[U-Boot] [PATCH] Drop linker-generated array creation when CONFIG_CMDLINE is disabled
Linker generated array entry is not needed when the command line is disabled. Remove this code in that case.
This is required as the commit 80a48dd47e3bf3ede676fae5a630cb6c80de3e69 breaks the linking stage when CONFIG_CMDLINE=n:
.. LDS u-boot.lds LD u-boot u-boot contains unexpected relocations: R_ARM_NONE R_ARM_RELATIVE make: *** [Makefile:1775: checkarmreloc] Error 1
Signed-off-by: Andrej Rosano andrej.rosano@f-secure.com --- cmd/help.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/cmd/help.c b/cmd/help.c index fa2010c67e..a1a0b99b6f 100644 --- a/cmd/help.c +++ b/cmd/help.c @@ -27,6 +27,7 @@ U_BOOT_CMD( " - print detailed usage of 'command'" );
+#ifdef CONFIG_CMDLINE /* This does not use the U_BOOT_CMD macro as ? can't be used in symbol names */ ll_entry_declare(cmd_tbl_t, question_mark, cmd) = { "?", CONFIG_SYS_MAXARGS, cmd_always_repeatable, do_help, @@ -35,3 +36,4 @@ ll_entry_declare(cmd_tbl_t, question_mark, cmd) = { "" #endif /* CONFIG_SYS_LONGHELP */ }; +#endif
andrej.rosanoļ¼ f-secure.com
