[U-Boot] [PATCH] OMAP5: Enable access to auxclk registers
auxclk0 and auxclk1 are utilized on some OMAP5 boards. Define the infrastructure needed for accessing them without using magic numbers.
Also remove unrelated TPS62361 defines from clocks.h
Signed-off-by: Lubomir Popov lpopov@mm-sol.com --- arch/arm/cpu/armv7/omap5/prcm-regs.c | 8 ++++++++ arch/arm/include/asm/arch-omap5/clocks.h | 32 ++++++++++++++---------------- arch/arm/include/asm/omap_common.h | 4 ++++ 3 files changed, 27 insertions(+), 17 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap5/prcm-regs.c b/arch/arm/cpu/armv7/omap5/prcm-regs.c index e9f6a32..5ba9bc4 100644 --- a/arch/arm/cpu/armv7/omap5/prcm-regs.c +++ b/arch/arm/cpu/armv7/omap5/prcm-regs.c @@ -307,6 +307,10 @@ struct prcm_regs const omap5_es1_prcm = { .prm_sldo_mpu_ctrl = 0x4ae07bd0, .prm_sldo_mm_setup = 0x4ae07bd4, .prm_sldo_mm_ctrl = 0x4ae07bd8, + + /* SCRM stuff, used by some boards */ + .scrm_auxclk0 = 0x4ae0a310, + .scrm_auxclk1 = 0x4ae0a314, };
struct omap_sys_ctrl_regs const omap5_ctrl = { @@ -740,6 +744,10 @@ struct prcm_regs const omap5_es2_prcm = { .prm_sldo_mpu_ctrl = 0x4ae07cd0, .prm_sldo_mm_setup = 0x4ae07cd4, .prm_sldo_mm_ctrl = 0x4ae07cd8, + + /* SCRM stuff, used by some boards */ + .scrm_auxclk0 = 0x4ae0a310, + .scrm_auxclk1 = 0x4ae0a314, };
struct prcm_regs const dra7xx_prcm = { diff --git a/arch/arm/include/asm/arch-omap5/clocks.h b/arch/arm/include/asm/arch-omap5/clocks.h index 68afa76..6e23b1e 100644 --- a/arch/arm/include/asm/arch-omap5/clocks.h +++ b/arch/arm/include/asm/arch-omap5/clocks.h @@ -195,9 +195,9 @@ #define RSTTIME1_MASK (0x3ff << 0)
/* Clock frequencies */ -#define OMAP_SYS_CLK_FREQ_38_4_MHZ 38400000 +#define OMAP_SYS_CLK_FREQ_38_4_MHZ 38400000 /* Not used; remove? */ #define OMAP_SYS_CLK_IND_38_4_MHZ 6 -#define OMAP_32K_CLK_FREQ 32768 +#define OMAP_32K_CLK_FREQ 32768 /* Not used; remove? */
/* PRM_VC_VAL_BYPASS */ #define PRM_VC_I2C_CHANNEL_FREQ_KHZ 400 @@ -232,21 +232,6 @@ /* Standard offset is 0.5v expressed in uv */ #define PALMAS_SMPS_BASE_VOLT_UV 500000
-/* TPS */ -#define TPS62361_I2C_SLAVE_ADDR 0x60 -#define TPS62361_REG_ADDR_SET0 0x0 -#define TPS62361_REG_ADDR_SET1 0x1 -#define TPS62361_REG_ADDR_SET2 0x2 -#define TPS62361_REG_ADDR_SET3 0x3 -#define TPS62361_REG_ADDR_CTRL 0x4 -#define TPS62361_REG_ADDR_TEMP 0x5 -#define TPS62361_REG_ADDR_RMP_CTRL 0x6 -#define TPS62361_REG_ADDR_CHIP_ID 0x8 -#define TPS62361_REG_ADDR_CHIP_ID_2 0x9 - -#define TPS62361_BASE_VOLT_MV 500 -#define TPS62361_VSEL0_GPIO 7 - /* Defines for DPLL setup */ #define DPLL_LOCKED_FREQ_TOLERANCE_0 0 #define DPLL_LOCKED_FREQ_TOLERANCE_500_KHZ 500 @@ -261,4 +246,17 @@ * into microsec and passing the value. */ #define CONFIG_DEFAULT_OMAP_RESET_TIME_MAX_USEC 31219 + +/* AUXCLKx reg fields */ +#define AUXCLK_ENABLE_MASK (1 << 8) +#define AUXCLK_SRCSELECT_SHIFT 1 +#define AUXCLK_SRCSELECT_MASK (3 << 1) +#define AUXCLK_CLKDIV_SHIFT 16 +#define AUXCLK_CLKDIV_MASK (0xF << 16) + +#define AUXCLK_SRCSELECT_SYS_CLK 0 +#define AUXCLK_SRCSELECT_CORE_DPLL 1 +#define AUXCLK_SRCSELECT_PER_DPLL 2 +#define AUXCLK_SRCSELECT_ALTERNATE 3 + #endif /* _CLOCKS_OMAP5_H_ */ diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index ee7b188..76f65ed 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -346,6 +346,10 @@ struct prcm_regs { u32 cm_l3init_usbphy_clkctrl; u32 cm_l4per_mcbsp4_clkctrl; u32 prm_vc_cfg_channel; + + /* SCRM stuff, used by some boards */ + u32 scrm_auxclk0; + u32 scrm_auxclk1; };
struct omap_sys_ctrl_regs {
Lubomir Popov
