[PATCH] fdt: Make fdt addr -q quieter
64597346 "fdt: Add -q option to fdt addr for distro_bootcmd" introduced the -q option for fdt addr, which sets the current working fdt address without printing any output.
baf41410 "fdt: Show a message when the working FDT changes" made the utility function set_working_fdt_addr (in cmd/fdt.c) output a message on each invocation, even if called via fdt addr -q, in which case its output is now slightly noisier.
To fix this, move the printf outside of set_working_fdt_addr to three call sites: * bootm_find_images (the use case for which the additional output was added in baf41410). * fdt addr, but only if the 'quiet' argument is not set. * fdt move.
This also has the advantage of printing the specified address instead of the translated address when using the sandbox.
Remove assertions from the fdt addr test case when: * Calling set_working_fdt_addr directly. * Calling fdt addr with the -q argument.
Signed-off-by: Peter Hoyes Peter.Hoyes@arm.com --- boot/bootm.c | 5 ++++- cmd/fdt.c | 13 +++++++++---- test/cmd/fdt.c | 6 ------ 3 files changed, 13 insertions(+), 11 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index 2eec60ec7b..be5e29088d 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -313,8 +313,11 @@ int bootm_find_images(int flag, int argc, char *const argv[], ulong start, return 1; }
- if (IS_ENABLED(CONFIG_CMD_FDT)) + if (IS_ENABLED(CONFIG_CMD_FDT)) { + printf("Working FDT set to %lx\n", (ulong)images.ft_addr); set_working_fdt_addr(map_to_sysmem(images.ft_addr)); + } + #endif
#if CONFIG_IS_ENABLED(FIT) diff --git a/cmd/fdt.c b/cmd/fdt.c index f38fe909c3..39f94759d9 100644 --- a/cmd/fdt.c +++ b/cmd/fdt.c @@ -40,7 +40,6 @@ void set_working_fdt_addr(ulong addr) { void *buf;
- printf("Working FDT set to %lx\n", addr); buf = map_sysmem(addr, 0); working_fdt = buf; env_set_hex("fdtaddr", addr); @@ -192,10 +191,13 @@ static int do_fdt(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) if ((quiet && fdt_check_header(blob)) || (!quiet && !fdt_valid(&blob))) return 1; - if (control) + if (control) { gd->fdt_blob = blob; - else + } else { + if (!quiet) + printf("Working FDT set to %lx\n", addr); set_working_fdt_addr(addr); + }
if (argc >= 2) { int len; @@ -223,6 +225,7 @@ static int do_fdt(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) * Move the working_fdt */ } else if (strncmp(argv[1], "mo", 2) == 0) { + unsigned long addr; struct fdt_header *newaddr; int len; int err; @@ -237,7 +240,8 @@ static int do_fdt(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) if (!fdt_valid(&working_fdt)) return 1;
- newaddr = map_sysmem(hextoul(argv[3], NULL), 0); + addr = hextoul(argv[3], NULL); + newaddr = map_sysmem(addr, 0);
/* * If the user specifies a length, use that. Otherwise use the @@ -264,6 +268,7 @@ static int do_fdt(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) fdt_strerror(err)); return 1; } + printf("Working FDT set to %lx\n", addr); set_working_fdt_addr(map_to_sysmem(newaddr));
return CMD_RET_SUCCESS; diff --git a/test/cmd/fdt.c b/test/cmd/fdt.c index cdbaf8c425..d2839d6dee 100644 --- a/test/cmd/fdt.c +++ b/test/cmd/fdt.c @@ -151,7 +151,6 @@ static int fdt_test_addr(struct unit_test_state *uts)
/* The working fdt is not set, so this should fail */ set_working_fdt_addr(0); - ut_assert_nextline("Working FDT set to 0"); ut_asserteq(CMD_RET_FAILURE, run_command("fdt addr", 0)); ut_assert_nextline("libfdt fdt_check_header(): FDT_ERR_BADMAGIC"); ut_assertok(ut_check_console_end(uts)); @@ -160,20 +159,17 @@ static int fdt_test_addr(struct unit_test_state *uts) ut_assertok(make_test_fdt(uts, fdt, sizeof(fdt))); addr = map_to_sysmem(fdt); set_working_fdt_addr(addr); - ut_assert_nextline("Working FDT set to %lx", addr); ut_assertok(run_command("fdt addr", 0)); ut_assert_nextline("Working fdt: %08lx", (ulong)map_to_sysmem(fdt)); ut_assertok(ut_check_console_end(uts));
/* Set the working FDT */ set_working_fdt_addr(0); - ut_assert_nextline("Working FDT set to 0"); ut_assertok(run_commandf("fdt addr %08x", addr)); ut_assert_nextline("Working FDT set to %lx", addr); ut_asserteq(addr, map_to_sysmem(working_fdt)); ut_assertok(ut_check_console_end(uts)); set_working_fdt_addr(0); - ut_assert_nextline("Working FDT set to 0");
/* Set the control FDT */ fdt_blob = gd->fdt_blob; @@ -194,7 +190,6 @@ static int fdt_test_addr(struct unit_test_state *uts) /* Test detecting an invalid FDT */ fdt[0] = 123; set_working_fdt_addr(addr); - ut_assert_nextline("Working FDT set to %lx", addr); ut_asserteq(1, run_commandf("fdt addr")); ut_assert_nextline("libfdt fdt_check_header(): FDT_ERR_BADMAGIC"); ut_assertok(ut_check_console_end(uts)); @@ -229,7 +224,6 @@ static int fdt_test_addr_resize(struct unit_test_state *uts)
/* ...quietly */ ut_assertok(run_commandf("fdt addr -q %08x %x", addr, sizeof(fdt) / 4)); - ut_assert_nextline("Working FDT set to %lx", addr); ut_assertok(ut_check_console_end(uts));
/* We cannot easily provoke errors in fdt_open_into(), so ignore that */
- bootm_find_images (the use case for which the additional output was added in baf41410).
- fdt addr, but only if the 'quiet' argument is not set.
- fdt move.
- Calling set_working_fdt_addr directly.
- Calling fdt addr with the -q argument.
Why not just pass the 'quiet' flag to set_working_fdt_addr() to avoid duplication ?
I considered this too, but there are other machine-specific call sites and I was trying to avoid adding an extra argument everywhere just for logging.
I'll send a v2 with a 'quiet' argument on Monday.
Peter
Hmmmm, what about creating a wrapper with the extra logging ? That way, you can have the logging in one place, without introducing the extra parameter.
int set_working_fdt_addr_verbose(...) { ret = set_working_fdt_addr(); printf(...); return ret; }
Peter Hoyes
Peter Hoyes
