[U-Boot] [PATCH] spi: kirkwood_spi: implement mvebu_spi_set_mode()
Set the appropriate bits in the interface config register based on the SPI_ mode flags.
Signed-off-by: Chris Packham judge.packham@gmail.com ---
arch/arm/include/asm/arch-mvebu/spi.h | 4 ++++ drivers/spi/kirkwood_spi.c | 13 +++++++++++++ 2 files changed, 17 insertions(+)
diff --git a/arch/arm/include/asm/arch-mvebu/spi.h b/arch/arm/include/asm/arch-mvebu/spi.h index 78869a253d1f..3545aed17347 100644 --- a/arch/arm/include/asm/arch-mvebu/spi.h +++ b/arch/arm/include/asm/arch-mvebu/spi.h @@ -52,6 +52,10 @@ struct kwspi_registers { #define KWSPI_ADRLEN_3BYTE (2 << 8) #define KWSPI_ADRLEN_4BYTE (3 << 8) #define KWSPI_ADRLEN_MASK (3 << 8) +#define KWSPI_CPOL (1 << 11) +#define KWSPI_CPHA (1 << 12) +#define KWSPI_TXLSBF (1 << 13) +#define KWSPI_RXLSBF (1 << 14)
#define KWSPI_IRQUNMASK 1 /* unmask SPI interrupt */ #define KWSPI_IRQMASK 0 /* mask SPI interrupt */ diff --git a/drivers/spi/kirkwood_spi.c b/drivers/spi/kirkwood_spi.c index 6851ba942f51..69a0be9ea5b2 100644 --- a/drivers/spi/kirkwood_spi.c +++ b/drivers/spi/kirkwood_spi.c @@ -271,6 +271,19 @@ static int mvebu_spi_set_speed(struct udevice *bus, uint hz)
static int mvebu_spi_set_mode(struct udevice *bus, uint mode) { + struct mvebu_spi_platdata *plat = dev_get_platdata(bus); + struct kwspi_registers *reg = plat->spireg; + u32 data = readl(®->cfg); + + if (mode & SPI_CPHA) + data |= KWSPI_CPHA; + if (mode & SPI_CPOL) + data |= KWSPI_CPOL; + if (mode & SPI_LSB_FIRST) + data |= (KWSPI_RXLSBF | KWSPI_TXLSBF); + + writel(data, ®->cfg); + return 0; }
Thanks, Stefan
On Fri, Oct 14, 2016 at 8:49 AM, Chris Packham judge.packham@gmail.com wrote:
Better to clear the bits(mask) on data before updating,
thanks!
Changes in v2: - Clear bits before updating
arch/arm/include/asm/arch-mvebu/spi.h | 4 ++++ drivers/spi/kirkwood_spi.c | 15 +++++++++++++++ 2 files changed, 19 insertions(+)
#define KWSPI_IRQUNMASK 1 /* unmask SPI interrupt */ #define KWSPI_IRQMASK 0 /* mask SPI interrupt */ diff --git a/drivers/spi/kirkwood_spi.c b/drivers/spi/kirkwood_spi.c index 6851ba942f51..791f3e8099c8 100644 --- a/drivers/spi/kirkwood_spi.c +++ b/drivers/spi/kirkwood_spi.c @@ -271,6 +271,21 @@ static int mvebu_spi_set_speed(struct udevice *bus, uint hz)
static int mvebu_spi_set_mode(struct udevice *bus, uint mode) { + struct mvebu_spi_platdata *plat = dev_get_platdata(bus); + struct kwspi_registers *reg = plat->spireg; + u32 data = readl(®->cfg); + + data &= ~(KWSPI_CPHA | KWSPI_CPOL | KWSPI_RXLSBF | KWSPI_TXLSBF); + + if (mode & SPI_CPHA) + data |= KWSPI_CPHA; + if (mode & SPI_CPOL) + data |= KWSPI_CPOL; + if (mode & SPI_LSB_FIRST) + data |= (KWSPI_RXLSBF | KWSPI_TXLSBF); + + writel(data, ®->cfg); + return 0; }
On Thu, Oct 27, 2016 at 1:46 PM, Chris Packham judge.packham@gmail.com wrote:
Missed updating Stefan Reviewed-by tag? please check for next time.
Changes in v2:
Applied, thanks!
That was semi-intentional. I thought v2 was different enough that I didn't want to assume Stefan's review would carry through.
Changes in v2:
Applied, thanks!
-- Jagan Teki Free Software Engineer | www.openedev.com U-Boot, Linux | Upstream Maintainer Hyderabad, India.
On 27.10.2016 11:49, Chris Packham wrote:
On 27/10/2016 10:41 PM, "Jagan Teki" <jagan@openedev.com mailto:jagan@openedev.com> wrote:
Signed-off-by: Chris Packham <judge.packham@gmail.com
Fair enough. I've overlooked the clearing of the bits spotted by Jagan. Please add my Reviewed-by now as well.
Thanks, Stefan
Yeah, added and applied!
Chris Packham
Jagan Teki
Stefan Roese
