[U-Boot] [PATCH 0/2] amlogic: Add Khadas VIM3 support
This mini-series adds initial support for Amlogic A311D based Khadas VIM3.
Regards, Andreas
Cc: Neil Armstrong narmstrong@baylibre.com
Andreas Färber (2): arm: dts: Import and update DT for Khadas VIM3 configs: Add Khadas VIM3 defconfig
arch/arm/dts/Makefile | 3 +- arch/arm/dts/meson-g12-common.dtsi | 2435 ++++++++++++++++++++ arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts | 15 + arch/arm/dts/meson-g12b-a311d.dtsi | 149 ++ arch/arm/dts/meson-g12b-khadas-vim3.dtsi | 544 +++++ arch/arm/dts/meson-g12b.dtsi | 39 +- board/amlogic/w400/MAINTAINERS | 1 + board/amlogic/w400/README.khadas-vim3 | 132 ++ configs/khadas-vim3_defconfig | 54 + include/dt-bindings/clock/g12a-clkc.h | 6 + include/dt-bindings/power/meson-g12a-power.h | 13 + .../reset/amlogic,meson-g12a-audio-reset.h | 38 + 12 files changed, 3425 insertions(+), 4 deletions(-) create mode 100644 arch/arm/dts/meson-g12-common.dtsi create mode 100644 arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts create mode 100644 arch/arm/dts/meson-g12b-a311d.dtsi create mode 100644 arch/arm/dts/meson-g12b-khadas-vim3.dtsi create mode 100644 board/amlogic/w400/README.khadas-vim3 create mode 100644 configs/khadas-vim3_defconfig create mode 100644 include/dt-bindings/power/meson-g12a-power.h create mode 100644 include/dt-bindings/reset/amlogic,meson-g12a-audio-reset.h
In Linux meson-g12-common.dtsi was introduced as well as new g12b nodes and headers, as dependencies of new meson-g12b-a311d-khadas-vim3.dts.
Signed-off-by: Andreas Färber afaerber@suse.de --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/meson-g12-common.dtsi | 2435 ++++++++++++++++++++ arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts | 15 + arch/arm/dts/meson-g12b-a311d.dtsi | 149 ++ arch/arm/dts/meson-g12b-khadas-vim3.dtsi | 544 +++++ arch/arm/dts/meson-g12b.dtsi | 39 +- include/dt-bindings/clock/g12a-clkc.h | 6 + include/dt-bindings/power/meson-g12a-power.h | 13 + .../reset/amlogic,meson-g12a-audio-reset.h | 38 + 9 files changed, 3238 insertions(+), 4 deletions(-) create mode 100644 arch/arm/dts/meson-g12-common.dtsi create mode 100644 arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts create mode 100644 arch/arm/dts/meson-g12b-a311d.dtsi create mode 100644 arch/arm/dts/meson-g12b-khadas-vim3.dtsi create mode 100644 include/dt-bindings/power/meson-g12a-power.h create mode 100644 include/dt-bindings/reset/amlogic,meson-g12a-audio-reset.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index aac1b83d49..6de5e4c62a 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -141,7 +141,8 @@ dtb-$(CONFIG_ARCH_MESON) += \ meson-axg-s400.dtb \ meson-g12a-u200.dtb \ meson-g12a-sei510.dtb \ - meson-g12b-odroid-n2.dtb + meson-g12b-odroid-n2.dtb \ + meson-g12b-a311d-khadas-vim3.dtb dtb-$(CONFIG_TEGRA) += tegra20-harmony.dtb \ tegra20-medcom-wide.dtb \ tegra20-paz00.dtb \ diff --git a/arch/arm/dts/meson-g12-common.dtsi b/arch/arm/dts/meson-g12-common.dtsi new file mode 100644 index 0000000000..3f39e020f7 --- /dev/null +++ b/arch/arm/dts/meson-g12-common.dtsi @@ -0,0 +1,2435 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 Amlogic, Inc. All rights reserved. + */ + +#include <dt-bindings/phy/phy.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/clock/axg-audio-clkc.h> +#include <dt-bindings/clock/g12a-clkc.h> +#include <dt-bindings/clock/g12a-aoclkc.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/reset/amlogic,meson-axg-audio-arb.h> +#include <dt-bindings/reset/amlogic,meson-g12a-audio-reset.h> +#include <dt-bindings/reset/amlogic,meson-g12a-reset.h> + +/ { + interrupt-parent = <&gic>; + #address-cells = <2>; + #size-cells = <2>; + + tdmif_a: audio-controller-0 { + compatible = "amlogic,axg-tdm-iface"; + #sound-dai-cells = <0>; + sound-name-prefix = "TDM_A"; + clocks = <&clkc_audio AUD_CLKID_MST_A_MCLK>, + <&clkc_audio AUD_CLKID_MST_A_SCLK>, + <&clkc_audio AUD_CLKID_MST_A_LRCLK>; + clock-names = "mclk", "sclk", "lrclk"; + status = "disabled"; + }; + + tdmif_b: audio-controller-1 { + compatible = "amlogic,axg-tdm-iface"; + #sound-dai-cells = <0>; + sound-name-prefix = "TDM_B"; + clocks = <&clkc_audio AUD_CLKID_MST_B_MCLK>, + <&clkc_audio AUD_CLKID_MST_B_SCLK>, + <&clkc_audio AUD_CLKID_MST_B_LRCLK>; + clock-names = "mclk", "sclk", "lrclk"; + status = "disabled"; + }; + + tdmif_c: audio-controller-2 { + compatible = "amlogic,axg-tdm-iface"; + #sound-dai-cells = <0>; + sound-name-prefix = "TDM_C"; + clocks = <&clkc_audio AUD_CLKID_MST_C_MCLK>, + <&clkc_audio AUD_CLKID_MST_C_SCLK>, + <&clkc_audio AUD_CLKID_MST_C_LRCLK>; + clock-names = "mclk", "sclk", "lrclk"; + status = "disabled"; + }; + + efuse: efuse { + compatible = "amlogic,meson-gxbb-efuse"; + clocks = <&clkc CLKID_EFUSE>; + #address-cells = <1>; + #size-cells = <1>; + read-only; + }; + + psci { + compatible = "arm,psci-1.0"; + method = "smc"; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + /* 3 MiB reserved for ARM Trusted Firmware (BL31) */ + secmon_reserved: secmon@5000000 { + reg = <0x0 0x05000000 0x0 0x300000>; + no-map; + }; + + linux,cma { + compatible = "shared-dma-pool"; + reusable; + size = <0x0 0x10000000>; + alignment = <0x0 0x400000>; + linux,cma-default; + }; + }; + + sm: secure-monitor { + compatible = "amlogic,meson-gxbb-sm"; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + ethmac: ethernet@ff3f0000 { + compatible = "amlogic,meson-axg-dwmac", + "snps,dwmac-3.70a", + "snps,dwmac"; + reg = <0x0 0xff3f0000 0x0 0x10000>, + <0x0 0xff634540 0x0 0x8>; + interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq"; + clocks = <&clkc CLKID_ETH>, + <&clkc CLKID_FCLK_DIV2>, + <&clkc CLKID_MPLL2>; + clock-names = "stmmaceth", "clkin0", "clkin1"; + rx-fifo-depth = <4096>; + tx-fifo-depth = <2048>; + status = "disabled"; + + mdio0: mdio { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dwmac-mdio"; + }; + }; + + apb: bus@ff600000 { + compatible = "simple-bus"; + reg = <0x0 0xff600000 0x0 0x200000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0xff600000 0x0 0x200000>; + + hdmi_tx: hdmi-tx@0 { + compatible = "amlogic,meson-g12a-dw-hdmi"; + reg = <0x0 0x0 0x0 0x10000>; + interrupts = <GIC_SPI 57 IRQ_TYPE_EDGE_RISING>; + resets = <&reset RESET_HDMITX_CAPB3>, + <&reset RESET_HDMITX_PHY>, + <&reset RESET_HDMITX>; + reset-names = "hdmitx_apb", "hdmitx", "hdmitx_phy"; + clocks = <&clkc CLKID_HDMI>, + <&clkc CLKID_HTX_PCLK>, + <&clkc CLKID_VPU_INTR>; + clock-names = "isfr", "iahb", "venci"; + #address-cells = <1>; + #size-cells = <0>; + #sound-dai-cells = <0>; + status = "disabled"; + + /* VPU VENC Input */ + hdmi_tx_venc_port: port@0 { + reg = <0>; + + hdmi_tx_in: endpoint { + remote-endpoint = <&hdmi_tx_out>; + }; + }; + + /* TMDS Output */ + hdmi_tx_tmds_port: port@1 { + reg = <1>; + }; + }; + + apb_efuse: bus@30000 { + compatible = "simple-bus"; + reg = <0x0 0x30000 0x0 0x2000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0x30000 0x0 0x2000>; + + hwrng: rng@218 { + compatible = "amlogic,meson-rng"; + reg = <0x0 0x218 0x0 0x4>; + }; + }; + + periphs: bus@34400 { + compatible = "simple-bus"; + reg = <0x0 0x34400 0x0 0x400>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0x34400 0x0 0x400>; + + periphs_pinctrl: pinctrl@40 { + compatible = "amlogic,meson-g12a-periphs-pinctrl"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + gpio: bank@40 { + reg = <0x0 0x40 0x0 0x4c>, + <0x0 0xe8 0x0 0x18>, + <0x0 0x120 0x0 0x18>, + <0x0 0x2c0 0x0 0x40>, + <0x0 0x340 0x0 0x1c>; + reg-names = "gpio", + "pull", + "pull-enable", + "mux", + "ds"; + gpio-controller; + #gpio-cells = <2>; + gpio-ranges = <&periphs_pinctrl 0 0 86>; + }; + + cec_ao_a_h_pins: cec_ao_a_h { + mux { + groups = "cec_ao_a_h"; + function = "cec_ao_a_h"; + bias-disable; + }; + }; + + cec_ao_b_h_pins: cec_ao_b_h { + mux { + groups = "cec_ao_b_h"; + function = "cec_ao_b_h"; + bias-disable; + }; + }; + + emmc_pins: emmc { + mux-0 { + groups = "emmc_nand_d0", + "emmc_nand_d1", + "emmc_nand_d2", + "emmc_nand_d3", + "emmc_nand_d4", + "emmc_nand_d5", + "emmc_nand_d6", + "emmc_nand_d7", + "emmc_cmd"; + function = "emmc"; + bias-pull-up; + drive-strength-microamp = <4000>; + }; + + mux-1 { + groups = "emmc_clk"; + function = "emmc"; + bias-disable; + drive-strength-microamp = <4000>; + }; + }; + + emmc_ds_pins: emmc-ds { + mux { + groups = "emmc_nand_ds"; + function = "emmc"; + bias-pull-down; + drive-strength-microamp = <4000>; + }; + }; + + emmc_clk_gate_pins: emmc_clk_gate { + mux { + groups = "BOOT_8"; + function = "gpio_periphs"; + bias-pull-down; + drive-strength-microamp = <4000>; + }; + }; + + hdmitx_ddc_pins: hdmitx_ddc { + mux { + groups = "hdmitx_sda", + "hdmitx_sck"; + function = "hdmitx"; + bias-disable; + drive-strength-microamp = <4000>; + }; + }; + + hdmitx_hpd_pins: hdmitx_hpd { + mux { + groups = "hdmitx_hpd_in"; + function = "hdmitx"; + bias-disable; + }; + }; + + + i2c0_sda_c_pins: i2c0-sda-c { + mux { + groups = "i2c0_sda_c"; + function = "i2c0"; + bias-disable; + drive-strength-microamp = <3000>; + + }; + }; + + i2c0_sck_c_pins: i2c0-sck-c { + mux { + groups = "i2c0_sck_c"; + function = "i2c0"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c0_sda_z0_pins: i2c0-sda-z0 { + mux { + groups = "i2c0_sda_z0"; + function = "i2c0"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c0_sck_z1_pins: i2c0-sck-z1 { + mux { + groups = "i2c0_sck_z1"; + function = "i2c0"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c0_sda_z7_pins: i2c0-sda-z7 { + mux { + groups = "i2c0_sda_z7"; + function = "i2c0"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c0_sda_z8_pins: i2c0-sda-z8 { + mux { + groups = "i2c0_sda_z8"; + function = "i2c0"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c1_sda_x_pins: i2c1-sda-x { + mux { + groups = "i2c1_sda_x"; + function = "i2c1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c1_sck_x_pins: i2c1-sck-x { + mux { + groups = "i2c1_sck_x"; + function = "i2c1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c1_sda_h2_pins: i2c1-sda-h2 { + mux { + groups = "i2c1_sda_h2"; + function = "i2c1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c1_sck_h3_pins: i2c1-sck-h3 { + mux { + groups = "i2c1_sck_h3"; + function = "i2c1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c1_sda_h6_pins: i2c1-sda-h6 { + mux { + groups = "i2c1_sda_h6"; + function = "i2c1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c1_sck_h7_pins: i2c1-sck-h7 { + mux { + groups = "i2c1_sck_h7"; + function = "i2c1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c2_sda_x_pins: i2c2-sda-x { + mux { + groups = "i2c2_sda_x"; + function = "i2c2"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c2_sck_x_pins: i2c2-sck-x { + mux { + groups = "i2c2_sck_x"; + function = "i2c2"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c2_sda_z_pins: i2c2-sda-z { + mux { + groups = "i2c2_sda_z"; + function = "i2c2"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c2_sck_z_pins: i2c2-sck-z { + mux { + groups = "i2c2_sck_z"; + function = "i2c2"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c3_sda_h_pins: i2c3-sda-h { + mux { + groups = "i2c3_sda_h"; + function = "i2c3"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c3_sck_h_pins: i2c3-sck-h { + mux { + groups = "i2c3_sck_h"; + function = "i2c3"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c3_sda_a_pins: i2c3-sda-a { + mux { + groups = "i2c3_sda_a"; + function = "i2c3"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c3_sck_a_pins: i2c3-sck-a { + mux { + groups = "i2c3_sck_a"; + function = "i2c3"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + mclk0_a_pins: mclk0-a { + mux { + groups = "mclk0_a"; + function = "mclk0"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + mclk1_a_pins: mclk1-a { + mux { + groups = "mclk1_a"; + function = "mclk1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + mclk1_x_pins: mclk1-x { + mux { + groups = "mclk1_x"; + function = "mclk1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + mclk1_z_pins: mclk1-z { + mux { + groups = "mclk1_z"; + function = "mclk1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + pdm_din0_a_pins: pdm-din0-a { + mux { + groups = "pdm_din0_a"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din0_c_pins: pdm-din0-c { + mux { + groups = "pdm_din0_c"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din0_x_pins: pdm-din0-x { + mux { + groups = "pdm_din0_x"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din0_z_pins: pdm-din0-z { + mux { + groups = "pdm_din0_z"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din1_a_pins: pdm-din1-a { + mux { + groups = "pdm_din1_a"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din1_c_pins: pdm-din1-c { + mux { + groups = "pdm_din1_c"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din1_x_pins: pdm-din1-x { + mux { + groups = "pdm_din1_x"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din1_z_pins: pdm-din1-z { + mux { + groups = "pdm_din1_z"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din2_a_pins: pdm-din2-a { + mux { + groups = "pdm_din2_a"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din2_c_pins: pdm-din2-c { + mux { + groups = "pdm_din2_c"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din2_x_pins: pdm-din2-x { + mux { + groups = "pdm_din2_x"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din2_z_pins: pdm-din2-z { + mux { + groups = "pdm_din2_z"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din3_a_pins: pdm-din3-a { + mux { + groups = "pdm_din3_a"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din3_c_pins: pdm-din3-c { + mux { + groups = "pdm_din3_c"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din3_x_pins: pdm-din3-x { + mux { + groups = "pdm_din3_x"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din3_z_pins: pdm-din3-z { + mux { + groups = "pdm_din3_z"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_dclk_a_pins: pdm-dclk-a { + mux { + groups = "pdm_dclk_a"; + function = "pdm"; + bias-disable; + drive-strength-microamp = <500>; + }; + }; + + pdm_dclk_c_pins: pdm-dclk-c { + mux { + groups = "pdm_dclk_c"; + function = "pdm"; + bias-disable; + drive-strength-microamp = <500>; + }; + }; + + pdm_dclk_x_pins: pdm-dclk-x { + mux { + groups = "pdm_dclk_x"; + function = "pdm"; + bias-disable; + drive-strength-microamp = <500>; + }; + }; + + pdm_dclk_z_pins: pdm-dclk-z { + mux { + groups = "pdm_dclk_z"; + function = "pdm"; + bias-disable; + drive-strength-microamp = <500>; + }; + }; + + pwm_a_pins: pwm-a { + mux { + groups = "pwm_a"; + function = "pwm_a"; + bias-disable; + }; + }; + + pwm_b_x7_pins: pwm-b-x7 { + mux { + groups = "pwm_b_x7"; + function = "pwm_b"; + bias-disable; + }; + }; + + pwm_b_x19_pins: pwm-b-x19 { + mux { + groups = "pwm_b_x19"; + function = "pwm_b"; + bias-disable; + }; + }; + + pwm_c_c_pins: pwm-c-c { + mux { + groups = "pwm_c_c"; + function = "pwm_c"; + bias-disable; + }; + }; + + pwm_c_x5_pins: pwm-c-x5 { + mux { + groups = "pwm_c_x5"; + function = "pwm_c"; + bias-disable; + }; + }; + + pwm_c_x8_pins: pwm-c-x8 { + mux { + groups = "pwm_c_x8"; + function = "pwm_c"; + bias-disable; + }; + }; + + pwm_d_x3_pins: pwm-d-x3 { + mux { + groups = "pwm_d_x3"; + function = "pwm_d"; + bias-disable; + }; + }; + + pwm_d_x6_pins: pwm-d-x6 { + mux { + groups = "pwm_d_x6"; + function = "pwm_d"; + bias-disable; + }; + }; + + pwm_e_pins: pwm-e { + mux { + groups = "pwm_e"; + function = "pwm_e"; + bias-disable; + }; + }; + + pwm_f_x_pins: pwm-f-x { + mux { + groups = "pwm_f_x"; + function = "pwm_f"; + bias-disable; + }; + }; + + pwm_f_h_pins: pwm-f-h { + mux { + groups = "pwm_f_h"; + function = "pwm_f"; + bias-disable; + }; + }; + + sdcard_c_pins: sdcard_c { + mux-0 { + groups = "sdcard_d0_c", + "sdcard_d1_c", + "sdcard_d2_c", + "sdcard_d3_c", + "sdcard_cmd_c"; + function = "sdcard"; + bias-pull-up; + drive-strength-microamp = <4000>; + }; + + mux-1 { + groups = "sdcard_clk_c"; + function = "sdcard"; + bias-disable; + drive-strength-microamp = <4000>; + }; + }; + + sdcard_clk_gate_c_pins: sdcard_clk_gate_c { + mux { + groups = "GPIOC_4"; + function = "gpio_periphs"; + bias-pull-down; + drive-strength-microamp = <4000>; + }; + }; + + sdcard_z_pins: sdcard_z { + mux-0 { + groups = "sdcard_d0_z", + "sdcard_d1_z", + "sdcard_d2_z", + "sdcard_d3_z", + "sdcard_cmd_z"; + function = "sdcard"; + bias-pull-up; + drive-strength-microamp = <4000>; + }; + + mux-1 { + groups = "sdcard_clk_z"; + function = "sdcard"; + bias-disable; + drive-strength-microamp = <4000>; + }; + }; + + sdcard_clk_gate_z_pins: sdcard_clk_gate_z { + mux { + groups = "GPIOZ_6"; + function = "gpio_periphs"; + bias-pull-down; + drive-strength-microamp = <4000>; + }; + }; + + sdio_pins: sdio { + mux { + groups = "sdio_d0", + "sdio_d1", + "sdio_d2", + "sdio_d3", + "sdio_clk", + "sdio_cmd"; + function = "sdio"; + bias-disable; + drive-strength-microamp = <4000>; + }; + }; + + sdio_clk_gate_pins: sdio_clk_gate { + mux { + groups = "GPIOX_4"; + function = "gpio_periphs"; + bias-pull-down; + drive-strength-microamp = <4000>; + }; + }; + + spdif_in_a10_pins: spdif-in-a10 { + mux { + groups = "spdif_in_a10"; + function = "spdif_in"; + bias-disable; + }; + }; + + spdif_in_a12_pins: spdif-in-a12 { + mux { + groups = "spdif_in_a12"; + function = "spdif_in"; + bias-disable; + }; + }; + + spdif_in_h_pins: spdif-in-h { + mux { + groups = "spdif_in_h"; + function = "spdif_in"; + bias-disable; + }; + }; + + spdif_out_h_pins: spdif-out-h { + mux { + groups = "spdif_out_h"; + function = "spdif_out"; + drive-strength-microamp = <500>; + bias-disable; + }; + }; + + spdif_out_a11_pins: spdif-out-a11 { + mux { + groups = "spdif_out_a11"; + function = "spdif_out"; + drive-strength-microamp = <500>; + bias-disable; + }; + }; + + spdif_out_a13_pins: spdif-out-a13 { + mux { + groups = "spdif_out_a13"; + function = "spdif_out"; + drive-strength-microamp = <500>; + bias-disable; + }; + }; + + tdm_a_din0_pins: tdm-a-din0 { + mux { + groups = "tdm_a_din0"; + function = "tdm_a"; + bias-disable; + }; + }; + + + tdm_a_din1_pins: tdm-a-din1 { + mux { + groups = "tdm_a_din1"; + function = "tdm_a"; + bias-disable; + }; + }; + + tdm_a_dout0_pins: tdm-a-dout0 { + mux { + groups = "tdm_a_dout0"; + function = "tdm_a"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_a_dout1_pins: tdm-a-dout1 { + mux { + groups = "tdm_a_dout1"; + function = "tdm_a"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_a_fs_pins: tdm-a-fs { + mux { + groups = "tdm_a_fs"; + function = "tdm_a"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_a_sclk_pins: tdm-a-sclk { + mux { + groups = "tdm_a_sclk"; + function = "tdm_a"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_a_slv_fs_pins: tdm-a-slv-fs { + mux { + groups = "tdm_a_slv_fs"; + function = "tdm_a"; + bias-disable; + }; + }; + + + tdm_a_slv_sclk_pins: tdm-a-slv-sclk { + mux { + groups = "tdm_a_slv_sclk"; + function = "tdm_a"; + bias-disable; + }; + }; + + tdm_b_din0_pins: tdm-b-din0 { + mux { + groups = "tdm_b_din0"; + function = "tdm_b"; + bias-disable; + }; + }; + + tdm_b_din1_pins: tdm-b-din1 { + mux { + groups = "tdm_b_din1"; + function = "tdm_b"; + bias-disable; + }; + }; + + tdm_b_din2_pins: tdm-b-din2 { + mux { + groups = "tdm_b_din2"; + function = "tdm_b"; + bias-disable; + }; + }; + + tdm_b_din3_a_pins: tdm-b-din3-a { + mux { + groups = "tdm_b_din3_a"; + function = "tdm_b"; + bias-disable; + }; + }; + + tdm_b_din3_h_pins: tdm-b-din3-h { + mux { + groups = "tdm_b_din3_h"; + function = "tdm_b"; + bias-disable; + }; + }; + + tdm_b_dout0_pins: tdm-b-dout0 { + mux { + groups = "tdm_b_dout0"; + function = "tdm_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_b_dout1_pins: tdm-b-dout1 { + mux { + groups = "tdm_b_dout1"; + function = "tdm_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_b_dout2_pins: tdm-b-dout2 { + mux { + groups = "tdm_b_dout2"; + function = "tdm_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_b_dout3_a_pins: tdm-b-dout3-a { + mux { + groups = "tdm_b_dout3_a"; + function = "tdm_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_b_dout3_h_pins: tdm-b-dout3-h { + mux { + groups = "tdm_b_dout3_h"; + function = "tdm_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_b_fs_pins: tdm-b-fs { + mux { + groups = "tdm_b_fs"; + function = "tdm_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_b_sclk_pins: tdm-b-sclk { + mux { + groups = "tdm_b_sclk"; + function = "tdm_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_b_slv_fs_pins: tdm-b-slv-fs { + mux { + groups = "tdm_b_slv_fs"; + function = "tdm_b"; + bias-disable; + }; + }; + + tdm_b_slv_sclk_pins: tdm-b-slv-sclk { + mux { + groups = "tdm_b_slv_sclk"; + function = "tdm_b"; + bias-disable; + }; + }; + + tdm_c_din0_a_pins: tdm-c-din0-a { + mux { + groups = "tdm_c_din0_a"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_din0_z_pins: tdm-c-din0-z { + mux { + groups = "tdm_c_din0_z"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_din1_a_pins: tdm-c-din1-a { + mux { + groups = "tdm_c_din1_a"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_din1_z_pins: tdm-c-din1-z { + mux { + groups = "tdm_c_din1_z"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_din2_a_pins: tdm-c-din2-a { + mux { + groups = "tdm_c_din2_a"; + function = "tdm_c"; + bias-disable; + }; + }; + + eth_leds_pins: eth-leds { + mux { + groups = "eth_link_led", + "eth_act_led"; + function = "eth"; + bias-disable; + }; + }; + + eth_pins: eth { + mux { + groups = "eth_mdio", + "eth_mdc", + "eth_rgmii_rx_clk", + "eth_rx_dv", + "eth_rxd0", + "eth_rxd1", + "eth_txen", + "eth_txd0", + "eth_txd1"; + function = "eth"; + drive-strength-microamp = <4000>; + bias-disable; + }; + }; + + eth_rgmii_pins: eth-rgmii { + mux { + groups = "eth_rxd2_rgmii", + "eth_rxd3_rgmii", + "eth_rgmii_tx_clk", + "eth_txd2_rgmii", + "eth_txd3_rgmii"; + function = "eth"; + drive-strength-microamp = <4000>; + bias-disable; + }; + }; + + tdm_c_din2_z_pins: tdm-c-din2-z { + mux { + groups = "tdm_c_din2_z"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_din3_a_pins: tdm-c-din3-a { + mux { + groups = "tdm_c_din3_a"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_din3_z_pins: tdm-c-din3-z { + mux { + groups = "tdm_c_din3_z"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_dout0_a_pins: tdm-c-dout0-a { + mux { + groups = "tdm_c_dout0_a"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_dout0_z_pins: tdm-c-dout0-z { + mux { + groups = "tdm_c_dout0_z"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_dout1_a_pins: tdm-c-dout1-a { + mux { + groups = "tdm_c_dout1_a"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_dout1_z_pins: tdm-c-dout1-z { + mux { + groups = "tdm_c_dout1_z"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_dout2_a_pins: tdm-c-dout2-a { + mux { + groups = "tdm_c_dout2_a"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_dout2_z_pins: tdm-c-dout2-z { + mux { + groups = "tdm_c_dout2_z"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_dout3_a_pins: tdm-c-dout3-a { + mux { + groups = "tdm_c_dout3_a"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_dout3_z_pins: tdm-c-dout3-z { + mux { + groups = "tdm_c_dout3_z"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_fs_a_pins: tdm-c-fs-a { + mux { + groups = "tdm_c_fs_a"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_fs_z_pins: tdm-c-fs-z { + mux { + groups = "tdm_c_fs_z"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_sclk_a_pins: tdm-c-sclk-a { + mux { + groups = "tdm_c_sclk_a"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_sclk_z_pins: tdm-c-sclk-z { + mux { + groups = "tdm_c_sclk_z"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_slv_fs_a_pins: tdm-c-slv-fs-a { + mux { + groups = "tdm_c_slv_fs_a"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_slv_fs_z_pins: tdm-c-slv-fs-z { + mux { + groups = "tdm_c_slv_fs_z"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_slv_sclk_a_pins: tdm-c-slv-sclk-a { + mux { + groups = "tdm_c_slv_sclk_a"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_slv_sclk_z_pins: tdm-c-slv-sclk-z { + mux { + groups = "tdm_c_slv_sclk_z"; + function = "tdm_c"; + bias-disable; + }; + }; + + uart_a_pins: uart-a { + mux { + groups = "uart_a_tx", + "uart_a_rx"; + function = "uart_a"; + bias-disable; + }; + }; + + uart_a_cts_rts_pins: uart-a-cts-rts { + mux { + groups = "uart_a_cts", + "uart_a_rts"; + function = "uart_a"; + bias-disable; + }; + }; + + uart_b_pins: uart-b { + mux { + groups = "uart_b_tx", + "uart_b_rx"; + function = "uart_b"; + bias-disable; + }; + }; + + uart_c_pins: uart-c { + mux { + groups = "uart_c_tx", + "uart_c_rx"; + function = "uart_c"; + bias-disable; + }; + }; + + uart_c_cts_rts_pins: uart-c-cts-rts { + mux { + groups = "uart_c_cts", + "uart_c_rts"; + function = "uart_c"; + bias-disable; + }; + }; + }; + }; + + usb2_phy0: phy@36000 { + compatible = "amlogic,g12a-usb2-phy"; + reg = <0x0 0x36000 0x0 0x2000>; + clocks = <&xtal>; + clock-names = "xtal"; + resets = <&reset RESET_USB_PHY20>; + reset-names = "phy"; + #phy-cells = <0>; + }; + + dmc: bus@38000 { + compatible = "simple-bus"; + reg = <0x0 0x38000 0x0 0x400>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0x38000 0x0 0x400>; + + canvas: video-lut@48 { + compatible = "amlogic,canvas"; + reg = <0x0 0x48 0x0 0x14>; + }; + }; + + usb2_phy1: phy@3a000 { + compatible = "amlogic,g12a-usb2-phy"; + reg = <0x0 0x3a000 0x0 0x2000>; + clocks = <&xtal>; + clock-names = "xtal"; + resets = <&reset RESET_USB_PHY21>; + reset-names = "phy"; + #phy-cells = <0>; + }; + + hiu: bus@3c000 { + compatible = "simple-bus"; + reg = <0x0 0x3c000 0x0 0x1400>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0x3c000 0x0 0x1400>; + + hhi: system-controller@0 { + compatible = "amlogic,meson-gx-hhi-sysctrl", + "simple-mfd", "syscon"; + reg = <0 0 0 0x400>; + + clkc: clock-controller { + compatible = "amlogic,g12a-clkc"; + #clock-cells = <1>; + clocks = <&xtal>; + clock-names = "xtal"; + }; + + pwrc: power-controller { + compatible = "amlogic,meson-g12a-pwrc"; + #power-domain-cells = <1>; + amlogic,ao-sysctrl = <&rti>; + resets = <&reset RESET_VIU>, + <&reset RESET_VENC>, + <&reset RESET_VCBUS>, + <&reset RESET_BT656>, + <&reset RESET_RDMA>, + <&reset RESET_VENCI>, + <&reset RESET_VENCP>, + <&reset RESET_VDAC>, + <&reset RESET_VDI6>, + <&reset RESET_VENCL>, + <&reset RESET_VID_LOCK>; + reset-names = "viu", "venc", "vcbus", "bt656", + "rdma", "venci", "vencp", "vdac", + "vdi6", "vencl", "vid_lock"; + clocks = <&clkc CLKID_VPU>, + <&clkc CLKID_VAPB>; + clock-names = "vpu", "vapb"; + /* + * VPU clocking is provided by two identical clock paths + * VPU_0 and VPU_1 muxed to a single clock by a glitch + * free mux to safely change frequency while running. + * Same for VAPB but with a final gate after the glitch free mux. + */ + assigned-clocks = <&clkc CLKID_VPU_0_SEL>, + <&clkc CLKID_VPU_0>, + <&clkc CLKID_VPU>, /* Glitch free mux */ + <&clkc CLKID_VAPB_0_SEL>, + <&clkc CLKID_VAPB_0>, + <&clkc CLKID_VAPB_SEL>; /* Glitch free mux */ + assigned-clock-parents = <&clkc CLKID_FCLK_DIV3>, + <0>, /* Do Nothing */ + <&clkc CLKID_VPU_0>, + <&clkc CLKID_FCLK_DIV4>, + <0>, /* Do Nothing */ + <&clkc CLKID_VAPB_0>; + assigned-clock-rates = <0>, /* Do Nothing */ + <666666666>, + <0>, /* Do Nothing */ + <0>, /* Do Nothing */ + <250000000>, + <0>; /* Do Nothing */ + }; + }; + }; + + pdm: audio-controller@40000 { + compatible = "amlogic,g12a-pdm", + "amlogic,axg-pdm"; + reg = <0x0 0x40000 0x0 0x34>; + #sound-dai-cells = <0>; + sound-name-prefix = "PDM"; + clocks = <&clkc_audio AUD_CLKID_PDM>, + <&clkc_audio AUD_CLKID_PDM_DCLK>, + <&clkc_audio AUD_CLKID_PDM_SYSCLK>; + clock-names = "pclk", "dclk", "sysclk"; + status = "disabled"; + }; + + audio: bus@42000 { + compatible = "simple-bus"; + reg = <0x0 0x42000 0x0 0x2000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0x42000 0x0 0x2000>; + + clkc_audio: clock-controller@0 { + status = "disabled"; + compatible = "amlogic,g12a-audio-clkc"; + reg = <0x0 0x0 0x0 0xb4>; + #clock-cells = <1>; + #reset-cells = <1>; + + clocks = <&clkc CLKID_AUDIO>, + <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>, + <&clkc CLKID_MPLL2>, + <&clkc CLKID_MPLL3>, + <&clkc CLKID_HIFI_PLL>, + <&clkc CLKID_FCLK_DIV3>, + <&clkc CLKID_FCLK_DIV4>, + <&clkc CLKID_GP0_PLL>; + clock-names = "pclk", + "mst_in0", + "mst_in1", + "mst_in2", + "mst_in3", + "mst_in4", + "mst_in5", + "mst_in6", + "mst_in7"; + + resets = <&reset RESET_AUDIO>; + }; + + toddr_a: audio-controller@100 { + compatible = "amlogic,g12a-toddr", + "amlogic,axg-toddr"; + reg = <0x0 0x100 0x0 0x1c>; + #sound-dai-cells = <0>; + sound-name-prefix = "TODDR_A"; + interrupts = <GIC_SPI 148 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_TODDR_A>; + resets = <&arb AXG_ARB_TODDR_A>; + status = "disabled"; + }; + + toddr_b: audio-controller@140 { + compatible = "amlogic,g12a-toddr", + "amlogic,axg-toddr"; + reg = <0x0 0x140 0x0 0x1c>; + #sound-dai-cells = <0>; + sound-name-prefix = "TODDR_B"; + interrupts = <GIC_SPI 149 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_TODDR_B>; + resets = <&arb AXG_ARB_TODDR_B>; + status = "disabled"; + }; + + toddr_c: audio-controller@180 { + compatible = "amlogic,g12a-toddr", + "amlogic,axg-toddr"; + reg = <0x0 0x180 0x0 0x1c>; + #sound-dai-cells = <0>; + sound-name-prefix = "TODDR_C"; + interrupts = <GIC_SPI 150 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_TODDR_C>; + resets = <&arb AXG_ARB_TODDR_C>; + status = "disabled"; + }; + + frddr_a: audio-controller@1c0 { + compatible = "amlogic,g12a-frddr", + "amlogic,axg-frddr"; + reg = <0x0 0x1c0 0x0 0x1c>; + #sound-dai-cells = <0>; + sound-name-prefix = "FRDDR_A"; + interrupts = <GIC_SPI 152 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_FRDDR_A>; + resets = <&arb AXG_ARB_FRDDR_A>; + status = "disabled"; + }; + + frddr_b: audio-controller@200 { + compatible = "amlogic,g12a-frddr", + "amlogic,axg-frddr"; + reg = <0x0 0x200 0x0 0x1c>; + #sound-dai-cells = <0>; + sound-name-prefix = "FRDDR_B"; + interrupts = <GIC_SPI 153 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_FRDDR_B>; + resets = <&arb AXG_ARB_FRDDR_B>; + status = "disabled"; + }; + + frddr_c: audio-controller@240 { + compatible = "amlogic,g12a-frddr", + "amlogic,axg-frddr"; + reg = <0x0 0x240 0x0 0x1c>; + #sound-dai-cells = <0>; + sound-name-prefix = "FRDDR_C"; + interrupts = <GIC_SPI 154 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_FRDDR_C>; + resets = <&arb AXG_ARB_FRDDR_C>; + status = "disabled"; + }; + + arb: reset-controller@280 { + status = "disabled"; + compatible = "amlogic,meson-axg-audio-arb"; + reg = <0x0 0x280 0x0 0x4>; + #reset-cells = <1>; + clocks = <&clkc_audio AUD_CLKID_DDR_ARB>; + }; + + tdmin_a: audio-controller@300 { + compatible = "amlogic,g12a-tdmin", + "amlogic,axg-tdmin"; + reg = <0x0 0x300 0x0 0x40>; + sound-name-prefix = "TDMIN_A"; + resets = <&clkc_audio AUD_RESET_TDMIN_A>; + clocks = <&clkc_audio AUD_CLKID_TDMIN_A>, + <&clkc_audio AUD_CLKID_TDMIN_A_SCLK>, + <&clkc_audio AUD_CLKID_TDMIN_A_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMIN_A_LRCLK>, + <&clkc_audio AUD_CLKID_TDMIN_A_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmin_b: audio-controller@340 { + compatible = "amlogic,g12a-tdmin", + "amlogic,axg-tdmin"; + reg = <0x0 0x340 0x0 0x40>; + sound-name-prefix = "TDMIN_B"; + resets = <&clkc_audio AUD_RESET_TDMIN_B>; + clocks = <&clkc_audio AUD_CLKID_TDMIN_B>, + <&clkc_audio AUD_CLKID_TDMIN_B_SCLK>, + <&clkc_audio AUD_CLKID_TDMIN_B_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMIN_B_LRCLK>, + <&clkc_audio AUD_CLKID_TDMIN_B_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmin_c: audio-controller@380 { + compatible = "amlogic,g12a-tdmin", + "amlogic,axg-tdmin"; + reg = <0x0 0x380 0x0 0x40>; + sound-name-prefix = "TDMIN_C"; + resets = <&clkc_audio AUD_RESET_TDMIN_C>; + clocks = <&clkc_audio AUD_CLKID_TDMIN_C>, + <&clkc_audio AUD_CLKID_TDMIN_C_SCLK>, + <&clkc_audio AUD_CLKID_TDMIN_C_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMIN_C_LRCLK>, + <&clkc_audio AUD_CLKID_TDMIN_C_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmin_lb: audio-controller@3c0 { + compatible = "amlogic,g12a-tdmin", + "amlogic,axg-tdmin"; + reg = <0x0 0x3c0 0x0 0x40>; + sound-name-prefix = "TDMIN_LB"; + resets = <&clkc_audio AUD_RESET_TDMIN_LB>; + clocks = <&clkc_audio AUD_CLKID_TDMIN_LB>, + <&clkc_audio AUD_CLKID_TDMIN_LB_SCLK>, + <&clkc_audio AUD_CLKID_TDMIN_LB_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMIN_LB_LRCLK>, + <&clkc_audio AUD_CLKID_TDMIN_LB_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + spdifin: audio-controller@400 { + compatible = "amlogic,g12a-spdifin", + "amlogic,axg-spdifin"; + reg = <0x0 0x400 0x0 0x30>; + #sound-dai-cells = <0>; + sound-name-prefix = "SPDIFIN"; + interrupts = <GIC_SPI 151 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_SPDIFIN>, + <&clkc_audio AUD_CLKID_SPDIFIN_CLK>; + clock-names = "pclk", "refclk"; + status = "disabled"; + }; + + spdifout: audio-controller@480 { + compatible = "amlogic,g12a-spdifout", + "amlogic,axg-spdifout"; + reg = <0x0 0x480 0x0 0x50>; + #sound-dai-cells = <0>; + sound-name-prefix = "SPDIFOUT"; + clocks = <&clkc_audio AUD_CLKID_SPDIFOUT>, + <&clkc_audio AUD_CLKID_SPDIFOUT_CLK>; + clock-names = "pclk", "mclk"; + status = "disabled"; + }; + + tdmout_a: audio-controller@500 { + compatible = "amlogic,g12a-tdmout"; + reg = <0x0 0x500 0x0 0x40>; + sound-name-prefix = "TDMOUT_A"; + resets = <&clkc_audio AUD_RESET_TDMOUT_A>; + clocks = <&clkc_audio AUD_CLKID_TDMOUT_A>, + <&clkc_audio AUD_CLKID_TDMOUT_A_SCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_A_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMOUT_A_LRCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_A_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmout_b: audio-controller@540 { + compatible = "amlogic,g12a-tdmout"; + reg = <0x0 0x540 0x0 0x40>; + sound-name-prefix = "TDMOUT_B"; + resets = <&clkc_audio AUD_RESET_TDMOUT_B>; + clocks = <&clkc_audio AUD_CLKID_TDMOUT_B>, + <&clkc_audio AUD_CLKID_TDMOUT_B_SCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_B_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMOUT_B_LRCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_B_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmout_c: audio-controller@580 { + compatible = "amlogic,g12a-tdmout"; + reg = <0x0 0x580 0x0 0x40>; + sound-name-prefix = "TDMOUT_C"; + resets = <&clkc_audio AUD_RESET_TDMOUT_C>; + clocks = <&clkc_audio AUD_CLKID_TDMOUT_C>, + <&clkc_audio AUD_CLKID_TDMOUT_C_SCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_C_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMOUT_C_LRCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_C_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + spdifout_b: audio-controller@680 { + compatible = "amlogic,g12a-spdifout", + "amlogic,axg-spdifout"; + reg = <0x0 0x680 0x0 0x50>; + #sound-dai-cells = <0>; + sound-name-prefix = "SPDIFOUT_B"; + clocks = <&clkc_audio AUD_CLKID_SPDIFOUT_B>, + <&clkc_audio AUD_CLKID_SPDIFOUT_B_CLK>; + clock-names = "pclk", "mclk"; + status = "disabled"; + }; + + tohdmitx: audio-controller@744 { + compatible = "amlogic,g12a-tohdmitx"; + reg = <0x0 0x744 0x0 0x4>; + #sound-dai-cells = <1>; + sound-name-prefix = "TOHDMITX"; + status = "disabled"; + }; + }; + + usb3_pcie_phy: phy@46000 { + compatible = "amlogic,g12a-usb3-pcie-phy"; + reg = <0x0 0x46000 0x0 0x2000>; + clocks = <&clkc CLKID_PCIE_PLL>; + clock-names = "ref_clk"; + resets = <&reset RESET_PCIE_PHY>; + reset-names = "phy"; + assigned-clocks = <&clkc CLKID_PCIE_PLL>; + assigned-clock-rates = <100000000>; + #phy-cells = <1>; + }; + + eth_phy: mdio-multiplexer@4c000 { + compatible = "amlogic,g12a-mdio-mux"; + reg = <0x0 0x4c000 0x0 0xa4>; + clocks = <&clkc CLKID_ETH_PHY>, + <&xtal>, + <&clkc CLKID_MPLL_50M>; + clock-names = "pclk", "clkin0", "clkin1"; + mdio-parent-bus = <&mdio0>; + #address-cells = <1>; + #size-cells = <0>; + + ext_mdio: mdio@0 { + reg = <0>; + #address-cells = <1>; + #size-cells = <0>; + }; + + int_mdio: mdio@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + + internal_ephy: ethernet_phy@8 { + compatible = "ethernet-phy-id0180.3301", + "ethernet-phy-ieee802.3-c22"; + interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; + reg = <8>; + max-speed = <100>; + }; + }; + }; + }; + + aobus: bus@ff800000 { + compatible = "simple-bus"; + reg = <0x0 0xff800000 0x0 0x100000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0xff800000 0x0 0x100000>; + + rti: sys-ctrl@0 { + compatible = "amlogic,meson-gx-ao-sysctrl", + "simple-mfd", "syscon"; + reg = <0x0 0x0 0x0 0x100>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0x0 0x0 0x100>; + + clkc_AO: clock-controller { + compatible = "amlogic,meson-g12a-aoclkc"; + #clock-cells = <1>; + #reset-cells = <1>; + clocks = <&xtal>, <&clkc CLKID_CLK81>; + clock-names = "xtal", "mpeg-clk"; + }; + + ao_pinctrl: pinctrl@14 { + compatible = "amlogic,meson-g12a-aobus-pinctrl"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + gpio_ao: bank@14 { + reg = <0x0 0x14 0x0 0x8>, + <0x0 0x1c 0x0 0x8>, + <0x0 0x24 0x0 0x14>; + reg-names = "mux", + "ds", + "gpio"; + gpio-controller; + #gpio-cells = <2>; + gpio-ranges = <&ao_pinctrl 0 0 15>; + }; + + i2c_ao_sck_pins: i2c_ao_sck_pins { + mux { + groups = "i2c_ao_sck"; + function = "i2c_ao"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c_ao_sda_pins: i2c_ao_sda { + mux { + groups = "i2c_ao_sda"; + function = "i2c_ao"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c_ao_sck_e_pins: i2c_ao_sck_e { + mux { + groups = "i2c_ao_sck_e"; + function = "i2c_ao"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c_ao_sda_e_pins: i2c_ao_sda_e { + mux { + groups = "i2c_ao_sda_e"; + function = "i2c_ao"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + mclk0_ao_pins: mclk0-ao { + mux { + groups = "mclk0_ao"; + function = "mclk0_ao"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_ao_b_din0_pins: tdm-ao-b-din0 { + mux { + groups = "tdm_ao_b_din0"; + function = "tdm_ao_b"; + bias-disable; + }; + }; + + spdif_ao_out_pins: spdif-ao-out { + mux { + groups = "spdif_ao_out"; + function = "spdif_ao_out"; + drive-strength-microamp = <500>; + bias-disable; + }; + }; + + tdm_ao_b_din1_pins: tdm-ao-b-din1 { + mux { + groups = "tdm_ao_b_din1"; + function = "tdm_ao_b"; + bias-disable; + }; + }; + + tdm_ao_b_din2_pins: tdm-ao-b-din2 { + mux { + groups = "tdm_ao_b_din2"; + function = "tdm_ao_b"; + bias-disable; + }; + }; + + tdm_ao_b_dout0_pins: tdm-ao-b-dout0 { + mux { + groups = "tdm_ao_b_dout0"; + function = "tdm_ao_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_ao_b_dout1_pins: tdm-ao-b-dout1 { + mux { + groups = "tdm_ao_b_dout1"; + function = "tdm_ao_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_ao_b_dout2_pins: tdm-ao-b-dout2 { + mux { + groups = "tdm_ao_b_dout2"; + function = "tdm_ao_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_ao_b_fs_pins: tdm-ao-b-fs { + mux { + groups = "tdm_ao_b_fs"; + function = "tdm_ao_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_ao_b_sclk_pins: tdm-ao-b-sclk { + mux { + groups = "tdm_ao_b_sclk"; + function = "tdm_ao_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_ao_b_slv_fs_pins: tdm-ao-b-slv-fs { + mux { + groups = "tdm_ao_b_slv_fs"; + function = "tdm_ao_b"; + bias-disable; + }; + }; + + tdm_ao_b_slv_sclk_pins: tdm-ao-b-slv-sclk { + mux { + groups = "tdm_ao_b_slv_sclk"; + function = "tdm_ao_b"; + bias-disable; + }; + }; + + uart_ao_a_pins: uart-a-ao { + mux { + groups = "uart_ao_a_tx", + "uart_ao_a_rx"; + function = "uart_ao_a"; + bias-disable; + }; + }; + + uart_ao_a_cts_rts_pins: uart-ao-a-cts-rts { + mux { + groups = "uart_ao_a_cts", + "uart_ao_a_rts"; + function = "uart_ao_a"; + bias-disable; + }; + }; + + pwm_a_e_pins: pwm-a-e { + mux { + groups = "pwm_a_e"; + function = "pwm_a_e"; + bias-disable; + }; + }; + + pwm_ao_a_pins: pwm-ao-a { + mux { + groups = "pwm_ao_a"; + function = "pwm_ao_a"; + bias-disable; + }; + }; + + pwm_ao_b_pins: pwm-ao-b { + mux { + groups = "pwm_ao_b"; + function = "pwm_ao_b"; + bias-disable; + }; + }; + + pwm_ao_c_4_pins: pwm-ao-c-4 { + mux { + groups = "pwm_ao_c_4"; + function = "pwm_ao_c"; + bias-disable; + }; + }; + + pwm_ao_c_6_pins: pwm-ao-c-6 { + mux { + groups = "pwm_ao_c_6"; + function = "pwm_ao_c"; + bias-disable; + }; + }; + + pwm_ao_d_5_pins: pwm-ao-d-5 { + mux { + groups = "pwm_ao_d_5"; + function = "pwm_ao_d"; + bias-disable; + }; + }; + + pwm_ao_d_10_pins: pwm-ao-d-10 { + mux { + groups = "pwm_ao_d_10"; + function = "pwm_ao_d"; + bias-disable; + }; + }; + + pwm_ao_d_e_pins: pwm-ao-d-e { + mux { + groups = "pwm_ao_d_e"; + function = "pwm_ao_d"; + }; + }; + + remote_input_ao_pins: remote-input-ao { + mux { + groups = "remote_ao_input"; + function = "remote_ao_input"; + bias-disable; + }; + }; + }; + }; + + vrtc: rtc@0a8 { + compatible = "amlogic,meson-vrtc"; + reg = <0x0 0x000a8 0x0 0x4>; + }; + + cec_AO: cec@100 { + compatible = "amlogic,meson-gx-ao-cec"; + reg = <0x0 0x00100 0x0 0x14>; + interrupts = <GIC_SPI 199 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_AO CLKID_AO_CEC>; + clock-names = "core"; + status = "disabled"; + }; + + sec_AO: ao-secure@140 { + compatible = "amlogic,meson-gx-ao-secure", "syscon"; + reg = <0x0 0x140 0x0 0x140>; + amlogic,has-chip-id; + }; + + cecb_AO: cec@280 { + compatible = "amlogic,meson-g12a-ao-cec"; + reg = <0x0 0x00280 0x0 0x1c>; + interrupts = <GIC_SPI 203 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_AO CLKID_AO_CTS_OSCIN>; + clock-names = "oscin"; + status = "disabled"; + }; + + pwm_AO_cd: pwm@2000 { + compatible = "amlogic,meson-g12a-ao-pwm-cd"; + reg = <0x0 0x2000 0x0 0x20>; + #pwm-cells = <3>; + status = "disabled"; + }; + + uart_AO: serial@3000 { + compatible = "amlogic,meson-gx-uart", + "amlogic,meson-ao-uart"; + reg = <0x0 0x3000 0x0 0x18>; + interrupts = <GIC_SPI 193 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>, <&clkc_AO CLKID_AO_UART>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; + status = "disabled"; + }; + + uart_AO_B: serial@4000 { + compatible = "amlogic,meson-gx-uart", + "amlogic,meson-ao-uart"; + reg = <0x0 0x4000 0x0 0x18>; + interrupts = <GIC_SPI 197 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>, <&clkc_AO CLKID_AO_UART2>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; + status = "disabled"; + }; + + i2c_AO: i2c@5000 { + compatible = "amlogic,meson-axg-i2c"; + status = "disabled"; + reg = <0x0 0x05000 0x0 0x20>; + interrupts = <GIC_SPI 195 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&clkc CLKID_I2C>; + }; + + pwm_AO_ab: pwm@7000 { + compatible = "amlogic,meson-g12a-ao-pwm-ab"; + reg = <0x0 0x7000 0x0 0x20>; + #pwm-cells = <3>; + status = "disabled"; + }; + + ir: ir@8000 { + compatible = "amlogic,meson-gxbb-ir"; + reg = <0x0 0x8000 0x0 0x20>; + interrupts = <GIC_SPI 196 IRQ_TYPE_EDGE_RISING>; + status = "disabled"; + }; + + saradc: adc@9000 { + compatible = "amlogic,meson-g12a-saradc", + "amlogic,meson-saradc"; + reg = <0x0 0x9000 0x0 0x48>; + #io-channel-cells = <1>; + interrupts = <GIC_SPI 200 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>, + <&clkc_AO CLKID_AO_SAR_ADC>, + <&clkc_AO CLKID_AO_SAR_ADC_CLK>, + <&clkc_AO CLKID_AO_SAR_ADC_SEL>; + clock-names = "clkin", "core", "adc_clk", "adc_sel"; + status = "disabled"; + }; + }; + + vpu: vpu@ff900000 { + compatible = "amlogic,meson-g12a-vpu"; + reg = <0x0 0xff900000 0x0 0x100000>, + <0x0 0xff63c000 0x0 0x1000>; + reg-names = "vpu", "hhi"; + interrupts = <GIC_SPI 3 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + amlogic,canvas = <&canvas>; + + /* CVBS VDAC output port */ + cvbs_vdac_port: port@0 { + reg = <0>; + }; + + /* HDMI-TX output port */ + hdmi_tx_port: port@1 { + reg = <1>; + + hdmi_tx_out: endpoint { + remote-endpoint = <&hdmi_tx_in>; + }; + }; + }; + + gic: interrupt-controller@ffc01000 { + compatible = "arm,gic-400"; + reg = <0x0 0xffc01000 0 0x1000>, + <0x0 0xffc02000 0 0x2000>, + <0x0 0xffc04000 0 0x2000>, + <0x0 0xffc06000 0 0x2000>; + interrupt-controller; + interrupts = <GIC_PPI 9 + (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_HIGH)>; + #interrupt-cells = <3>; + #address-cells = <0>; + }; + + cbus: bus@ffd00000 { + compatible = "simple-bus"; + reg = <0x0 0xffd00000 0x0 0x100000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0xffd00000 0x0 0x100000>; + + reset: reset-controller@1004 { + compatible = "amlogic,meson-axg-reset"; + reg = <0x0 0x1004 0x0 0x9c>; + #reset-cells = <1>; + }; + + gpio_intc: interrupt-controller@f080 { + compatible = "amlogic,meson-g12a-gpio-intc", + "amlogic,meson-gpio-intc"; + reg = <0x0 0xf080 0x0 0x10>; + interrupt-controller; + #interrupt-cells = <2>; + amlogic,channel-interrupts = <64 65 66 67 68 69 70 71>; + }; + + pwm_ef: pwm@19000 { + compatible = "amlogic,meson-g12a-ee-pwm"; + reg = <0x0 0x19000 0x0 0x20>; + #pwm-cells = <3>; + status = "disabled"; + }; + + pwm_cd: pwm@1a000 { + compatible = "amlogic,meson-g12a-ee-pwm"; + reg = <0x0 0x1a000 0x0 0x20>; + #pwm-cells = <3>; + status = "disabled"; + }; + + pwm_ab: pwm@1b000 { + compatible = "amlogic,meson-g12a-ee-pwm"; + reg = <0x0 0x1b000 0x0 0x20>; + #pwm-cells = <3>; + status = "disabled"; + }; + + i2c3: i2c@1c000 { + compatible = "amlogic,meson-axg-i2c"; + status = "disabled"; + reg = <0x0 0x1c000 0x0 0x20>; + interrupts = <GIC_SPI 39 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&clkc CLKID_I2C>; + }; + + i2c2: i2c@1d000 { + compatible = "amlogic,meson-axg-i2c"; + status = "disabled"; + reg = <0x0 0x1d000 0x0 0x20>; + interrupts = <GIC_SPI 215 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&clkc CLKID_I2C>; + }; + + i2c1: i2c@1e000 { + compatible = "amlogic,meson-axg-i2c"; + status = "disabled"; + reg = <0x0 0x1e000 0x0 0x20>; + interrupts = <GIC_SPI 214 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&clkc CLKID_I2C>; + }; + + i2c0: i2c@1f000 { + compatible = "amlogic,meson-axg-i2c"; + status = "disabled"; + reg = <0x0 0x1f000 0x0 0x20>; + interrupts = <GIC_SPI 21 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&clkc CLKID_I2C>; + }; + + clk_msr: clock-measure@18000 { + compatible = "amlogic,meson-g12a-clk-measure"; + reg = <0x0 0x18000 0x0 0x10>; + }; + + uart_C: serial@22000 { + compatible = "amlogic,meson-gx-uart"; + reg = <0x0 0x22000 0x0 0x18>; + interrupts = <GIC_SPI 93 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>, <&clkc CLKID_UART2>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; + status = "disabled"; + }; + + uart_B: serial@23000 { + compatible = "amlogic,meson-gx-uart"; + reg = <0x0 0x23000 0x0 0x18>; + interrupts = <GIC_SPI 75 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>, <&clkc CLKID_UART1>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; + status = "disabled"; + }; + + uart_A: serial@24000 { + compatible = "amlogic,meson-gx-uart"; + reg = <0x0 0x24000 0x0 0x18>; + interrupts = <GIC_SPI 26 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>, <&clkc CLKID_UART0>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; + status = "disabled"; + }; + }; + + sd_emmc_a: sd@ffe03000 { + compatible = "amlogic,meson-axg-mmc"; + reg = <0x0 0xffe03000 0x0 0x800>; + interrupts = <GIC_SPI 189 IRQ_TYPE_EDGE_RISING>; + status = "disabled"; + clocks = <&clkc CLKID_SD_EMMC_A>, + <&clkc CLKID_SD_EMMC_A_CLK0>, + <&clkc CLKID_FCLK_DIV2>; + clock-names = "core", "clkin0", "clkin1"; + resets = <&reset RESET_SD_EMMC_A>; + }; + + sd_emmc_b: sd@ffe05000 { + compatible = "amlogic,meson-axg-mmc"; + reg = <0x0 0xffe05000 0x0 0x800>; + interrupts = <GIC_SPI 190 IRQ_TYPE_EDGE_RISING>; + status = "disabled"; + clocks = <&clkc CLKID_SD_EMMC_B>, + <&clkc CLKID_SD_EMMC_B_CLK0>, + <&clkc CLKID_FCLK_DIV2>; + clock-names = "core", "clkin0", "clkin1"; + resets = <&reset RESET_SD_EMMC_B>; + }; + + sd_emmc_c: mmc@ffe07000 { + compatible = "amlogic,meson-axg-mmc"; + reg = <0x0 0xffe07000 0x0 0x800>; + interrupts = <GIC_SPI 191 IRQ_TYPE_EDGE_RISING>; + status = "disabled"; + clocks = <&clkc CLKID_SD_EMMC_C>, + <&clkc CLKID_SD_EMMC_C_CLK0>, + <&clkc CLKID_FCLK_DIV2>; + clock-names = "core", "clkin0", "clkin1"; + resets = <&reset RESET_SD_EMMC_C>; + }; + + usb: usb@ffe09000 { + status = "disabled"; + compatible = "amlogic,meson-g12a-usb-ctrl"; + reg = <0x0 0xffe09000 0x0 0xa0>; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + clocks = <&clkc CLKID_USB>; + resets = <&reset RESET_USB>; + + dr_mode = "otg"; + + phys = <&usb2_phy0>, <&usb2_phy1>, + <&usb3_pcie_phy PHY_TYPE_USB3>; + phy-names = "usb2-phy0", "usb2-phy1", "usb3-phy0"; + + dwc2: usb@ff400000 { + compatible = "amlogic,meson-g12a-usb", "snps,dwc2"; + reg = <0x0 0xff400000 0x0 0x40000>; + interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clkc CLKID_USB1_DDR_BRIDGE>; + clock-names = "ddr"; + phys = <&usb2_phy1>; + phy-names = "usb2-phy"; + dr_mode = "peripheral"; + g-rx-fifo-size = <192>; + g-np-tx-fifo-size = <128>; + g-tx-fifo-size = <128 128 16 16 16>; + }; + + dwc3: usb@ff500000 { + compatible = "snps,dwc3"; + reg = <0x0 0xff500000 0x0 0x100000>; + interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; + dr_mode = "host"; + snps,dis_u2_susphy_quirk; + snps,quirk-frame-length-adjustment; + }; + }; + + mali: gpu@ffe40000 { + compatible = "amlogic,meson-g12a-mali", "arm,mali-bifrost"; + reg = <0x0 0xffe40000 0x0 0x40000>; + interrupt-parent = <&gic>; + interrupts = <GIC_SPI 160 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 162 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "gpu", "mmu", "job"; + clocks = <&clkc CLKID_MALI>; + resets = <&reset RESET_DVALIN_CAPB3>, <&reset RESET_DVALIN>; + + /* + * Mali clocking is provided by two identical clock paths + * MALI_0 and MALI_1 muxed to a single clock by a glitch + * free mux to safely change frequency while running. + */ + assigned-clocks = <&clkc CLKID_MALI_0_SEL>, + <&clkc CLKID_MALI_0>, + <&clkc CLKID_MALI>; /* Glitch free mux */ + assigned-clock-parents = <&clkc CLKID_FCLK_DIV2P5>, + <0>, /* Do Nothing */ + <&clkc CLKID_MALI_0>; + assigned-clock-rates = <0>, /* Do Nothing */ + <800000000>, + <0>; /* Do Nothing */ + }; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupts = <GIC_PPI 13 + (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 + (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 + (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 + (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_LEVEL_LOW)>; + arm,no-tick-in-suspend; + }; + + xtal: xtal-clk { + compatible = "fixed-clock"; + clock-frequency = <24000000>; + clock-output-names = "xtal"; + #clock-cells = <0>; + }; + +}; diff --git a/arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts b/arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts new file mode 100644 index 0000000000..73128ed243 --- /dev/null +++ b/arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts @@ -0,0 +1,15 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 BayLibre, SAS + * Author: Neil Armstrong narmstrong@baylibre.com + * Copyright (c) 2019 Christian Hewitt christianshewitt@gmail.com + */ + +/dts-v1/; + +#include "meson-g12b-a311d.dtsi" +#include "meson-g12b-khadas-vim3.dtsi" + +/ { + compatible = "khadas,vim3", "amlogic,a311d", "amlogic,g12b"; +}; diff --git a/arch/arm/dts/meson-g12b-a311d.dtsi b/arch/arm/dts/meson-g12b-a311d.dtsi new file mode 100644 index 0000000000..d61f43052a --- /dev/null +++ b/arch/arm/dts/meson-g12b-a311d.dtsi @@ -0,0 +1,149 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 BayLibre, SAS + * Author: Neil Armstrong narmstrong@baylibre.com + */ + +#include "meson-g12b.dtsi" + +/ { + cpu_opp_table_0: opp-table-0 { + compatible = "operating-points-v2"; + opp-shared; + + opp-100000000 { + opp-hz = /bits/ 64 <100000000>; + opp-microvolt = <731000>; + }; + + opp-250000000 { + opp-hz = /bits/ 64 <250000000>; + opp-microvolt = <731000>; + }; + + opp-500000000 { + opp-hz = /bits/ 64 <500000000>; + opp-microvolt = <731000>; + }; + + opp-667000000 { + opp-hz = /bits/ 64 <667000000>; + opp-microvolt = <731000>; + }; + + opp-1000000000 { + opp-hz = /bits/ 64 <1000000000>; + opp-microvolt = <761000>; + }; + + opp-1200000000 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <781000>; + }; + + opp-1398000000 { + opp-hz = /bits/ 64 <1398000000>; + opp-microvolt = <811000>; + }; + + opp-1512000000 { + opp-hz = /bits/ 64 <1512000000>; + opp-microvolt = <861000>; + }; + + opp-1608000000 { + opp-hz = /bits/ 64 <1608000000>; + opp-microvolt = <901000>; + }; + + opp-1704000000 { + opp-hz = /bits/ 64 <1704000000>; + opp-microvolt = <951000>; + }; + + opp-1800000000 { + opp-hz = /bits/ 64 <1800000000>; + opp-microvolt = <1001000>; + }; + }; + + cpub_opp_table_1: opp-table-1 { + compatible = "operating-points-v2"; + opp-shared; + + opp-100000000 { + opp-hz = /bits/ 64 <100000000>; + opp-microvolt = <731000>; + }; + + opp-250000000 { + opp-hz = /bits/ 64 <250000000>; + opp-microvolt = <731000>; + }; + + opp-500000000 { + opp-hz = /bits/ 64 <500000000>; + opp-microvolt = <731000>; + }; + + opp-667000000 { + opp-hz = /bits/ 64 <667000000>; + opp-microvolt = <731000>; + }; + + opp-1000000000 { + opp-hz = /bits/ 64 <1000000000>; + opp-microvolt = <731000>; + }; + + opp-1200000000 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <751000>; + }; + + opp-1398000000 { + opp-hz = /bits/ 64 <1398000000>; + opp-microvolt = <771000>; + }; + + opp-1512000000 { + opp-hz = /bits/ 64 <1512000000>; + opp-microvolt = <771000>; + }; + + opp-1608000000 { + opp-hz = /bits/ 64 <1608000000>; + opp-microvolt = <781000>; + }; + + opp-1704000000 { + opp-hz = /bits/ 64 <1704000000>; + opp-microvolt = <791000>; + }; + + opp-1800000000 { + opp-hz = /bits/ 64 <1800000000>; + opp-microvolt = <831000>; + }; + + opp-1908000000 { + opp-hz = /bits/ 64 <1908000000>; + opp-microvolt = <861000>; + }; + + opp-2016000000 { + opp-hz = /bits/ 64 <2016000000>; + opp-microvolt = <911000>; + }; + + opp-2108000000 { + opp-hz = /bits/ 64 <2108000000>; + opp-microvolt = <951000>; + }; + + opp-2208000000 { + opp-hz = /bits/ 64 <2208000000>; + opp-microvolt = <1011000>; + }; + }; +}; diff --git a/arch/arm/dts/meson-g12b-khadas-vim3.dtsi b/arch/arm/dts/meson-g12b-khadas-vim3.dtsi new file mode 100644 index 0000000000..9c3ca2edc7 --- /dev/null +++ b/arch/arm/dts/meson-g12b-khadas-vim3.dtsi @@ -0,0 +1,544 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 BayLibre, SAS + * Author: Neil Armstrong narmstrong@baylibre.com + * Copyright (c) 2019 Christian Hewitt christianshewitt@gmail.com + */ + +#include <dt-bindings/input/input.h> +#include <dt-bindings/gpio/meson-g12a-gpio.h> +#include <dt-bindings/sound/meson-g12a-tohdmitx.h> + +/ { + model = "Khadas VIM3"; + + aliases { + serial0 = &uart_AO; + ethernet0 = ðmac; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; + }; + + adc-keys { + compatible = "adc-keys"; + io-channels = <&saradc 2>; + io-channel-names = "buttons"; + keyup-threshold-microvolt = <1710000>; + + button-function { + label = "Function"; + linux,code = <KEY_FN>; + press-threshold-microvolt = <10000>; + }; + }; + + leds { + compatible = "gpio-leds"; + + white { + label = "vim3:white:sys"; + gpios = <&gpio_ao GPIOAO_4 GPIO_ACTIVE_LOW>; + linux,default-trigger = "heartbeat"; + }; + + red { + label = "vim3:red"; + gpios = <&gpio_expander 5 GPIO_ACTIVE_LOW>; + }; + }; + + emmc_pwrseq: emmc-pwrseq { + compatible = "mmc-pwrseq-emmc"; + reset-gpios = <&gpio BOOT_12 GPIO_ACTIVE_LOW>; + }; + + gpio-keys-polled { + compatible = "gpio-keys-polled"; + poll-interval = <100>; + + power-button { + label = "power"; + linux,code = <KEY_POWER>; + gpios = <&gpio_ao GPIOAO_7 GPIO_ACTIVE_LOW>; + }; + }; + + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&gpio GPIOX_6 GPIO_ACTIVE_LOW>; + clocks = <&wifi32k>; + clock-names = "ext_clock"; + }; + + dc_in: regulator-dc_in { + compatible = "regulator-fixed"; + regulator-name = "DC_IN"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + + vcc_5v: regulator-vcc_5v { + compatible = "regulator-fixed"; + regulator-name = "VCC_5V"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&dc_in>; + + gpio = <&gpio GPIOH_8 GPIO_OPEN_DRAIN>; + enable-active-high; + }; + + vcc_1v8: regulator-vcc_1v8 { + compatible = "regulator-fixed"; + regulator-name = "VCC_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_3v3>; + regulator-always-on; + }; + + vcc_3v3: regulator-vcc_3v3 { + compatible = "regulator-fixed"; + regulator-name = "VCC_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vsys_3v3>; + regulator-always-on; + /* FIXME: actually controlled by VDDCPU_B_EN */ + }; + + vddcpu_a: regulator-vddcpu-a { + /* + * MP8756GD Regulator. + */ + compatible = "pwm-regulator"; + + regulator-name = "VDDCPU_A"; + regulator-min-microvolt = <690000>; + regulator-max-microvolt = <1050000>; + + vin-supply = <&dc_in>; + + pwms = <&pwm_ab 0 1250 0>; + pwm-dutycycle-range = <100 0>; + + regulator-boot-on; + regulator-always-on; + }; + + vddcpu_b: regulator-vddcpu-b { + /* + * Silergy SY8030DEC Regulator. + */ + compatible = "pwm-regulator"; + + regulator-name = "VDDCPU_B"; + regulator-min-microvolt = <690000>; + regulator-max-microvolt = <1050000>; + + vin-supply = <&vsys_3v3>; + + pwms = <&pwm_AO_cd 1 1250 0>; + pwm-dutycycle-range = <100 0>; + + regulator-boot-on; + regulator-always-on; + }; + + vddao_1v8: regulator-vddao_1v8 { + compatible = "regulator-fixed"; + regulator-name = "VDDIO_AO1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vsys_3v3>; + regulator-always-on; + }; + + emmc_1v8: regulator-emmc_1v8 { + compatible = "regulator-fixed"; + regulator-name = "EMMC_AO1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_3v3>; + regulator-always-on; + }; + + vsys_3v3: regulator-vsys_3v3 { + compatible = "regulator-fixed"; + regulator-name = "VSYS_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&dc_in>; + regulator-always-on; + }; + + usb_pwr: regulator-usb_pwr { + compatible = "regulator-fixed"; + regulator-name = "USB_PWR"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc_5v>; + + gpio = <&gpio GPIOA_6 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_connector_in: endpoint { + remote-endpoint = <&hdmi_tx_tmds_out>; + }; + }; + }; + + wifi32k: wifi32k { + compatible = "pwm-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + pwms = <&pwm_ef 0 30518 0>; /* PWM_E at 32.768KHz */ + }; + + sound { + compatible = "amlogic,axg-sound-card"; + model = "G12A-KHADAS-VIM3"; + audio-aux-devs = <&tdmout_b>; + audio-routing = "TDMOUT_B IN 0", "FRDDR_A OUT 1", + "TDMOUT_B IN 1", "FRDDR_B OUT 1", + "TDMOUT_B IN 2", "FRDDR_C OUT 1", + "TDM_B Playback", "TDMOUT_B OUT"; + + assigned-clocks = <&clkc CLKID_MPLL2>, + <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>; + assigned-clock-parents = <0>, <0>, <0>; + assigned-clock-rates = <294912000>, + <270950400>, + <393216000>; + status = "okay"; + + dai-link-0 { + sound-dai = <&frddr_a>; + }; + + dai-link-1 { + sound-dai = <&frddr_b>; + }; + + dai-link-2 { + sound-dai = <&frddr_c>; + }; + + /* 8ch hdmi interface */ + dai-link-3 { + sound-dai = <&tdmif_b>; + dai-format = "i2s"; + dai-tdm-slot-tx-mask-0 = <1 1>; + dai-tdm-slot-tx-mask-1 = <1 1>; + dai-tdm-slot-tx-mask-2 = <1 1>; + dai-tdm-slot-tx-mask-3 = <1 1>; + mclk-fs = <256>; + + codec { + sound-dai = <&tohdmitx TOHDMITX_I2S_IN_B>; + }; + }; + + /* hdmi glue */ + dai-link-4 { + sound-dai = <&tohdmitx TOHDMITX_I2S_OUT>; + + codec { + sound-dai = <&hdmi_tx>; + }; + }; + }; +}; + +&arb { + status = "okay"; +}; + +&cec_AO { + pinctrl-0 = <&cec_ao_a_h_pins>; + pinctrl-names = "default"; + status = "disabled"; + hdmi-phandle = <&hdmi_tx>; +}; + +&cecb_AO { + pinctrl-0 = <&cec_ao_b_h_pins>; + pinctrl-names = "default"; + status = "okay"; + hdmi-phandle = <&hdmi_tx>; +}; + +&clkc_audio { + status = "okay"; +}; + +&cpu0 { + cpu-supply = <&vddcpu_b>; + operating-points-v2 = <&cpu_opp_table_0>; + clocks = <&clkc CLKID_CPU_CLK>; + clock-latency = <50000>; +}; + +&cpu1 { + cpu-supply = <&vddcpu_b>; + operating-points-v2 = <&cpu_opp_table_0>; + clocks = <&clkc CLKID_CPU_CLK>; + clock-latency = <50000>; +}; + +&cpu100 { + cpu-supply = <&vddcpu_a>; + operating-points-v2 = <&cpub_opp_table_1>; + clocks = <&clkc CLKID_CPUB_CLK>; + clock-latency = <50000>; +}; + +&cpu101 { + cpu-supply = <&vddcpu_a>; + operating-points-v2 = <&cpub_opp_table_1>; + clocks = <&clkc CLKID_CPUB_CLK>; + clock-latency = <50000>; +}; + +&cpu102 { + cpu-supply = <&vddcpu_a>; + operating-points-v2 = <&cpub_opp_table_1>; + clocks = <&clkc CLKID_CPUB_CLK>; + clock-latency = <50000>; +}; + +&cpu103 { + cpu-supply = <&vddcpu_a>; + operating-points-v2 = <&cpub_opp_table_1>; + clocks = <&clkc CLKID_CPUB_CLK>; + clock-latency = <50000>; +}; + +&ext_mdio { + external_phy: ethernet-phy@0 { + /* Realtek RTL8211F (0x001cc916) */ + reg = <0>; + max-speed = <1000>; + + interrupt-parent = <&gpio_intc>; + /* MAC_INTR on GPIOZ_14 */ + interrupts = <26 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +ðmac { + pinctrl-0 = <ð_pins>, <ð_rgmii_pins>; + pinctrl-names = "default"; + status = "okay"; + phy-mode = "rgmii"; + phy-handle = <&external_phy>; + amlogic,tx-delay-ns = <2>; +}; + +&frddr_a { + status = "okay"; +}; + +&frddr_b { + status = "okay"; +}; + +&frddr_c { + status = "okay"; +}; + +&hdmi_tx { + status = "okay"; + pinctrl-0 = <&hdmitx_hpd_pins>, <&hdmitx_ddc_pins>; + pinctrl-names = "default"; + hdmi-supply = <&vcc_5v>; +}; + +&hdmi_tx_tmds_port { + hdmi_tx_tmds_out: endpoint { + remote-endpoint = <&hdmi_connector_in>; + }; +}; + +&i2c_AO { + status = "okay"; + pinctrl-0 = <&i2c_ao_sck_pins>, <&i2c_ao_sda_pins>; + pinctrl-names = "default"; + + gpio_expander: gpio-controller@20 { + compatible = "ti,tca6408"; + reg = <0x20>; + vcc-supply = <&vcc_3v3>; + gpio-controller; + #gpio-cells = <2>; + }; + + rtc@51 { + compatible = "haoyu,hym8563"; + reg = <0x51>; + #clock-cells = <0>; + }; +}; + +&ir { + status = "okay"; + pinctrl-0 = <&remote_input_ao_pins>; + pinctrl-names = "default"; + linux,rc-map-name = "rc-khadas"; +}; + +&pwm_ab { + pinctrl-0 = <&pwm_a_e_pins>; + pinctrl-names = "default"; + clocks = <&xtal>; + clock-names = "clkin0"; + status = "okay"; +}; + +&pwm_AO_cd { + pinctrl-0 = <&pwm_ao_d_e_pins>; + pinctrl-names = "default"; + clocks = <&xtal>; + clock-names = "clkin1"; + status = "okay"; +}; + +&pwm_ef { + status = "okay"; + pinctrl-0 = <&pwm_e_pins>; + pinctrl-names = "default"; +}; + +&saradc { + status = "okay"; + vref-supply = <&vddao_1v8>; +}; + +/* SDIO */ +&sd_emmc_a { + status = "okay"; + pinctrl-0 = <&sdio_pins>; + pinctrl-1 = <&sdio_clk_gate_pins>; + pinctrl-names = "default", "clk-gate"; + #address-cells = <1>; + #size-cells = <0>; + + bus-width = <4>; + cap-sd-highspeed; + sd-uhs-sdr50; + max-frequency = <100000000>; + + non-removable; + disable-wp; + + mmc-pwrseq = <&sdio_pwrseq>; + + vmmc-supply = <&vsys_3v3>; + vqmmc-supply = <&vddao_1v8>; + + brcmf: wifi@1 { + reg = <1>; + compatible = "brcm,bcm4329-fmac"; + }; +}; + +/* SD card */ +&sd_emmc_b { + status = "okay"; + pinctrl-0 = <&sdcard_c_pins>; + pinctrl-1 = <&sdcard_clk_gate_c_pins>; + pinctrl-names = "default", "clk-gate"; + + bus-width = <4>; + cap-sd-highspeed; + max-frequency = <50000000>; + disable-wp; + + cd-gpios = <&gpio GPIOC_6 GPIO_ACTIVE_LOW>; + vmmc-supply = <&vsys_3v3>; + vqmmc-supply = <&vsys_3v3>; +}; + +/* eMMC */ +&sd_emmc_c { + status = "okay"; + pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>; + pinctrl-1 = <&emmc_clk_gate_pins>; + pinctrl-names = "default", "clk-gate"; + + bus-width = <8>; + cap-mmc-highspeed; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + max-frequency = <200000000>; + disable-wp; + + mmc-pwrseq = <&emmc_pwrseq>; + vmmc-supply = <&vcc_3v3>; + vqmmc-supply = <&emmc_1v8>; +}; + +&tdmif_b { + status = "okay"; +}; + +&tdmout_b { + status = "okay"; +}; + +&tohdmitx { + status = "okay"; +}; + +&uart_A { + status = "okay"; + pinctrl-0 = <&uart_a_pins>, <&uart_a_cts_rts_pins>; + pinctrl-names = "default"; + uart-has-rtscts; + + bluetooth { + compatible = "brcm,bcm43438-bt"; + shutdown-gpios = <&gpio GPIOX_17 GPIO_ACTIVE_HIGH>; + max-speed = <2000000>; + clocks = <&wifi32k>; + clock-names = "lpo"; + }; +}; + +&uart_AO { + status = "okay"; + pinctrl-0 = <&uart_ao_a_pins>; + pinctrl-names = "default"; +}; + +&usb2_phy0 { + phy-supply = <&dc_in>; +}; + +&usb2_phy1 { + phy-supply = <&usb_pwr>; +}; + +&usb3_pcie_phy { + phy-supply = <&usb_pwr>; +}; + +&usb { + status = "okay"; + dr_mode = "peripheral"; +}; diff --git a/arch/arm/dts/meson-g12b.dtsi b/arch/arm/dts/meson-g12b.dtsi index 9e88e513b2..5628ccd545 100644 --- a/arch/arm/dts/meson-g12b.dtsi +++ b/arch/arm/dts/meson-g12b.dtsi @@ -4,12 +4,16 @@ * Author: Neil Armstrong narmstrong@baylibre.com */
-#include "meson-g12a.dtsi" +#include "meson-g12-common.dtsi" +#include <dt-bindings/power/meson-g12a-power.h>
/ { compatible = "amlogic,g12b";
cpus { + #address-cells = <0x2>; + #size-cells = <0x0>; + cpu-map { cluster0 { core0 { @@ -40,8 +44,21 @@ }; };
- /delete-node/ cpu@2; - /delete-node/ cpu@3; + cpu0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x0 0x0>; + enable-method = "psci"; + next-level-cache = <&l2>; + }; + + cpu1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x0 0x1>; + enable-method = "psci"; + next-level-cache = <&l2>; + };
cpu100: cpu@100 { device_type = "cpu"; @@ -74,9 +91,25 @@ enable-method = "psci"; next-level-cache = <&l2>; }; + + l2: l2-cache0 { + compatible = "cache"; + }; }; };
&clkc { compatible = "amlogic,g12b-clkc"; }; + +ðmac { + power-domains = <&pwrc PWRC_G12A_ETH_ID>; +}; + +&vpu { + power-domains = <&pwrc PWRC_G12A_VPU_ID>; +}; + +&sd_emmc_a { + amlogic,dram-access-quirk; +}; diff --git a/include/dt-bindings/clock/g12a-clkc.h b/include/dt-bindings/clock/g12a-clkc.h index b6b127e456..0837c1a7ae 100644 --- a/include/dt-bindings/clock/g12a-clkc.h +++ b/include/dt-bindings/clock/g12a-clkc.h @@ -137,5 +137,11 @@ #define CLKID_VDEC_HEVC 207 #define CLKID_VDEC_HEVCF 210 #define CLKID_TS 212 +#define CLKID_CPUB_CLK 224 +#define CLKID_GP1_PLL 243 +#define CLKID_DSU_CLK 252 +#define CLKID_CPU1_CLK 253 +#define CLKID_CPU2_CLK 254 +#define CLKID_CPU3_CLK 255
#endif /* __G12A_CLKC_H */ diff --git a/include/dt-bindings/power/meson-g12a-power.h b/include/dt-bindings/power/meson-g12a-power.h new file mode 100644 index 0000000000..bb5e67a842 --- /dev/null +++ b/include/dt-bindings/power/meson-g12a-power.h @@ -0,0 +1,13 @@ +/* SPDX-License-Identifier: (GPL-2.0+ or MIT) */ +/* + * Copyright (c) 2019 BayLibre, SAS + * Author: Neil Armstrong narmstrong@baylibre.com + */ + +#ifndef _DT_BINDINGS_MESON_G12A_POWER_H +#define _DT_BINDINGS_MESON_G12A_POWER_H + +#define PWRC_G12A_VPU_ID 0 +#define PWRC_G12A_ETH_ID 1 + +#endif diff --git a/include/dt-bindings/reset/amlogic,meson-g12a-audio-reset.h b/include/dt-bindings/reset/amlogic,meson-g12a-audio-reset.h new file mode 100644 index 0000000000..14b78dabed --- /dev/null +++ b/include/dt-bindings/reset/amlogic,meson-g12a-audio-reset.h @@ -0,0 +1,38 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2019 BayLibre, SAS. + * Author: Jerome Brunet jbrunet@baylibre.com + * + */ + +#ifndef _DT_BINDINGS_AMLOGIC_MESON_G12A_AUDIO_RESET_H +#define _DT_BINDINGS_AMLOGIC_MESON_G12A_AUDIO_RESET_H + +#define AUD_RESET_PDM 0 +#define AUD_RESET_TDMIN_A 1 +#define AUD_RESET_TDMIN_B 2 +#define AUD_RESET_TDMIN_C 3 +#define AUD_RESET_TDMIN_LB 4 +#define AUD_RESET_LOOPBACK 5 +#define AUD_RESET_TODDR_A 6 +#define AUD_RESET_TODDR_B 7 +#define AUD_RESET_TODDR_C 8 +#define AUD_RESET_FRDDR_A 9 +#define AUD_RESET_FRDDR_B 10 +#define AUD_RESET_FRDDR_C 11 +#define AUD_RESET_TDMOUT_A 12 +#define AUD_RESET_TDMOUT_B 13 +#define AUD_RESET_TDMOUT_C 14 +#define AUD_RESET_SPDIFOUT 15 +#define AUD_RESET_SPDIFOUT_B 16 +#define AUD_RESET_SPDIFIN 17 +#define AUD_RESET_EQDRC 18 +#define AUD_RESET_RESAMPLE 19 +#define AUD_RESET_DDRARB 20 +#define AUD_RESET_POWDET 21 +#define AUD_RESET_TORAM 22 +#define AUD_RESET_TOACODEC 23 +#define AUD_RESET_TOHDMITX 24 +#define AUD_RESET_CLKTREE 25 + +#endif
Hi Andreas,
On 02/09/2019 04:28, Andreas Färber wrote:
In Linux meson-g12-common.dtsi was introduced as well as new g12b nodes and headers, as dependencies of new meson-g12b-a311d-khadas-vim3.dts.
Can you precise the Linux commit ID you sync'ed from ? The best would be to sync from the v2 dt64 PR from kevin : https://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-amlogic.git/ta...
Thanks, Neil
Signed-off-by: Andreas Färber afaerber@suse.de
arch/arm/dts/Makefile | 3 +- arch/arm/dts/meson-g12-common.dtsi | 2435 ++++++++++++++++++++ arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts | 15 +
Can you also sync the s922x version ?
arch/arm/dts/meson-g12b-a311d.dtsi | 149 ++ arch/arm/dts/meson-g12b-khadas-vim3.dtsi | 544 +++++ arch/arm/dts/meson-g12b.dtsi | 39 +- include/dt-bindings/clock/g12a-clkc.h | 6 + include/dt-bindings/power/meson-g12a-power.h | 13 + .../reset/amlogic,meson-g12a-audio-reset.h | 38 + 9 files changed, 3238 insertions(+), 4 deletions(-) create mode 100644 arch/arm/dts/meson-g12-common.dtsi create mode 100644 arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts create mode 100644 arch/arm/dts/meson-g12b-a311d.dtsi create mode 100644 arch/arm/dts/meson-g12b-khadas-vim3.dtsi create mode 100644 include/dt-bindings/power/meson-g12a-power.h create mode 100644 include/dt-bindings/reset/amlogic,meson-g12a-audio-reset.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index aac1b83d49..6de5e4c62a 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -141,7 +141,8 @@ dtb-$(CONFIG_ARCH_MESON) += \ meson-axg-s400.dtb \ meson-g12a-u200.dtb \ meson-g12a-sei510.dtb \
- meson-g12b-odroid-n2.dtb
- meson-g12b-odroid-n2.dtb \
- meson-g12b-a311d-khadas-vim3.dtb
Same here, can you also build the s922x variant ?
dtb-$(CONFIG_TEGRA) += tegra20-harmony.dtb \ tegra20-medcom-wide.dtb \ tegra20-paz00.dtb \ diff --git a/arch/arm/dts/meson-g12-common.dtsi b/arch/arm/dts/meson-g12-common.dtsi new file mode 100644 index 0000000000..3f39e020f7 --- /dev/null +++ b/arch/arm/dts/meson-g12-common.dtsi @@ -0,0 +1,2435 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/*
- Copyright (c) 2018 Amlogic, Inc. All rights reserved.
+#include <dt-bindings/phy/phy.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/clock/axg-audio-clkc.h> +#include <dt-bindings/clock/g12a-clkc.h> +#include <dt-bindings/clock/g12a-aoclkc.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/reset/amlogic,meson-axg-audio-arb.h> +#include <dt-bindings/reset/amlogic,meson-g12a-audio-reset.h> +#include <dt-bindings/reset/amlogic,meson-g12a-reset.h>
- interrupt-parent = <&gic>;
- #address-cells = <2>;
- #size-cells = <2>;
- tdmif_a: audio-controller-0 {
compatible = "amlogic,axg-tdm-iface";
sound-name-prefix = "TDM_A";
clocks = <&clkc_audio AUD_CLKID_MST_A_MCLK>,
<&clkc_audio AUD_CLKID_MST_A_SCLK>,
<&clkc_audio AUD_CLKID_MST_A_LRCLK>;
clock-names = "mclk", "sclk", "lrclk";
- tdmif_b: audio-controller-1 {
sound-name-prefix = "TDM_B";
clocks = <&clkc_audio AUD_CLKID_MST_B_MCLK>,
<&clkc_audio AUD_CLKID_MST_B_SCLK>,
<&clkc_audio AUD_CLKID_MST_B_LRCLK>;
- tdmif_c: audio-controller-2 {
sound-name-prefix = "TDM_C";
clocks = <&clkc_audio AUD_CLKID_MST_C_MCLK>,
<&clkc_audio AUD_CLKID_MST_C_SCLK>,
<&clkc_audio AUD_CLKID_MST_C_LRCLK>;
- efuse: efuse {
compatible = "amlogic,meson-gxbb-efuse";
clocks = <&clkc CLKID_EFUSE>;
#size-cells = <1>;
read-only;
- psci {
compatible = "arm,psci-1.0";
method = "smc";
- reserved-memory {
#size-cells = <2>;
ranges;
/* 3 MiB reserved for ARM Trusted Firmware (BL31) */
secmon_reserved: secmon@5000000 {
reg = <0x0 0x05000000 0x0 0x300000>;
no-map;
linux,cma {
compatible = "shared-dma-pool";
reusable;
size = <0x0 0x10000000>;
alignment = <0x0 0x400000>;
linux,cma-default;
- sm: secure-monitor {
compatible = "amlogic,meson-gxbb-sm";
- soc {
#size-cells = <2>;
ranges;
ethmac: ethernet@ff3f0000 {
compatible = "amlogic,meson-axg-dwmac",
"snps,dwmac-3.70a",
"snps,dwmac";
reg = <0x0 0xff3f0000 0x0 0x10000>,
<0x0 0xff634540 0x0 0x8>;
interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "macirq";
clocks = <&clkc CLKID_ETH>,
<&clkc CLKID_FCLK_DIV2>,
<&clkc CLKID_MPLL2>;
clock-names = "stmmaceth", "clkin0", "clkin1";
rx-fifo-depth = <4096>;
tx-fifo-depth = <2048>;
mdio0: mdio {
#size-cells = <0>;
compatible = "snps,dwmac-mdio";
apb: bus@ff600000 {
reg = <0x0 0xff600000 0x0 0x200000>;
#size-cells = <2>;
ranges = <0x0 0x0 0x0 0xff600000 0x0 0x200000>;
hdmi_tx: hdmi-tx@0 {
compatible = "amlogic,meson-g12a-dw-hdmi";
reg = <0x0 0x0 0x0 0x10000>;
interrupts = <GIC_SPI 57 IRQ_TYPE_EDGE_RISING>;
resets = <&reset RESET_HDMITX_CAPB3>,
<&reset RESET_HDMITX_PHY>,
<&reset RESET_HDMITX>;
reset-names = "hdmitx_apb", "hdmitx", "hdmitx_phy";
clocks = <&clkc CLKID_HDMI>,
<&clkc CLKID_HTX_PCLK>,
<&clkc CLKID_VPU_INTR>;
clock-names = "isfr", "iahb", "venci";
#size-cells = <0>;
/* VPU VENC Input */
hdmi_tx_venc_port: port@0 {
reg = <0>;
hdmi_tx_in: endpoint {
remote-endpoint = <&hdmi_tx_out>;
/* TMDS Output */
hdmi_tx_tmds_port: port@1 {
reg = <1>;
apb_efuse: bus@30000 {
reg = <0x0 0x30000 0x0 0x2000>;
#size-cells = <2>;
ranges = <0x0 0x0 0x0 0x30000 0x0 0x2000>;
hwrng: rng@218 {
compatible = "amlogic,meson-rng";
reg = <0x0 0x218 0x0 0x4>;
periphs: bus@34400 {
reg = <0x0 0x34400 0x0 0x400>;
#size-cells = <2>;
ranges = <0x0 0x0 0x0 0x34400 0x0 0x400>;
periphs_pinctrl: pinctrl@40 {
compatible = "amlogic,meson-g12a-periphs-pinctrl";
#size-cells = <2>;
ranges;
gpio: bank@40 {
reg = <0x0 0x40 0x0 0x4c>,
<0x0 0xe8 0x0 0x18>,
<0x0 0x120 0x0 0x18>,
<0x0 0x2c0 0x0 0x40>,
<0x0 0x340 0x0 0x1c>;
reg-names = "gpio",
"pull",
"pull-enable",
"mux",
"ds";
gpio-controller;
#gpio-cells = <2>;
gpio-ranges = <&periphs_pinctrl 0 0 86>;
cec_ao_a_h_pins: cec_ao_a_h {
mux {
groups = "cec_ao_a_h";
function = "cec_ao_a_h";
bias-disable;
cec_ao_b_h_pins: cec_ao_b_h {
mux {
groups = "cec_ao_b_h";
function = "cec_ao_b_h";
bias-disable;
emmc_pins: emmc {
mux-0 {
groups = "emmc_nand_d0",
"emmc_nand_d1",
"emmc_nand_d2",
"emmc_nand_d3",
"emmc_nand_d4",
"emmc_nand_d5",
"emmc_nand_d6",
"emmc_nand_d7",
"emmc_cmd";
function = "emmc";
bias-pull-up;
mux-1 {
groups = "emmc_clk";
function = "emmc";
bias-disable;
emmc_ds_pins: emmc-ds {
mux {
groups = "emmc_nand_ds";
function = "emmc";
bias-pull-down;
emmc_clk_gate_pins: emmc_clk_gate {
mux {
groups = "BOOT_8";
bias-pull-down;
hdmitx_ddc_pins: hdmitx_ddc {
mux {
groups = "hdmitx_sda",
"hdmitx_sck";
function = "hdmitx";
bias-disable;
hdmitx_hpd_pins: hdmitx_hpd {
mux {
groups = "hdmitx_hpd_in";
bias-disable;
i2c0_sda_c_pins: i2c0-sda-c {
mux {
groups = "i2c0_sda_c";
function = "i2c0";
bias-disable;
i2c0_sck_c_pins: i2c0-sck-c {
mux {
groups = "i2c0_sck_c";
function = "i2c0";
bias-disable;
i2c0_sda_z0_pins: i2c0-sda-z0 {
mux {
groups = "i2c0_sda_z0";
function = "i2c0";
bias-disable;
i2c0_sck_z1_pins: i2c0-sck-z1 {
mux {
groups = "i2c0_sck_z1";
function = "i2c0";
bias-disable;
i2c0_sda_z7_pins: i2c0-sda-z7 {
mux {
groups = "i2c0_sda_z7";
function = "i2c0";
bias-disable;
i2c0_sda_z8_pins: i2c0-sda-z8 {
mux {
groups = "i2c0_sda_z8";
function = "i2c0";
bias-disable;
i2c1_sda_x_pins: i2c1-sda-x {
mux {
groups = "i2c1_sda_x";
function = "i2c1";
bias-disable;
i2c1_sck_x_pins: i2c1-sck-x {
mux {
groups = "i2c1_sck_x";
function = "i2c1";
bias-disable;
i2c1_sda_h2_pins: i2c1-sda-h2 {
mux {
groups = "i2c1_sda_h2";
function = "i2c1";
bias-disable;
i2c1_sck_h3_pins: i2c1-sck-h3 {
mux {
groups = "i2c1_sck_h3";
function = "i2c1";
bias-disable;
i2c1_sda_h6_pins: i2c1-sda-h6 {
mux {
groups = "i2c1_sda_h6";
function = "i2c1";
bias-disable;
i2c1_sck_h7_pins: i2c1-sck-h7 {
mux {
groups = "i2c1_sck_h7";
function = "i2c1";
bias-disable;
i2c2_sda_x_pins: i2c2-sda-x {
mux {
groups = "i2c2_sda_x";
function = "i2c2";
bias-disable;
i2c2_sck_x_pins: i2c2-sck-x {
mux {
groups = "i2c2_sck_x";
function = "i2c2";
bias-disable;
i2c2_sda_z_pins: i2c2-sda-z {
mux {
groups = "i2c2_sda_z";
function = "i2c2";
bias-disable;
i2c2_sck_z_pins: i2c2-sck-z {
mux {
groups = "i2c2_sck_z";
function = "i2c2";
bias-disable;
i2c3_sda_h_pins: i2c3-sda-h {
mux {
groups = "i2c3_sda_h";
function = "i2c3";
bias-disable;
i2c3_sck_h_pins: i2c3-sck-h {
mux {
groups = "i2c3_sck_h";
function = "i2c3";
bias-disable;
i2c3_sda_a_pins: i2c3-sda-a {
mux {
groups = "i2c3_sda_a";
function = "i2c3";
bias-disable;
i2c3_sck_a_pins: i2c3-sck-a {
mux {
groups = "i2c3_sck_a";
function = "i2c3";
bias-disable;
mclk0_a_pins: mclk0-a {
mux {
groups = "mclk0_a";
function = "mclk0";
bias-disable;
mclk1_a_pins: mclk1-a {
mux {
groups = "mclk1_a";
function = "mclk1";
bias-disable;
mclk1_x_pins: mclk1-x {
mux {
groups = "mclk1_x";
function = "mclk1";
bias-disable;
mclk1_z_pins: mclk1-z {
mux {
groups = "mclk1_z";
function = "mclk1";
bias-disable;
pdm_din0_a_pins: pdm-din0-a {
mux {
groups = "pdm_din0_a";
function = "pdm";
bias-disable;
pdm_din0_c_pins: pdm-din0-c {
mux {
groups = "pdm_din0_c";
function = "pdm";
bias-disable;
pdm_din0_x_pins: pdm-din0-x {
mux {
groups = "pdm_din0_x";
function = "pdm";
bias-disable;
pdm_din0_z_pins: pdm-din0-z {
mux {
groups = "pdm_din0_z";
function = "pdm";
bias-disable;
pdm_din1_a_pins: pdm-din1-a {
mux {
groups = "pdm_din1_a";
function = "pdm";
bias-disable;
pdm_din1_c_pins: pdm-din1-c {
mux {
groups = "pdm_din1_c";
function = "pdm";
bias-disable;
pdm_din1_x_pins: pdm-din1-x {
mux {
groups = "pdm_din1_x";
function = "pdm";
bias-disable;
pdm_din1_z_pins: pdm-din1-z {
mux {
groups = "pdm_din1_z";
function = "pdm";
bias-disable;
pdm_din2_a_pins: pdm-din2-a {
mux {
groups = "pdm_din2_a";
function = "pdm";
bias-disable;
pdm_din2_c_pins: pdm-din2-c {
mux {
groups = "pdm_din2_c";
function = "pdm";
bias-disable;
pdm_din2_x_pins: pdm-din2-x {
mux {
groups = "pdm_din2_x";
function = "pdm";
bias-disable;
pdm_din2_z_pins: pdm-din2-z {
mux {
groups = "pdm_din2_z";
function = "pdm";
bias-disable;
pdm_din3_a_pins: pdm-din3-a {
mux {
groups = "pdm_din3_a";
function = "pdm";
bias-disable;
pdm_din3_c_pins: pdm-din3-c {
mux {
groups = "pdm_din3_c";
function = "pdm";
bias-disable;
pdm_din3_x_pins: pdm-din3-x {
mux {
groups = "pdm_din3_x";
function = "pdm";
bias-disable;
pdm_din3_z_pins: pdm-din3-z {
mux {
groups = "pdm_din3_z";
function = "pdm";
bias-disable;
pdm_dclk_a_pins: pdm-dclk-a {
mux {
groups = "pdm_dclk_a";
function = "pdm";
bias-disable;
pdm_dclk_c_pins: pdm-dclk-c {
mux {
groups = "pdm_dclk_c";
function = "pdm";
bias-disable;
pdm_dclk_x_pins: pdm-dclk-x {
mux {
groups = "pdm_dclk_x";
function = "pdm";
bias-disable;
pdm_dclk_z_pins: pdm-dclk-z {
mux {
groups = "pdm_dclk_z";
function = "pdm";
bias-disable;
pwm_a_pins: pwm-a {
mux {
groups = "pwm_a";
function = "pwm_a";
bias-disable;
pwm_b_x7_pins: pwm-b-x7 {
mux {
groups = "pwm_b_x7";
function = "pwm_b";
bias-disable;
pwm_b_x19_pins: pwm-b-x19 {
mux {
groups = "pwm_b_x19";
function = "pwm_b";
bias-disable;
pwm_c_c_pins: pwm-c-c {
mux {
groups = "pwm_c_c";
function = "pwm_c";
bias-disable;
pwm_c_x5_pins: pwm-c-x5 {
mux {
groups = "pwm_c_x5";
function = "pwm_c";
bias-disable;
pwm_c_x8_pins: pwm-c-x8 {
mux {
groups = "pwm_c_x8";
function = "pwm_c";
bias-disable;
pwm_d_x3_pins: pwm-d-x3 {
mux {
groups = "pwm_d_x3";
function = "pwm_d";
bias-disable;
pwm_d_x6_pins: pwm-d-x6 {
mux {
groups = "pwm_d_x6";
function = "pwm_d";
bias-disable;
pwm_e_pins: pwm-e {
mux {
groups = "pwm_e";
function = "pwm_e";
bias-disable;
pwm_f_x_pins: pwm-f-x {
mux {
groups = "pwm_f_x";
function = "pwm_f";
bias-disable;
pwm_f_h_pins: pwm-f-h {
mux {
groups = "pwm_f_h";
function = "pwm_f";
bias-disable;
sdcard_c_pins: sdcard_c {
mux-0 {
groups = "sdcard_d0_c",
"sdcard_d1_c",
"sdcard_d2_c",
"sdcard_d3_c",
"sdcard_cmd_c";
function = "sdcard";
bias-pull-up;
mux-1 {
groups = "sdcard_clk_c";
bias-disable;
sdcard_clk_gate_c_pins: sdcard_clk_gate_c {
mux {
groups = "GPIOC_4";
function = "gpio_periphs";
bias-pull-down;
sdcard_z_pins: sdcard_z {
mux-0 {
groups = "sdcard_d0_z",
"sdcard_d1_z",
"sdcard_d2_z",
"sdcard_d3_z",
"sdcard_cmd_z";
bias-pull-up;
mux-1 {
groups = "sdcard_clk_z";
bias-disable;
sdcard_clk_gate_z_pins: sdcard_clk_gate_z {
mux {
groups = "GPIOZ_6";
bias-pull-down;
sdio_pins: sdio {
mux {
groups = "sdio_d0",
"sdio_d1",
"sdio_d2",
"sdio_d3",
"sdio_clk",
"sdio_cmd";
function = "sdio";
bias-disable;
sdio_clk_gate_pins: sdio_clk_gate {
mux {
groups = "GPIOX_4";
bias-pull-down;
drive-strength-microamp = <4000>;
spdif_in_a10_pins: spdif-in-a10 {
mux {
groups = "spdif_in_a10";
function = "spdif_in";
bias-disable;
spdif_in_a12_pins: spdif-in-a12 {
mux {
groups = "spdif_in_a12";
bias-disable;
spdif_in_h_pins: spdif-in-h {
mux {
groups = "spdif_in_h";
bias-disable;
spdif_out_h_pins: spdif-out-h {
mux {
groups = "spdif_out_h";
function = "spdif_out";
bias-disable;
spdif_out_a11_pins: spdif-out-a11 {
mux {
groups = "spdif_out_a11";
bias-disable;
spdif_out_a13_pins: spdif-out-a13 {
mux {
groups = "spdif_out_a13";
bias-disable;
tdm_a_din0_pins: tdm-a-din0 {
mux {
groups = "tdm_a_din0";
function = "tdm_a";
bias-disable;
tdm_a_din1_pins: tdm-a-din1 {
mux {
groups = "tdm_a_din1";
function = "tdm_a";
bias-disable;
tdm_a_dout0_pins: tdm-a-dout0 {
mux {
groups = "tdm_a_dout0";
function = "tdm_a";
bias-disable;
tdm_a_dout1_pins: tdm-a-dout1 {
mux {
groups = "tdm_a_dout1";
function = "tdm_a";
bias-disable;
tdm_a_fs_pins: tdm-a-fs {
mux {
groups = "tdm_a_fs";
function = "tdm_a";
bias-disable;
tdm_a_sclk_pins: tdm-a-sclk {
mux {
groups = "tdm_a_sclk";
function = "tdm_a";
bias-disable;
tdm_a_slv_fs_pins: tdm-a-slv-fs {
mux {
groups = "tdm_a_slv_fs";
function = "tdm_a";
bias-disable;
tdm_a_slv_sclk_pins: tdm-a-slv-sclk {
mux {
groups = "tdm_a_slv_sclk";
function = "tdm_a";
bias-disable;
tdm_b_din0_pins: tdm-b-din0 {
mux {
groups = "tdm_b_din0";
function = "tdm_b";
bias-disable;
tdm_b_din1_pins: tdm-b-din1 {
mux {
groups = "tdm_b_din1";
function = "tdm_b";
bias-disable;
tdm_b_din2_pins: tdm-b-din2 {
mux {
groups = "tdm_b_din2";
function = "tdm_b";
bias-disable;
tdm_b_din3_a_pins: tdm-b-din3-a {
mux {
groups = "tdm_b_din3_a";
function = "tdm_b";
bias-disable;
tdm_b_din3_h_pins: tdm-b-din3-h {
mux {
groups = "tdm_b_din3_h";
function = "tdm_b";
bias-disable;
tdm_b_dout0_pins: tdm-b-dout0 {
mux {
groups = "tdm_b_dout0";
function = "tdm_b";
bias-disable;
tdm_b_dout1_pins: tdm-b-dout1 {
mux {
groups = "tdm_b_dout1";
function = "tdm_b";
bias-disable;
tdm_b_dout2_pins: tdm-b-dout2 {
mux {
groups = "tdm_b_dout2";
function = "tdm_b";
bias-disable;
tdm_b_dout3_a_pins: tdm-b-dout3-a {
mux {
groups = "tdm_b_dout3_a";
function = "tdm_b";
bias-disable;
tdm_b_dout3_h_pins: tdm-b-dout3-h {
mux {
groups = "tdm_b_dout3_h";
function = "tdm_b";
bias-disable;
tdm_b_fs_pins: tdm-b-fs {
mux {
groups = "tdm_b_fs";
function = "tdm_b";
bias-disable;
tdm_b_sclk_pins: tdm-b-sclk {
mux {
groups = "tdm_b_sclk";
function = "tdm_b";
bias-disable;
tdm_b_slv_fs_pins: tdm-b-slv-fs {
mux {
groups = "tdm_b_slv_fs";
function = "tdm_b";
bias-disable;
tdm_b_slv_sclk_pins: tdm-b-slv-sclk {
mux {
groups = "tdm_b_slv_sclk";
function = "tdm_b";
bias-disable;
tdm_c_din0_a_pins: tdm-c-din0-a {
mux {
groups = "tdm_c_din0_a";
function = "tdm_c";
bias-disable;
tdm_c_din0_z_pins: tdm-c-din0-z {
mux {
groups = "tdm_c_din0_z";
function = "tdm_c";
bias-disable;
tdm_c_din1_a_pins: tdm-c-din1-a {
mux {
groups = "tdm_c_din1_a";
function = "tdm_c";
bias-disable;
tdm_c_din1_z_pins: tdm-c-din1-z {
mux {
groups = "tdm_c_din1_z";
function = "tdm_c";
bias-disable;
tdm_c_din2_a_pins: tdm-c-din2-a {
mux {
groups = "tdm_c_din2_a";
function = "tdm_c";
bias-disable;
eth_leds_pins: eth-leds {
mux {
groups = "eth_link_led",
"eth_act_led";
function = "eth";
bias-disable;
eth_pins: eth {
mux {
groups = "eth_mdio",
"eth_mdc",
"eth_rgmii_rx_clk",
"eth_rx_dv",
"eth_rxd0",
"eth_rxd1",
"eth_txen",
"eth_txd0",
"eth_txd1";
function = "eth";
bias-disable;
eth_rgmii_pins: eth-rgmii {
mux {
groups = "eth_rxd2_rgmii",
"eth_rxd3_rgmii",
"eth_rgmii_tx_clk",
"eth_txd2_rgmii",
"eth_txd3_rgmii";
function = "eth";
bias-disable;
tdm_c_din2_z_pins: tdm-c-din2-z {
mux {
groups = "tdm_c_din2_z";
function = "tdm_c";
bias-disable;
tdm_c_din3_a_pins: tdm-c-din3-a {
mux {
groups = "tdm_c_din3_a";
function = "tdm_c";
bias-disable;
tdm_c_din3_z_pins: tdm-c-din3-z {
mux {
groups = "tdm_c_din3_z";
function = "tdm_c";
bias-disable;
tdm_c_dout0_a_pins: tdm-c-dout0-a {
mux {
groups = "tdm_c_dout0_a";
function = "tdm_c";
bias-disable;
tdm_c_dout0_z_pins: tdm-c-dout0-z {
mux {
groups = "tdm_c_dout0_z";
function = "tdm_c";
bias-disable;
tdm_c_dout1_a_pins: tdm-c-dout1-a {
mux {
groups = "tdm_c_dout1_a";
function = "tdm_c";
bias-disable;
tdm_c_dout1_z_pins: tdm-c-dout1-z {
mux {
groups = "tdm_c_dout1_z";
function = "tdm_c";
bias-disable;
tdm_c_dout2_a_pins: tdm-c-dout2-a {
mux {
groups = "tdm_c_dout2_a";
function = "tdm_c";
bias-disable;
tdm_c_dout2_z_pins: tdm-c-dout2-z {
mux {
groups = "tdm_c_dout2_z";
function = "tdm_c";
bias-disable;
tdm_c_dout3_a_pins: tdm-c-dout3-a {
mux {
groups = "tdm_c_dout3_a";
function = "tdm_c";
bias-disable;
tdm_c_dout3_z_pins: tdm-c-dout3-z {
mux {
groups = "tdm_c_dout3_z";
function = "tdm_c";
bias-disable;
tdm_c_fs_a_pins: tdm-c-fs-a {
mux {
groups = "tdm_c_fs_a";
function = "tdm_c";
bias-disable;
tdm_c_fs_z_pins: tdm-c-fs-z {
mux {
groups = "tdm_c_fs_z";
function = "tdm_c";
bias-disable;
tdm_c_sclk_a_pins: tdm-c-sclk-a {
mux {
groups = "tdm_c_sclk_a";
function = "tdm_c";
bias-disable;
tdm_c_sclk_z_pins: tdm-c-sclk-z {
mux {
groups = "tdm_c_sclk_z";
function = "tdm_c";
bias-disable;
tdm_c_slv_fs_a_pins: tdm-c-slv-fs-a {
mux {
groups = "tdm_c_slv_fs_a";
function = "tdm_c";
bias-disable;
tdm_c_slv_fs_z_pins: tdm-c-slv-fs-z {
mux {
groups = "tdm_c_slv_fs_z";
function = "tdm_c";
bias-disable;
tdm_c_slv_sclk_a_pins: tdm-c-slv-sclk-a {
mux {
groups = "tdm_c_slv_sclk_a";
function = "tdm_c";
bias-disable;
tdm_c_slv_sclk_z_pins: tdm-c-slv-sclk-z {
mux {
groups = "tdm_c_slv_sclk_z";
function = "tdm_c";
bias-disable;
uart_a_pins: uart-a {
mux {
groups = "uart_a_tx",
"uart_a_rx";
function = "uart_a";
bias-disable;
uart_a_cts_rts_pins: uart-a-cts-rts {
mux {
groups = "uart_a_cts",
"uart_a_rts";
bias-disable;
uart_b_pins: uart-b {
mux {
groups = "uart_b_tx",
"uart_b_rx";
function = "uart_b";
bias-disable;
uart_c_pins: uart-c {
mux {
groups = "uart_c_tx",
"uart_c_rx";
function = "uart_c";
bias-disable;
uart_c_cts_rts_pins: uart-c-cts-rts {
mux {
groups = "uart_c_cts",
"uart_c_rts";
bias-disable;
usb2_phy0: phy@36000 {
compatible = "amlogic,g12a-usb2-phy";
reg = <0x0 0x36000 0x0 0x2000>;
clocks = <&xtal>;
clock-names = "xtal";
resets = <&reset RESET_USB_PHY20>;
#phy-cells = <0>;
dmc: bus@38000 {
reg = <0x0 0x38000 0x0 0x400>;
#size-cells = <2>;
ranges = <0x0 0x0 0x0 0x38000 0x0 0x400>;
canvas: video-lut@48 {
compatible = "amlogic,canvas";
reg = <0x0 0x48 0x0 0x14>;
usb2_phy1: phy@3a000 {
reg = <0x0 0x3a000 0x0 0x2000>;
clocks = <&xtal>;
resets = <&reset RESET_USB_PHY21>;
#phy-cells = <0>;
hiu: bus@3c000 {
reg = <0x0 0x3c000 0x0 0x1400>;
#size-cells = <2>;
ranges = <0x0 0x0 0x0 0x3c000 0x0 0x1400>;
hhi: system-controller@0 {
compatible = "amlogic,meson-gx-hhi-sysctrl",
reg = <0 0 0 0x400>;
clkc: clock-controller {
compatible = "amlogic,g12a-clkc";
#clock-cells = <1>;
clocks = <&xtal>;
pwrc: power-controller {
compatible = "amlogic,meson-g12a-pwrc";
#power-domain-cells = <1>;
amlogic,ao-sysctrl = <&rti>;
resets = <&reset RESET_VIU>,
<&reset RESET_VENC>,
<&reset RESET_VCBUS>,
<&reset RESET_BT656>,
<&reset RESET_RDMA>,
<&reset RESET_VENCI>,
<&reset RESET_VENCP>,
<&reset RESET_VDAC>,
<&reset RESET_VDI6>,
<&reset RESET_VENCL>,
<&reset RESET_VID_LOCK>;
reset-names = "viu", "venc", "vcbus", "bt656",
"rdma", "venci", "vencp", "vdac",
"vdi6", "vencl", "vid_lock";
clocks = <&clkc CLKID_VPU>,
<&clkc CLKID_VAPB>;
clock-names = "vpu", "vapb";
* VPU clocking is provided by two identical clock paths
* VPU_0 and VPU_1 muxed to a single clock by a glitch
* Same for VAPB but with a final gate after the glitch free mux.
assigned-clocks = <&clkc CLKID_VPU_0_SEL>,
<&clkc CLKID_VPU_0>,
<&clkc CLKID_VPU>, /* Glitch free mux */
<&clkc CLKID_VAPB_0_SEL>,
<&clkc CLKID_VAPB_0>,
<&clkc CLKID_VAPB_SEL>; /* Glitch free mux */
assigned-clock-parents = <&clkc CLKID_FCLK_DIV3>,
<&clkc CLKID_FCLK_DIV4>,
<&clkc CLKID_VAPB_0>;
<666666666>,
<250000000>,
pdm: audio-controller@40000 {
compatible = "amlogic,g12a-pdm",
"amlogic,axg-pdm";
reg = <0x0 0x40000 0x0 0x34>;
sound-name-prefix = "PDM";
clocks = <&clkc_audio AUD_CLKID_PDM>,
<&clkc_audio AUD_CLKID_PDM_DCLK>,
<&clkc_audio AUD_CLKID_PDM_SYSCLK>;
clock-names = "pclk", "dclk", "sysclk";
audio: bus@42000 {
reg = <0x0 0x42000 0x0 0x2000>;
#size-cells = <2>;
ranges = <0x0 0x0 0x0 0x42000 0x0 0x2000>;
clkc_audio: clock-controller@0 {
compatible = "amlogic,g12a-audio-clkc";
reg = <0x0 0x0 0x0 0xb4>;
#clock-cells = <1>;
#reset-cells = <1>;
clocks = <&clkc CLKID_AUDIO>,
<&clkc CLKID_MPLL1>,
<&clkc CLKID_MPLL3>,
<&clkc CLKID_HIFI_PLL>,
<&clkc CLKID_GP0_PLL>;
"mst_in0",
"mst_in1",
"mst_in2",
"mst_in3",
"mst_in4",
"mst_in5",
"mst_in6",
"mst_in7";
resets = <&reset RESET_AUDIO>;
toddr_a: audio-controller@100 {
compatible = "amlogic,g12a-toddr",
"amlogic,axg-toddr";
reg = <0x0 0x100 0x0 0x1c>;
sound-name-prefix = "TODDR_A";
interrupts = <GIC_SPI 148 IRQ_TYPE_EDGE_RISING>;
clocks = <&clkc_audio AUD_CLKID_TODDR_A>;
resets = <&arb AXG_ARB_TODDR_A>;
toddr_b: audio-controller@140 {
reg = <0x0 0x140 0x0 0x1c>;
sound-name-prefix = "TODDR_B";
interrupts = <GIC_SPI 149 IRQ_TYPE_EDGE_RISING>;
clocks = <&clkc_audio AUD_CLKID_TODDR_B>;
resets = <&arb AXG_ARB_TODDR_B>;
toddr_c: audio-controller@180 {
reg = <0x0 0x180 0x0 0x1c>;
sound-name-prefix = "TODDR_C";
interrupts = <GIC_SPI 150 IRQ_TYPE_EDGE_RISING>;
clocks = <&clkc_audio AUD_CLKID_TODDR_C>;
resets = <&arb AXG_ARB_TODDR_C>;
frddr_a: audio-controller@1c0 {
compatible = "amlogic,g12a-frddr",
"amlogic,axg-frddr";
reg = <0x0 0x1c0 0x0 0x1c>;
sound-name-prefix = "FRDDR_A";
interrupts = <GIC_SPI 152 IRQ_TYPE_EDGE_RISING>;
clocks = <&clkc_audio AUD_CLKID_FRDDR_A>;
resets = <&arb AXG_ARB_FRDDR_A>;
frddr_b: audio-controller@200 {
reg = <0x0 0x200 0x0 0x1c>;
sound-name-prefix = "FRDDR_B";
interrupts = <GIC_SPI 153 IRQ_TYPE_EDGE_RISING>;
clocks = <&clkc_audio AUD_CLKID_FRDDR_B>;
resets = <&arb AXG_ARB_FRDDR_B>;
frddr_c: audio-controller@240 {
reg = <0x0 0x240 0x0 0x1c>;
sound-name-prefix = "FRDDR_C";
interrupts = <GIC_SPI 154 IRQ_TYPE_EDGE_RISING>;
clocks = <&clkc_audio AUD_CLKID_FRDDR_C>;
resets = <&arb AXG_ARB_FRDDR_C>;
arb: reset-controller@280 {
compatible = "amlogic,meson-axg-audio-arb";
reg = <0x0 0x280 0x0 0x4>;
#reset-cells = <1>;
clocks = <&clkc_audio AUD_CLKID_DDR_ARB>;
tdmin_a: audio-controller@300 {
reg = <0x0 0x300 0x0 0x40>;
sound-name-prefix = "TDMIN_A";
resets = <&clkc_audio AUD_RESET_TDMIN_A>;
clocks = <&clkc_audio AUD_CLKID_TDMIN_A>,
<&clkc_audio AUD_CLKID_TDMIN_A_SCLK>,
<&clkc_audio AUD_CLKID_TDMIN_A_SCLK_SEL>,
<&clkc_audio AUD_CLKID_TDMIN_A_LRCLK>,
<&clkc_audio AUD_CLKID_TDMIN_A_LRCLK>;
tdmin_b: audio-controller@340 {
reg = <0x0 0x340 0x0 0x40>;
sound-name-prefix = "TDMIN_B";
resets = <&clkc_audio AUD_RESET_TDMIN_B>;
clocks = <&clkc_audio AUD_CLKID_TDMIN_B>,
<&clkc_audio AUD_CLKID_TDMIN_B_SCLK>,
<&clkc_audio AUD_CLKID_TDMIN_B_SCLK_SEL>,
<&clkc_audio AUD_CLKID_TDMIN_B_LRCLK>,
<&clkc_audio AUD_CLKID_TDMIN_B_LRCLK>;
tdmin_c: audio-controller@380 {
reg = <0x0 0x380 0x0 0x40>;
sound-name-prefix = "TDMIN_C";
resets = <&clkc_audio AUD_RESET_TDMIN_C>;
clocks = <&clkc_audio AUD_CLKID_TDMIN_C>,
<&clkc_audio AUD_CLKID_TDMIN_C_SCLK>,
<&clkc_audio AUD_CLKID_TDMIN_C_SCLK_SEL>,
<&clkc_audio AUD_CLKID_TDMIN_C_LRCLK>,
<&clkc_audio AUD_CLKID_TDMIN_C_LRCLK>;
tdmin_lb: audio-controller@3c0 {
compatible = "amlogic,g12a-tdmin",
"amlogic,axg-tdmin";
reg = <0x0 0x3c0 0x0 0x40>;
sound-name-prefix = "TDMIN_LB";
resets = <&clkc_audio AUD_RESET_TDMIN_LB>;
clocks = <&clkc_audio AUD_CLKID_TDMIN_LB>,
<&clkc_audio AUD_CLKID_TDMIN_LB_SCLK>,
<&clkc_audio AUD_CLKID_TDMIN_LB_SCLK_SEL>,
<&clkc_audio AUD_CLKID_TDMIN_LB_LRCLK>,
<&clkc_audio AUD_CLKID_TDMIN_LB_LRCLK>;
spdifin: audio-controller@400 {
compatible = "amlogic,g12a-spdifin",
"amlogic,axg-spdifin";
reg = <0x0 0x400 0x0 0x30>;
sound-name-prefix = "SPDIFIN";
interrupts = <GIC_SPI 151 IRQ_TYPE_EDGE_RISING>;
clocks = <&clkc_audio AUD_CLKID_SPDIFIN>,
<&clkc_audio AUD_CLKID_SPDIFIN_CLK>;
clock-names = "pclk", "refclk";
spdifout: audio-controller@480 {
reg = <0x0 0x480 0x0 0x50>;
sound-name-prefix = "SPDIFOUT";
clocks = <&clkc_audio AUD_CLKID_SPDIFOUT>,
<&clkc_audio AUD_CLKID_SPDIFOUT_CLK>;
#phy-cells = <1>;
<&xtal>,
#size-cells = <0>;
ext_mdio: mdio@0 {
reg = <0>;
#size-cells = <0>;
int_mdio: mdio@1 {
reg = <1>;
#size-cells = <0>;
reg = <8>;
max-speed = <100>;
#size-cells = <2>;
rti: sys-ctrl@0 {
#size-cells = <2>;
#clock-cells = <1>;
#reset-cells = <1>;
#size-cells = <2>;
ranges;
gpio_ao: bank@14 {
<0x0 0x1c 0x0 0x8>,
reg-names = "mux",
"ds",
"gpio";
gpio-controller;
#gpio-cells = <2>;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
"uart_ao_a_rx";
bias-disable;
mux {
"uart_ao_a_rts";
bias-disable;
mux {
groups = "pwm_a_e";
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
mux {
bias-disable;
vrtc: rtc@0a8 {
cec_AO: cec@100 {
cecb_AO: cec@280 {
#pwm-cells = <3>;
i2c_AO: i2c@5000 {
#size-cells = <0>;
#pwm-cells = <3>;
ir: ir@8000 {
saradc: adc@9000 {
clocks = <&xtal>,
vpu: vpu@ff900000 {
#size-cells = <0>;
reg = <0>;
reg = <1>;
#size-cells = <2>;
#reset-cells = <1>;
pwm_ef: pwm@19000 {
#pwm-cells = <3>;
pwm_cd: pwm@1a000 {
#pwm-cells = <3>;
pwm_ab: pwm@1b000 {
#pwm-cells = <3>;
i2c3: i2c@1c000 {
#size-cells = <0>;
i2c2: i2c@1d000 {
#size-cells = <0>;
i2c1: i2c@1e000 {
#size-cells = <0>;
i2c0: i2c@1f000 {
#size-cells = <0>;
usb: usb@ffe09000 {
#size-cells = <2>;
ranges;
dr_mode = "otg";
dr_mode = "host";
<800000000>,
- timer {
<GIC_PPI 14
<GIC_PPI 11
<GIC_PPI 10
- xtal: xtal-clk {
#clock-cells = <0>;
- Copyright (c) 2019 BayLibre, SAS
- Author: Neil Armstrong narmstrong@baylibre.com
- Copyright (c) 2019 Christian Hewitt christianshewitt@gmail.com
+/dts-v1/;
- compatible = "khadas,vim3", "amlogic,a311d", "amlogic,g12b";
- cpu_opp_table_0: opp-table-0 {
opp-shared;
opp-100000000 {
opp-250000000 {
opp-500000000 {
opp-667000000 {
opp-1000000000 {
opp-1200000000 {
opp-1398000000 {
opp-1512000000 {
opp-1608000000 {
opp-1704000000 {
opp-1800000000 {
- cpub_opp_table_1: opp-table-1 {
opp-shared;
opp-100000000 {
opp-250000000 {
opp-500000000 {
opp-667000000 {
opp-1000000000 {
opp-1200000000 {
opp-1398000000 {
opp-1512000000 {
opp-1608000000 {
opp-1704000000 {
opp-1800000000 {
opp-1908000000 {
opp-2016000000 {
opp-2108000000 {
opp-2208000000 {
- model = "Khadas VIM3";
- aliases {
serial0 = &uart_AO;
ethernet0 = ðmac;
- chosen {
- memory@0 {
- adc-keys {
button-function {
label = "Function";
- leds {
white {
red {
label = "vim3:red";
- emmc_pwrseq: emmc-pwrseq {
- gpio-keys-polled {
power-button {
label = "power";
- sdio_pwrseq: sdio-pwrseq {
- dc_in: regulator-dc_in {
- vcc_5v: regulator-vcc_5v {
enable-active-high;
- vcc_1v8: regulator-vcc_1v8 {
- vcc_3v3: regulator-vcc_3v3 {
- vddcpu_a: regulator-vddcpu-a {
regulator-boot-on;
- vddcpu_b: regulator-vddcpu-b {
regulator-boot-on;
- vddao_1v8: regulator-vddao_1v8 {
- emmc_1v8: regulator-emmc_1v8 {
- vsys_3v3: regulator-vsys_3v3 {
- usb_pwr: regulator-usb_pwr {
enable-active-high;
- hdmi-connector {
type = "a";
port {
- wifi32k: wifi32k {
#clock-cells = <0>;
- sound {
<270950400>,
<393216000>;
status = "okay";
dai-link-0 {
dai-link-1 {
dai-link-2 {
dai-link-3 {
dai-format = "i2s";
mclk-fs = <256>;
codec {
/* hdmi glue */
dai-link-4 {
codec {
+&arb {
- status = "okay";
+&cec_AO {
- pinctrl-0 = <&cec_ao_a_h_pins>;
- pinctrl-names = "default";
- status = "disabled";
- hdmi-phandle = <&hdmi_tx>;
+&cecb_AO {
- pinctrl-0 = <&cec_ao_b_h_pins>;
- status = "okay";
+&clkc_audio {
- status = "okay";
+&cpu0 {
- cpu-supply = <&vddcpu_b>;
- operating-points-v2 = <&cpu_opp_table_0>;
- clocks = <&clkc CLKID_CPU_CLK>;
- clock-latency = <50000>;
+&cpu1 {
+&cpu100 {
- cpu-supply = <&vddcpu_a>;
- operating-points-v2 = <&cpub_opp_table_1>;
- clocks = <&clkc CLKID_CPUB_CLK>;
+&cpu101 {
+&cpu102 {
+&cpu103 {
+&ext_mdio {
- external_phy: ethernet-phy@0 {
reg = <0>;
max-speed = <1000>;
+ðmac {
status = "okay";
phy-mode = "rgmii";
+&frddr_a {
- status = "okay";
+&frddr_b {
- status = "okay";
+&frddr_c {
- status = "okay";
+&hdmi_tx {
- status = "okay";
- pinctrl-0 = <&hdmitx_hpd_pins>, <&hdmitx_ddc_pins>;
- hdmi-supply = <&vcc_5v>;
- hdmi_tx_tmds_out: endpoint {
+&i2c_AO {
- status = "okay";
- pinctrl-0 = <&i2c_ao_sck_pins>, <&i2c_ao_sda_pins>;
- gpio_expander: gpio-controller@20 {
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
- rtc@51 {
reg = <0x51>;
#clock-cells = <0>;
+&ir {
- status = "okay";
- pinctrl-0 = <&remote_input_ao_pins>;
- linux,rc-map-name = "rc-khadas";
+&pwm_ab {
- pinctrl-0 = <&pwm_a_e_pins>;
- clocks = <&xtal>;
- clock-names = "clkin0";
- status = "okay";
+&pwm_AO_cd {
- pinctrl-0 = <&pwm_ao_d_e_pins>;
- clocks = <&xtal>;
- clock-names = "clkin1";
- status = "okay";
+&pwm_ef {
status = "okay";
+&saradc {
- status = "okay";
- vref-supply = <&vddao_1v8>;
- status = "okay";
- pinctrl-0 = <&sdio_pins>;
- pinctrl-1 = <&sdio_clk_gate_pins>;
- pinctrl-names = "default", "clk-gate";
- #address-cells = <1>;
- #size-cells = <0>;
- bus-width = <4>;
- cap-sd-highspeed;
- sd-uhs-sdr50;
- max-frequency = <100000000>;
- non-removable;
- disable-wp;
- mmc-pwrseq = <&sdio_pwrseq>;
- vmmc-supply = <&vsys_3v3>;
- vqmmc-supply = <&vddao_1v8>;
- brcmf: wifi@1 {
reg = <1>;
- status = "okay";
- pinctrl-0 = <&sdcard_c_pins>;
- pinctrl-1 = <&sdcard_clk_gate_c_pins>;
- bus-width = <4>;
- cap-sd-highspeed;
- max-frequency = <50000000>;
- disable-wp;
- cd-gpios = <&gpio GPIOC_6 GPIO_ACTIVE_LOW>;
- vqmmc-supply = <&vsys_3v3>;
- status = "okay";
- pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>;
- pinctrl-1 = <&emmc_clk_gate_pins>;
- bus-width = <8>;
- cap-mmc-highspeed;
- mmc-ddr-1_8v;
- mmc-hs200-1_8v;
- max-frequency = <200000000>;
- disable-wp;
- mmc-pwrseq = <&emmc_pwrseq>;
- vmmc-supply = <&vcc_3v3>;
- vqmmc-supply = <&emmc_1v8>;
+&tdmif_b {
- status = "okay";
+&tdmout_b {
- status = "okay";
+&tohdmitx {
- status = "okay";
+&uart_A {
- status = "okay";
- pinctrl-0 = <&uart_a_pins>, <&uart_a_cts_rts_pins>;
- uart-has-rtscts;
- bluetooth {
+&uart_AO {
- status = "okay";
- pinctrl-0 = <&uart_ao_a_pins>;
+&usb2_phy0 {
- phy-supply = <&dc_in>;
+&usb2_phy1 {
- phy-supply = <&usb_pwr>;
+&usb3_pcie_phy {
+&usb {
- status = "okay";
- dr_mode = "peripheral";
cpus {
- cpu-map { cluster0 { core0 {
cpu0: cpu@0 {
reg = <0x0 0x0>;
cpu1: cpu@1 {
reg = <0x0 0x1>;
l2: l2-cache0 {
+ðmac {
- power-domains = <&pwrc PWRC_G12A_ETH_ID>;
+&vpu {
- power-domains = <&pwrc PWRC_G12A_VPU_ID>;
+&sd_emmc_a {
- amlogic,dram-access-quirk;
- Copyright (c) 2019 BayLibre, SAS.
- Author: Jerome Brunet jbrunet@baylibre.com
Hi Neil,
Am 02.09.19 um 12:03 schrieb Neil Armstrong:
It was yesterday's linux-next.git (via cgit), adding tag next-20190830.
Thanks, Neil
Why? No such model is being sold: https://www.khadas.com/vim3
In any case, if you or someone has such a pre-production model you can add it as follow-up. In fact you could even entirely replace this import patch if you so desired, it's intentionally separate.
Again, I don't see why, in particular when we don't have a defconfig using it. If you intend to add one, you can still add it later.
Adding Gouwa for insights.
To my knowledge the VIM3L will have S905D3, not S922X. VIM3 is A311D.
https://www.khadas.com/post/khadas-vim3-won-t-use-s922x
Regards, Andreas
Hi Andreas
On 02/09/2019 14:03, Andreas Färber wrote:
Hi Neil,
Please don't use linux next, it's not a stable tree, either wait for 5.4-rc1 or use kevin's amlogic-dt64-2.1 tag, since it will be kept in the final merge.
Thanks, Neil
Didn't want to offend you, don't sync it if you don't want...
Since I maintain the whole stuff, it would have saved my time.
Neil
Regards, Andreas
Hi Neil,
Am 02.09.19 um 14:10 schrieb Neil Armstrong:
Well, in my view linux-next would contain whatever vX patchset Kevin applied to his tree... let's wait for -rc1 then.
Thanks, Neil
It was an honest question. So I take it you have such a prototype?
What I do feel offended about is that my NanoPi K2 patch got ignored and someone else's got merged without crediting or even notifying me. I've become rather hesitant to send U-Boot patches for new boards since, as I don't have much time for it lately and I'd rather spend it productively.
https://patchwork.ozlabs.org/patch/762194/ https://patchwork.ozlabs.org/patch/762483/ https://patchwork.ozlabs.org/patch/934377/ https://gitlab.denx.de/u-boot/u-boot/commit/eee45b4f545902a9089f68331c925898...
Sorry, no time to redo this patch the next ~3 weeks due to travels. It was not scripted.
Thanks for your quick review.
Regards, Andreas
On 02/09/2019 14:45, Andreas Färber wrote:
Hi Neil,
Sorry to be picky, but yes let's wait -rc1 since I'll anyway wait until next U-Boot release cycle to send these patches to Tom.
Thanks, Neil
I was not aware you did the Nanopi K2 support... since I only managed the Amlogic U-boot patches in a Custodian and send PRs to Tom since early this year, I can't really be accused of ignoring a patch you sent 2y ago before I sent a single patch to the U-Boot ML about Amlogic SoCs support:
commit 486221564920e8fcb9a58854a485dac1f8f4d1d3 Author: Neil Armstrong narmstrong@baylibre.com Date: Thu Oct 12 15:50:30 2017 +0200
ARM: dts: Synchronize Amlogic from Linux Mainline 4.13.5
As you can see, Thomas McKahan did the work and I simply posted the patch to the list.
Regards, Andreas
Thanks for doing this anyway, Neil
Derived from odroid-n2_defconfig and README.odroid-n2.
Signed-off-by: Andreas Färber afaerber@suse.de --- board/amlogic/w400/MAINTAINERS | 1 + board/amlogic/w400/README.khadas-vim3 | 132 ++++++++++++++++++++++++++++++++++ configs/khadas-vim3_defconfig | 54 ++++++++++++++ 3 files changed, 187 insertions(+) create mode 100644 board/amlogic/w400/README.khadas-vim3 create mode 100644 configs/khadas-vim3_defconfig
diff --git a/board/amlogic/w400/MAINTAINERS b/board/amlogic/w400/MAINTAINERS index 6e68fa73f7..3b21f50367 100644 --- a/board/amlogic/w400/MAINTAINERS +++ b/board/amlogic/w400/MAINTAINERS @@ -3,4 +3,5 @@ M: Neil Armstrong narmstrong@baylibre.com S: Maintained L: u-boot-amlogic@groups.io F: board/amlogic/w400/ +F: configs/khadas-vim3_defconfig F: configs/odroid-n2_defconfig diff --git a/board/amlogic/w400/README.khadas-vim3 b/board/amlogic/w400/README.khadas-vim3 new file mode 100644 index 0000000000..39b2b06000 --- /dev/null +++ b/board/amlogic/w400/README.khadas-vim3 @@ -0,0 +1,132 @@ +U-Boot for Khadas VIM3 +====================== + +Khadas VIM3 is a single board computer manufactured by Shenzhen Wesion +Technology Co., Ltd. with the following specifications: + + - Amlogic A311D Arm Cortex-A53 dual-core + Cortex-A73 quad-core SoC + - 4GB LPDDR4 SDRAM + - Gigabit Ethernet + - HDMI 2.1 display + - 40-pin GPIO header + - 1 x USB 3.0 Host, 1 x USB 2.0 Host + - eMMC, microSD + - M.2 + - Infrared receiver + +Schematics are available on the manufacturer website. + +Currently the U-Boot port supports the following devices: + - serial + - eMMC, microSD + - Ethernet + - I2C + - Regulators + - Reset controller + - Clock controller + - ADC + +u-boot compilation +================== + + > export ARCH=arm + > export CROSS_COMPILE=aarch64-none-elf- + > make khadas-vim3_defconfig + > make + +Image creation +============== + +Amlogic doesn't provide sources for the firmware and for tools needed +to create the bootloader image, so it is necessary to obtain them from +the git tree published by the board vendor: + + > wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... + > wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... + > tar xvfJ gcc-linaro-aarch64-none-elf-4.8-2013.11_linux.tar.xz + > tar xvfJ gcc-linaro-arm-none-eabi-4.8-2013.11_linux.tar.xz + > export PATH=$PWD/gcc-linaro-aarch64-none-elf-4.8-2013.11_linux/bin:$PWD/gcc-linaro-arm-none-eabi-4.8-2013.11_linux/bin:$PATH + + > DIR=vim3-u-boot + > git clone --depth 1 \ + https://github.com/khadas/u-boot.git -b khadas-vim3-v2015.01 \ + $DIR + + > cd vim3-u-boot + > make kvim3_defconfig + > make + > export UBOOTDIR=$PWD + + Go back to mainline U-Boot source tree then : + > mkdir fip + + > cp $UBOOTDIR/build/scp_task/bl301.bin fip/ + > cp $UBOOTDIR/build/board/khadas/kvim3/firmware/acs.bin fip/ + > cp $UBOOTDIR/fip/g12b/bl2.bin fip/ + > cp $UBOOTDIR/fip/g12b/bl30.bin fip/ + > cp $UBOOTDIR/fip/g12b/bl31.img fip/ + > cp $UBOOTDIR/fip/g12b/ddr3_1d.fw fip/ + > cp $UBOOTDIR/fip/g12b/ddr4_1d.fw fip/ + > cp $UBOOTDIR/fip/g12b/ddr4_2d.fw fip/ + > cp $UBOOTDIR/fip/g12b/diag_lpddr4.fw fip/ + > cp $UBOOTDIR/fip/g12b/lpddr3_1d.fw fip/ + > cp $UBOOTDIR/fip/g12b/lpddr4_1d.fw fip/ + > cp $UBOOTDIR/fip/g12b/lpddr4_2d.fw fip/ + > cp $UBOOTDIR/fip/g12b/piei.fw fip/ + > cp $UBOOTDIR/fip/g12b/aml_ddr.fw fip/ + > cp u-boot.bin fip/bl33.bin + + > sh fip/blx_fix.sh \ + fip/bl30.bin \ + fip/zero_tmp \ + fip/bl30_zero.bin \ + fip/bl301.bin \ + fip/bl301_zero.bin \ + fip/bl30_new.bin \ + bl30 + + > sh fip/blx_fix.sh \ + fip/bl2.bin \ + fip/zero_tmp \ + fip/bl2_zero.bin \ + fip/acs.bin \ + fip/bl21_zero.bin \ + fip/bl2_new.bin \ + bl2 + + > $UBOOTDIR/fip/g12b/aml_encrypt_g12b --bl30sig --input fip/bl30_new.bin \ + --output fip/bl30_new.bin.g12a.enc \ + --level v3 + > $UBOOTDIR/fip/g12b/aml_encrypt_g12b --bl3sig --input fip/bl30_new.bin.g12a.enc \ + --output fip/bl30_new.bin.enc \ + --level v3 --type bl30 + > $UBOOTDIR/fip/g12b/aml_encrypt_g12b --bl3sig --input fip/bl31.img \ + --output fip/bl31.img.enc \ + --level v3 --type bl31 + > $UBOOTDIR/fip/g12b/aml_encrypt_g12b --bl3sig --input fip/bl33.bin --compress lz4 \ + --output fip/bl33.bin.enc \ + --level v3 --type bl33 --compress lz4 + > $UBOOTDIR/fip/g12b/aml_encrypt_g12b --bl2sig --input fip/bl2_new.bin \ + --output fip/bl2.n.bin.sig + > $UBOOTDIR/fip/g12b/aml_encrypt_g12b --bootmk \ + --output fip/u-boot.bin \ + --bl2 fip/bl2.n.bin.sig \ + --bl30 fip/bl30_new.bin.enc \ + --bl31 fip/bl31.img.enc \ + --bl33 fip/bl33.bin.enc \ + --ddrfw1 fip/ddr4_1d.fw \ + --ddrfw2 fip/ddr4_2d.fw \ + --ddrfw3 fip/ddr3_1d.fw \ + --ddrfw4 fip/piei.fw \ + --ddrfw5 fip/lpddr4_1d.fw \ + --ddrfw6 fip/lpddr4_2d.fw \ + --ddrfw7 fip/diag_lpddr4.fw \ + --ddrfw8 fip/aml_ddr.fw \ + --ddrfw9 fip/lpddr3_1d.fw \ + --level v3 + +and then write the image to SD with: + + > DEV=/dev/your_sd_device + > dd if=fip/u-boot.bin.sd.bin of=$DEV conv=fsync,notrunc bs=512 skip=1 seek=1 + > dd if=fip/u-boot.bin.sd.bin of=$DEV conv=fsync,notrunc bs=1 count=444 diff --git a/configs/khadas-vim3_defconfig b/configs/khadas-vim3_defconfig new file mode 100644 index 0000000000..cd37f7840e --- /dev/null +++ b/configs/khadas-vim3_defconfig @@ -0,0 +1,54 @@ +CONFIG_ARM=y +CONFIG_SYS_BOARD="w400" +CONFIG_ARCH_MESON=y +CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_MESON_G12A=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEBUG_UART_BASE=0xff803000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_IDENT_STRING=" khadas-vim3" +CONFIG_DEBUG_UART=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_IMI is not set +CONFIG_CMD_GPIO=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="meson-g12b-a311d-khadas-vim3" +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM_GPIO=y +CONFIG_DM_MMC=y +CONFIG_MMC_MESON_GX=y +CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_MESON_G12A_USB_PHY=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_MESON_G12A=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_RESET=y +CONFIG_DEBUG_UART_MESON=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_MESON_SERIAL=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_MESON_G12A=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x1b8e +CONFIG_USB_GADGET_PRODUCT_NUM=0xfada +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_OF_LIBFDT_OVERLAY=y
Am 02.09.19 um 04:28 schrieb Andreas Färber:
DIR=vim3-u-boot git clone --depth 1 \https://github.com/khadas/u-boot.git -b khadas-vim3-v2015.01 \
$DIR
That branch name should've been khadas-vims-v2015.01 - both exist, the above one was not working and the reason I held back the patches.
Regards, Andreas
$DIR
Ok, this patch looks fine, please add : Reviewed-by: Neil Armstrong narmstrong@baylibre.com when you re-spin.
Neil
Regards, Andreas
Andreas Färber
Neil Armstrong
