[U-Boot-Users] PPC405EP ethernet problems
Hi
I'm having problems setting up the ethernet on a custom board with an AMCC PPC405EP. Whenever I run a command which uses the ethernet, I get a similar behaviour: First U-Boot displays 66 times the following message:
miiphy_register: non unique device name 'ppc_4xx_eth0' ENET Speed is 100 Mbps - FULL duplex connection
Then it starts printing the following in an endless loop:
ppc_4xx_eth_initialize: Cannot allocate private hw data for eth_device 0
The ethernet part in the configuration file reads as follows:
#define CONFIG_MII // Enable MII PHY management #define CONFIG_PHY_ADDR 0x0C // Front eth phy (addr via pin strapping) #define CONFIG_IPADDR 192.168.248.103 // Default IP address (test only) #define CONFIG_SERVERIP 192.168.248.111 // tftpboot from stein #define CONFIG_ETHADDR 00:40:63:DC:B6:93 // MAC address
Has anyone an idea where the error could lie? Could anybody give me a hint, where to continue debugging?
Thank you very much in advance, Reto Stalder
Hi Reto,
can you try it with
... #define CONFIG_NET_MULTI 1 #undef CONFIG_HAS_ETH1 ...
in your configuration file.
Perhaps that helps.
Matthias
Matthias Fuchs
Stalder, Reto
