Re: [PATCH 2/4] rockchip: rk3308: no DEBUG_UART_BOARD_INIT for ROCK Pi S
On 2023/7/15 18:19, Pegorer Massimo wrote:
Call to board_debug_uart_init() is useless, as mainline U-Boot can not build TPL for rk3308, and proprietary ddr.bin to be used as TPL is responsible to init debug uart. Moreover current implementation of board_debug_uart_init() is not compatible with ROCK Pi S, as it sets pins for UART2 channel 1 breaking access to sdmmc due to pinmux conflict. Debug uart for ROCK Pi S is UART0.
Thus, avoid ROCKCHIP_RK3308 to select DEBUG_UART_BOARD_INIT and allow to deselct it in rock-pi-s-rk3308_defconfig. The DEBUG_UART_BOARD_INIT is already implied by ARCH_ROCKCHIP, therefore other boards based on rk3308 chip are not affected by change.
Signed-off-by: Massimo Pegorer massimo.pegorer@vimar.com
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
arch/arm/mach-rockchip/Kconfig | 1 - configs/rock-pi-s-rk3308_defconfig | 1 + 2 files changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 9d6d20bf8e..3f8c6d3e3c 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -152,7 +152,6 @@ config ROCKCHIP_RK3288 config ROCKCHIP_RK3308 bool "Support Rockchip RK3308" select ARM64
- select DEBUG_UART_BOARD_INIT select SUPPORT_SPL select SUPPORT_TPL select SPL
diff --git a/configs/rock-pi-s-rk3308_defconfig b/configs/rock-pi-s-rk3308_defconfig index c6fae07913..d306b58b8e 100644 --- a/configs/rock-pi-s-rk3308_defconfig +++ b/configs/rock-pi-s-rk3308_defconfig @@ -18,6 +18,7 @@ CONFIG_SPL_STACK_R_ADDR=0xc00000 CONFIG_SPL_STACK=0x400000 CONFIG_DEBUG_UART_BASE=0xFF0A0000 CONFIG_DEBUG_UART_CLOCK=24000000 +# CONFIG_DEBUG_UART_BOARD_INIT is not set CONFIG_SYS_LOAD_ADDR=0xc00800 CONFIG_DEBUG_UART=y CONFIG_ANDROID_BOOT_IMAGE=y
Kever Yang
