[U-Boot] [PATCH] sun7i: Add bananapi board
The Banana Pi is an A20 based development board using Raspberry Pi compatible IO headers. It comes with 1 GB RAM, 1 Gb ethernet, 2x USB host, sata, hdmi and stereo audio out + various expenansion headers:
Signed-off-by: Hans de Goede hdegoede@redhat.com --- board/sunxi/Makefile | 1 + board/sunxi/dram_bananapi.c | 31 +++++++++++++++++++++++++++++++ boards.cfg | 1 + 3 files changed, 33 insertions(+) create mode 100644 board/sunxi/dram_bananapi.c
diff --git a/board/sunxi/Makefile b/board/sunxi/Makefile index 3fc7513..cf001e7 100644 --- a/board/sunxi/Makefile +++ b/board/sunxi/Makefile @@ -19,6 +19,7 @@ obj-$(CONFIG_A20_OLINUXINO_M) += dram_sun7i_384_1024_iow16.o # This is not a typo, uses the same mem settings as the a10s-olinuxino-m obj-$(CONFIG_AUXTEK_T004) += dram_a10s_olinuxino_m.o obj-$(CONFIG_BA10_TV_BOX) += dram_sun4i_384_1024_iow8.o +obj-$(CONFIG_BANANAPI) += dram_bananapi.o obj-$(CONFIG_CUBIEBOARD) += dram_cubieboard.o obj-$(CONFIG_CUBIEBOARD2) += dram_cubieboard2.o obj-$(CONFIG_CUBIETRUCK) += dram_cubietruck.o diff --git a/board/sunxi/dram_bananapi.c b/board/sunxi/dram_bananapi.c new file mode 100644 index 0000000..0ed7943 --- /dev/null +++ b/board/sunxi/dram_bananapi.c @@ -0,0 +1,31 @@ +/* this file is generated, don't edit it yourself */ + +#include <common.h> +#include <asm/arch/dram.h> + +static struct dram_para dram_para = { + .clock = 432, + .type = 3, + .rank_num = 1, + .density = 4096, + .io_width = 16, + .bus_width = 32, + .cas = 9, + .zq = 0x7f, + .odt_en = 0, + .size = 1024, + .tpr0 = 0x42d899b7, + .tpr1 = 0xa090, + .tpr2 = 0x22a00, + .tpr3 = 0x0, + .tpr4 = 0x1, + .tpr5 = 0x0, + .emr1 = 0x4, + .emr2 = 0x10, + .emr3 = 0x0, +}; + +unsigned long sunxi_dram_init(void) +{ + return dramc_init(&dram_para); +} diff --git a/boards.cfg b/boards.cfg index a9b6106..eeba90a 100644 --- a/boards.cfg +++ b/boards.cfg @@ -386,6 +386,7 @@ Active arm armv7 sunxi - sunxi Active arm armv7 sunxi - sunxi A20-OLinuXino_MICRO sun7i:A20_OLINUXINO_M,SPL,AXP209_POWER,SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8),USB_EHCI Hans de Goede hdegoede@redhat.com Active arm armv7 sunxi - sunxi Auxtek-T004 sun5i:AUXTEK_T004,SPL,AXP152_POWER,USB_EHCI,SUNXI_USB_VBUS0_GPIO=SUNXI_GPG(13) Hans de Goede hdegoede@redhat.com Active arm armv7 sunxi - sunxi ba10_tv_box sun4i:BA10_TV_BOX,SPL,AXP209_POWER,SUNXI_EMAC,USB_EHCI,SUNXI_USB_VBUS1_GPIO=SUNXI_GPH(12) Hans de Goede hdegoede@redhat.com +Active arm armv7 sunxi - sunxi Bananapi sun7i:BANANAPI,SPL,AXP209_POWER,SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI,USB_EHCI Hans de Goede hdegoede@redhat.com Active arm armv7 sunxi - sunxi Cubieboard sun4i:CUBIEBOARD,SPL,AXP209_POWER,SUNXI_EMAC,AHCI,SATAPWR=SUNXI_GPB(8),USB_EHCI Hans de Goede hdegoede@redhat.com Active arm armv7 sunxi - sunxi Cubieboard2 sun7i:CUBIEBOARD2,SPL,AXP209_POWER,SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8),USB_EHCI Ian Campbell ijc@hellion.org.uk:Hans de Goede hdegoede@redhat.com Active arm armv7 sunxi - sunxi Cubieboard2_FEL sun7i:CUBIEBOARD2,SPL_FEL,AXP209_POWER,SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8),USB_EHCI Ian Campbell ijc@hellion.org.uk:Hans de Goede hdegoede@redhat.com
"expansion"
Acked-by: Ian Campbell ijc@hellion.org.uk
Hello Hans,
i tried to test your patch, but unfortunately i cannot apply it to a freshly cloned u-boot:
Applying: sun7i: Add bananapi board error: patch failed: board/sunxi/Makefile:19 error: board/sunxi/Makefile: patch does not apply error: patch failed: boards.cfg:386 error: boards.cfg: patch does not apply Patch failed at 0001 sun7i: Add bananapi board The copy of the patch that failed is found in: /home/petermaierh/work/u-boot/.git/rebase-apply/patch When you have resolved this problem, run "git am --resolved". If you prefer to skip this patch, run "git am --skip" instead. To restore the original branch and stop patching, run "git am --abort".
any ideas ?
best regards, hannes
- .clock = 432,
- .type = 3,
- .rank_num = 1,
- .density = 4096,
- .io_width = 16,
- .bus_width = 32,
- .cas = 9,
- .zq = 0x7f,
- .odt_en = 0,
- .size = 1024,
- .tpr0 = 0x42d899b7,
- .tpr1 = 0xa090,
- .tpr2 = 0x22a00,
- .tpr3 = 0x0,
- .tpr4 = 0x1,
- .tpr5 = 0x0,
- .emr1 = 0x4,
- .emr2 = 0x10,
- .emr3 = 0x0,
- return dramc_init(&dram_para);
On Tue, 2014-07-29 at 20:57 +0200, Hannes Petermaier wrote:
Hello Hans,
It applies to the current u-boot-arm.git#master plus the set of changes currently in u-boot-sunxi.git#master. In fact I would expect it to show up in the latter pretty soon.
Ian.
Many thanks, now the patch applies and i can compile u-boot.
maybe tomorrow i get the ordered board from pollin.de and can test this.
Hello Hans,
i tried to test your patch, but unfortunately i cannot apply it to a get freshly cloned u-boot:
Ian.
Hannes Petermaier
Hans de Goede
Ian Campbell
