[U-Boot] ENV library broken with setenv/printenv argument structs
Hi Andreas,
your series for the U-Boot environment tools does not let to use anymore the tools as library to be linked to custom program.
In fact, tools/env/Makefile generates a library too:
lib-y += fw_env.o \ crc32.o ctype.o linux_string.o \ env_attr.o env_flags.o aes.o
that means that fw_main should not maintain any structure that is referenced by the library. In fact, linking with the library (renamed as ibubootenv.a), gives the errors:
undefined reference to `printenv_args' undefined reference to `common_args'
The two functions fw_printenv() and fw_setenv() are then supposed to be called by a custom program, what it does not work anymore.
Can you take a look at it ?
Thanks, Stefano Babic
HI Stefano,
I was not aware of the use case. I have sent out a simple patch that moves the definition of the structs from fw_main_env.c to fw_env.c, which should avoid the linking problem. Do you have test application you could send me. I without doing the option parsing as done in fw_env_main, you probably use only use a very limited subset of the library.
/Andi
2016-03-25 10:31 GMT+01:00 Stefano Babic sbabic@denx.de:
Hi Andreas,
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-53 Fax: +49-8142-66989-80 Email: sbabic@denx.de =====================================================================
Hi Andreas,
On 25/03/2016 15:00, Andreas Fenkart wrote:
HI Stefano,
Yes, currently I am using just fw_parse_script. But exporting a library, it can be possible that someone else need other options. I see you sent a patch, I send an answer.
Stefano
/Andi
Hi Andreas,
Andreas Fenkart
Stefano Babic
