[U-Boot] OMAP3: proposal: dont piggy back on ROMCode interrupt vectors
Hi, Current interrupt vectors[1] are piggy backing on OMAP3 ROM Code vectors This has the disadvantage that "external boot" option of OMAP GP devices for booting off NOR devices would probably not function as the interrupt vectors are not setup.
I had faced this during the port of u-boot-v2 and had done an implementation[2] for this. would we be interested in pulling this back in for u-boot-v1? I suppose all OMAP3 devices could benefit from it.
Regards, Nishanth Menon
Ref: [1] http://git.denx.de/?p=u-boot/u-boot-ti.git;a=blob;f=cpu/arm_cortexa8/start.S... [2] http://git.denx.de/?p=u-boot/u-boot-v2.git;a=blob;f=arch/arm/mach-omap/omap3...
In general we want to limit dependencies of ROM code. And it should be moved to omap3 so other cortexa8 users don't have to code around it. Like we did for the cache flushing.
Poking around it does not look like any of the omap boards define CONFIG_USE_IRQ so it seems like you really will be creating the interrupt handlers. I think this is a good idea as long as the existing non-interrupts still works. I would be happy to test whatever you want to do. Should we set up a special ti-omap-irq topic branch ?
Tom
Ref: [1] http://git.denx.de/?p=u-boot/u-boot-ti.git;a=blob;f=cpu/arm_cortexa8/start.S... [2] http://git.denx.de/?p=u-boot/u-boot-v2.git;a=blob;f=arch/arm/mach-omap/omap3... _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
it is going to be just a silly little patch.. and given it is a cp15 feature, I think it might be cortex_a8 specific and not OMAP3 specific.. it would be good to have the irqs to be enabled for data abort reports etc.. but then, that is just my 2 cents..
Tom
Ref: [1]
Nishanth Menon
Tom Rix
