[PATCH v1 0/9] TI TPS6594 PMIC support for multiple TI EVMs
TPS6594 is a Power Management IC which provides regulators and others features like GPIOs, RTC, watchdog, ESMs (Error Signal Monitor), and PFSM (Pre-configurable Finite State Machine). The SoC and the PMIC can communicate through the I2C or SPI interfaces. TPS6594 is the super-set device while TPS6593 and LP8764X are derivatives.
This series fixes LDO voltage conversion for TPS6594 PMIC, it adds support for its derivatives.
The features implemented are: - Regulators - WD disable
WD disable is not a watchdog driver implementation. Watchdog is active by default causing a reboot even if not used. This implementation allow to disable the watchdog at boot time.
Due to current situation with upstream u-boot dts, this patch suite can be applied only after u-boot dts upstream is resynched on latest Linux dts. Link: https://gist.github.com/nmenon/030b11b085473fa008145429b39fcc75
This should be applied on top of Linux patch series (for dts inheritence) Link: https://lore.kernel.org/all/20230406075622.8990-1-jpanis@baylibre.com/ Link: https://lore.kernel.org/all/20230328091448.648452-1-eblanc@baylibre.com/
Tested on boards listed below (resynched manually on Linux 6.3 dts)
Supported boards: - j721eXSOMXEVM: Link: https://www.ti.com/tool/J721EXSOMXEVM - AM62A-SKEVM: Link: https://www.ti.com/tool/SK-AM62A-LP
basic tests: => pmic list => regulator list => regulator dev reg_name_to_be_tested => regulator info => regulator value => regulator value my_test_val => regulator value Check WD reset is not happening when dip switch SW2 on GPIO8 is High.
Jerome Neanne (4): drivers: pmic: TPS65941 add support for WD disable drivers: regulator: Fixes for TPS65941 LDO voltage conversion configs: j721e_evm: Add support for TPS65941 PMICs on j721e TI EVM board board: ti: k3-j721e: Force TPS65941 PMIC WD disable on j721e TI EVM board
Jerome Neanne (4): DONOTMERGE: arm: dts: k3-j721e: u-boot overlay for TI tps6594 PMIC DONOTMERGE: arm: dts: k3-j721e: refactor r5 board file to use Linux dts tps6594 description DONOTMERGE: arm: dts: k3-j721e: realign node name on linux dts name DONOTMERGE: arm: dts: k3-am62a7-sk: Add TI TPS6593 PMIC support
Julien Panis (1): configs: am62ax_evm_a53: Enable support for TI TPS6593 PMIC
arch/arm/dts/k3-am62a7-sk-u-boot.dtsi | 24 ++++++- .../k3-j721e-common-proc-board-u-boot.dtsi | 21 ++++++ .../k3-j721e-r5-common-proc-board-u-boot.dtsi | 2 +- .../arm/dts/k3-j721e-r5-common-proc-board.dts | 48 ++++++------- board/ti/j721e/evm.c | 8 +++ configs/am62ax_evm_a53_defconfig | 9 ++- configs/j721e_evm_a72_defconfig | 9 +++ drivers/power/pmic/tps65941.c | 36 ++++++++++ drivers/power/regulator/tps65941_regulator.c | 71 ++++++++++++++++--- include/power/tps65941.h | 25 ++++++- 10 files changed, 213 insertions(+), 40 deletions(-)
This is not a proper WD driver because it's not planned to support WD driver for PMIC in u-boot at any time. The purpose is just WD disable.
Signed-off-by: Jerome Neanne jneanne@baylibre.com --- drivers/power/pmic/tps65941.c | 36 +++++++++++++++++++++++++++++++++++ include/power/tps65941.h | 25 ++++++++++++++++++++++-- 2 files changed, 59 insertions(+), 2 deletions(-)
diff --git a/drivers/power/pmic/tps65941.c b/drivers/power/pmic/tps65941.c index 83d0f83c64..643ea6179c 100644 --- a/drivers/power/pmic/tps65941.c +++ b/drivers/power/pmic/tps65941.c @@ -47,6 +47,9 @@ static int tps65941_bind(struct udevice *dev) ofnode regulators_node; int children;
+ if (dev->driver_data == TPS65941_WD) + return 0; + regulators_node = dev_read_subnode(dev, "regulators"); if (!ofnode_valid(regulators_node)) { debug("%s: %s regulators subnode not found!\n", __func__, @@ -64,6 +67,36 @@ static int tps65941_bind(struct udevice *dev) return dm_scan_fdt_dev(dev); }
+static int stop_watchdog(struct udevice *wd_i2c_dev) +{ + int ret; + + ret = dm_i2c_reg_read(wd_i2c_dev, TPS65941_WD_MODE_REG); + if (ret < 0) { + debug("failed to write i2c reg (%d)\n", ret); + return 0; + } + + ret &= ~TPS65941_WD_PWRHOLD_MASK; + ret |= TPS65941_WD_PWRHOLD_MASK; + ret = dm_i2c_reg_write(wd_i2c_dev, TPS65941_WD_MODE_REG, ret); + if (ret) + debug("%s: %s write WD disable fail!\n", __func__, wd_i2c_dev->name); + ret = dm_i2c_reg_read(wd_i2c_dev, TPS65941_WD_MODE_REG); + if (ret < 0) { + debug("failed to read back i2c reg (%d)\n", ret); + return 0; + } + return 0; +} + +static int tps65941_probe(struct udevice *dev) +{ + if (dev->driver_data == TPS65941_WD) + return stop_watchdog(dev); + return 0; +} + static struct dm_pmic_ops tps65941_ops = { .read = tps65941_read, .write = tps65941_write, @@ -73,7 +106,9 @@ static const struct udevice_id tps65941_ids[] = { { .compatible = "ti,tps659411", .data = TPS659411 }, { .compatible = "ti,tps659412", .data = TPS659411 }, { .compatible = "ti,tps659413", .data = TPS659413 }, + { .compatible = "ti,tps659312", .data = TPS659312 }, { .compatible = "ti,lp876441", .data = LP876441 }, + { .compatible = "ti,tps65941_watchdog", .data = TPS65941_WD }, { } };
@@ -82,5 +117,6 @@ U_BOOT_DRIVER(pmic_tps65941) = { .id = UCLASS_PMIC, .of_match = tps65941_ids, .bind = tps65941_bind, + .probe = tps65941_probe, .ops = &tps65941_ops, }; diff --git a/include/power/tps65941.h b/include/power/tps65941.h index a2bc6814ba..70c7274355 100644 --- a/include/power/tps65941.h +++ b/include/power/tps65941.h @@ -2,7 +2,9 @@ #define TPS659412 0x1 #define TPS659413 0x2 #define TPS659414 0x3 -#define LP876441 0x4 +#define TPS659312 0x4 +#define LP876441 0x5 +#define TPS65941_WD 0x20
/* I2C device address for pmic tps65941 */ #define TPS65941_I2C_ADDR (0x12 >> 1) @@ -18,10 +20,29 @@ #define TPS65941_BUCK_VOLT_MAX 3340000 #define TPS65941_BUCK_MODE_MASK 0x1
-#define TPS65941_LDO_VOLT_MASK 0x3E +#define TPS65941_LDO_VOLT_MASK 0x7F #define TPS65941_LDO_VOLT_MAX_HEX 0x3A #define TPS65941_LDO_VOLT_MIN_HEX 0x4 #define TPS65941_LDO_VOLT_MAX 3300000 #define TPS65941_LDO_MODE_MASK 0x1 #define TPS65941_LDO_BYPASS_EN 0x80 #define TP65941_BUCK_CONF_SLEW_MASK 0x7 + +/* BYPASS is bit7 of VOUT TPS65941_LDO_BYP_MASK */ +#define TPS65941_LDO123_BYP_CONFIG 7 + +#define TPS65941_LDO123_VOLT_BYP_MIN 1700000 +#define TPS65941_LDO123_VOLT_BYP_MAX 3600000 +#define TPS65941_LDO123_VOLT_MIN 600000 +#define TPS65941_LDO4_VOLT_MIN 1200000 +#define TPS65941_LDO4_VOLT_MIN 1200000 +#define TPS65941_LDO123_VSET_MIN 0x04 +#define TPS65941_LDO4_VSET_MIN 0x20 +#define TPS65941_LDO123_VSET_MAX 0x3A +#define TPS65941_LDO4_VSET_MAX 0x74 +#define TPS65941_LDO123_STEP 50000 +#define TPS65941_LDO4_STEP 25000 + +#define TPS65941_WD_MODE_REG 0x406 +#define TPS65941_WD_PWRHOLD_MASK BIT(2) +
Fixes: 065a452ae6a power: regulator: tps65941: add regulator support
LDO voltage conversion was incorrect. This was checked by writing and reading back value.
Signed-off-by: Jerome Neanne jneanne@baylibre.com --- drivers/power/regulator/tps65941_regulator.c | 71 +++++++++++++++++--- 1 file changed, 63 insertions(+), 8 deletions(-)
diff --git a/drivers/power/regulator/tps65941_regulator.c b/drivers/power/regulator/tps65941_regulator.c index b041126775..7afd68c5c4 100644 --- a/drivers/power/regulator/tps65941_regulator.c +++ b/drivers/power/regulator/tps65941_regulator.c @@ -212,12 +212,55 @@ static int tps65941_ldo_enable(struct udevice *dev, int op, bool *enable) return 0; }
-static int tps65941_ldo_val2volt(int val) +static int tps65941_ldo_volt2val(int idx, int uV) { - if (val > TPS65941_LDO_VOLT_MAX_HEX || val < TPS65941_LDO_VOLT_MIN_HEX) + int base = TPS65941_LDO123_VOLT_MIN; + int max = TPS65941_LDO_VOLT_MAX; + int offset = TPS65941_LDO123_VSET_MIN; + int step = TPS65941_LDO123_STEP; + + if (idx > 2) { + base = TPS65941_LDO4_VOLT_MIN; + offset = TPS65941_LDO4_VSET_MIN; + step = TPS65941_LDO4_STEP; + } + + if (uV > max) return -EINVAL; - else if (val >= TPS65941_LDO_VOLT_MIN_HEX) - return 600000 + (val - TPS65941_LDO_VOLT_MIN_HEX) * 50000; + else if (uV >= base) + return (uV - base) / step + offset; + else + return -EINVAL; +} + +static int tps65941_ldo_val2volt(int idx, int val) +{ + int reg_base = TPS65941_LDO123_VSET_MIN; + int reg_max = TPS65941_LDO123_VSET_MAX; + int base = TPS65941_LDO123_VOLT_MIN; + int max = TPS65941_LDO_VOLT_MAX; + int step = TPS65941_LDO123_STEP; + int mask = TPS65941_LDO_VOLT_MASK >> 1; + + if (idx > 2) { + base = TPS65941_LDO4_VOLT_MIN; + max = TPS65941_LDO_VOLT_MAX; + reg_base = TPS65941_LDO4_VSET_MIN; + reg_max = TPS65941_LDO4_VSET_MAX; + step = TPS65941_LDO4_STEP; + mask = TPS65941_LDO_VOLT_MASK; + } else { + val = val >> 1; + } + + if (val > mask || val < 0) + return -EINVAL; + else if (val >= reg_max) + return max; + else if (val <= reg_base) + return base; + else if (val >= 0) + return base + (step * (val - reg_base)); else return -EINVAL; } @@ -227,7 +270,9 @@ static int tps65941_ldo_val(struct udevice *dev, int op, int *uV) unsigned int hex, adr; int ret; struct dm_regulator_uclass_plat *uc_pdata; + int idx;
+ idx = dev->driver_data - 1; uc_pdata = dev_get_uclass_plat(dev);
if (op == PMIC_OP_GET) @@ -240,7 +285,8 @@ static int tps65941_ldo_val(struct udevice *dev, int op, int *uV) return ret;
ret &= TPS65941_LDO_VOLT_MASK; - ret = tps65941_ldo_val2volt(ret); + ret = tps65941_ldo_val2volt(idx, ret); + if (ret < 0) return ret;
@@ -249,12 +295,21 @@ static int tps65941_ldo_val(struct udevice *dev, int op, int *uV) return 0; }
- hex = tps65941_buck_volt2val(*uV); + /* LDO1, LDO2 & LDO3 in BYPASS mode only supports 1.7V min to 3.6V max */ + if (idx < 2 && + (ret & BIT(TPS65941_LDO123_BYP_CONFIG)) && + *uV < TPS65941_LDO123_VOLT_BYP_MIN) + return -EINVAL; + + hex = tps65941_ldo_volt2val(idx, *uV); if (hex < 0) return hex;
- ret &= 0x0; - ret = hex; + if (idx < 2) + hex = hex << 1; + + ret &= ~TPS65941_LDO_VOLT_MASK; + ret |= hex;
ret = pmic_reg_write(dev->parent, adr, ret);
Add PMIC and regulators feature support for j721e. PMIC is controlled by SoC through I2C interface.
Signed-off-by: Jerome Neanne jneanne@baylibre.com --- configs/j721e_evm_a72_defconfig | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index 452e4b9695..7774330b60 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -77,6 +77,8 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y CONFIG_MTDIDS_DEFAULT="nor0=47040000.spi.0,nor0=47034000.hyperbus" CONFIG_MTDPARTS_DEFAULT="mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57344k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs)" @@ -205,3 +207,10 @@ CONFIG_UFS=y CONFIG_CADENCE_UFS=y CONFIG_TI_J721E_UFS=y CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_TPS65941=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_TPS65941=y +CONFIG_CMD_DM=y +CONFIG_OF_PLATDATA=y +
Using uclass_probe_all forces probe on all devices: Only probe for WD stop is really needed here. Probing other devices has no impact.
Signed-off-by: Jerome Neanne jneanne@baylibre.com --- board/ti/j721e/evm.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index d4e672a7ac..a3304468d4 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -27,6 +27,8 @@
#include "../common/board_detect.h"
+#include <power/tps65941.h> + #define board_is_j721e_som() (board_ti_k3_is("J721EX-PM1-SOM") || \ board_ti_k3_is("J721EX-PM2-SOM"))
@@ -43,6 +45,12 @@ DECLARE_GLOBAL_DATA_PTR;
int board_init(void) { + int ret; + + /* WD stop is applied unconditionally on all platforms*/ + ret = uclass_probe_all(UCLASS_PMIC); + if (ret) + printf("Failed to probe! stop tps65941 wd\n"); return 0; }
j721e board includes 2 instances of TPS6594: - Primary PMIC - Secondary PMIC
Add AVS class0 in u-boot SPL. AVS is supported only on CPU rail: vdd_cpu_avs. This rail is supplied by the primary PMIC: tps659413 This rail is supplied by a dual-phased buck: buck12.
Other PMICs rails are not AVS capable.
Each PMIC includes a Watchdog that is active by default at boot. This would issue a platform reset unless pmic GPIO8 is driven or this is handled by SW. Watchdog driver is not required for identified use of this product. This software disable inside u-boot avoids parasitic wd reset. GPIO8 can then be used for other purpose.
Board documentation: Link: https://www.ti.com/tool/J721EXSOMXEVM
Signed-off-by: Jerome Neanne jneanne@baylibre.com --- .../k3-j721e-common-proc-board-u-boot.dtsi | 21 +++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi index b2b81f804d..d05d3610ff 100644 --- a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi @@ -79,6 +79,14 @@ chipid@43000014 { u-boot,dm-spl; }; + + mcu_i2c0: i2c@40b00000 { + status = "okay"; + tps65941_wd: tps65941-wd@12 { + compatible = "ti,tps65941_watchdog"; + reg = <0x12>; + }; + }; };
&secure_proxy_main { @@ -170,6 +178,19 @@
&wkup_i2c0 { u-boot,dm-spl; + tps659413: tps659413@48 { + u-boot,dm-spl; + compatible = "ti,tps659413"; + + regulators { + u-boot,dm-spl; + bucka12_reg: buck12 { + }; + }; + }; + tps659411: tps659411@4c { + compatible = "ti,tps659411"; + }; };
&main_i2c0 {
Use a copy of Linux dts for TPS6594 PMIC description instead of custom u-boot
Signed-off-by: Jerome Neanne jneanne@baylibre.com --- .../arm/dts/k3-j721e-r5-common-proc-board.dts | 48 +++++++++---------- 1 file changed, 22 insertions(+), 26 deletions(-)
diff --git a/arch/arm/dts/k3-j721e-r5-common-proc-board.dts b/arch/arm/dts/k3-j721e-r5-common-proc-board.dts index ab9d6e65d8..a5c0222e91 100644 --- a/arch/arm/dts/k3-j721e-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j721e-r5-common-proc-board.dts @@ -21,6 +21,27 @@ tick-timer = &timer1; };
+ evm_12v0: fixedregulator-evm12v0 { + /* main supply */ + compatible = "regulator-fixed"; + regulator-name = "evm_12v0"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + regulator-always-on; + regulator-boot-on; + }; + + vsys_3v3: fixedregulator-vsys3v3 { + /* Output of LM5140 */ + compatible = "regulator-fixed"; + regulator-name = "vsys_3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&evm_12v0>; + regulator-always-on; + regulator-boot-on; + }; + a72_0: a72@0 { compatible = "ti,am654-rproc"; reg = <0x0 0x00a90000 0x0 0x10>; @@ -276,33 +297,8 @@ ti,driver-strength-ohm = <50>; };
-&wkup_i2c0 { - u-boot,dm-spl; - tps659413a: tps659413a@48 { - reg = <0x48>; - compatible = "ti,tps659413"; - u-boot,dm-spl; - pinctrl-names = "default"; - pinctrl-0 = <&wkup_i2c0_pins_default>; - clock-frequency = <400000>; - - regulators: regulators { - u-boot,dm-spl; - buck12_reg: buck12 { - /*VDD_CPU*/ - regulator-name = "buck12"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <900000>; - regulator-always-on; - regulator-boot-on; - u-boot,dm-spl; - }; - }; - }; -}; - &wkup_vtm0 { - vdd-supply-2 = <&buck12_reg>; + vdd-supply-2 = <&bucka12_reg>; u-boot,dm-spl; };
Change node name to reuse Linux common dts naming style.
Signed-off-by: Jerome Neanne jneanne@baylibre.com --- arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi index 48c6ddf672..206f8560f9 100644 --- a/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi @@ -21,7 +21,7 @@ }; };
-&tps659413a { +&tps659413 { esm: esm { compatible = "ti,tps659413-esm"; u-boot,dm-spl;
Add support for TPS6593 regulators and watchdog. PMIC is controlled by SoC through I2C interface.
Signed-off-by: Julien Panis jpanis@baylibre.com Signed-off-by: Jerome Neanne jneanne@baylibre.com --- configs/am62ax_evm_a53_defconfig | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/configs/am62ax_evm_a53_defconfig b/configs/am62ax_evm_a53_defconfig index 8b48f5e8e6..358271204a 100644 --- a/configs/am62ax_evm_a53_defconfig +++ b/configs/am62ax_evm_a53_defconfig @@ -50,7 +50,6 @@ CONFIG_SPL_CLK=y CONFIG_CLK_TI_SCI=y CONFIG_TI_SCI_PROTOCOL=y # CONFIG_GPIO is not set -# CONFIG_I2C is not set CONFIG_DM_MAILBOX=y CONFIG_K3_SEC_PROXY=y CONFIG_MMC_SDHCI=y @@ -74,3 +73,11 @@ CONFIG_SPL_SYSRESET=y CONFIG_SYSRESET_TI_SCI=y CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_TPS65941=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_TPS65941=y +CONFIG_DM_I2C=y +CONFIG_I2C=y +CONFIG_SPL_I2C=y +CONFIG_SYS_I2C_OMAP24XX=y
Add support for TPS6593 PMIC devices: - regulators (bucks and LDOs) on main I2C0 bus, - watchdog on MCU I2C0 bus.
Signed-off-by: Julien Panis jpanis@baylibre.com Signed-off-by: Jerome Neanne jneanne@baylibre.com --- arch/arm/dts/k3-am62a7-sk-u-boot.dtsi | 24 ++++++++++++++++++++++-- 1 file changed, 22 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/k3-am62a7-sk-u-boot.dtsi b/arch/arm/dts/k3-am62a7-sk-u-boot.dtsi index 7fc749ed70..4b2e9f7d22 100644 --- a/arch/arm/dts/k3-am62a7-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am62a7-sk-u-boot.dtsi @@ -84,7 +84,14 @@ };
&mcu_pmx0 { - u-boot,dm-spl; + status = "okay"; + + mcu_i2c0_pins_default: mcu_i2c0_pins_default { + pinctrl-single,pins = < + AM62X_MCU_IOPAD(0x044, PIN_INPUT_PULLUP, 0) /* (E12) MCU_I2C0_SCL */ + AM62X_MCU_IOPAD(0x048, PIN_INPUT_PULLUP, 0) /* (D9) MCU_I2C0_SDA */ + >; + }; };
&wkup_uart0 { @@ -96,7 +103,20 @@ };
&main_i2c0 { - u-boot,dm-spl; + tps659312: tps659312@48 { + compatible = "ti,tps659312"; + }; +}; + +&mcu_i2c0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&mcu_i2c0_pins_default>; + + tps65931_wd: tps65931_wd@12 { + compatible = "ti,tps65941_watchdog"; + reg = <0x12>; + }; };
&main_i2c0_pins_default {
- Regulators
- WD disable
Supported boards:
- j721eXSOMXEVM:
- AM62A-SKEVM:
The code seems fine. The defconfig changes don't seem to have been done with a "savedefconfig" (one add a blank line at the end for example), but you can hold off on v2'ing things, barring other feedback, until the DTS situation is resolved.
Jerome Neanne
