 | ((ADDR << 23) | (REG & 0x1f) << 18)) - -#define mk_mii_write(ADDR, REG, VAL) (0x50020000 | ((ADDR << 23) | (REG & 0x1f) << 18) | (VAL & 0xffff)) - -/* PHY identification */ -#define PHY_ID_LXT970 0x78100000 /* LXT970 */ -#define PHY_ID_LXT971 0x001378e0 /* LXT971 and 972 */ -#define PHY_ID_82555 0x02a80150 /* Intel 82555 */ -#define PHY_ID_QS6612 0x01814400 /* QS6612 */ -#define PHY_ID_AMD79C784 0x00225610 /* AMD 79C784 */ -#define PHY_ID_AMD79C874VC 0x0022561B /* AMD 79C874 */ -#define PHY_ID_LSI80225 0x0016f870 /* LSI 80225 */ -#define PHY_ID_LSI80225B 0x0016f880 /* LSI 80225/B */ -#define PHY_ID_DP83848VV 0x20005C90 /* National 83848 */ -#define PHY_ID_DP83849 0x20005CA2 /* National 82849 */ - -#define STR_ID_LXT970 "LXT970" -#define STR_ID_LXT971 "LXT971" -#define STR_ID_82555 "Intel82555" -#define STR_ID_QS6612 "QS6612" -#define STR_ID_AMD79C784 "AMD79C784" -#define STR_ID_AMD79C874VC "AMD79C874VC" -#define STR_ID_LSI80225 "LSI80225" -#define STR_ID_LSI80225B "LSI80225/B" -#define STR_ID_DP83848VV "N83848" -#define STR_ID_DP83849 "N83849" - -/**************************************************************************** - * mii_init -- Initialize the MII for MII command without ethernet - * This function is a subset of eth_init - **************************************************************************** - */ -void mii_reset(struct fec_info_s *info) -{ - volatile fec_t *fecp = (fec_t *) (info->miibase); - int i; - - fecp->ecr = FEC_ECR_RESET; - for (i = 0; (fecp->ecr & FEC_ECR_RESET) && (i < FEC_RESET_DELAY); ++i) { - udelay(1); - } - if (i == FEC_RESET_DELAY) { - printf("FEC_RESET_DELAY timeout\n"); - } -} - -/* send command to phy using mii, wait for result */ -uint mii_send(uint mii_cmd) -{ - struct fec_info_s *info; - struct eth_device *dev; - volatile fec_t *ep; - uint mii_reply; - int j = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - ep = (fec_t *) info->miibase; - - ep->mmfr = mii_cmd; /* command to phy */ - - /* wait for mii complete */ - while (!(ep->eir & FEC_EIR_MII) && (j < MCFFEC_TOUT_LOOP)) { - udelay(1); - j++; - } - if (j >= MCFFEC_TOUT_LOOP) { - printf("MII not complete\n"); - return -1; - } - - mii_reply = ep->mmfr; /* result from phy */ - ep->eir = FEC_EIR_MII; /* clear MII complete */ -#ifdef ET_DEBUG - printf("%s[%d] %s: sent=0x%8.8x, reply=0x%8.8x\n", - __FILE__, __LINE__, __FUNCTION__, mii_cmd, mii_reply); -#endif - - return (mii_reply & 0xffff); /* data read from phy */ -} -#endif /* CONFIG_SYS_DISCOVER_PHY || CONFIG_CMD_MII */ - -#if defined(CONFIG_SYS_DISCOVER_PHY) -int mii_discover_phy(struct eth_device *dev) -{ -#define MAX_PHY_PASSES 11 - struct fec_info_s *info = dev->priv; - int phyaddr, pass; - uint phyno, phytype; - - if (info->phyname_init) - return info->phy_addr; - - phyaddr = -1; /* didn't find a PHY yet */ - for (pass = 1; pass <= MAX_PHY_PASSES && phyaddr < 0; ++pass) { - if (pass > 1) { - /* PHY may need more time to recover from reset. - * The LXT970 needs 50ms typical, no maximum is - * specified, so wait 10ms before try again. - * With 11 passes this gives it 100ms to wake up. - */ - udelay(10000); /* wait 10ms */ - } - - for (phyno = 0; phyno < 32 && phyaddr < 0; ++phyno) { - - phytype = mii_send(mk_mii_read(phyno, PHY_PHYIDR1)); -#ifdef ET_DEBUG - printf("PHY type 0x%x pass %d type\n", phytype, pass); -#endif - if (phytype != 0xffff) { - phyaddr = phyno; - phytype <<= 16; - phytype |= - mii_send(mk_mii_read(phyno, PHY_PHYIDR2)); - - switch (phytype & 0xffffffff) { - case PHY_ID_AMD79C874VC: - strcpy(info->phy_name, - STR_ID_AMD79C874VC); - info->phyname_init = 1; - break; - default: - strcpy(info->phy_name, "unknown"); - info->phyname_init = 1; - break; - } - -#ifdef ET_DEBUG - printf("PHY @ 0x%x pass %d type ", phyno, pass); - switch (phytype & 0xffffffff) { - case PHY_ID_AMD79C874VC: - printf(STR_ID_AMD79C874VC); - break; - default: - printf("0x%08x\n", phytype); - break; - } -#endif - } - } - } - if (phyaddr < 0) - printf("No PHY device found.\n"); - - return phyaddr; -} -#endif /* CONFIG_SYS_DISCOVER_PHY */ - -void mii_init(void) __attribute__((weak,alias("__mii_init"))); - -void __mii_init(void) -{ - volatile fec_t *fecp; - struct fec_info_s *info; - struct eth_device *dev; - int miispd = 0, i = 0; - u16 autoneg = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - fecp = (fec_t *) info->miibase; - - fecpin_setclear(dev, 1); - - mii_reset(info); - - /* We use strictly polling mode only */ - fecp->eimr = 0; - - /* Clear any pending interrupt */ - fecp->eir = 0xffffffff; - - /* Set MII speed */ - miispd = (gd->bus_clk / 1000000) / 5; - fecp->mscr = miispd << 1; - - info->phy_addr = mii_discover_phy(dev); - -#define AUTONEGLINK (PHY_BMSR_AUTN_COMP | PHY_BMSR_LS) - while (i < MCFFEC_TOUT_LOOP) { - autoneg = 0; - miiphy_read(dev->name, info->phy_addr, PHY_BMSR, &autoneg); - i++; - - if ((autoneg & AUTONEGLINK) == AUTONEGLINK) - break; - - udelay(500); - } - if (i >= MCFFEC_TOUT_LOOP) { - printf("Auto Negotiation not complete\n"); - } - - /* adapt to the half/full speed settings */ - info->dup_spd = miiphy_duplex(dev->name, info->phy_addr) << 16; - info->dup_spd |= miiphy_speed(dev->name, info->phy_addr); -} - -/***************************************************************************** - * Read and write a MII PHY register, routines used by MII Utilities - * - * FIXME: These routines are expected to return 0 on success, but mii_send - * does _not_ return an error code. Maybe 0xFFFF means error, i.e. - * no PHY connected... - * For now always return 0. - * FIXME: These routines only work after calling eth_init() at least once! - * Otherwise they hang in mii_send() !!! Sorry! - *****************************************************************************/ - -int mcffec_miiphy_read(char *devname, unsigned char addr, unsigned char reg, - unsigned short *value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_read(0x%x) @ 0x%x = ", reg, addr); -#endif - rdreg = mii_send(mk_mii_read(addr, reg)); - - *value = rdreg; - -#ifdef MII_DEBUG - printf("0x%04x\n", *value); -#endif - - return 0; -} - -int mcffec_miiphy_write(char *devname, unsigned char addr, unsigned char reg, - unsigned short value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_write(0x%x) @ 0x%x = ", reg, addr); -#endif - - rdreg = mii_send(mk_mii_write(addr, reg, value)); - -#ifdef MII_DEBUG - printf("0x%04x\n", value); -#endif - - return 0; -} - -#endif /* CONFIG_CMD_NET, FEC_ENET & NET_MULTI */ diff --git a/board/freescale/m5235evb/Makefile b/board/freescale/m5235evb/Makefile index 74c2528..981763d 100644 --- a/board/freescale/m5235evb/Makefile +++ b/board/freescale/m5235evb/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
-COBJS = $(BOARD).o mii.o +COBJS = $(BOARD).o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/freescale/m5235evb/mii.c b/board/freescale/m5235evb/mii.c deleted file mode 100644 index 5fbbd66..0000000 --- a/board/freescale/m5235evb/mii.c +++ /dev/null @@ -1,307 +0,0 @@ -/* - * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. - * TsiChung Liew (Tsi-Chung.Liew@freescale.com) - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/fec.h> -#include <asm/immap.h> - -#include <config.h> -#include <net.h> - -DECLARE_GLOBAL_DATA_PTR; - -#if defined(CONFIG_CMD_NET) && defined(CONFIG_NET_MULTI) -#undef MII_DEBUG -#undef ET_DEBUG - -int fecpin_setclear(struct eth_device *dev, int setclear) -{ - volatile gpio_t *gpio = (gpio_t *) MMAP_GPIO; - - if (setclear) { - gpio->par_feci2c |= - (GPIO_PAR_FECI2C_EMDC_FECEMDC | GPIO_PAR_FECI2C_EMDIO_FECEMDIO); - } else { - gpio->par_feci2c &= - ~(GPIO_PAR_FECI2C_EMDC_MASK | GPIO_PAR_FECI2C_EMDIO_MASK); - } - - return 0; -} - -#if defined(CONFIG_SYS_DISCOVER_PHY) || defined(CONFIG_MII) -#include <miiphy.h> - -/* Make MII read/write commands for the FEC. */ -#define mk_mii_read(ADDR, REG) (0x60020000 | ((ADDR << 23) | (REG & 0x1f) << 18)) - -#define mk_mii_write(ADDR, REG, VAL) (0x50020000 | ((ADDR << 23) | (REG & 0x1f) << 18) | (VAL & 0xffff)) - -/* PHY identification */ -#define PHY_ID_LXT970 0x78100000 /* LXT970 */ -#define PHY_ID_LXT971 0x001378e0 /* LXT971 and 972 */ -#define PHY_ID_82555 0x02a80150 /* Intel 82555 */ -#define PHY_ID_QS6612 0x01814400 /* QS6612 */ -#define PHY_ID_AMD79C784 0x00225610 /* AMD 79C784 */ -#define PHY_ID_LSI80225 0x0016f870 /* LSI 80225 */ -#define PHY_ID_LSI80225B 0x0016f880 /* LSI 80225/B */ -#define PHY_ID_DP83848VV 0x20005C90 /* National 83848 */ -#define PHY_ID_DP83849 0x20005CA2 /* National 82849 */ -#define PHY_ID_KS8721BL 0x00221619 /* Micrel KS8721BL/SL */ - -#define STR_ID_LXT970 "LXT970" -#define STR_ID_LXT971 "LXT971" -#define STR_ID_82555 "Intel82555" -#define STR_ID_QS6612 "QS6612" -#define STR_ID_AMD79C784 "AMD79C784" -#define STR_ID_LSI80225 "LSI80225" -#define STR_ID_LSI80225B "LSI80225/B" -#define STR_ID_DP83848VV "N83848" -#define STR_ID_DP83849 "N83849" -#define STR_ID_KS8721BL "KS8721BL" - -/**************************************************************************** - * mii_init -- Initialize the MII for MII command without ethernet - * This function is a subset of eth_init - **************************************************************************** - */ -void mii_reset(struct fec_info_s *info) -{ - volatile fec_t *fecp = (fec_t *) (info->miibase); - int i; - - fecp->ecr = FEC_ECR_RESET; - for (i = 0; (fecp->ecr & FEC_ECR_RESET) && (i < FEC_RESET_DELAY); ++i) { - udelay(1); - } - if (i == FEC_RESET_DELAY) { - printf("FEC_RESET_DELAY timeout\n"); - } -} - -/* send command to phy using mii, wait for result */ -uint mii_send(uint mii_cmd) -{ - struct fec_info_s *info; - struct eth_device *dev; - volatile fec_t *ep; - uint mii_reply; - int j = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - ep = (fec_t *) info->miibase; - - ep->mmfr = mii_cmd; /* command to phy */ - - /* wait for mii complete */ - while (!(ep->eir & FEC_EIR_MII) && (j < MCFFEC_TOUT_LOOP)) { - udelay(1); - j++; - } - if (j >= MCFFEC_TOUT_LOOP) { - printf("MII not complete\n"); - return -1; - } - - mii_reply = ep->mmfr; /* result from phy */ - ep->eir = FEC_EIR_MII; /* clear MII complete */ -#ifdef ET_DEBUG - printf("%s[%d] %s: sent=0x%8.8x, reply=0x%8.8x\n", - __FILE__, __LINE__, __FUNCTION__, mii_cmd, mii_reply); -#endif - - return (mii_reply & 0xffff); /* data read from phy */ -} -#endif /* CONFIG_SYS_DISCOVER_PHY || (CONFIG_MII) */ - -#if defined(CONFIG_SYS_DISCOVER_PHY) -int mii_discover_phy(struct eth_device *dev) -{ -#define MAX_PHY_PASSES 11 - struct fec_info_s *info = dev->priv; - int phyaddr, pass; - uint phyno, phytype; - - if (info->phyname_init) - return info->phy_addr; - - phyaddr = -1; /* didn't find a PHY yet */ - for (pass = 1; pass <= MAX_PHY_PASSES && phyaddr < 0; ++pass) { - if (pass > 1) { - /* PHY may need more time to recover from reset. - * The LXT970 needs 50ms typical, no maximum is - * specified, so wait 10ms before try again. - * With 11 passes this gives it 100ms to wake up. - */ - udelay(10000); /* wait 10ms */ - } - - for (phyno = 0; phyno < 32 && phyaddr < 0; ++phyno) { - - phytype = mii_send(mk_mii_read(phyno, PHY_PHYIDR1)); -#ifdef ET_DEBUG - printf("PHY type 0x%x pass %d type\n", phytype, pass); -#endif - if (phytype != 0xffff) { - phyaddr = phyno; - phytype <<= 16; - phytype |= - mii_send(mk_mii_read(phyno, PHY_PHYIDR2)); - - switch (phytype & 0xffffffff) { - case PHY_ID_KS8721BL: - strcpy(info->phy_name, - STR_ID_KS8721BL); - info->phyname_init = 1; - break; - default: - strcpy(info->phy_name, "unknown"); - info->phyname_init = 1; - break; - } - -#ifdef ET_DEBUG - printf("PHY @ 0x%x pass %d type ", phyno, pass); - switch (phytype & 0xffffffff) { - case PHY_ID_KS8721BL: - printf(STR_ID_KS8721BL); - break; - default: - printf("0x%08x\n", phytype); - break; - } -#endif - } - } - } - if (phyaddr < 0) - printf("No PHY device found.\n"); - - return phyaddr; -} -#endif /* CONFIG_SYS_DISCOVER_PHY */ - -void mii_init(void) __attribute__((weak,alias("__mii_init"))); - -void __mii_init(void) -{ - volatile fec_t *fecp; - struct fec_info_s *info; - struct eth_device *dev; - int miispd = 0, i = 0; - u16 autoneg = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - fecp = (fec_t *) info->miibase; - - fecpin_setclear(dev, 1); - - mii_reset(info); - - /* We use strictly polling mode only */ - fecp->eimr = 0; - - /* Clear any pending interrupt */ - fecp->eir = 0xffffffff; - - /* Set MII speed */ - miispd = (gd->bus_clk / 1000000) / 5; - fecp->mscr = miispd << 1; - - info->phy_addr = mii_discover_phy(dev); - -#define AUTONEGLINK (PHY_BMSR_AUTN_COMP | PHY_BMSR_LS) - while (i < MCFFEC_TOUT_LOOP) { - autoneg = 0; - miiphy_read(dev->name, info->phy_addr, PHY_BMSR, &autoneg); - i++; - - if ((autoneg & AUTONEGLINK) == AUTONEGLINK) - break; - - udelay(500); - } - if (i >= MCFFEC_TOUT_LOOP) { - printf("Auto Negotiation not complete\n"); - } - - /* adapt to the half/full speed settings */ - info->dup_spd = miiphy_duplex(dev->name, info->phy_addr) << 16; - info->dup_spd |= miiphy_speed(dev->name, info->phy_addr); -} - -/***************************************************************************** - * Read and write a MII PHY register, routines used by MII Utilities - * - * FIXME: These routines are expected to return 0 on success, but mii_send - * does _not_ return an error code. Maybe 0xFFFF means error, i.e. - * no PHY connected... - * For now always return 0. - * FIXME: These routines only work after calling eth_init() at least once! - * Otherwise they hang in mii_send() !!! Sorry! - *****************************************************************************/ - -int mcffec_miiphy_read(char *devname, unsigned char addr, unsigned char reg, - unsigned short *value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_read(0x%x) @ 0x%x = ", reg, addr); -#endif - rdreg = mii_send(mk_mii_read(addr, reg)); - - *value = rdreg; - -#ifdef MII_DEBUG - printf("0x%04x\n", *value); -#endif - - return 0; -} - -int mcffec_miiphy_write(char *devname, unsigned char addr, unsigned char reg, - unsigned short value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_write(0x%x) @ 0x%x = ", reg, addr); -#endif - - rdreg = mii_send(mk_mii_write(addr, reg, value)); - -#ifdef MII_DEBUG - printf("0x%04x\n", value); -#endif - - return 0; -} - -#endif /* CONFIG_CMD_NET, FEC_ENET & NET_MULTI */ diff --git a/board/freescale/m5271evb/Makefile b/board/freescale/m5271evb/Makefile index 2ec71ee..424ab1c 100644 --- a/board/freescale/m5271evb/Makefile +++ b/board/freescale/m5271evb/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/freescale/m5271evb/mii.c b/board/freescale/m5271evb/mii.c deleted file mode 100644 index e79fa19..0000000 --- a/board/freescale/m5271evb/mii.c +++ /dev/null @@ -1,303 +0,0 @@ -/* - * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. - * TsiChung Liew (Tsi-Chung.Liew@freescale.com) - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/fec.h> -#include <asm/immap.h> - -#include <config.h> -#include <net.h> - -DECLARE_GLOBAL_DATA_PTR; - -#if defined(CONFIG_CMD_NET) && defined(CONFIG_NET_MULTI) -#undef MII_DEBUG -#undef ET_DEBUG - -int fecpin_setclear(struct eth_device *dev, int setclear) -{ - if (setclear) { - /* Enable Ethernet pins */ - mbar_writeByte(MCF_GPIO_PAR_FECI2C, CONFIG_SYS_FECI2C); - } else { - } - - return 0; -} - -#if defined(CONFIG_SYS_DISCOVER_PHY) || defined(CONFIG_CMD_MII) -#include <miiphy.h> - -/* Make MII read/write commands for the FEC. */ -#define mk_mii_read(ADDR, REG) (0x60020000 | ((ADDR << 23) | (REG & 0x1f) << 18)) - -#define mk_mii_write(ADDR, REG, VAL) (0x50020000 | ((ADDR << 23) | (REG & 0x1f) << 18) | (VAL & 0xffff)) - -/* PHY identification */ -#define PHY_ID_LXT970 0x78100000 /* LXT970 */ -#define PHY_ID_LXT971 0x001378e0 /* LXT971 and 972 */ -#define PHY_ID_82555 0x02a80150 /* Intel 82555 */ -#define PHY_ID_QS6612 0x01814400 /* QS6612 */ -#define PHY_ID_AMD79C784 0x00225610 /* AMD 79C784 */ -#define PHY_ID_LSI80225 0x0016f870 /* LSI 80225 */ -#define PHY_ID_LSI80225B 0x0016f880 /* LSI 80225/B */ -#define PHY_ID_DP83848VV 0x20005C90 /* National 83848 */ -#define PHY_ID_DP83849 0x20005CA2 /* National 82849 */ -#define PHY_ID_KS8721BL 0x00221619 /* Micrel KS8721BL/SL */ - -#define STR_ID_LXT970 "LXT970" -#define STR_ID_LXT971 "LXT971" -#define STR_ID_82555 "Intel82555" -#define STR_ID_QS6612 "QS6612" -#define STR_ID_AMD79C784 "AMD79C784" -#define STR_ID_LSI80225 "LSI80225" -#define STR_ID_LSI80225B "LSI80225/B" -#define STR_ID_DP83848VV "N83848" -#define STR_ID_DP83849 "N83849" -#define STR_ID_KS8721BL "KS8721BL" - -/**************************************************************************** - * mii_init -- Initialize the MII for MII command without ethernet - * This function is a subset of eth_init - **************************************************************************** - */ -void mii_reset(struct fec_info_s *info) -{ - volatile fec_t *fecp = (fec_t *) (info->miibase); - int i; - - fecp->ecr = FEC_ECR_RESET; - for (i = 0; (fecp->ecr & FEC_ECR_RESET) && (i < FEC_RESET_DELAY); ++i) { - udelay(1); - } - if (i == FEC_RESET_DELAY) { - printf("FEC_RESET_DELAY timeout\n"); - } -} - -/* send command to phy using mii, wait for result */ -uint mii_send(uint mii_cmd) -{ - struct fec_info_s *info; - struct eth_device *dev; - volatile fec_t *ep; - uint mii_reply; - int j = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - ep = (fec_t *) info->miibase; - - ep->mmfr = mii_cmd; /* command to phy */ - - /* wait for mii complete */ - while (!(ep->eir & FEC_EIR_MII) && (j < MCFFEC_TOUT_LOOP)) { - udelay(1); - j++; - } - if (j >= MCFFEC_TOUT_LOOP) { - printf("MII not complete\n"); - return -1; - } - - mii_reply = ep->mmfr; /* result from phy */ - ep->eir = FEC_EIR_MII; /* clear MII complete */ -#ifdef ET_DEBUG - printf("%s[%d] %s: sent=0x%8.8x, reply=0x%8.8x\n", - __FILE__, __LINE__, __FUNCTION__, mii_cmd, mii_reply); -#endif - - return (mii_reply & 0xffff); /* data read from phy */ -} -#endif /* CONFIG_SYS_DISCOVER_PHY || CONFIG_CMD_MII */ - -#if defined(CONFIG_SYS_DISCOVER_PHY) -int mii_discover_phy(struct eth_device *dev) -{ -#define MAX_PHY_PASSES 11 - struct fec_info_s *info = dev->priv; - int phyaddr, pass; - uint phyno, phytype; - - if (info->phyname_init) - return info->phy_addr; - - phyaddr = -1; /* didn't find a PHY yet */ - for (pass = 1; pass <= MAX_PHY_PASSES && phyaddr < 0; ++pass) { - if (pass > 1) { - /* PHY may need more time to recover from reset. - * The LXT970 needs 50ms typical, no maximum is - * specified, so wait 10ms before try again. - * With 11 passes this gives it 100ms to wake up. - */ - udelay(10000); /* wait 10ms */ - } - - for (phyno = 0; phyno < 32 && phyaddr < 0; ++phyno) { - - phytype = mii_send(mk_mii_read(phyno, PHY_PHYIDR1)); -#ifdef ET_DEBUG - printf("PHY type 0x%x pass %d type\n", phytype, pass); -#endif - if (phytype != 0xffff) { - phyaddr = phyno; - phytype <<= 16; - phytype |= - mii_send(mk_mii_read(phyno, PHY_PHYIDR2)); - - switch (phytype & 0xffffffff) { - case PHY_ID_KS8721BL: - strcpy(info->phy_name, - STR_ID_KS8721BL); - info->phyname_init = 1; - break; - default: - strcpy(info->phy_name, "unknown"); - info->phyname_init = 1; - break; - } - -#ifdef ET_DEBUG - printf("PHY @ 0x%x pass %d type ", phyno, pass); - switch (phytype & 0xffffffff) { - case PHY_ID_KS8721BL: - printf(STR_ID_KS8721BL); - break; - default: - printf("0x%08x\n", phytype); - break; - } -#endif - } - } - } - if (phyaddr < 0) - printf("No PHY device found.\n"); - - return phyaddr; -} -#endif /* CONFIG_SYS_DISCOVER_PHY */ - -void mii_init(void) __attribute__((weak,alias("__mii_init"))); - -void __mii_init(void) -{ - volatile fec_t *fecp; - struct fec_info_s *info; - struct eth_device *dev; - int miispd = 0, i = 0; - u16 autoneg = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - fecp = (fec_t *) info->miibase; - - fecpin_setclear(dev, 1); - - mii_reset(info); - - /* We use strictly polling mode only */ - fecp->eimr = 0; - - /* Clear any pending interrupt */ - fecp->eir = 0xffffffff; - - /* Set MII speed */ - miispd = (gd->bus_clk / 1000000) / 5; - fecp->mscr = miispd << 1; - - info->phy_addr = mii_discover_phy(dev); - -#define AUTONEGLINK (PHY_BMSR_AUTN_COMP | PHY_BMSR_LS) - while (i < MCFFEC_TOUT_LOOP) { - autoneg = 0; - miiphy_read(dev->name, info->phy_addr, PHY_BMSR, &autoneg); - i++; - - if ((autoneg & AUTONEGLINK) == AUTONEGLINK) - break; - - udelay(500); - } - if (i >= MCFFEC_TOUT_LOOP) { - printf("Auto Negotiation not complete\n"); - } - - /* adapt to the half/full speed settings */ - info->dup_spd = miiphy_duplex(dev->name, info->phy_addr) << 16; - info->dup_spd |= miiphy_speed(dev->name, info->phy_addr); -} - -/***************************************************************************** - * Read and write a MII PHY register, routines used by MII Utilities - * - * FIXME: These routines are expected to return 0 on success, but mii_send - * does _not_ return an error code. Maybe 0xFFFF means error, i.e. - * no PHY connected... - * For now always return 0. - * FIXME: These routines only work after calling eth_init() at least once! - * Otherwise they hang in mii_send() !!! Sorry! - *****************************************************************************/ - -int mcffec_miiphy_read(char *devname, unsigned char addr, unsigned char reg, - unsigned short *value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_read(0x%x) @ 0x%x = ", reg, addr); -#endif - rdreg = mii_send(mk_mii_read(addr, reg)); - - *value = rdreg; - -#ifdef MII_DEBUG - printf("0x%04x\n", *value); -#endif - - return 0; -} - -int mcffec_miiphy_write(char *devname, unsigned char addr, unsigned char reg, - unsigned short value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_write(0x%x) @ 0x%x = ", reg, addr); -#endif - - rdreg = mii_send(mk_mii_write(addr, reg, value)); - -#ifdef MII_DEBUG - printf("0x%04x\n", value); -#endif - - return 0; -} - -#endif /* CONFIG_CMD_NET, FEC_ENET & NET_MULTI */ diff --git a/board/freescale/m5272c3/Makefile b/board/freescale/m5272c3/Makefile index be704b7..cf07cf4 100644 --- a/board/freescale/m5272c3/Makefile +++ b/board/freescale/m5272c3/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/freescale/m5272c3/mii.c b/board/freescale/m5272c3/mii.c deleted file mode 100644 index 161c694..0000000 --- a/board/freescale/m5272c3/mii.c +++ /dev/null @@ -1,303 +0,0 @@ -/* - * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. - * TsiChung Liew (Tsi-Chung.Liew@freescale.com) - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/fec.h> -#include <asm/immap.h> - -#include <config.h> -#include <net.h> - -DECLARE_GLOBAL_DATA_PTR; - -#if defined(CONFIG_CMD_NET) && defined(CONFIG_NET_MULTI) -#undef MII_DEBUG -#undef ET_DEBUG - -int fecpin_setclear(struct eth_device *dev, int setclear) -{ - volatile gpio_t *gpio = (gpio_t *) MMAP_GPIO; - - if (setclear) { - gpio->gpio_pbcnt |= GPIO_PBCNT_E_MDC | GPIO_PBCNT_E_RXER | GPIO_PBCNT_E_RXD1 | GPIO_PBCNT_E_RXD2 | GPIO_PBCNT_E_RXD3 | GPIO_PBCNT_E_TXD1 | GPIO_PBCNT_E_TXD2 | GPIO_PBCNT_E_TXD3; - } else { - } - return 0; -} - -#if defined(CONFIG_SYS_DISCOVER_PHY) || defined(CONFIG_CMD_MII) -#include <miiphy.h> - -/* Make MII read/write commands for the FEC. */ -#define mk_mii_read(ADDR, REG) (0x60020000 | ((ADDR << 23) | (REG & 0x1f) << 18)) - -#define mk_mii_write(ADDR, REG, VAL) (0x50020000 | ((ADDR << 23) | (REG & 0x1f) << 18) | (VAL & 0xffff)) - -/* PHY identification */ -#define PHY_ID_LXT970 0x78100000 /* LXT970 */ -#define PHY_ID_LXT971 0x001378e0 /* LXT971 and 972 */ -#define PHY_ID_82555 0x02a80150 /* Intel 82555 */ -#define PHY_ID_QS6612 0x01814400 /* QS6612 */ -#define PHY_ID_AMD79C784 0x00225610 /* AMD 79C784 */ -#define PHY_ID_AMD79C874VC 0x0022561B /* AMD 79C874 */ -#define PHY_ID_LSI80225 0x0016f870 /* LSI 80225 */ -#define PHY_ID_LSI80225B 0x0016f880 /* LSI 80225/B */ -#define PHY_ID_DP83848VV 0x20005C90 /* National 83848 */ -#define PHY_ID_DP83849 0x20005CA2 /* National 82849 */ - -#define STR_ID_LXT970 "LXT970" -#define STR_ID_LXT971 "LXT971" -#define STR_ID_82555 "Intel82555" -#define STR_ID_QS6612 "QS6612" -#define STR_ID_AMD79C784 "AMD79C784" -#define STR_ID_AMD79C874VC "AMD79C874VC" -#define STR_ID_LSI80225 "LSI80225" -#define STR_ID_LSI80225B "LSI80225/B" -#define STR_ID_DP83848VV "N83848" -#define STR_ID_DP83849 "N83849" - -/**************************************************************************** - * mii_init -- Initialize the MII for MII command without ethernet - * This function is a subset of eth_init - **************************************************************************** - */ -void mii_reset(struct fec_info_s *info) -{ - volatile fec_t *fecp = (fec_t *) (info->miibase); - int i; - - fecp->ecr = FEC_ECR_RESET; - for (i = 0; (fecp->ecr & FEC_ECR_RESET) && (i < FEC_RESET_DELAY); ++i) { - udelay(1); - } - if (i == FEC_RESET_DELAY) { - printf("FEC_RESET_DELAY timeout\n"); - } -} - -/* send command to phy using mii, wait for result */ -uint mii_send(uint mii_cmd) -{ - struct fec_info_s *info; - struct eth_device *dev; - volatile fec_t *ep; - uint mii_reply; - int j = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - ep = (fec_t *) info->miibase; - - ep->mmfr = mii_cmd; /* command to phy */ - - /* wait for mii complete */ - while (!(ep->eir & FEC_EIR_MII) && (j < MCFFEC_TOUT_LOOP)) { - udelay(1); - j++; - } - if (j >= MCFFEC_TOUT_LOOP) { - printf("MII not complete\n"); - return -1; - } - - mii_reply = ep->mmfr; /* result from phy */ - ep->eir = FEC_EIR_MII; /* clear MII complete */ -#ifdef ET_DEBUG - printf("%s[%d] %s: sent=0x%8.8x, reply=0x%8.8x\n", - __FILE__, __LINE__, __FUNCTION__, mii_cmd, mii_reply); -#endif - - return (mii_reply & 0xffff); /* data read from phy */ -} -#endif /* CONFIG_SYS_DISCOVER_PHY || CONFIG_CMD_MII */ - -#if defined(CONFIG_SYS_DISCOVER_PHY) -int mii_discover_phy(struct eth_device *dev) -{ -#define MAX_PHY_PASSES 11 - struct fec_info_s *info = dev->priv; - int phyaddr, pass; - uint phyno, phytype; - - if (info->phyname_init) - return info->phy_addr; - - phyaddr = -1; /* didn't find a PHY yet */ - for (pass = 1; pass <= MAX_PHY_PASSES && phyaddr < 0; ++pass) { - if (pass > 1) { - /* PHY may need more time to recover from reset. - * The LXT970 needs 50ms typical, no maximum is - * specified, so wait 10ms before try again. - * With 11 passes this gives it 100ms to wake up. - */ - udelay(10000); /* wait 10ms */ - } - - for (phyno = 0; phyno < 32 && phyaddr < 0; ++phyno) { - - phytype = mii_send(mk_mii_read(phyno, PHY_PHYIDR1)); -#ifdef ET_DEBUG - printf("PHY type 0x%x pass %d type\n", phytype, pass); -#endif - if (phytype != 0xffff) { - phyaddr = phyno; - phytype <<= 16; - phytype |= - mii_send(mk_mii_read(phyno, PHY_PHYIDR2)); - - switch (phytype & 0xffffffff) { - case PHY_ID_AMD79C874VC: - strcpy(info->phy_name, - STR_ID_AMD79C874VC); - info->phyname_init = 1; - break; - default: - strcpy(info->phy_name, "unknown"); - info->phyname_init = 1; - break; - } - -#ifdef ET_DEBUG - printf("PHY @ 0x%x pass %d type ", phyno, pass); - switch (phytype & 0xffffffff) { - case PHY_ID_AMD79C874VC: - printf(STR_ID_AMD79C874VC); - break; - default: - printf("0x%08x\n", phytype); - break; - } -#endif - } - } - } - if (phyaddr < 0) - printf("No PHY device found.\n"); - - return phyaddr; -} -#endif /* CONFIG_SYS_DISCOVER_PHY */ - -void mii_init(void) __attribute__((weak,alias("__mii_init"))); - -void __mii_init(void) -{ - volatile fec_t *fecp; - struct fec_info_s *info; - struct eth_device *dev; - int miispd = 0, i = 0; - u16 autoneg = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - fecp = (fec_t *) info->miibase; - - fecpin_setclear(dev, 1); - - mii_reset(info); - - /* We use strictly polling mode only */ - fecp->eimr = 0; - - /* Clear any pending interrupt */ - fecp->eir = 0xffffffff; - - /* Set MII speed */ - miispd = (gd->bus_clk / 1000000) / 5; - fecp->mscr = miispd << 1; - - info->phy_addr = mii_discover_phy(dev); - -#define AUTONEGLINK (PHY_BMSR_AUTN_COMP | PHY_BMSR_LS) - while (i < MCFFEC_TOUT_LOOP) { - autoneg = 0; - miiphy_read(dev->name, info->phy_addr, PHY_BMSR, &autoneg); - i++; - - if ((autoneg & AUTONEGLINK) == AUTONEGLINK) - break; - - udelay(500); - } - if (i >= MCFFEC_TOUT_LOOP) { - printf("Auto Negotiation not complete\n"); - } - - /* adapt to the half/full speed settings */ - info->dup_spd = miiphy_duplex(dev->name, info->phy_addr) << 16; - info->dup_spd |= miiphy_speed(dev->name, info->phy_addr); -} - -/***************************************************************************** - * Read and write a MII PHY register, routines used by MII Utilities - * - * FIXME: These routines are expected to return 0 on success, but mii_send - * does _not_ return an error code. Maybe 0xFFFF means error, i.e. - * no PHY connected... - * For now always return 0. - * FIXME: These routines only work after calling eth_init() at least once! - * Otherwise they hang in mii_send() !!! Sorry! - *****************************************************************************/ - -int mcffec_miiphy_read(char *devname, unsigned char addr, unsigned char reg, - unsigned short *value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_read(0x%x) @ 0x%x = ", reg, addr); -#endif - rdreg = mii_send(mk_mii_read(addr, reg)); - - *value = rdreg; - -#ifdef MII_DEBUG - printf("0x%04x\n", *value); -#endif - - return 0; -} - -int mcffec_miiphy_write(char *devname, unsigned char addr, unsigned char reg, - unsigned short value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_write(0x%x) @ 0x%x = ", reg, addr); -#endif - - rdreg = mii_send(mk_mii_write(addr, reg, value)); - -#ifdef MII_DEBUG - printf("0x%04x\n", value); -#endif - - return 0; -} - -#endif /* CONFIG_CMD_NET, FEC_ENET & NET_MULTI */ diff --git a/board/freescale/m5275evb/Makefile b/board/freescale/m5275evb/Makefile index 74c2528..981763d 100644 --- a/board/freescale/m5275evb/Makefile +++ b/board/freescale/m5275evb/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/freescale/m5275evb/mii.c b/board/freescale/m5275evb/mii.c deleted file mode 100644 index 706d8d6..0000000 --- a/board/freescale/m5275evb/mii.c +++ /dev/null @@ -1,319 +0,0 @@ -/* - * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. - * TsiChung Liew (Tsi-Chung.Liew@freescale.com) - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/fec.h> -#include <asm/immap.h> - -#include <config.h> -#include <net.h> - -DECLARE_GLOBAL_DATA_PTR; - -#if defined(CONFIG_CMD_NET) && defined(CONFIG_NET_MULTI) -#undef MII_DEBUG -#undef ET_DEBUG - -int fecpin_setclear(struct eth_device *dev, int setclear) -{ - struct fec_info_s *info = (struct fec_info_s *) dev->priv; - volatile gpio_t *gpio = (gpio_t *)MMAP_GPIO; - - if (setclear) { - /* Enable Ethernet pins */ - if (info->iobase == CONFIG_SYS_FEC0_IOBASE) { - gpio->par_feci2c |= 0x0F00; - gpio->par_fec0hl |= 0xC0; - } else { - gpio->par_feci2c |= 0x00A0; - gpio->par_fec1hl |= 0xC0; - } - } else { - if (info->iobase == CONFIG_SYS_FEC0_IOBASE) { - gpio->par_feci2c &= ~0x0F00; - gpio->par_fec0hl &= ~0xC0; - } else { - gpio->par_feci2c &= ~0x00A0; - gpio->par_fec1hl &= ~0xC0; - } - } - - return 0; -} - -#if defined(CONFIG_SYS_DISCOVER_PHY) || defined(CONFIG_CMD_MII) -#include <miiphy.h> - -/* Make MII read/write commands for the FEC. */ -#define mk_mii_read(ADDR, REG) (0x60020000 | ((ADDR << 23) | (REG & 0x1f) << 18)) - -#define mk_mii_write(ADDR, REG, VAL) (0x50020000 | ((ADDR << 23) | (REG & 0x1f) << 18) | (VAL & 0xffff)) - -/* PHY identification */ -#define PHY_ID_LXT970 0x78100000 /* LXT970 */ -#define PHY_ID_LXT971 0x001378e0 /* LXT971 and 972 */ -#define PHY_ID_82555 0x02a80150 /* Intel 82555 */ -#define PHY_ID_QS6612 0x01814400 /* QS6612 */ -#define PHY_ID_AMD79C784 0x00225610 /* AMD 79C784 */ -#define PHY_ID_LSI80225 0x0016f870 /* LSI 80225 */ -#define PHY_ID_LSI80225B 0x0016f880 /* LSI 80225/B */ -#define PHY_ID_DP83848VV 0x20005C90 /* National 83848 */ -#define PHY_ID_DP83849 0x20005CA2 /* National 82849 */ -#define PHY_ID_KS8721BL 0x00221619 /* Micrel KS8721BL/SL */ - -#define STR_ID_LXT970 "LXT970" -#define STR_ID_LXT971 "LXT971" -#define STR_ID_82555 "Intel82555" -#define STR_ID_QS6612 "QS6612" -#define STR_ID_AMD79C784 "AMD79C784" -#define STR_ID_LSI80225 "LSI80225" -#define STR_ID_LSI80225B "LSI80225/B" -#define STR_ID_DP83848VV "N83848" -#define STR_ID_DP83849 "N83849" -#define STR_ID_KS8721BL "KS8721BL" - -/**************************************************************************** - * mii_init -- Initialize the MII for MII command without ethernet - * This function is a subset of eth_init - **************************************************************************** - */ -void mii_reset(struct fec_info_s *info) -{ - volatile fec_t *fecp = (fec_t *) (info->miibase); - int i; - - fecp->ecr = FEC_ECR_RESET; - for (i = 0; (fecp->ecr & FEC_ECR_RESET) && (i < FEC_RESET_DELAY); ++i) { - udelay(1); - } - if (i == FEC_RESET_DELAY) { - printf("FEC_RESET_DELAY timeout\n"); - } -} - -/* send command to phy using mii, wait for result */ -uint mii_send(uint mii_cmd) -{ - struct fec_info_s *info; - struct eth_device *dev; - volatile fec_t *ep; - uint mii_reply; - int j = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - ep = (fec_t *) info->miibase; - - ep->mmfr = mii_cmd; /* command to phy */ - - /* wait for mii complete */ - while (!(ep->eir & FEC_EIR_MII) && (j < MCFFEC_TOUT_LOOP)) { - udelay(1); - j++; - } - if (j >= MCFFEC_TOUT_LOOP) { - printf("MII not complete\n"); - return -1; - } - - mii_reply = ep->mmfr; /* result from phy */ - ep->eir = FEC_EIR_MII; /* clear MII complete */ -#ifdef ET_DEBUG - printf("%s[%d] %s: sent=0x%8.8x, reply=0x%8.8x\n", - __FILE__, __LINE__, __FUNCTION__, mii_cmd, mii_reply); -#endif - - return (mii_reply & 0xffff); /* data read from phy */ -} -#endif /* CONFIG_SYS_DISCOVER_PHY || (CONFIG_COMMANDS & CONFIG_CMD_MII) */ - -#if defined(CONFIG_SYS_DISCOVER_PHY) -int mii_discover_phy(struct eth_device *dev) -{ -#define MAX_PHY_PASSES 11 - struct fec_info_s *info = dev->priv; - int phyaddr, pass; - uint phyno, phytype; - - if (info->phyname_init) - return info->phy_addr; - - phyaddr = -1; /* didn't find a PHY yet */ - for (pass = 1; pass <= MAX_PHY_PASSES && phyaddr < 0; ++pass) { - if (pass > 1) { - /* PHY may need more time to recover from reset. - * The LXT970 needs 50ms typical, no maximum is - * specified, so wait 10ms before try again. - * With 11 passes this gives it 100ms to wake up. - */ - udelay(10000); /* wait 10ms */ - } - - for (phyno = 0; phyno < 32 && phyaddr < 0; ++phyno) { - - phytype = mii_send(mk_mii_read(phyno, PHY_PHYIDR1)); -#ifdef ET_DEBUG - printf("PHY type 0x%x pass %d type\n", phytype, pass); -#endif - if (phytype != 0xffff) { - phyaddr = phyno; - phytype <<= 16; - phytype |= - mii_send(mk_mii_read(phyno, PHY_PHYIDR2)); - - switch (phytype & 0xffffffff) { - case PHY_ID_KS8721BL: - strcpy(info->phy_name, - STR_ID_KS8721BL); - info->phyname_init = 1; - break; - default: - strcpy(info->phy_name, "unknown"); - info->phyname_init = 1; - break; - } - -#ifdef ET_DEBUG - printf("PHY @ 0x%x pass %d type ", phyno, pass); - switch (phytype & 0xffffffff) { - case PHY_ID_KS8721BL: - printf(STR_ID_KS8721BL); - break; - default: - printf("0x%08x\n", phytype); - break; - } -#endif - } - } - } - if (phyaddr < 0) - printf("No PHY device found.\n"); - - return phyaddr; -} -#endif /* CONFIG_SYS_DISCOVER_PHY */ - -void mii_init(void) __attribute__((weak,alias("__mii_init"))); - -void __mii_init(void) -{ - volatile fec_t *fecp; - struct fec_info_s *info; - struct eth_device *dev; - int miispd = 0, i = 0; - u16 autoneg = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - fecp = (fec_t *) info->miibase; - - fecpin_setclear(dev, 1); - - mii_reset(info); - - /* We use strictly polling mode only */ - fecp->eimr = 0; - - /* Clear any pending interrupt */ - fecp->eir = 0xffffffff; - - /* Set MII speed */ - miispd = (gd->bus_clk / 1000000) / 5; - fecp->mscr = miispd << 1; - - info->phy_addr = mii_discover_phy(dev); - -#define AUTONEGLINK (PHY_BMSR_AUTN_COMP | PHY_BMSR_LS) - while (i < MCFFEC_TOUT_LOOP) { - autoneg = 0; - miiphy_read(dev->name, info->phy_addr, PHY_BMSR, &autoneg); - i++; - - if ((autoneg & AUTONEGLINK) == AUTONEGLINK) - break; - - udelay(500); - } - if (i >= MCFFEC_TOUT_LOOP) { - printf("Auto Negotiation not complete\n"); - } - - /* adapt to the half/full speed settings */ - info->dup_spd = miiphy_duplex(dev->name, info->phy_addr) << 16; - info->dup_spd |= miiphy_speed(dev->name, info->phy_addr); -} - -/***************************************************************************** - * Read and write a MII PHY register, routines used by MII Utilities - * - * FIXME: These routines are expected to return 0 on success, but mii_send - * does _not_ return an error code. Maybe 0xFFFF means error, i.e. - * no PHY connected... - * For now always return 0. - * FIXME: These routines only work after calling eth_init() at least once! - * Otherwise they hang in mii_send() !!! Sorry! - *****************************************************************************/ - -int mcffec_miiphy_read(char *devname, unsigned char addr, unsigned char reg, - unsigned short *value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_read(0x%x) @ 0x%x = ", reg, addr); -#endif - rdreg = mii_send(mk_mii_read(addr, reg)); - - *value = rdreg; - -#ifdef MII_DEBUG - printf("0x%04x\n", *value); -#endif - - return 0; -} - -int mcffec_miiphy_write(char *devname, unsigned char addr, unsigned char reg, - unsigned short value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_write(0x%x) @ 0x%x = ", reg, addr); -#endif - - rdreg = mii_send(mk_mii_write(addr, reg, value)); - -#ifdef MII_DEBUG - printf("0x%04x\n", value); -#endif - - return 0; -} - -#endif /* CONFIG_CMD_NET, FEC_ENET & NET_MULTI */ diff --git a/board/freescale/m5282evb/Makefile b/board/freescale/m5282evb/Makefile index 2ec71ee..424ab1c 100644 --- a/board/freescale/m5282evb/Makefile +++ b/board/freescale/m5282evb/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/freescale/m5282evb/mii.c b/board/freescale/m5282evb/mii.c deleted file mode 100644 index 7f92514..0000000 --- a/board/freescale/m5282evb/mii.c +++ /dev/null @@ -1,304 +0,0 @@ -/* - * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. - * TsiChung Liew (Tsi-Chung.Liew@freescale.com) - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/fec.h> -#include <asm/immap.h> - -#include <config.h> -#include <net.h> - -DECLARE_GLOBAL_DATA_PTR; - -#if defined(CONFIG_CMD_NET) && defined(CONFIG_NET_MULTI) -#undef MII_DEBUG -#undef ET_DEBUG - -int fecpin_setclear(struct eth_device *dev, int setclear) -{ - if (setclear) { - MCFGPIO_PASPAR |= 0x0F00; - MCFGPIO_PEHLPAR = CONFIG_SYS_PEHLPAR; - } else { - MCFGPIO_PASPAR &= 0xF0FF; - MCFGPIO_PEHLPAR &= ~CONFIG_SYS_PEHLPAR; - } - return 0; -} - -#if defined(CONFIG_SYS_DISCOVER_PHY) || defined(CONFIG_CMD_MII) -#include <miiphy.h> - -/* Make MII read/write commands for the FEC. */ -#define mk_mii_read(ADDR, REG) (0x60020000 | ((ADDR << 23) | (REG & 0x1f) << 18)) - -#define mk_mii_write(ADDR, REG, VAL) (0x50020000 | ((ADDR << 23) | (REG & 0x1f) << 18) | (VAL & 0xffff)) - -/* PHY identification */ -#define PHY_ID_LXT970 0x78100000 /* LXT970 */ -#define PHY_ID_LXT971 0x001378e0 /* LXT971 and 972 */ -#define PHY_ID_82555 0x02a80150 /* Intel 82555 */ -#define PHY_ID_QS6612 0x01814400 /* QS6612 */ -#define PHY_ID_AMD79C784 0x00225610 /* AMD 79C784 */ -#define PHY_ID_AMD79C874VC 0x0022561B /* AMD 79C874 */ -#define PHY_ID_LSI80225 0x0016f870 /* LSI 80225 */ -#define PHY_ID_LSI80225B 0x0016f880 /* LSI 80225/B */ -#define PHY_ID_DP83848VV 0x20005C90 /* National 83848 */ -#define PHY_ID_DP83849 0x20005CA2 /* National 82849 */ - -#define STR_ID_LXT970 "LXT970" -#define STR_ID_LXT971 "LXT971" -#define STR_ID_82555 "Intel82555" -#define STR_ID_QS6612 "QS6612" -#define STR_ID_AMD79C784 "AMD79C784" -#define STR_ID_AMD79C874VC "AMD79C874VC" -#define STR_ID_LSI80225 "LSI80225" -#define STR_ID_LSI80225B "LSI80225/B" -#define STR_ID_DP83848VV "N83848" -#define STR_ID_DP83849 "N83849" - -/**************************************************************************** - * mii_init -- Initialize the MII for MII command without ethernet - * This function is a subset of eth_init - **************************************************************************** - */ -void mii_reset(struct fec_info_s *info) -{ - volatile fec_t *fecp = (fec_t *) (info->miibase); - int i; - - fecp->ecr = FEC_ECR_RESET; - for (i = 0; (fecp->ecr & FEC_ECR_RESET) && (i < FEC_RESET_DELAY); ++i) { - udelay(1); - } - if (i == FEC_RESET_DELAY) { - printf("FEC_RESET_DELAY timeout\n"); - } -} - -/* send command to phy using mii, wait for result */ -uint mii_send(uint mii_cmd) -{ - struct fec_info_s *info; - struct eth_device *dev; - volatile fec_t *ep; - uint mii_reply; - int j = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - ep = (fec_t *) info->miibase; - - ep->mmfr = mii_cmd; /* command to phy */ - - /* wait for mii complete */ - while (!(ep->eir & FEC_EIR_MII) && (j < MCFFEC_TOUT_LOOP)) { - udelay(1); - j++; - } - if (j >= MCFFEC_TOUT_LOOP) { - printf("MII not complete\n"); - return -1; - } - - mii_reply = ep->mmfr; /* result from phy */ - ep->eir = FEC_EIR_MII; /* clear MII complete */ -#ifdef ET_DEBUG - printf("%s[%d] %s: sent=0x%8.8x, reply=0x%8.8x\n", - __FILE__, __LINE__, __FUNCTION__, mii_cmd, mii_reply); -#endif - - return (mii_reply & 0xffff); /* data read from phy */ -} -#endif /* CONFIG_SYS_DISCOVER_PHY || CONFIG_CMD_MII */ - -#if defined(CONFIG_SYS_DISCOVER_PHY) -int mii_discover_phy(struct eth_device *dev) -{ -#define MAX_PHY_PASSES 11 - struct fec_info_s *info = dev->priv; - int phyaddr, pass; - uint phyno, phytype; - - if (info->phyname_init) - return info->phy_addr; - - phyaddr = -1; /* didn't find a PHY yet */ - for (pass = 1; pass <= MAX_PHY_PASSES && phyaddr < 0; ++pass) { - if (pass > 1) { - /* PHY may need more time to recover from reset. - * The LXT970 needs 50ms typical, no maximum is - * specified, so wait 10ms before try again. - * With 11 passes this gives it 100ms to wake up. - */ - udelay(10000); /* wait 10ms */ - } - - for (phyno = 0; phyno < 32 && phyaddr < 0; ++phyno) { - - phytype = mii_send(mk_mii_read(phyno, PHY_PHYIDR1)); -#ifdef ET_DEBUG - printf("PHY type 0x%x pass %d type\n", phytype, pass); -#endif - if (phytype != 0xffff) { - phyaddr = phyno; - phytype <<= 16; - phytype |= - mii_send(mk_mii_read(phyno, PHY_PHYIDR2)); - - switch (phytype & 0xffffffff) { - case PHY_ID_AMD79C874VC: - strcpy(info->phy_name, - STR_ID_AMD79C874VC); - info->phyname_init = 1; - break; - default: - strcpy(info->phy_name, "unknown"); - info->phyname_init = 1; - break; - } - -#ifdef ET_DEBUG - printf("PHY @ 0x%x pass %d type ", phyno, pass); - switch (phytype & 0xffffffff) { - case PHY_ID_AMD79C874VC: - printf(STR_ID_AMD79C874VC); - break; - default: - printf("0x%08x\n", phytype); - break; - } -#endif - } - } - } - if (phyaddr < 0) - printf("No PHY device found.\n"); - - return phyaddr; -} -#endif /* CONFIG_SYS_DISCOVER_PHY */ - -void mii_init(void) __attribute__((weak,alias("__mii_init"))); - -void __mii_init(void) -{ - volatile fec_t *fecp; - struct fec_info_s *info; - struct eth_device *dev; - int miispd = 0, i = 0; - u16 autoneg = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - fecp = (fec_t *) info->miibase; - - fecpin_setclear(dev, 1); - - mii_reset(info); - - /* We use strictly polling mode only */ - fecp->eimr = 0; - - /* Clear any pending interrupt */ - fecp->eir = 0xffffffff; - - /* Set MII speed */ - miispd = (gd->bus_clk / 1000000) / 5; - fecp->mscr = miispd << 1; - - info->phy_addr = mii_discover_phy(dev); - -#define AUTONEGLINK (PHY_BMSR_AUTN_COMP | PHY_BMSR_LS) - while (i < MCFFEC_TOUT_LOOP) { - autoneg = 0; - miiphy_read(dev->name, info->phy_addr, PHY_BMSR, &autoneg); - i++; - - if ((autoneg & AUTONEGLINK) == AUTONEGLINK) - break; - - udelay(500); - } - if (i >= MCFFEC_TOUT_LOOP) { - printf("Auto Negotiation not complete\n"); - } - - /* adapt to the half/full speed settings */ - info->dup_spd = miiphy_duplex(dev->name, info->phy_addr) << 16; - info->dup_spd |= miiphy_speed(dev->name, info->phy_addr); -} - -/***************************************************************************** - * Read and write a MII PHY register, routines used by MII Utilities - * - * FIXME: These routines are expected to return 0 on success, but mii_send - * does _not_ return an error code. Maybe 0xFFFF means error, i.e. - * no PHY connected... - * For now always return 0. - * FIXME: These routines only work after calling eth_init() at least once! - * Otherwise they hang in mii_send() !!! Sorry! - *****************************************************************************/ - -int mcffec_miiphy_read(char *devname, unsigned char addr, unsigned char reg, - unsigned short *value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_read(0x%x) @ 0x%x = ", reg, addr); -#endif - rdreg = mii_send(mk_mii_read(addr, reg)); - - *value = rdreg; - -#ifdef MII_DEBUG - printf("0x%04x\n", *value); -#endif - - return 0; -} - -int mcffec_miiphy_write(char *devname, unsigned char addr, unsigned char reg, - unsigned short value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_write(0x%x) @ 0x%x = ", reg, addr); -#endif - - rdreg = mii_send(mk_mii_write(addr, reg, value)); - -#ifdef MII_DEBUG - printf("0x%04x\n", value); -#endif - - return 0; -} - -#endif /* CONFIG_CMD_NET, FEC_ENET & NET_MULTI */ diff --git a/board/freescale/m5329evb/Makefile b/board/freescale/m5329evb/Makefile index ab0f11e..07b693c 100644 --- a/board/freescale/m5329evb/Makefile +++ b/board/freescale/m5329evb/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).a
-COBJS = $(BOARD).o mii.o nand.o +COBJS = $(BOARD).o nand.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/freescale/m5329evb/mii.c b/board/freescale/m5329evb/mii.c deleted file mode 100644 index c0f5817..0000000 --- a/board/freescale/m5329evb/mii.c +++ /dev/null @@ -1,306 +0,0 @@ -/* - * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. - * TsiChung Liew (Tsi-Chung.Liew@freescale.com) - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/fec.h> -#include <asm/immap.h> - -#include <config.h> -#include <net.h> - -DECLARE_GLOBAL_DATA_PTR; - -#if defined(CONFIG_CMD_NET) && defined(CONFIG_NET_MULTI) -#undef MII_DEBUG -#undef ET_DEBUG - -int fecpin_setclear(struct eth_device *dev, int setclear) -{ - volatile gpio_t *gpio = (gpio_t *) MMAP_GPIO; - - if (setclear) { - gpio->par_fec |= GPIO_PAR_FEC_7W_FEC | GPIO_PAR_FEC_MII_FEC; - gpio->par_feci2c |= - GPIO_PAR_FECI2C_MDC_EMDC | GPIO_PAR_FECI2C_MDIO_EMDIO; - } else { - gpio->par_fec &= ~(GPIO_PAR_FEC_7W_FEC | GPIO_PAR_FEC_MII_FEC); - gpio->par_feci2c &= - ~(GPIO_PAR_FECI2C_MDC_EMDC | GPIO_PAR_FECI2C_MDIO_EMDIO); - } - return 0; -} - -#if defined(CONFIG_SYS_DISCOVER_PHY) || defined(CONFIG_CMD_MII) -#include <miiphy.h> - -/* Make MII read/write commands for the FEC. */ -#define mk_mii_read(ADDR, REG) (0x60020000 | ((ADDR << 23) | (REG & 0x1f) << 18)) - -#define mk_mii_write(ADDR, REG, VAL) (0x50020000 | ((ADDR << 23) | (REG & 0x1f) << 18) | (VAL & 0xffff)) - -/* PHY identification */ -#define PHY_ID_LXT970 0x78100000 /* LXT970 */ -#define PHY_ID_LXT971 0x001378e0 /* LXT971 and 972 */ -#define PHY_ID_82555 0x02a80150 /* Intel 82555 */ -#define PHY_ID_QS6612 0x01814400 /* QS6612 */ -#define PHY_ID_AMD79C784 0x00225610 /* AMD 79C784 */ -#define PHY_ID_LSI80225 0x0016f870 /* LSI 80225 */ -#define PHY_ID_LSI80225B 0x0016f880 /* LSI 80225/B */ -#define PHY_ID_DP83848VV 0x20005C90 /* National 83848 */ -#define PHY_ID_DP83849 0x20005CA2 /* National 82849 */ - -#define STR_ID_LXT970 "LXT970" -#define STR_ID_LXT971 "LXT971" -#define STR_ID_82555 "Intel82555" -#define STR_ID_QS6612 "QS6612" -#define STR_ID_AMD79C784 "AMD79C784" -#define STR_ID_LSI80225 "LSI80225" -#define STR_ID_LSI80225B "LSI80225/B" -#define STR_ID_DP83848VV "N83848" -#define STR_ID_DP83849 "N83849" - -/**************************************************************************** - * mii_init -- Initialize the MII for MII command without ethernet - * This function is a subset of eth_init - **************************************************************************** - */ -void mii_reset(struct fec_info_s *info) -{ - volatile fec_t *fecp = (fec_t *) (info->miibase); - int i; - - fecp->ecr = FEC_ECR_RESET; - for (i = 0; (fecp->ecr & FEC_ECR_RESET) && (i < FEC_RESET_DELAY); ++i) { - udelay(1); - } - if (i == FEC_RESET_DELAY) { - printf("FEC_RESET_DELAY timeout\n"); - } -} - -/* send command to phy using mii, wait for result */ -uint mii_send(uint mii_cmd) -{ - struct fec_info_s *info; - struct eth_device *dev; - volatile fec_t *ep; - uint mii_reply; - int j = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - ep = (fec_t *) info->miibase; - - ep->mmfr = mii_cmd; /* command to phy */ - - /* wait for mii complete */ - while (!(ep->eir & FEC_EIR_MII) && (j < MCFFEC_TOUT_LOOP)) { - udelay(1); - j++; - } - if (j >= MCFFEC_TOUT_LOOP) { - printf("MII not complete\n"); - return -1; - } - - mii_reply = ep->mmfr; /* result from phy */ - ep->eir = FEC_EIR_MII; /* clear MII complete */ -#ifdef ET_DEBUG - printf("%s[%d] %s: sent=0x%8.8x, reply=0x%8.8x\n", - __FILE__, __LINE__, __FUNCTION__, mii_cmd, mii_reply); -#endif - - return (mii_reply & 0xffff); /* data read from phy */ -} -#endif /* CONFIG_SYS_DISCOVER_PHY || CONFIG_CMD_MII */ - -#if defined(CONFIG_SYS_DISCOVER_PHY) -int mii_discover_phy(struct eth_device *dev) -{ -#define MAX_PHY_PASSES 11 - struct fec_info_s *info = dev->priv; - int phyaddr, pass; - uint phyno, phytype; - - if (info->phyname_init) - return info->phy_addr; - - phyaddr = -1; /* didn't find a PHY yet */ - for (pass = 1; pass <= MAX_PHY_PASSES && phyaddr < 0; ++pass) { - if (pass > 1) { - /* PHY may need more time to recover from reset. - * The LXT970 needs 50ms typical, no maximum is - * specified, so wait 10ms before try again. - * With 11 passes this gives it 100ms to wake up. - */ - udelay(10000); /* wait 10ms */ - } - - for (phyno = 0; phyno < 32 && phyaddr < 0; ++phyno) { - - phytype = mii_send(mk_mii_read(phyno, PHY_PHYIDR1)); -#ifdef ET_DEBUG - printf("PHY type 0x%x pass %d type\n", phytype, pass); -#endif - if (phytype != 0xffff) { - phyaddr = phyno; - phytype <<= 16; - phytype |= - mii_send(mk_mii_read(phyno, PHY_PHYIDR2)); - - switch (phytype & 0xffffffff) { - case PHY_ID_DP83848VV: - strcpy(info->phy_name, - STR_ID_DP83848VV); - info->phyname_init = 1; - break; - default: - strcpy(info->phy_name, "unknown"); - info->phyname_init = 1; - break; - } - -#ifdef ET_DEBUG - printf("PHY @ 0x%x pass %d type ", phyno, pass); - switch (phytype & 0xffffffff) { - case PHY_ID_DP83848VV: - printf(STR_ID_DP83848VV); - break; - default: - printf("0x%08x\n", phytype); - break; - } -#endif - } - } - } - if (phyaddr < 0) - printf("No PHY device found.\n"); - - return phyaddr; -} -#endif /* CONFIG_SYS_DISCOVER_PHY */ - -void mii_init(void) __attribute__((weak,alias("__mii_init"))); - -void __mii_init(void) -{ - volatile fec_t *fecp; - struct fec_info_s *info; - struct eth_device *dev; - int miispd = 0, i = 0; - u16 autoneg = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - fecp = (fec_t *) info->miibase; - - fecpin_setclear(dev, 1); - - mii_reset(info); - - /* We use strictly polling mode only */ - fecp->eimr = 0; - - /* Clear any pending interrupt */ - fecp->eir = 0xffffffff; - - /* Set MII speed */ - miispd = (gd->bus_clk / 1000000) / 5; - fecp->mscr = miispd << 1; - - info->phy_addr = mii_discover_phy(dev); - -#define AUTONEGLINK (PHY_BMSR_AUTN_COMP | PHY_BMSR_LS) - while (i < MCFFEC_TOUT_LOOP) { - autoneg = 0; - miiphy_read(dev->name, info->phy_addr, PHY_BMSR, &autoneg); - i++; - - if ((autoneg & AUTONEGLINK) == AUTONEGLINK) - break; - - udelay(500); - } - if (i >= MCFFEC_TOUT_LOOP) { - printf("Auto Negotiation not complete\n"); - } - - /* adapt to the half/full speed settings */ - info->dup_spd = miiphy_duplex(dev->name, info->phy_addr) << 16; - info->dup_spd |= miiphy_speed(dev->name, info->phy_addr); -} - -/***************************************************************************** - * Read and write a MII PHY register, routines used by MII Utilities - * - * FIXME: These routines are expected to return 0 on success, but mii_send - * does _not_ return an error code. Maybe 0xFFFF means error, i.e. - * no PHY connected... - * For now always return 0. - * FIXME: These routines only work after calling eth_init() at least once! - * Otherwise they hang in mii_send() !!! Sorry! - *****************************************************************************/ - -int mcffec_miiphy_read(char *devname, unsigned char addr, unsigned char reg, - unsigned short *value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_read(0x%x) @ 0x%x = ", reg, addr); -#endif - rdreg = mii_send(mk_mii_read(addr, reg)); - - *value = rdreg; - -#ifdef MII_DEBUG - printf("0x%04x\n", *value); -#endif - - return 0; -} - -int mcffec_miiphy_write(char *devname, unsigned char addr, unsigned char reg, - unsigned short value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_write(0x%x) @ 0x%x = ", reg, addr); -#endif - - rdreg = mii_send(mk_mii_write(addr, reg, value)); - -#ifdef MII_DEBUG - printf("0x%04x\n", value); -#endif - - return 0; -} - -#endif /* CONFIG_CMD_NET, FEC_ENET & NET_MULTI */ diff --git a/board/freescale/m5373evb/Makefile b/board/freescale/m5373evb/Makefile index ab0f11e..07b693c 100644 --- a/board/freescale/m5373evb/Makefile +++ b/board/freescale/m5373evb/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/freescale/m5373evb/mii.c b/board/freescale/m5373evb/mii.c deleted file mode 100644 index c0f5817..0000000 --- a/board/freescale/m5373evb/mii.c +++ /dev/null @@ -1,306 +0,0 @@ -/* - * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. - * TsiChung Liew (Tsi-Chung.Liew@freescale.com) - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/fec.h> -#include <asm/immap.h> - -#include <config.h> -#include <net.h> - -DECLARE_GLOBAL_DATA_PTR; - -#if defined(CONFIG_CMD_NET) && defined(CONFIG_NET_MULTI) -#undef MII_DEBUG -#undef ET_DEBUG - -int fecpin_setclear(struct eth_device *dev, int setclear) -{ - volatile gpio_t *gpio = (gpio_t *) MMAP_GPIO; - - if (setclear) { - gpio->par_fec |= GPIO_PAR_FEC_7W_FEC | GPIO_PAR_FEC_MII_FEC; - gpio->par_feci2c |= - GPIO_PAR_FECI2C_MDC_EMDC | GPIO_PAR_FECI2C_MDIO_EMDIO; - } else { - gpio->par_fec &= ~(GPIO_PAR_FEC_7W_FEC | GPIO_PAR_FEC_MII_FEC); - gpio->par_feci2c &= - ~(GPIO_PAR_FECI2C_MDC_EMDC | GPIO_PAR_FECI2C_MDIO_EMDIO); - } - return 0; -} - -#if defined(CONFIG_SYS_DISCOVER_PHY) || defined(CONFIG_CMD_MII) -#include <miiphy.h> - -/* Make MII read/write commands for the FEC. */ -#define mk_mii_read(ADDR, REG) (0x60020000 | ((ADDR << 23) | (REG & 0x1f) << 18)) - -#define mk_mii_write(ADDR, REG, VAL) (0x50020000 | ((ADDR << 23) | (REG & 0x1f) << 18) | (VAL & 0xffff)) - -/* PHY identification */ -#define PHY_ID_LXT970 0x78100000 /* LXT970 */ -#define PHY_ID_LXT971 0x001378e0 /* LXT971 and 972 */ -#define PHY_ID_82555 0x02a80150 /* Intel 82555 */ -#define PHY_ID_QS6612 0x01814400 /* QS6612 */ -#define PHY_ID_AMD79C784 0x00225610 /* AMD 79C784 */ -#define PHY_ID_LSI80225 0x0016f870 /* LSI 80225 */ -#define PHY_ID_LSI80225B 0x0016f880 /* LSI 80225/B */ -#define PHY_ID_DP83848VV 0x20005C90 /* National 83848 */ -#define PHY_ID_DP83849 0x20005CA2 /* National 82849 */ - -#define STR_ID_LXT970 "LXT970" -#define STR_ID_LXT971 "LXT971" -#define STR_ID_82555 "Intel82555" -#define STR_ID_QS6612 "QS6612" -#define STR_ID_AMD79C784 "AMD79C784" -#define STR_ID_LSI80225 "LSI80225" -#define STR_ID_LSI80225B "LSI80225/B" -#define STR_ID_DP83848VV "N83848" -#define STR_ID_DP83849 "N83849" - -/**************************************************************************** - * mii_init -- Initialize the MII for MII command without ethernet - * This function is a subset of eth_init - **************************************************************************** - */ -void mii_reset(struct fec_info_s *info) -{ - volatile fec_t *fecp = (fec_t *) (info->miibase); - int i; - - fecp->ecr = FEC_ECR_RESET; - for (i = 0; (fecp->ecr & FEC_ECR_RESET) && (i < FEC_RESET_DELAY); ++i) { - udelay(1); - } - if (i == FEC_RESET_DELAY) { - printf("FEC_RESET_DELAY timeout\n"); - } -} - -/* send command to phy using mii, wait for result */ -uint mii_send(uint mii_cmd) -{ - struct fec_info_s *info; - struct eth_device *dev; - volatile fec_t *ep; - uint mii_reply; - int j = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - ep = (fec_t *) info->miibase; - - ep->mmfr = mii_cmd; /* command to phy */ - - /* wait for mii complete */ - while (!(ep->eir & FEC_EIR_MII) && (j < MCFFEC_TOUT_LOOP)) { - udelay(1); - j++; - } - if (j >= MCFFEC_TOUT_LOOP) { - printf("MII not complete\n"); - return -1; - } - - mii_reply = ep->mmfr; /* result from phy */ - ep->eir = FEC_EIR_MII; /* clear MII complete */ -#ifdef ET_DEBUG - printf("%s[%d] %s: sent=0x%8.8x, reply=0x%8.8x\n", - __FILE__, __LINE__, __FUNCTION__, mii_cmd, mii_reply); -#endif - - return (mii_reply & 0xffff); /* data read from phy */ -} -#endif /* CONFIG_SYS_DISCOVER_PHY || CONFIG_CMD_MII */ - -#if defined(CONFIG_SYS_DISCOVER_PHY) -int mii_discover_phy(struct eth_device *dev) -{ -#define MAX_PHY_PASSES 11 - struct fec_info_s *info = dev->priv; - int phyaddr, pass; - uint phyno, phytype; - - if (info->phyname_init) - return info->phy_addr; - - phyaddr = -1; /* didn't find a PHY yet */ - for (pass = 1; pass <= MAX_PHY_PASSES && phyaddr < 0; ++pass) { - if (pass > 1) { - /* PHY may need more time to recover from reset. - * The LXT970 needs 50ms typical, no maximum is - * specified, so wait 10ms before try again. - * With 11 passes this gives it 100ms to wake up. - */ - udelay(10000); /* wait 10ms */ - } - - for (phyno = 0; phyno < 32 && phyaddr < 0; ++phyno) { - - phytype = mii_send(mk_mii_read(phyno, PHY_PHYIDR1)); -#ifdef ET_DEBUG - printf("PHY type 0x%x pass %d type\n", phytype, pass); -#endif - if (phytype != 0xffff) { - phyaddr = phyno; - phytype <<= 16; - phytype |= - mii_send(mk_mii_read(phyno, PHY_PHYIDR2)); - - switch (phytype & 0xffffffff) { - case PHY_ID_DP83848VV: - strcpy(info->phy_name, - STR_ID_DP83848VV); - info->phyname_init = 1; - break; - default: - strcpy(info->phy_name, "unknown"); - info->phyname_init = 1; - break; - } - -#ifdef ET_DEBUG - printf("PHY @ 0x%x pass %d type ", phyno, pass); - switch (phytype & 0xffffffff) { - case PHY_ID_DP83848VV: - printf(STR_ID_DP83848VV); - break; - default: - printf("0x%08x\n", phytype); - break; - } -#endif - } - } - } - if (phyaddr < 0) - printf("No PHY device found.\n"); - - return phyaddr; -} -#endif /* CONFIG_SYS_DISCOVER_PHY */ - -void mii_init(void) __attribute__((weak,alias("__mii_init"))); - -void __mii_init(void) -{ - volatile fec_t *fecp; - struct fec_info_s *info; - struct eth_device *dev; - int miispd = 0, i = 0; - u16 autoneg = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - fecp = (fec_t *) info->miibase; - - fecpin_setclear(dev, 1); - - mii_reset(info); - - /* We use strictly polling mode only */ - fecp->eimr = 0; - - /* Clear any pending interrupt */ - fecp->eir = 0xffffffff; - - /* Set MII speed */ - miispd = (gd->bus_clk / 1000000) / 5; - fecp->mscr = miispd << 1; - - info->phy_addr = mii_discover_phy(dev); - -#define AUTONEGLINK (PHY_BMSR_AUTN_COMP | PHY_BMSR_LS) - while (i < MCFFEC_TOUT_LOOP) { - autoneg = 0; - miiphy_read(dev->name, info->phy_addr, PHY_BMSR, &autoneg); - i++; - - if ((autoneg & AUTONEGLINK) == AUTONEGLINK) - break; - - udelay(500); - } - if (i >= MCFFEC_TOUT_LOOP) { - printf("Auto Negotiation not complete\n"); - } - - /* adapt to the half/full speed settings */ - info->dup_spd = miiphy_duplex(dev->name, info->phy_addr) << 16; - info->dup_spd |= miiphy_speed(dev->name, info->phy_addr); -} - -/***************************************************************************** - * Read and write a MII PHY register, routines used by MII Utilities - * - * FIXME: These routines are expected to return 0 on success, but mii_send - * does _not_ return an error code. Maybe 0xFFFF means error, i.e. - * no PHY connected... - * For now always return 0. - * FIXME: These routines only work after calling eth_init() at least once! - * Otherwise they hang in mii_send() !!! Sorry! - *****************************************************************************/ - -int mcffec_miiphy_read(char *devname, unsigned char addr, unsigned char reg, - unsigned short *value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_read(0x%x) @ 0x%x = ", reg, addr); -#endif - rdreg = mii_send(mk_mii_read(addr, reg)); - - *value = rdreg; - -#ifdef MII_DEBUG - printf("0x%04x\n", *value); -#endif - - return 0; -} - -int mcffec_miiphy_write(char *devname, unsigned char addr, unsigned char reg, - unsigned short value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_write(0x%x) @ 0x%x = ", reg, addr); -#endif - - rdreg = mii_send(mk_mii_write(addr, reg, value)); - -#ifdef MII_DEBUG - printf("0x%04x\n", value); -#endif - - return 0; -} - -#endif /* CONFIG_CMD_NET, FEC_ENET & NET_MULTI */ diff --git a/board/freescale/m54451evb/Makefile b/board/freescale/m54451evb/Makefile index 74c2528..981763d 100644 --- a/board/freescale/m54451evb/Makefile +++ b/board/freescale/m54451evb/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
-COBJS = $(BOARD).o mii.o +COBJS = $(BOARD).o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/freescale/m54451evb/mii.c b/board/freescale/m54451evb/mii.c deleted file mode 100644 index 6e24736..0000000 --- a/board/freescale/m54451evb/mii.c +++ /dev/null @@ -1,303 +0,0 @@ -/* - * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. - * TsiChung Liew (Tsi-Chung.Liew@freescale.com) - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/fec.h> -#include <asm/immap.h> - -#include <config.h> -#include <net.h> - -DECLARE_GLOBAL_DATA_PTR; - -#if defined(CONFIG_CMD_NET) && defined(CONFIG_NET_MULTI) -#undef MII_DEBUG -#undef ET_DEBUG - -int fecpin_setclear(struct eth_device *dev, int setclear) -{ - volatile gpio_t *gpio = (gpio_t *) MMAP_GPIO; - struct fec_info_s *info = (struct fec_info_s *)dev->priv; - - if (setclear) { - gpio->par_feci2c |= - (GPIO_PAR_FECI2C_MDC0_MDC0 | GPIO_PAR_FECI2C_MDIO0_MDIO0); - - if (info->iobase == CONFIG_SYS_FEC0_IOBASE) - gpio->par_fec |= GPIO_PAR_FEC_FEC0_RMII_GPIO; - else - gpio->par_fec |= GPIO_PAR_FEC_FEC1_RMII_ATA; - } else { - gpio->par_feci2c &= - ~(GPIO_PAR_FECI2C_MDC0_MDC0 | GPIO_PAR_FECI2C_MDIO0_MDIO0); - - if (info->iobase == CONFIG_SYS_FEC0_IOBASE) - gpio->par_fec &= GPIO_PAR_FEC_FEC0_MASK; - else - gpio->par_fec &= GPIO_PAR_FEC_FEC1_MASK; - } - return 0; -} - -#if defined(CONFIG_SYS_DISCOVER_PHY) || defined(CONFIG_CMD_MII) -#include <miiphy.h> - -/* Make MII read/write commands for the FEC. */ -#define mk_mii_read(ADDR, REG) (0x60020000 | ((ADDR << 23) | (REG & 0x1f) << 18)) - -#define mk_mii_write(ADDR, REG, VAL) (0x50020000 | ((ADDR << 23) | (REG & 0x1f) << 18) | (VAL & 0xffff)) - -/* PHY identification */ -#define PHY_ID_KSZ8041NL 0x00221512 -#define STR_ID_KSZ8041NL "KSZ8041NL" - -/**************************************************************************** - * mii_init -- Initialize the MII for MII command without ethernet - * This function is a subset of eth_init - **************************************************************************** - */ -void mii_reset(struct fec_info_s *info) -{ - volatile fec_t *fecp = (fec_t *) (info->miibase); - struct eth_device *dev; - int i, miispd; - u16 rst = 0; - - dev = eth_get_dev(); - - miispd = (gd->bus_clk / 1000000) / 5; - fecp->mscr = miispd << 1; - - miiphy_write(dev->name, info->phy_addr, PHY_BMCR, PHY_BMCR_RESET); - for (i = 0; i < FEC_RESET_DELAY; ++i) { - udelay(500); - miiphy_read(dev->name, info->phy_addr, PHY_BMCR, &rst); - if ((rst & PHY_BMCR_RESET) == 0) - break; - } - if (i == FEC_RESET_DELAY) - printf("Mii reset timeout %d\n", i); -} - -/* send command to phy using mii, wait for result */ -uint mii_send(uint mii_cmd) -{ - struct fec_info_s *info; - struct eth_device *dev; - volatile fec_t *ep; - uint mii_reply; - int j = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - ep = (fec_t *) info->miibase; - - ep->mmfr = mii_cmd; /* command to phy */ - - /* wait for mii complete */ - while (!(ep->eir & FEC_EIR_MII) && (j < MCFFEC_TOUT_LOOP)) { - udelay(1); - j++; - } - if (j >= MCFFEC_TOUT_LOOP) { - printf("MII not complete\n"); - return -1; - } - - mii_reply = ep->mmfr; /* result from phy */ - ep->eir = FEC_EIR_MII; /* clear MII complete */ -#ifdef ET_DEBUG - printf("%s[%d] %s: sent=0x%8.8x, reply=0x%8.8x\n", - __FILE__, __LINE__, __FUNCTION__, mii_cmd, mii_reply); -#endif - - return (mii_reply & 0xffff); /* data read from phy */ -} -#endif /* CONFIG_SYS_DISCOVER_PHY || (CONFIG_MII) */ - -#if defined(CONFIG_SYS_DISCOVER_PHY) -int mii_discover_phy(struct eth_device *dev) -{ -#define MAX_PHY_PASSES 11 - struct fec_info_s *info = dev->priv; - int phyaddr, pass; - uint phyno, phytype; - - if (info->phyname_init) - return info->phy_addr; - - phyaddr = -1; /* didn't find a PHY yet */ - for (pass = 1; pass <= MAX_PHY_PASSES && phyaddr < 0; ++pass) { - if (pass > 1) { - /* PHY may need more time to recover from reset. - * The LXT970 needs 50ms typical, no maximum is - * specified, so wait 10ms before try again. - * With 11 passes this gives it 100ms to wake up. - */ - udelay(10000); /* wait 10ms */ - } - - for (phyno = 0; phyno < 32 && phyaddr < 0; ++phyno) { - - phytype = mii_send(mk_mii_read(phyno, PHY_PHYIDR1)); -#ifdef ET_DEBUG - printf("PHY type 0x%x pass %d type\n", phytype, pass); -#endif - if (phytype != 0xffff) { - phyaddr = phyno; - phytype <<= 16; - phytype |= - mii_send(mk_mii_read(phyno, PHY_PHYIDR2)); - - switch (phytype & 0xffffffff) { - case PHY_ID_KSZ8041NL: - strcpy(info->phy_name, - STR_ID_KSZ8041NL); - info->phyname_init = 1; - break; - default: - strcpy(info->phy_name, "unknown"); - info->phyname_init = 1; - break; - } - -#ifdef ET_DEBUG - printf("PHY @ 0x%x pass %d type ", phyno, pass); - switch (phytype & 0xffffffff) { - case PHY_ID_KSZ8041NL: - printf(STR_ID_KSZ8041NL); - break; - default: - printf("0x%08x\n", phytype); - break; - } -#endif - } - } - } - if (phyaddr < 0) - printf("No PHY device found.\n"); - - return phyaddr; -} -#endif /* CONFIG_SYS_DISCOVER_PHY */ - -void mii_init(void) __attribute__ ((weak, alias("__mii_init"))); - -void __mii_init(void) -{ - volatile fec_t *fecp; - struct fec_info_s *info; - struct eth_device *dev; - int miispd = 0, i = 0; - u16 autoneg = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - fecp = (fec_t *) info->miibase; - - /* We use strictly polling mode only */ - fecp->eimr = 0; - - /* Clear any pending interrupt */ - fecp->eir = 0xffffffff; - - /* Set MII speed */ - miispd = (gd->bus_clk / 1000000) / 5; - fecp->mscr = miispd << 1; - - info->phy_addr = mii_discover_phy(dev); - -#define AUTONEGLINK (PHY_BMSR_AUTN_COMP | PHY_BMSR_LS) - while (i < MCFFEC_TOUT_LOOP) { - autoneg = 0; - miiphy_read(dev->name, info->phy_addr, PHY_BMSR, &autoneg); - i++; - - if ((autoneg & AUTONEGLINK) == AUTONEGLINK) - break; - - udelay(500); - } - if (i >= MCFFEC_TOUT_LOOP) { - printf("Auto Negotiation not complete\n"); - } - - /* adapt to the half/full speed settings */ - info->dup_spd = miiphy_duplex(dev->name, info->phy_addr) << 16; - info->dup_spd |= miiphy_speed(dev->name, info->phy_addr); -} - -/***************************************************************************** - * Read and write a MII PHY register, routines used by MII Utilities - * - * FIXME: These routines are expected to return 0 on success, but mii_send - * does _not_ return an error code. Maybe 0xFFFF means error, i.e. - * no PHY connected... - * For now always return 0. - * FIXME: These routines only work after calling eth_init() at least once! - * Otherwise they hang in mii_send() !!! Sorry! - *****************************************************************************/ - -int mcffec_miiphy_read(char *devname, unsigned char addr, unsigned char reg, - unsigned short *value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_read(0x%x) @ 0x%x = ", reg, addr); -#endif - rdreg = mii_send(mk_mii_read(addr, reg)); - - *value = rdreg; - -#ifdef MII_DEBUG - printf("0x%04x\n", *value); -#endif - - return 0; -} - -int mcffec_miiphy_write(char *devname, unsigned char addr, unsigned char reg, - unsigned short value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_write(0x%x) @ 0x%x = ", reg, addr); -#endif - - rdreg = mii_send(mk_mii_write(addr, reg, value)); - -#ifdef MII_DEBUG - printf("0x%04x\n", value); -#endif - - return 0; -} - -#endif /* CONFIG_CMD_NET, FEC_ENET & NET_MULTI */ diff --git a/board/freescale/m54455evb/Makefile b/board/freescale/m54455evb/Makefile index 74c2528..981763d 100644 --- a/board/freescale/m54455evb/Makefile +++ b/board/freescale/m54455evb/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/freescale/m54455evb/mii.c b/board/freescale/m54455evb/mii.c deleted file mode 100644 index c195191..0000000 --- a/board/freescale/m54455evb/mii.c +++ /dev/null @@ -1,324 +0,0 @@ -/* - * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. - * TsiChung Liew (Tsi-Chung.Liew@freescale.com) - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/fec.h> -#include <asm/immap.h> - -#include <config.h> -#include <net.h> - -DECLARE_GLOBAL_DATA_PTR; - -#if defined(CONFIG_CMD_NET) && defined(CONFIG_NET_MULTI) -#undef MII_DEBUG -#undef ET_DEBUG - -int fecpin_setclear(struct eth_device *dev, int setclear) -{ - volatile gpio_t *gpio = (gpio_t *) MMAP_GPIO; - struct fec_info_s *info = (struct fec_info_s *)dev->priv; - - if (setclear) { - gpio->par_feci2c |= - (GPIO_PAR_FECI2C_MDC0_MDC0 | GPIO_PAR_FECI2C_MDIO0_MDIO0); - - if (info->iobase == CONFIG_SYS_FEC0_IOBASE) - gpio->par_fec |= GPIO_PAR_FEC_FEC0_RMII_GPIO; - else - gpio->par_fec |= GPIO_PAR_FEC_FEC1_RMII_ATA; - } else { - gpio->par_feci2c &= - ~(GPIO_PAR_FECI2C_MDC0_MDC0 | GPIO_PAR_FECI2C_MDIO0_MDIO0); - - if (info->iobase == CONFIG_SYS_FEC0_IOBASE) - gpio->par_fec &= GPIO_PAR_FEC_FEC0_MASK; - else - gpio->par_fec &= GPIO_PAR_FEC_FEC1_MASK; - } - return 0; -} - -#if defined(CONFIG_SYS_DISCOVER_PHY) || defined(CONFIG_CMD_MII) -#include <miiphy.h> - -/* Make MII read/write commands for the FEC. */ -#define mk_mii_read(ADDR, REG) (0x60020000 | ((ADDR << 23) | (REG & 0x1f) << 18)) - -#define mk_mii_write(ADDR, REG, VAL) (0x50020000 | ((ADDR << 23) | (REG & 0x1f) << 18) | (VAL & 0xffff)) - -/* PHY identification */ -#define PHY_ID_LXT970 0x78100000 /* LXT970 */ -#define PHY_ID_LXT971 0x001378e0 /* LXT971 and 972 */ -#define PHY_ID_82555 0x02a80150 /* Intel 82555 */ -#define PHY_ID_QS6612 0x01814400 /* QS6612 */ -#define PHY_ID_AMD79C784 0x00225610 /* AMD 79C784 */ -#define PHY_ID_LSI80225 0x0016f870 /* LSI 80225 */ -#define PHY_ID_LSI80225B 0x0016f880 /* LSI 80225/B */ -#define PHY_ID_DP83848VV 0x20005C90 /* National 83848 */ -#define PHY_ID_DP83849 0x20005CA2 /* National 82849 */ - -#define STR_ID_LXT970 "LXT970" -#define STR_ID_LXT971 "LXT971" -#define STR_ID_82555 "Intel82555" -#define STR_ID_QS6612 "QS6612" -#define STR_ID_AMD79C784 "AMD79C784" -#define STR_ID_LSI80225 "LSI80225" -#define STR_ID_LSI80225B "LSI80225/B" -#define STR_ID_DP83848VV "N83848" -#define STR_ID_DP83849 "N83849" - -/**************************************************************************** - * mii_init -- Initialize the MII for MII command without ethernet - * This function is a subset of eth_init - **************************************************************************** - */ -void mii_reset(struct fec_info_s *info) -{ - volatile fec_t *fecp = (fec_t *) (info->miibase); - struct eth_device *dev; - int i, miispd; - u16 rst = 0; - - dev = eth_get_dev(); - - miispd = (gd->bus_clk / 1000000) / 5; - fecp->mscr = miispd << 1; - - miiphy_write(dev->name, info->phy_addr, PHY_BMCR, PHY_BMCR_RESET); - for (i = 0; i < FEC_RESET_DELAY; ++i) { - udelay(500); - miiphy_read(dev->name, info->phy_addr, PHY_BMCR, &rst); - if ((rst & PHY_BMCR_RESET) == 0) - break; - } - if (i == FEC_RESET_DELAY) - printf("Mii reset timeout %d\n", i); -} - -/* send command to phy using mii, wait for result */ -uint mii_send(uint mii_cmd) -{ - struct fec_info_s *info; - struct eth_device *dev; - volatile fec_t *ep; - uint mii_reply; - int j = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - ep = (fec_t *) info->miibase; - - ep->mmfr = mii_cmd; /* command to phy */ - - /* wait for mii complete */ - while (!(ep->eir & FEC_EIR_MII) && (j < MCFFEC_TOUT_LOOP)) { - udelay(1); - j++; - } - if (j >= MCFFEC_TOUT_LOOP) { - printf("MII not complete\n"); - return -1; - } - - mii_reply = ep->mmfr; /* result from phy */ - ep->eir = FEC_EIR_MII; /* clear MII complete */ -#ifdef ET_DEBUG - printf("%s[%d] %s: sent=0x%8.8x, reply=0x%8.8x\n", - __FILE__, __LINE__, __FUNCTION__, mii_cmd, mii_reply); -#endif - - return (mii_reply & 0xffff); /* data read from phy */ -} -#endif /* CONFIG_SYS_DISCOVER_PHY || (CONFIG_MII) */ - -#if defined(CONFIG_SYS_DISCOVER_PHY) -int mii_discover_phy(struct eth_device *dev) -{ -#define MAX_PHY_PASSES 11 - struct fec_info_s *info = dev->priv; - int phyaddr, pass; - uint phyno, phytype; - - if (info->phyname_init) - return info->phy_addr; - - phyaddr = -1; /* didn't find a PHY yet */ - for (pass = 1; pass <= MAX_PHY_PASSES && phyaddr < 0; ++pass) { - if (pass > 1) { - /* PHY may need more time to recover from reset. - * The LXT970 needs 50ms typical, no maximum is - * specified, so wait 10ms before try again. - * With 11 passes this gives it 100ms to wake up. - */ - udelay(10000); /* wait 10ms */ - } - - for (phyno = 0; phyno < 32 && phyaddr < 0; ++phyno) { - - phytype = mii_send(mk_mii_read(phyno, PHY_PHYIDR1)); -#ifdef ET_DEBUG - printf("PHY type 0x%x pass %d type\n", phytype, pass); -#endif - if (phytype != 0xffff) { - phyaddr = phyno; - phytype <<= 16; - phytype |= - mii_send(mk_mii_read(phyno, PHY_PHYIDR2)); - - switch (phytype & 0xffffffff) { - case PHY_ID_DP83848VV: - strcpy(info->phy_name, - STR_ID_DP83848VV); - info->phyname_init = 1; - break; - default: - strcpy(info->phy_name, "unknown"); - info->phyname_init = 1; - break; - } - -#ifdef ET_DEBUG - printf("PHY @ 0x%x pass %d type ", phyno, pass); - switch (phytype & 0xffffffff) { - case PHY_ID_DP83848VV: - printf(STR_ID_DP83848VV); - break; - default: - printf("0x%08x\n", phytype); - break; - } -#endif - } - } - } - if (phyaddr < 0) - printf("No PHY device found.\n"); - - return phyaddr; -} -#endif /* CONFIG_SYS_DISCOVER_PHY */ - -void mii_init(void) __attribute__((weak,alias("__mii_init"))); - -void __mii_init(void) -{ - volatile fec_t *fecp; - struct fec_info_s *info; - struct eth_device *dev; - int miispd = 0, i = 0; - u16 autoneg = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - fecp = (fec_t *) info->miibase; - - fecpin_setclear(dev, 1); - - mii_reset(info); - - /* We use strictly polling mode only */ - fecp->eimr = 0; - - /* Clear any pending interrupt */ - fecp->eir = 0xffffffff; - - /* Set MII speed */ - miispd = (gd->bus_clk / 1000000) / 5; - fecp->mscr = miispd << 1; - - info->phy_addr = mii_discover_phy(dev); - -#define AUTONEGLINK (PHY_BMSR_AUTN_COMP | PHY_BMSR_LS) - while (i < MCFFEC_TOUT_LOOP) { - autoneg = 0; - miiphy_read(dev->name, info->phy_addr, PHY_BMSR, &autoneg); - i++; - - if ((autoneg & AUTONEGLINK) == AUTONEGLINK) - break; - - udelay(500); - } - if (i >= MCFFEC_TOUT_LOOP) { - printf("Auto Negotiation not complete\n"); - } - - /* adapt to the half/full speed settings */ - info->dup_spd = miiphy_duplex(dev->name, info->phy_addr) << 16; - info->dup_spd |= miiphy_speed(dev->name, info->phy_addr); -} - -/***************************************************************************** - * Read and write a MII PHY register, routines used by MII Utilities - * - * FIXME: These routines are expected to return 0 on success, but mii_send - * does _not_ return an error code. Maybe 0xFFFF means error, i.e. - * no PHY connected... - * For now always return 0. - * FIXME: These routines only work after calling eth_init() at least once! - * Otherwise they hang in mii_send() !!! Sorry! - *****************************************************************************/ - -int mcffec_miiphy_read(char *devname, unsigned char addr, unsigned char reg, - unsigned short *value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_read(0x%x) @ 0x%x = ", reg, addr); -#endif - rdreg = mii_send(mk_mii_read(addr, reg)); - - *value = rdreg; - -#ifdef MII_DEBUG - printf("0x%04x\n", *value); -#endif - - return 0; -} - -int mcffec_miiphy_write(char *devname, unsigned char addr, unsigned char reg, - unsigned short value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_write(0x%x) @ 0x%x = ", reg, addr); -#endif - - rdreg = mii_send(mk_mii_write(addr, reg, value)); - -#ifdef MII_DEBUG - printf("0x%04x\n", value); -#endif - - return 0; -} - -#endif /* CONFIG_CMD_NET, FEC_ENET & NET_MULTI */ diff --git a/board/freescale/m547xevb/Makefile b/board/freescale/m547xevb/Makefile index 74c2528..981763d 100644 --- a/board/freescale/m547xevb/Makefile +++ b/board/freescale/m547xevb/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/freescale/m547xevb/mii.c b/board/freescale/m547xevb/mii.c deleted file mode 100644 index 4d11506..0000000 --- a/board/freescale/m547xevb/mii.c +++ /dev/null @@ -1,322 +0,0 @@ -/* - * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. - * TsiChung Liew (Tsi-Chung.Liew@freescale.com) - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <config.h> -#include <net.h> - -#include <asm/immap.h> -#include <asm/fec.h> -#include <asm/fsl_mcdmafec.h> - -DECLARE_GLOBAL_DATA_PTR; - -#if defined(CONFIG_CMD_NET) && defined(CONFIG_NET_MULTI) -#undef MII_DEBUG -#undef ET_DEBUG - -int fecpin_setclear(struct eth_device *dev, int setclear) -{ - volatile gpio_t *gpio = (gpio_t *) MMAP_GPIO; - struct fec_info_dma *info = (struct fec_info_dma *)dev->priv; - - if (setclear) { - if (info->iobase == CONFIG_SYS_FEC0_IOBASE) - gpio->par_feci2cirq |= 0xF000; - else - gpio->par_feci2cirq |= 0x0FC0; - } else { - if (info->iobase == CONFIG_SYS_FEC0_IOBASE) - gpio->par_feci2cirq &= 0x0FFF; - else - gpio->par_feci2cirq &= 0xF03F; - } - return 0; -} - -#if defined(CONFIG_SYS_DISCOVER_PHY) || defined(CONFIG_CMD_MII) -#include <miiphy.h> - -/* Make MII read/write commands for the FEC. */ -#define mk_mii_read(ADDR, REG) (0x60020000 | ((ADDR << 23) | (REG & 0x1f) << 18)) - -#define mk_mii_write(ADDR, REG, VAL) (0x50020000 | ((ADDR << 23) | (REG & 0x1f) << 18) | (VAL & 0xffff)) - -/* PHY identification */ -#define PHY_ID_LXT970 0x78100000 /* LXT970 */ -#define PHY_ID_LXT971 0x001378e0 /* LXT971 and 972 */ -#define PHY_ID_82555 0x02a80150 /* Intel 82555 */ -#define PHY_ID_QS6612 0x01814400 /* QS6612 */ -#define PHY_ID_AMD79C784 0x00225610 /* AMD 79C784 */ -#define PHY_ID_LSI80225 0x0016f870 /* LSI 80225 */ -#define PHY_ID_LSI80225B 0x0016f880 /* LSI 80225/B */ -#define PHY_ID_DP83848VV 0x20005C90 /* National 83848 */ -#define PHY_ID_DP83849 0x20005CA2 /* National 82849 */ -#define PHY_ID_BCM5222 0x00406322 /* Broadcom 5222 */ - -#define STR_ID_LXT970 "LXT970" -#define STR_ID_LXT971 "LXT971" -#define STR_ID_82555 "Intel82555" -#define STR_ID_QS6612 "QS6612" -#define STR_ID_AMD79C784 "AMD79C784" -#define STR_ID_LSI80225 "LSI80225" -#define STR_ID_LSI80225B "LSI80225/B" -#define STR_ID_DP83848VV "N83848" -#define STR_ID_DP83849 "N83849" -#define STR_ID_BCM5222 "BCM5222" - -/**************************************************************************** - * mii_init -- Initialize the MII for MII command without ethernet - * This function is a subset of eth_init - **************************************************************************** - */ -void mii_reset(struct fec_info_dma *info) -{ - volatile fecdma_t *fecp = (fecdma_t *) (info->miibase); - int i; - - fecp->ecr = FEC_ECR_RESET; - for (i = 0; (fecp->ecr & FEC_ECR_RESET) && (i < FEC_RESET_DELAY); ++i) { - udelay(1); - } - if (i == FEC_RESET_DELAY) { - printf("FEC_RESET_DELAY timeout\n"); - } -} - -/* send command to phy using mii, wait for result */ -uint mii_send(uint mii_cmd) -{ - struct fec_info_dma *info; - struct eth_device *dev; - volatile fecdma_t *ep; - uint mii_reply; - int j = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - ep = (fecdma_t *) info->miibase; - - ep->mmfr = mii_cmd; /* command to phy */ - - /* wait for mii complete */ - while (!(ep->eir & FEC_EIR_MII) && (j < MCFFEC_TOUT_LOOP)) { - udelay(1); - j++; - } - if (j >= MCFFEC_TOUT_LOOP) { - printf("MII not complete\n"); - return -1; - } - - mii_reply = ep->mmfr; /* result from phy */ - ep->eir = FEC_EIR_MII; /* clear MII complete */ -#ifdef ET_DEBUG - printf("%s[%d] %s: sent=0x%8.8x, reply=0x%8.8x\n", - __FILE__, __LINE__, __FUNCTION__, mii_cmd, mii_reply); -#endif - - return (mii_reply & 0xffff); /* data read from phy */ -} -#endif /* CONFIG_SYS_DISCOVER_PHY || CONFIG_CMD_MII */ - -#if defined(CONFIG_SYS_DISCOVER_PHY) -int mii_discover_phy(struct eth_device *dev) -{ -#define MAX_PHY_PASSES 11 - struct fec_info_dma *info = dev->priv; - int phyaddr, pass, temp; - uint phyno, phytype; - - if (info->phyname_init) { - return info->phy_addr; - } - - phyaddr = -1; /* didn't find a PHY yet */ - for (pass = 1; pass <= MAX_PHY_PASSES && phyaddr < 0; ++pass) { - if (pass > 1) { - /* PHY may need more time to recover from reset. - * The LXT970 needs 50ms typical, no maximum is - * specified, so wait 10ms before try again. - * With 11 passes this gives it 100ms to wake up. - */ - udelay(10000); /* wait 10ms */ - } - - temp = 0; - if (info->index > 0) { - /* Some phy have multiple address, to solve the issue - where phyno keeps starting from 0, check the - previous phy address if both miibase are the same. */ - if (info->miibase == (info->next)->miibase) { - temp = (info->next)->phy_addr + 1; - } - } - - for (phyno = temp; phyno < 32 && phyaddr < 0; ++phyno) { - - phytype = mii_send(mk_mii_read(phyno, PHY_PHYIDR1)); -#ifdef ET_DEBUG - printf("PHY type 0x%x pass %d type\n", phytype, pass); -#endif - if (phytype != 0xffff) { - phyaddr = phyno; - phytype <<= 16; - phytype |= - mii_send(mk_mii_read(phyno, PHY_PHYIDR2)); - - switch (phytype & 0xffffffff) { - case PHY_ID_BCM5222: - strcpy(info->phy_name, STR_ID_BCM5222); - info->phyname_init = 1; - break; - default: - strcpy(info->phy_name, "unknown"); - info->phyname_init = 1; - break; - } - -#ifdef ET_DEBUG - printf("PHY @ 0x%x pass %d type ", phyno, pass); - switch (phytype & 0xffffffff) { - case PHY_ID_BCM5222: - printf(STR_ID_BCM5222); - break; - default: - printf("0x%08x\n", phytype); - break; - } -#endif - } - } - } - if (phyaddr < 0) - printf("No PHY device found.\n"); - - return phyaddr; -} -#endif /* CONFIG_SYS_DISCOVER_PHY */ - -void mii_init(void) __attribute__ ((weak, alias("__mii_init"))); - -void __mii_init(void) -{ - volatile fecdma_t *fecp; - struct fec_info_dma *info; - struct eth_device *dev; - int miispd = 0, i = 0; - u16 autoneg = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - fecp = (fecdma_t *) info->miibase; - - fecpin_setclear(dev, 1); - - mii_reset(info); - - /* We use strictly polling mode only */ - fecp->eimr = 0; - - /* Clear any pending interrupt */ - fecp->eir = 0xffffffff; - - /* Set MII speed */ - miispd = (gd->bus_clk / 1000000) / 5; - fecp->mscr = miispd << 1; - - info->phy_addr = mii_discover_phy(dev); - -#define AUTONEGLINK (PHY_BMSR_AUTN_COMP | PHY_BMSR_LS) - while (i < MCFFEC_TOUT_LOOP) { - autoneg = 0; - miiphy_read(dev->name, info->phy_addr, PHY_BMSR, &autoneg); - i++; - - if ((autoneg & AUTONEGLINK) == AUTONEGLINK) - break; - - udelay(500); - } - if (i >= MCFFEC_TOUT_LOOP) { - printf("Auto Negotiation not complete\n"); - } - - /* adapt to the half/full speed settings */ - info->dup_spd = miiphy_duplex(dev->name, info->phy_addr) << 16; - info->dup_spd |= miiphy_speed(dev->name, info->phy_addr); -} - -/***************************************************************************** - * Read and write a MII PHY register, routines used by MII Utilities - * - * FIXME: These routines are expected to return 0 on success, but mii_send - * does _not_ return an error code. Maybe 0xFFFF means error, i.e. - * no PHY connected... - * For now always return 0. - * FIXME: These routines only work after calling eth_init() at least once! - * Otherwise they hang in mii_send() !!! Sorry! - *****************************************************************************/ - -int mcffec_miiphy_read(char *devname, unsigned char addr, unsigned char reg, - unsigned short *value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_read(0x%x) @ 0x%x = ", reg, addr); -#endif - rdreg = mii_send(mk_mii_read(addr, reg)); - - *value = rdreg; - -#ifdef MII_DEBUG - printf("0x%04x\n", *value); -#endif - - return 0; -} - -int mcffec_miiphy_write(char *devname, unsigned char addr, unsigned char reg, - unsigned short value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_write(0x%x) @ 0x%x = ", reg, addr); -#endif - - rdreg = mii_send(mk_mii_write(addr, reg, value)); - -#ifdef MII_DEBUG - printf("0x%04x\n", value); -#endif - - return 0; -} - -#endif /* CONFIG_CMD_NET, FEC_ENET & NET_MULTI */ diff --git a/board/freescale/m548xevb/Makefile b/board/freescale/m548xevb/Makefile index 74c2528..981763d 100644 --- a/board/freescale/m548xevb/Makefile +++ b/board/freescale/m548xevb/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/freescale/m548xevb/mii.c b/board/freescale/m548xevb/mii.c deleted file mode 100644 index 4d11506..0000000 --- a/board/freescale/m548xevb/mii.c +++ /dev/null @@ -1,322 +0,0 @@ -/* - * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. - * TsiChung Liew (Tsi-Chung.Liew@freescale.com) - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <config.h> -#include <net.h> - -#include <asm/immap.h> -#include <asm/fec.h> -#include <asm/fsl_mcdmafec.h> - -DECLARE_GLOBAL_DATA_PTR; - -#if defined(CONFIG_CMD_NET) && defined(CONFIG_NET_MULTI) -#undef MII_DEBUG -#undef ET_DEBUG - -int fecpin_setclear(struct eth_device *dev, int setclear) -{ - volatile gpio_t *gpio = (gpio_t *) MMAP_GPIO; - struct fec_info_dma *info = (struct fec_info_dma *)dev->priv; - - if (setclear) { - if (info->iobase == CONFIG_SYS_FEC0_IOBASE) - gpio->par_feci2cirq |= 0xF000; - else - gpio->par_feci2cirq |= 0x0FC0; - } else { - if (info->iobase == CONFIG_SYS_FEC0_IOBASE) - gpio->par_feci2cirq &= 0x0FFF; - else - gpio->par_feci2cirq &= 0xF03F; - } - return 0; -} - -#if defined(CONFIG_SYS_DISCOVER_PHY) || defined(CONFIG_CMD_MII) -#include <miiphy.h> - -/* Make MII read/write commands for the FEC. */ -#define mk_mii_read(ADDR, REG) (0x60020000 | ((ADDR << 23) | (REG & 0x1f) << 18)) - -#define mk_mii_write(ADDR, REG, VAL) (0x50020000 | ((ADDR << 23) | (REG & 0x1f) << 18) | (VAL & 0xffff)) - -/* PHY identification */ -#define PHY_ID_LXT970 0x78100000 /* LXT970 */ -#define PHY_ID_LXT971 0x001378e0 /* LXT971 and 972 */ -#define PHY_ID_82555 0x02a80150 /* Intel 82555 */ -#define PHY_ID_QS6612 0x01814400 /* QS6612 */ -#define PHY_ID_AMD79C784 0x00225610 /* AMD 79C784 */ -#define PHY_ID_LSI80225 0x0016f870 /* LSI 80225 */ -#define PHY_ID_LSI80225B 0x0016f880 /* LSI 80225/B */ -#define PHY_ID_DP83848VV 0x20005C90 /* National 83848 */ -#define PHY_ID_DP83849 0x20005CA2 /* National 82849 */ -#define PHY_ID_BCM5222 0x00406322 /* Broadcom 5222 */ - -#define STR_ID_LXT970 "LXT970" -#define STR_ID_LXT971 "LXT971" -#define STR_ID_82555 "Intel82555" -#define STR_ID_QS6612 "QS6612" -#define STR_ID_AMD79C784 "AMD79C784" -#define STR_ID_LSI80225 "LSI80225" -#define STR_ID_LSI80225B "LSI80225/B" -#define STR_ID_DP83848VV "N83848" -#define STR_ID_DP83849 "N83849" -#define STR_ID_BCM5222 "BCM5222" - -/**************************************************************************** - * mii_init -- Initialize the MII for MII command without ethernet - * This function is a subset of eth_init - **************************************************************************** - */ -void mii_reset(struct fec_info_dma *info) -{ - volatile fecdma_t *fecp = (fecdma_t *) (info->miibase); - int i; - - fecp->ecr = FEC_ECR_RESET; - for (i = 0; (fecp->ecr & FEC_ECR_RESET) && (i < FEC_RESET_DELAY); ++i) { - udelay(1); - } - if (i == FEC_RESET_DELAY) { - printf("FEC_RESET_DELAY timeout\n"); - } -} - -/* send command to phy using mii, wait for result */ -uint mii_send(uint mii_cmd) -{ - struct fec_info_dma *info; - struct eth_device *dev; - volatile fecdma_t *ep; - uint mii_reply; - int j = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - ep = (fecdma_t *) info->miibase; - - ep->mmfr = mii_cmd; /* command to phy */ - - /* wait for mii complete */ - while (!(ep->eir & FEC_EIR_MII) && (j < MCFFEC_TOUT_LOOP)) { - udelay(1); - j++; - } - if (j >= MCFFEC_TOUT_LOOP) { - printf("MII not complete\n"); - return -1; - } - - mii_reply = ep->mmfr; /* result from phy */ - ep->eir = FEC_EIR_MII; /* clear MII complete */ -#ifdef ET_DEBUG - printf("%s[%d] %s: sent=0x%8.8x, reply=0x%8.8x\n", - __FILE__, __LINE__, __FUNCTION__, mii_cmd, mii_reply); -#endif - - return (mii_reply & 0xffff); /* data read from phy */ -} -#endif /* CONFIG_SYS_DISCOVER_PHY || CONFIG_CMD_MII */ - -#if defined(CONFIG_SYS_DISCOVER_PHY) -int mii_discover_phy(struct eth_device *dev) -{ -#define MAX_PHY_PASSES 11 - struct fec_info_dma *info = dev->priv; - int phyaddr, pass, temp; - uint phyno, phytype; - - if (info->phyname_init) { - return info->phy_addr; - } - - phyaddr = -1; /* didn't find a PHY yet */ - for (pass = 1; pass <= MAX_PHY_PASSES && phyaddr < 0; ++pass) { - if (pass > 1) { - /* PHY may need more time to recover from reset. - * The LXT970 needs 50ms typical, no maximum is - * specified, so wait 10ms before try again. - * With 11 passes this gives it 100ms to wake up. - */ - udelay(10000); /* wait 10ms */ - } - - temp = 0; - if (info->index > 0) { - /* Some phy have multiple address, to solve the issue - where phyno keeps starting from 0, check the - previous phy address if both miibase are the same. */ - if (info->miibase == (info->next)->miibase) { - temp = (info->next)->phy_addr + 1; - } - } - - for (phyno = temp; phyno < 32 && phyaddr < 0; ++phyno) { - - phytype = mii_send(mk_mii_read(phyno, PHY_PHYIDR1)); -#ifdef ET_DEBUG - printf("PHY type 0x%x pass %d type\n", phytype, pass); -#endif - if (phytype != 0xffff) { - phyaddr = phyno; - phytype <<= 16; - phytype |= - mii_send(mk_mii_read(phyno, PHY_PHYIDR2)); - - switch (phytype & 0xffffffff) { - case PHY_ID_BCM5222: - strcpy(info->phy_name, STR_ID_BCM5222); - info->phyname_init = 1; - break; - default: - strcpy(info->phy_name, "unknown"); - info->phyname_init = 1; - break; - } - -#ifdef ET_DEBUG - printf("PHY @ 0x%x pass %d type ", phyno, pass); - switch (phytype & 0xffffffff) { - case PHY_ID_BCM5222: - printf(STR_ID_BCM5222); - break; - default: - printf("0x%08x\n", phytype); - break; - } -#endif - } - } - } - if (phyaddr < 0) - printf("No PHY device found.\n"); - - return phyaddr; -} -#endif /* CONFIG_SYS_DISCOVER_PHY */ - -void mii_init(void) __attribute__ ((weak, alias("__mii_init"))); - -void __mii_init(void) -{ - volatile fecdma_t *fecp; - struct fec_info_dma *info; - struct eth_device *dev; - int miispd = 0, i = 0; - u16 autoneg = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - fecp = (fecdma_t *) info->miibase; - - fecpin_setclear(dev, 1); - - mii_reset(info); - - /* We use strictly polling mode only */ - fecp->eimr = 0; - - /* Clear any pending interrupt */ - fecp->eir = 0xffffffff; - - /* Set MII speed */ - miispd = (gd->bus_clk / 1000000) / 5; - fecp->mscr = miispd << 1; - - info->phy_addr = mii_discover_phy(dev); - -#define AUTONEGLINK (PHY_BMSR_AUTN_COMP | PHY_BMSR_LS) - while (i < MCFFEC_TOUT_LOOP) { - autoneg = 0; - miiphy_read(dev->name, info->phy_addr, PHY_BMSR, &autoneg); - i++; - - if ((autoneg & AUTONEGLINK) == AUTONEGLINK) - break; - - udelay(500); - } - if (i >= MCFFEC_TOUT_LOOP) { - printf("Auto Negotiation not complete\n"); - } - - /* adapt to the half/full speed settings */ - info->dup_spd = miiphy_duplex(dev->name, info->phy_addr) << 16; - info->dup_spd |= miiphy_speed(dev->name, info->phy_addr); -} - -/***************************************************************************** - * Read and write a MII PHY register, routines used by MII Utilities - * - * FIXME: These routines are expected to return 0 on success, but mii_send - * does _not_ return an error code. Maybe 0xFFFF means error, i.e. - * no PHY connected... - * For now always return 0. - * FIXME: These routines only work after calling eth_init() at least once! - * Otherwise they hang in mii_send() !!! Sorry! - *****************************************************************************/ - -int mcffec_miiphy_read(char *devname, unsigned char addr, unsigned char reg, - unsigned short *value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_read(0x%x) @ 0x%x = ", reg, addr); -#endif - rdreg = mii_send(mk_mii_read(addr, reg)); - - *value = rdreg; - -#ifdef MII_DEBUG - printf("0x%04x\n", *value); -#endif - - return 0; -} - -int mcffec_miiphy_write(char *devname, unsigned char addr, unsigned char reg, - unsigned short value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_write(0x%x) @ 0x%x = ", reg, addr); -#endif - - rdreg = mii_send(mk_mii_write(addr, reg, value)); - -#ifdef MII_DEBUG - printf("0x%04x\n", value); -#endif - - return 0; -} - -#endif /* CONFIG_CMD_NET, FEC_ENET & NET_MULTI */ diff --git a/board/idmr/Makefile b/board/idmr/Makefile index be704b7..cf07cf4 100644 --- a/board/idmr/Makefile +++ b/board/idmr/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
-COBJS = $(BOARD).o flash.o mii.o +COBJS = $(BOARD).o flash.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/idmr/mii.c b/board/idmr/mii.c deleted file mode 100644 index e79fa19..0000000 --- a/board/idmr/mii.c +++ /dev/null @@ -1,303 +0,0 @@ -/* - * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. - * TsiChung Liew (Tsi-Chung.Liew@freescale.com) - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/fec.h> -#include <asm/immap.h> - -#include <config.h> -#include <net.h> - -DECLARE_GLOBAL_DATA_PTR; - -#if defined(CONFIG_CMD_NET) && defined(CONFIG_NET_MULTI) -#undef MII_DEBUG -#undef ET_DEBUG - -int fecpin_setclear(struct eth_device *dev, int setclear) -{ - if (setclear) { - /* Enable Ethernet pins */ - mbar_writeByte(MCF_GPIO_PAR_FECI2C, CONFIG_SYS_FECI2C); - } else { - } - - return 0; -} - -#if defined(CONFIG_SYS_DISCOVER_PHY) || defined(CONFIG_CMD_MII) -#include <miiphy.h> - -/* Make MII read/write commands for the FEC. */ -#define mk_mii_read(ADDR, REG) (0x60020000 | ((ADDR << 23) | (REG & 0x1f) << 18)) - -#define mk_mii_write(ADDR, REG, VAL) (0x50020000 | ((ADDR << 23) | (REG & 0x1f) << 18) | (VAL & 0xffff)) - -/* PHY identification */ -#define PHY_ID_LXT970 0x78100000 /* LXT970 */ -#define PHY_ID_LXT971 0x001378e0 /* LXT971 and 972 */ -#define PHY_ID_82555 0x02a80150 /* Intel 82555 */ -#define PHY_ID_QS6612 0x01814400 /* QS6612 */ -#define PHY_ID_AMD79C784 0x00225610 /* AMD 79C784 */ -#define PHY_ID_LSI80225 0x0016f870 /* LSI 80225 */ -#define PHY_ID_LSI80225B 0x0016f880 /* LSI 80225/B */ -#define PHY_ID_DP83848VV 0x20005C90 /* National 83848 */ -#define PHY_ID_DP83849 0x20005CA2 /* National 82849 */ -#define PHY_ID_KS8721BL 0x00221619 /* Micrel KS8721BL/SL */ - -#define STR_ID_LXT970 "LXT970" -#define STR_ID_LXT971 "LXT971" -#define STR_ID_82555 "Intel82555" -#define STR_ID_QS6612 "QS6612" -#define STR_ID_AMD79C784 "AMD79C784" -#define STR_ID_LSI80225 "LSI80225" -#define STR_ID_LSI80225B "LSI80225/B" -#define STR_ID_DP83848VV "N83848" -#define STR_ID_DP83849 "N83849" -#define STR_ID_KS8721BL "KS8721BL" - -/**************************************************************************** - * mii_init -- Initialize the MII for MII command without ethernet - * This function is a subset of eth_init - **************************************************************************** - */ -void mii_reset(struct fec_info_s *info) -{ - volatile fec_t *fecp = (fec_t *) (info->miibase); - int i; - - fecp->ecr = FEC_ECR_RESET; - for (i = 0; (fecp->ecr & FEC_ECR_RESET) && (i < FEC_RESET_DELAY); ++i) { - udelay(1); - } - if (i == FEC_RESET_DELAY) { - printf("FEC_RESET_DELAY timeout\n"); - } -} - -/* send command to phy using mii, wait for result */ -uint mii_send(uint mii_cmd) -{ - struct fec_info_s *info; - struct eth_device *dev; - volatile fec_t *ep; - uint mii_reply; - int j = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - ep = (fec_t *) info->miibase; - - ep->mmfr = mii_cmd; /* command to phy */ - - /* wait for mii complete */ - while (!(ep->eir & FEC_EIR_MII) && (j < MCFFEC_TOUT_LOOP)) { - udelay(1); - j++; - } - if (j >= MCFFEC_TOUT_LOOP) { - printf("MII not complete\n"); - return -1; - } - - mii_reply = ep->mmfr; /* result from phy */ - ep->eir = FEC_EIR_MII; /* clear MII complete */ -#ifdef ET_DEBUG - printf("%s[%d] %s: sent=0x%8.8x, reply=0x%8.8x\n", - __FILE__, __LINE__, __FUNCTION__, mii_cmd, mii_reply); -#endif - - return (mii_reply & 0xffff); /* data read from phy */ -} -#endif /* CONFIG_SYS_DISCOVER_PHY || CONFIG_CMD_MII */ - -#if defined(CONFIG_SYS_DISCOVER_PHY) -int mii_discover_phy(struct eth_device *dev) -{ -#define MAX_PHY_PASSES 11 - struct fec_info_s *info = dev->priv; - int phyaddr, pass; - uint phyno, phytype; - - if (info->phyname_init) - return info->phy_addr; - - phyaddr = -1; /* didn't find a PHY yet */ - for (pass = 1; pass <= MAX_PHY_PASSES && phyaddr < 0; ++pass) { - if (pass > 1) { - /* PHY may need more time to recover from reset. - * The LXT970 needs 50ms typical, no maximum is - * specified, so wait 10ms before try again. - * With 11 passes this gives it 100ms to wake up. - */ - udelay(10000); /* wait 10ms */ - } - - for (phyno = 0; phyno < 32 && phyaddr < 0; ++phyno) { - - phytype = mii_send(mk_mii_read(phyno, PHY_PHYIDR1)); -#ifdef ET_DEBUG - printf("PHY type 0x%x pass %d type\n", phytype, pass); -#endif - if (phytype != 0xffff) { - phyaddr = phyno; - phytype <<= 16; - phytype |= - mii_send(mk_mii_read(phyno, PHY_PHYIDR2)); - - switch (phytype & 0xffffffff) { - case PHY_ID_KS8721BL: - strcpy(info->phy_name, - STR_ID_KS8721BL); - info->phyname_init = 1; - break; - default: - strcpy(info->phy_name, "unknown"); - info->phyname_init = 1; - break; - } - -#ifdef ET_DEBUG - printf("PHY @ 0x%x pass %d type ", phyno, pass); - switch (phytype & 0xffffffff) { - case PHY_ID_KS8721BL: - printf(STR_ID_KS8721BL); - break; - default: - printf("0x%08x\n", phytype); - break; - } -#endif - } - } - } - if (phyaddr < 0) - printf("No PHY device found.\n"); - - return phyaddr; -} -#endif /* CONFIG_SYS_DISCOVER_PHY */ - -void mii_init(void) __attribute__((weak,alias("__mii_init"))); - -void __mii_init(void) -{ - volatile fec_t *fecp; - struct fec_info_s *info; - struct eth_device *dev; - int miispd = 0, i = 0; - u16 autoneg = 0; - - /* retrieve from register structure */ - dev = eth_get_dev(); - info = dev->priv; - - fecp = (fec_t *) info->miibase; - - fecpin_setclear(dev, 1); - - mii_reset(info); - - /* We use strictly polling mode only */ - fecp->eimr = 0; - - /* Clear any pending interrupt */ - fecp->eir = 0xffffffff; - - /* Set MII speed */ - miispd = (gd->bus_clk / 1000000) / 5; - fecp->mscr = miispd << 1; - - info->phy_addr = mii_discover_phy(dev); - -#define AUTONEGLINK (PHY_BMSR_AUTN_COMP | PHY_BMSR_LS) - while (i < MCFFEC_TOUT_LOOP) { - autoneg = 0; - miiphy_read(dev->name, info->phy_addr, PHY_BMSR, &autoneg); - i++; - - if ((autoneg & AUTONEGLINK) == AUTONEGLINK) - break; - - udelay(500); - } - if (i >= MCFFEC_TOUT_LOOP) { - printf("Auto Negotiation not complete\n"); - } - - /* adapt to the half/full speed settings */ - info->dup_spd = miiphy_duplex(dev->name, info->phy_addr) << 16; - info->dup_spd |= miiphy_speed(dev->name, info->phy_addr); -} - -/***************************************************************************** - * Read and write a MII PHY register, routines used by MII Utilities - * - * FIXME: These routines are expected to return 0 on success, but mii_send - * does _not_ return an error code. Maybe 0xFFFF means error, i.e. - * no PHY connected... - * For now always return 0. - * FIXME: These routines only work after calling eth_init() at least once! - * Otherwise they hang in mii_send() !!! Sorry! - *****************************************************************************/ - -int mcffec_miiphy_read(char *devname, unsigned char addr, unsigned char reg, - unsigned short *value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_read(0x%x) @ 0x%x = ", reg, addr); -#endif - rdreg = mii_send(mk_mii_read(addr, reg)); - - *value = rdreg; - -#ifdef MII_DEBUG - printf("0x%04x\n", *value); -#endif - - return 0; -} - -int mcffec_miiphy_write(char *devname, unsigned char addr, unsigned char reg, - unsigned short value) -{ - short rdreg; /* register working value */ - -#ifdef MII_DEBUG - printf("miiphy_write(0x%x) @ 0x%x = ", reg, addr); -#endif - - rdreg = mii_send(mk_mii_write(addr, reg, value)); - -#ifdef MII_DEBUG - printf("0x%04x\n", value); -#endif - - return 0; -} - -#endif /* CONFIG_CMD_NET, FEC_ENET & NET_MULTI */
Tsi-Chung Liew
