RE: [U-Boot-Users] 16Bit NAND flash
I have implemented NAND only boot in an ARM board (OMAP1710 H3). The NAND flash is a 16-bit Samsung chip. The code is not general enough for a patch. Anyone is interested in making it a patch?
Yes, I did push a patch for NAND based environment. It is available at U-Boot site.
Regards, Jian
-----Original Message----- From: u-boot-users-admin@lists.sourceforge.net [mailto:u-boot-users- admin@lists.sourceforge.net] On Behalf Of hermann.brugger@gmx.de Sent: Thursday, September 23, 2004 2:17 AM To: u-boot-users@lists.sourceforge.net Subject: [U-Boot-Users] 16Bit NAND flash
does U-boot support 16Bit wide NAND flashs? If I look inside the cmd_nand.c only u_char are used.
Does someone have experience in using U-boot only with NAND flash (maybe 16Bit NAND flash) and SDRAM and an ARM with NAND boot option? I think it is not possible to store the environment of U-boot
in
NAND flash so I cannot save the environment.
Thanks Hermann
This SF.Net email is sponsored by: YOU BE THE JUDGE. Be one of 170 Project Admins to receive an Apple iPod Mini FREE for your judgement
on
who ports your project to Linux PPC the best. Sponsored by IBM. Deadline: Sept. 24. Go here: http://sf.net/ppc_contest.php _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
In message BA2832125C3C994384FCC051CDFC7369B8A292@dlee2k05.ent.ti.com you wrote:
Which means it is essentially lost (or at lease significantly delayed). If you want to see it integrated into the source tree, then post it here.
Zhang, Jian
