Re: [U-Boot] [PATCH v2] arm: cm4008, cm41xx: set gd->ram_size in dram_init
On Thursday 05 July 2012 16:48:22 you wrote:
On 05.07.2012 14:11, Yann Vernier wrote:
Leave dram_init_banksize to set up the bank info data. ram_size was previously uninitialized. Also, generalize lowlevel assembly to support more RAM options.
Signed-off-by: Yann Vernier yann.vernier@orsoc.se
Changes for v2:
- Update to use CONFIG_SYS_SDRAM_ constants
- Update cm41xx also
- Map SDRAM to match configuration
arch/arm/cpu/arm920t/ks8695/lowlevel_init.S | 8 +++----- board/cm4008/cm4008.c | 5 +++-- board/cm41xx/cm41xx.c | 5 +++-- include/configs/cm4008.h | 5 ++--- include/configs/cm41xx.h | 5 ++--- 5 files changed, 13 insertions(+), 15 deletions(-)
diff --git a/arch/arm/cpu/arm920t/ks8695/lowlevel_init.S b/arch/arm/cpu/arm920t/ks8695/lowlevel_init.S index e9f1227..df13de6 100644 --- a/arch/arm/cpu/arm920t/ks8695/lowlevel_init.S +++ b/arch/arm/cpu/arm920t/ks8695/lowlevel_init.S
@@ -131,11 +131,9 @@ highflash: * before relocating, we have to setup RAM timing */
ldr r1, =(KS8695_IO_BASE+KS8695_SDRAM_CTRL0)
-#if (PHYS_SDRAM_1_SIZE == 0x02000000)
- ldr r2, =0x7fc0000e /* 32MB */
-#else
- ldr r2, =0x3fc0000e /* 16MB */
-#endif
- /* 8 column address bits, 4 banks, 32 bits data width */
- ldr r2,
=((CONFIG_SYS_SDRAM_BASE+CONFIG_SYS_SDRAM_SIZE-0x10000)<<(22-16) | \ + (CONFIG_SYS_SDRAM_BASE>>(16-12) | 0x00e))
ugh ... magic. Will it work for every possible setting? How about one setting CONFIG_SYS_SDRAM_BASE != 0x0? I the base address related to register content in any way?
Would be great to have a little documentation here why it is shifted that way, unfortunately I can not find a KS8695 spec in the net. Don't get me wrong it is ok to do so. I think it is way better than hard coding the values like before but would be great to understand why it is done that way.
Best regards
Andreas Bießmann
It's not a guarded secret, although it is far from obvious where to find it. One way is micrel.com - Products - Ethernet ICs / ARM based SOC's - HW Design Kit. Within that zip file, KS8695X_EVAL_HW_RV4.0_DP/RegDescription/KS8695X Register Description v1.1.pdf
My personal thought on the matter is that the existing code is rather heavy on magic numbers, ergo the comment once I figured out what the first ROM reconfiguration was even for.
The memory mapping registers allow you to reconfigure the address recognition for each memory region. The low 16 bits are not configurable, so you can only relocate to 64KiB aligned addresses. Bits 25-16 are configured as an inclusive range, with the top value in bits 31-22 of the register, and the bottom in bits 21-12. The lower bits configure things like SDRAM geometry or SRAM/ROM access times, with one value meaning disabled.
Come to think of it, I fear I've miscalculated where the high region actually is. That comment in lowlevel_init should read 48MB and 32MB, not 768 and 512. I'll fix that and insert a little more explanatory text.
Dear Yann Vernier,
<snip>
- ldr r2,
Best regards
Andreas Bießmann
With this information I understand your equation. I think you should not do it that way. You may solve the current state (all devices have 8 column, 4 bank and 32 bit). But one adding (well, if that will ever come ;) another board with different setting will get in trouble here and need to find another solution. Maybe more sophisticated by doing another equation.
I think a straight forward solution here would be to add another special define in the board config, write the magic number down there and maybe describe what the number stands for. You can then just use the previously defined value in start.S. You may have a look for at91 lowlevel_init, there it is done that way.
Well, thats true.
Best regards
Andreas Bießmann
I shall. In fact, I may already have this problem as I need to verify the timing on the flash memory (I have the demo board, not a cm4xxx), and the reason I work on this is that we may design another board soon.
I'm a little hesitant about how to fit these changes together, though; for now I have three barely separated patches, but overhauling all those magic numbers changes them all yet again. These three patches are all necessary to make my u-boot work in the first place, while fixing the magic values is a code cleanup change - probably editing arch/arm/include/asm/arch-ks8695/platform.h which currently contains a few meaningless constants like KS8695_SDRAM_START and a consistent misspelling of definitions.
Could I save the value decoding and corresponding configuration changes for a fourth patch?
Dear Yann Vernier,
I'm fine with this suggestion. So the next question is who would pull it in mainline? Since this is arm related I guess Albert is the one in question. I think these three patches are all fixes to get a board already in mainline working. So I think we should try to get these in -rc1. Albert, can you please comment?
Best regards
Andreas Bießmann
Hi Andreas,
On Fri, 06 Jul 2012 12:25:00 +0200, "Andreas Bießmann" andreas.devel@googlemail.com wrote:
Dear Yann Vernier,
Ah, board-related patches. :)
If the cm4008/cm41xx board maintainer (as per MAINTAINERS, this is Greg Ungerer, Cc:) green-lights it, then I'm ok for pulling it in.
Best regards
Andreas Bießmann
Amicalement,
On 07/10/2012 07:58 AM, Albert ARIBAUD wrote:
Hi Andreas,
Dear Yann Vernier,
> =((CONFIG_SYS_SDRAM_BASE+CONFIG_SYS_SDRAM_SIZE-0x10000)<<(22-16) | \ + > (CONFIG_SYS_SDRAM_BASE>>(16-12) | 0x00e))
Fixes or improvements?
I have no problem with them. I have only done a visual inspection of the revised patches in the mail archives, and not tested them on the real hardware.
I would suggest defining the proper meanings of the remaining bits in the SDRAM setup registers that are still magic numbers, but that can be a future change.
Acked-by: Greg Ungerer greg.ungerer@opengear.com
Regards Greg
Hi Andreas,
Dear Yann Vernier,
<snip>
I think these are fixes cause the board seems to not working without these changes.
Definitely.
Best regards
Andreas Bießmann
Dear Albert Aribaud,
On 09.07.2012 23:58, Albert ARIBAUD wrote:
Hi Andreas,
Dear Yann Vernier,
<snip>
Ouch, I should have added the board maintainer in cc earlier ... still a lot to learn for me.
Best regards
Andreas Bießmann
Albert ARIBAUD
Andreas Bießmann
Greg Ungerer
Yann Vernier
