[U-Boot] [PATCH] ARM DaVinci: Remove duplicate code in cpu/arm926ejs/davinci/dp83848.c
Signed-off-by: Hugo Villeneuve hugo.villeneuve@lyrtech.com
Remove duplicate code in a if/else block in cpu/arm926ejs/davinci/dp83848.c.
cpu/arm926ejs/config.mk | 2 +- cpu/arm926ejs/davinci/dp83848.c | 32 +++++++++----------------------- 2 files changed, 10 insertions(+), 24 deletions(-)
diff --git a/cpu/arm926ejs/config.mk b/cpu/arm926ejs/config.mk index 8db4adb..fc54845 100644 --- a/cpu/arm926ejs/config.mk +++ b/cpu/arm926ejs/config.mk @@ -30,5 +30,5 @@ PLATFORM_CPPFLAGS += -march=armv4 # Supply options according to compiler version # # ========================================================================= -PLATFORM_CPPFLAGS +=$(call cc-option,-mapcs-32,-mabi=apcs-gnu) +PLATFORM_CPPFLAGS +=$(call cc-option,-mapcs-32) PLATFORM_RELFLAGS +=$(call cc-option,-mshort-load-bytes,$(call cc-option,-malignment-traps,)) diff --git a/cpu/arm926ejs/davinci/dp83848.c b/cpu/arm926ejs/davinci/dp83848.c index 2aa9ef1..ef77ecb 100644 --- a/cpu/arm926ejs/davinci/dp83848.c +++ b/cpu/arm926ejs/davinci/dp83848.c @@ -64,29 +64,15 @@ int dp83848_get_link_speed(int phy_addr) return(0);
/* Speed doesn't matter, there is no setting for it in EMAC... */ - if (tmp & DP83848_SPEED) { - if (tmp & DP83848_DUPLEX) { - /* set DM644x EMAC for Full Duplex */ - emac->MACCONTROL = EMAC_MACCONTROL_MIIEN_ENABLE | EMAC_MACCONTROL_FULLDUPLEX_ENABLE; - } else { - /*set DM644x EMAC for Half Duplex */ - emac->MACCONTROL = EMAC_MACCONTROL_MIIEN_ENABLE; - } - - return(1); - } else { - if (tmp & DP83848_DUPLEX) { - /* set DM644x EMAC for Full Duplex */ - emac->MACCONTROL = EMAC_MACCONTROL_MIIEN_ENABLE | EMAC_MACCONTROL_FULLDUPLEX_ENABLE; - } else { - /*set DM644x EMAC for Half Duplex */ - emac->MACCONTROL = EMAC_MACCONTROL_MIIEN_ENABLE; - } - - return(1); - } - - return(0); + if (tmp & DP83848_DUPLEX) + /* Set DM644x EMAC for Full Duplex */ + emac->MACCONTROL = EMAC_MACCONTROL_MIIEN_ENABLE | + EMAC_MACCONTROL_FULLDUPLEX_ENABLE; + else + /* Set DM644x EMAC for Half Duplex */ + emac->MACCONTROL = EMAC_MACCONTROL_MIIEN_ENABLE; + + return(1); }
On Mon, 1 Sep 2008, Hugo Villeneuve wrote:
ACK-by: Sergey Kubushyn ksi@koi8.net
} else {
return(1);
- } else {
} else {
return(1);
- return(0);
- else
- return(1);
--- ****************************************************************** * KSI@home KOI8 Net < > The impossible we do immediately. * * Las Vegas NV, USA < > Miracles require 24-hour notice. * ******************************************************************
why do you remove -mabi=apcs-gnu
which is unrelated to the commit comment
Best Regards, J.
Sorry about that, you can forget it, it was some temporary workaround for an old toolchain :)
Hugo V.
cpu/arm926ejs/davinci/dp83848.c | 27 +++++++-------------------- 1 files changed, 7 insertions(+), 20 deletions(-)
diff --git a/cpu/arm926ejs/davinci/dp83848.c b/cpu/arm926ejs/davinci/dp83848.c index 59f039b..c71c685 100644 --- a/cpu/arm926ejs/davinci/dp83848.c +++ b/cpu/arm926ejs/davinci/dp83848.c @@ -64,29 +64,16 @@ int dp83848_get_link_speed(int phy_addr) return(0);
/* Speed doesn't matter, there is no setting for it in EMAC... */ - if (tmp & DP83848_SPEED) { - if (tmp & DP83848_DUPLEX) { - /* set DM644x EMAC for Full Duplex */ - emac->MACCONTROL = EMAC_MACCONTROL_MIIEN_ENABLE | EMAC_MACCONTROL_FULLDUPLEX_ENABLE; - } else { - /*set DM644x EMAC for Half Duplex */ - emac->MACCONTROL = EMAC_MACCONTROL_MIIEN_ENABLE; - } - - return(1); + if (tmp & DP83848_DUPLEX) { + /* set DM644x EMAC for Full Duplex */ + emac->MACCONTROL = EMAC_MACCONTROL_MIIEN_ENABLE | + EMAC_MACCONTROL_FULLDUPLEX_ENABLE; } else { - if (tmp & DP83848_DUPLEX) { - /* set DM644x EMAC for Full Duplex */ - emac->MACCONTROL = EMAC_MACCONTROL_MIIEN_ENABLE | EMAC_MACCONTROL_FULLDUPLEX_ENABLE; - } else { - /*set DM644x EMAC for Half Duplex */ - emac->MACCONTROL = EMAC_MACCONTROL_MIIEN_ENABLE; - } - - return(1); + /*set DM644x EMAC for Half Duplex */ + emac->MACCONTROL = EMAC_MACCONTROL_MIIEN_ENABLE; }
- return(0); + return(1); }
Hugo Villeneuve
ksi@koi8.net
